[GRASS-SVN] r55986 - grass/trunk/gui/wxpython/psmap
Wed Apr 24 12:05:43 PDT 2013
Author: annakrat
Date: 2013-04-24 12:05:43 -0700 (Wed, 24 Apr 2013)
New Revision: 55986
   grass/trunk/gui/wxpython/psmap/dialogs.py
   grass/trunk/gui/wxpython/psmap/frame.py
   grass/trunk/gui/wxpython/psmap/instructions.py
   grass/trunk/gui/wxpython/psmap/toolbars.py
wxGUI/psmap: add labels support
Modified: grass/trunk/gui/wxpython/psmap/dialogs.py
--- grass/trunk/gui/wxpython/psmap/dialogs.py	2013-04-24 17:32:43 UTC (rev 55985)
+++ grass/trunk/gui/wxpython/psmap/dialogs.py	2013-04-24 19:05:43 UTC (rev 55986)
@@ -4967,3 +4967,55 @@
         """!Update text coordinates, after moving"""
         pass
+class LabelsDialog(PsmapDialog):
+    def __init__(self, parent, id, settings):
+        PsmapDialog.__init__(self, parent = parent, id = id, title = _("Vector labels"),
+                             settings=settings)
+        self.objectType = ('labels',)
+        if self.id is not None:
+            self.labels = self.instruction[self.id]
+        else:
+            self.id = wx.NewId()
+            self.labels = Labels(self.id)
+        self.labelsDict = self.labels.GetInstruction()
+        self.panel = self._labelPanel()
+        self._layout(self.panel)
+    def _labelPanel(self):
+        panel = wx.Panel(parent=self, id=wx.ID_ANY, style=wx.TAB_TRAVERSAL)
+        border = wx.BoxSizer(wx.VERTICAL)
+        box   = wx.StaticBox(parent=panel, id=wx.ID_ANY,
+                             label=" %s " % _("Vector label files created beforehand by v.label module"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        self.select = Select(parent=panel, multiple=True, type='labels', fullyQualified=False)
+        self.select.SetValue(','.join(self.labelsDict['labels']))
+        self.select.SetFocus()
+        sizer.Add(item=self.select, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+        helpText = wx.StaticText(panel, id=wx.ID_ANY, label=_("You can select multiple label files."))
+        helpText.SetForegroundColour(wx.SystemSettings_GetColour(wx.SYS_COLOUR_GRAYTEXT))
+        sizer.Add(item=helpText, proportion=0, flag=wx.EXPAND | wx.LEFT | wx.RIGHT, border=5)
+        border.Add(sizer, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+        panel.SetSizer(border)
+        return panel
+    def update(self):
+        value = self.select.GetValue()
+        if not value:
+            self.labelsDict['labels'] = []
+        else:
+            self.labelsDict['labels'] = value.split(',')
+        if self.id not in self.instruction:
+            labels = Labels(self.id)
+            self.instruction.AddInstruction(labels)
+        self.instruction[self.id].SetInstruction(self.labelsDict)
+        return True
Modified: grass/trunk/gui/wxpython/psmap/frame.py
--- grass/trunk/gui/wxpython/psmap/frame.py	2013-04-24 17:32:43 UTC (rev 55985)
+++ grass/trunk/gui/wxpython/psmap/frame.py	2013-04-24 19:05:43 UTC (rev 55986)
@@ -744,6 +744,17 @@
             dlg.OnApply(event = None)
         dlg.Show()
+    def OnAddLabels(self, event, id = None):
+        """!Show dialog for labels"""
+        if self.instruction.FindInstructionByType('labels'):
+            id = self.instruction.FindInstructionByType('labels').id
+        else: id = None
+        if 'labels' not in self.openDialogs:
+            dlg = LabelsDialog(self, id = id, settings = self.instruction)
+            self.openDialogs['labels'] = dlg
+        self.openDialogs['labels'].Show()
     def getModifiedTextBounds(self, x, y, textExtent, rotation):
         """!computes bounding box of rotated text, not very precisely"""
         w, h = textExtent
@@ -948,7 +959,7 @@
                                         coords = coords, bounds = bounds)
                 self.canvas.RedrawSelectBox(id)
-            if itype in ('map', 'vector', 'raster'):
+            if itype in ('map', 'vector', 'raster', 'labels'):
                 if itype == 'raster':#set resolution
                     info = grass.raster_info(self.instruction[id]['raster'])
@@ -1086,13 +1097,13 @@
         #labels
-        self.itemLabelsDict = { 'map': 'MAP FRAME',
-                                'rasterLegend': 'RASTER LEGEND',
-                                'vectorLegend': 'VECTOR LEGEND',
-                                'mapinfo': 'MAP INFO',
-                                'scalebar': 'SCALE BAR',
-                                'image': 'IMAGE',
-                                'northArrow': 'NORTH ARROW'}
+        self.itemLabelsDict = { 'map': _("MAP FRAME"),
+                                'rasterLegend': _("RASTER LEGEND"),
+                                'vectorLegend': _("VECTOR LEGEND"),
+                                'mapinfo': _("MAP INFO"),
+                                'scalebar': _("SCALE BAR"),
+                                'image': _("IMAGE"),
+                                'northArrow': _("NORTH ARROW")}
         self.itemLabels = {}
         # define PseudoDC
@@ -1810,10 +1821,12 @@
             #redraw objects
             for id in self.objectId:
+                type = self.instruction[id].type
+                if type == 'labels':  # why it's here? it should not
+                    continue
                 oRect = self.CanvasPaperCoordinates(
                     rect = self.instruction[id]['rect'], canvasToPaper = False)
-                type = self.instruction[id].type
                 if type == 'text':
                     coords = self.instruction[id]['coords']# recalculate coordinates, they are not equal to BB
