[GRASS-SVN] r55992 - grass/trunk/lib/python/temporal
Thu Apr 25 03:46:19 PDT 2013
Author: huhabla
Date: 2013-04-25 03:46:18 -0700 (Thu, 25 Apr 2013)
New Revision: 55992
   grass/trunk/lib/python/temporal/core.py
Fixed wrong command column creation for old tgis databases.
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py	2013-04-25 09:16:02 UTC (rev 55991)
+++ grass/trunk/lib/python/temporal/core.py	2013-04-25 10:46:18 UTC (rev 55992)
@@ -183,18 +183,18 @@
             name = cursor.fetchone()[0]
             if name == "raster_base":
                 db_exists = True
                 # Try to add the command column to the space time dataset metadata tables
                 try:
-                    c.execute('ALTER TABLE strds_metadata ADD COLUMN command VARCHAR;')
+                    cursor.execute('ALTER TABLE strds_metadata ADD COLUMN command VARCHAR;')
                 except:
                     pass
                 try:
-                    c.execute('ALTER TABLE str3ds_metadata ADD COLUMN command VARCHAR;')
+                    cursor.execute('ALTER TABLE str3ds_metadata ADD COLUMN command VARCHAR;')
                 except:
                     pass
                 try:
-                    c.execute('ALTER TABLE stvds_metadata ADD COLUMN command VARCHAR;')
+                    cursor.execute('ALTER TABLE stvds_metadata ADD COLUMN command VARCHAR;')
                 except:
                     pass
@@ -213,15 +213,15 @@
         if db_exists:
             try:
             except:
                 pass
             try:
             except:
                 pass
             try:
             except:
                 pass
