[GRASS-SVN] r55999 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Apr 25 16:29:30 PDT 2013
Author: mmetz
Date: 2013-04-25 16:29:30 -0700 (Thu, 25 Apr 2013)
New Revision: 55999
grass/trunk/lib/vector/Vlib/remove_duplicates.c
Vlib: speed up Vect_remove_duplicates)
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c 2013-04-25 23:07:37 UTC (rev 55998)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c 2013-04-25 23:29:30 UTC (rev 55999)
@@ -17,6 +17,41 @@
#include <grass/vector.h>
#include <grass/glocale.h>
+static int cmp_int(const void *a, const void *b)
+ return (*(int *)a - *(int *)b);
+static int boxlist_add_sorted(struct boxlist *list, int id)
+ int i;
+ if (list->n_values > 0) {
+ if (bsearch(&id, list->id, list->n_values, sizeof(int), cmp_int))
+ return 0;
+ if (list->n_values == list->alloc_values) {
+ size_t size = (list->n_values + 100) * sizeof(int);
+ list->id = (int *)G_realloc((void *)list->id, size);
+ list->alloc_values = list->n_values + 100;
+ i = 0;
+ for (i = list->n_values; i > 0; i--) {
+ if (list->id[i - 1] < id)
+ break;
+ list->id[i] = list->id[i - 1];
+ list->id[i] = id;
+ list->n_values++;
+ return 1;
\brief Remove duplicate features from vector map.
@@ -37,6 +72,7 @@
struct line_cats *ACats, *BCats;
int i, c, atype, btype, aline, bline;
int nlines, nacats_orig, npoints;
+ int na1, na2, nb1, nb2, nodelines, nline;
struct bound_box ABox;
struct boxlist *List;
int ndupl, is_dupl;
@@ -73,17 +109,38 @@
Vect_line_prune(APoints);
if (npoints != APoints->n_points) {
+ G_debug(3, "Line %d pruned, %d vertices removed", aline, npoints - APoints->n_points);
Vect_rewrite_line(Map, aline, atype, APoints, ACats);
nlines = Vect_get_num_lines(Map);
continue;
- /* select potential duplicates */
- ABox.E = ABox.W = APoints->x[0];
- ABox.N = ABox.S = APoints->y[0];
- ABox.T = ABox.B = APoints->z[0];
- Vect_select_lines_by_box(Map, &ABox, type, List);
- G_debug(3, " %d lines selected by box", List->n_values);
+ na1 = na2 = -1;
+ if (atype & GV_LINES) {
+ /* faster than Vect_select_lines_by_box() */
+ Vect_reset_boxlist(List);
+ Vect_get_line_nodes(Map, aline, &na1, &na2);
+ nodelines = Vect_get_node_n_lines(Map, na1);
+ for (i = 0; i < nodelines; i++) {
+ nline = abs(Vect_get_node_line(Map, na1, i));
+ if (nline == aline)
+ continue;
+ if (Vect_get_line_type(Map, nline) != atype)
+ continue;
+ boxlist_add_sorted(List, nline);
+ else {
+ /* select potential duplicates */
+ ABox.E = ABox.W = APoints->x[0];
+ ABox.N = ABox.S = APoints->y[0];
+ ABox.T = ABox.B = APoints->z[0];
+ Vect_select_lines_by_box(Map, &ABox, atype, List);
+ G_debug(3, " %d lines selected by box", List->n_values);
is_dupl = 0;
@@ -95,6 +152,15 @@
if (aline <= bline)
continue;
+ nb1 = nb2 = -1;
+ Vect_get_line_nodes(Map, bline, &nb1, &nb2);
+ if ((na1 == nb1 && na2 != nb2) ||
+ (na1 == nb2 && na2 != nb1))
+ continue;
btype = Vect_read_line(Map, BPoints, BCats, bline);
Vect_line_prune(BPoints);