                     self.instruction[id]['coords'] = coords = [(int(coord) - view[i]) * zoomFactor
@@ -2144,6 +2157,14 @@
         if vectorId:
             for map in self.instruction[vectorId]['list']:
                 self.itemLabels[mapId].append('vector: ' + map[0].split('@')[0])
+        labels = self.instruction.FindInstructionByType('labels')
+        if labels:
+            labelFiles = self.instruction[labels.id]['labels']
+            if not labelFiles:
+                return
+            labelFiles = [lFile.split('@')[0] for lFile in labelFiles]
+            self.itemLabels[mapId].append(_("labels: ") + ', '.join(labelFiles))
     def UpdateLabel(self, itype, id):
         self.itemLabels[id] = []
Modified: grass/trunk/gui/wxpython/psmap/instructions.py
--- grass/trunk/gui/wxpython/psmap/instructions.py	2013-04-24 17:32:43 UTC (rev 55985)
+++ grass/trunk/gui/wxpython/psmap/instructions.py	2013-04-24 19:05:43 UTC (rev 55986)
@@ -226,7 +226,6 @@
                 isBuffer = True
                 buffer.append(line)
             elif line.startswith('scalebar'):
                 instruction = 'scalebar'
                 isBuffer = True
@@ -284,7 +283,13 @@
                 isBuffer = True
                 buffer.append(line)
+            elif line.startswith('labels'):
+                instruction = 'labels'
+                isBuffer = True
+                buffer.append(line)
         rasterLegend = self.FindInstructionByType('rasterLegend')
         raster = self.FindInstructionByType('raster')
@@ -373,7 +378,8 @@
                               vlines = ['vector', 'vProperties'],
                               vareas = ['vector', 'vProperties'],
                               colortable = ['rasterLegend'],
-                              vlegend = ['vectorLegend']
+                              vlegend = ['vectorLegend'],
+                              labels = ['labels']
         myInstrDict = dict(page = PageSetup,
@@ -390,7 +396,8 @@
                            rasterLegend = RasterLegend,
                            vectorLegend = VectorLegend,
                            vector = Vector,
-                           vProperties = VProperties
+                           vProperties = VProperties,
+                           labels = Labels
         myInstruction = psmapInstrDict[instruction]
@@ -1814,3 +1821,34 @@
         self.instruction.update(instr)
         return True
+class Labels(InstructionObject):
+    """!Class representing labels instruction"""
+    def __init__(self, id):
+        InstructionObject.__init__(self, id = id)
+        self.type = 'labels'
+        # default values
+        self.defaultInstruction = dict(labels=[])
+        # current values
+        self.instruction = dict(self.defaultInstruction)
+    def __str__(self):
+        instr = ''
+        for label in self.instruction['labels']:
+            instr += "labels %s\n" % label
+            instr += "end\n"
+        return instr
+    def Read(self, instruction, text, **kwargs):
+        """!Read instruction and save information"""
+        for line in text:
+            try:
+                if line.startswith('labels'):
+                    labels = line.split(None, 1)[1]
+                    self.instruction['labels'].append(labels)
+            except(IndexError, ValueError):
+                GError(_("Failed to read instruction %s") % instruction)
+                return False
+        return True
Modified: grass/trunk/gui/wxpython/psmap/toolbars.py
--- grass/trunk/gui/wxpython/psmap/toolbars.py	2013-04-24 17:32:43 UTC (rev 55985)
+++ grass/trunk/gui/wxpython/psmap/toolbars.py	2013-04-24 19:05:43 UTC (rev 55986)
@@ -37,7 +37,7 @@
         # custom button for graphics mode selection
         # TODO: could this be somehow generalized?
         self.arrowButton = self.CreateSelectionButton()
-        self.arrowButtonId = self.InsertControl(17, self.arrowButton)
+        self.arrowButtonId = self.InsertControl(18, self.arrowButton)
         self.arrowButton.Bind(wx.EVT_BUTTON, self.OnDrawGraphicsMenu)
         self.drawGraphicsAction = None
@@ -99,6 +99,10 @@
                                      label = _('Line')),
             'rectangleAdd': MetaIcon(img = 'rectangle-add',
                                      label = _('Rectangle')),
+            'overlaysAdd': MetaIcon(img = 'layer-more',
+                                    label = _("Add overlays")),
+            'labelsAdd': MetaIcon(img = 'layer-label-add',
+                                    label = _("Add labels"))
         self.icons = icons
@@ -127,6 +131,8 @@
                                       self.parent.OnAddRaster),
                                      ('addVector', BaseIcons['addVect'],
                                       self.parent.OnAddVect),
+                                     ('overlaysAdd', icons['overlaysAdd'],
+                                      self.OnAddOverlays),
                                      ("delete", icons["deleteObj"],
                                       self.parent.OnDelete),
                                      ("dec", BaseIcons["overlay"],
@@ -157,6 +163,9 @@
                       (self.icons["addImage"],      self.parent.OnAddImage),
                       (self.icons["addNorthArrow"], self.parent.OnAddNorthArrow)))
+    def OnAddOverlays(self, event):
+        self._onMenu(((self.icons['labelsAdd'], self.parent.OnAddLabels), ))
     def OnDrawGraphics(self, event):
         """!Graphics tool activated."""
         self.OnTool(event)
