[GRASS-SVN] r55995 - grass/trunk/mswindows/osgeo4w
svn_grass at osgeo.org
Thu Apr 25 15:46:33 PDT 2013
Author: mmetz
Date: 2013-04-25 15:46:33 -0700 (Thu, 25 Apr 2013)
New Revision: 55995
grass/trunk/mswindows/osgeo4w/msys.bat
update msys.bat to 2009 version
Modified: grass/trunk/mswindows/osgeo4w/msys.bat
--- grass/trunk/mswindows/osgeo4w/msys.bat 2013-04-25 12:31:17 UTC (rev 55994)
+++ grass/trunk/mswindows/osgeo4w/msys.bat 2013-04-25 22:46:33 UTC (rev 55995)
@@ -47,31 +47,26 @@
if NOT EXIST "%WD%msys-1.0.dll" set WD=%~dps0bin\
rem echo %WD%
-rem if installed in a directory containing spaces prepare for a world of pain
-for /F %%i IN ('echo %WD%') DO @set PART1=%%i
-if NOT "%PART1%" == "%WD%" (
- echo Path names containing spaces are not supported -- aborting.
- pause
- exit 1
rem ember Set up option to use rxvt based on value of %1
set MSYSCON=unknown
if "x%1" == "x-norxvt" set MSYSCON=sh.exe
if "x%1" == "x--norxvt" set MSYSCON=sh.exe
if "x%1" == "x-rxvt" set MSYSCON=rxvt.exe
if "x%1" == "x--rxvt" set MSYSCON=rxvt.exe
+if "x%1" == "x-mintty" set MSYSCON=mintty.exe
+if "x%1" == "x--mintty" set MSYSCON=mintty.exe
if NOT "x%MSYSCON%" == "xunknown" shift
if "x%MSYSCON%" == "xunknown" set MSYSCON=sh.exe
rem the default is a MSYS (user), not a MINGW (developer) console
-if "x%MSYSTEM%" == "x" set MSYSTEM=MINGW32
+if "x%MSYSTEM%" == "x" set MSYSTEM=MSYS
if "%1" == "MINGW32" set MSYSTEM=MINGW32
if "%1" == "MSYS" set MSYSTEM=MSYS
if NOT "x%DISPLAY%" == "x" set DISPLAY=
+if "x%MSYSCON%" == "xmintty.exe" goto startmintty
if "x%MSYSCON%" == "xrxvt.exe" goto startrxvt
if "x%MSYSCON%" == "xsh.exe" goto startsh
@@ -85,6 +80,11 @@
pause
exit 1
+:startmintty
+if NOT EXIST "%WD%mintty.exe" goto startsh
+start "%WD%mintty" /bin/bash -l
+exit
rem If you don't want to use rxvt then rename the file rxvt.exe to something
rem else. Then sh.exe will be used instead.
:startrxvt
@@ -201,3 +201,7 @@
rem * Keith's modified patch fails on x64; start did funny things.
rem Reworked, for correct behaviour on both platforms.
rem
+rem 2009.03.17 Keith Marshall mailto:keithmarshall at users.sf.net
+rem * Add -rxvt or --rxvt switch; start in --norxvt mode by default.
+rem Make it deterministic; (do not inherit MSYSCON from parent).
+rem
