[GRASS-SVN] r56014 - in grass/trunk: lib/python/temporal lib/temporal/SQL temporal/t.topology temporal/t.vect.observe.strds
svn_grass at osgeo.org
Sat Apr 27 09:08:48 PDT 2013
Author: huhabla
Date: 2013-04-27 09:08:47 -0700 (Sat, 27 Apr 2013)
New Revision: 56014
Added:
grass/trunk/lib/temporal/SQL/raster3d_views.sql
grass/trunk/lib/temporal/SQL/raster_views.sql
grass/trunk/lib/temporal/SQL/str3ds_views.sql
grass/trunk/lib/temporal/SQL/strds_views.sql
grass/trunk/lib/temporal/SQL/stvds_views.sql
grass/trunk/lib/temporal/SQL/vector_views.sql
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/pythontemporallib.dox
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql
grass/trunk/lib/temporal/SQL/raster_metadata_table.sql
grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql
grass/trunk/lib/temporal/SQL/strds_metadata_table.sql
grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql
grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
grass/trunk/temporal/t.topology/t.topology.py
grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh
Added bottom and top to views and separated them in new files. Support for spatio-temporal topology analysis.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2013-04-27 16:08:47 UTC (rev 56014)
@@ -91,7 +91,7 @@
- finished
To access topological information the spatial, temporal or booth topologies must be build first
- using the SpatialTopologyBuilder, TemporalTopologyBuilder or SpatioTemporalTopologyBuilder.
+ using the SpatioTemporalTopologyBuilder.
@return the dictionary with relations as keys and number as values or None in case the topology wasn't build
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-04-27 16:08:47 UTC (rev 56014)
@@ -381,13 +381,16 @@
return gaps
- def print_temporal_relationships(self, maps=None, dbif=None):
+ def print_spatio_temporal_relationships(self, maps=None, spatial=None, dbif=None):
"""!Print the temporal relation matrix of all registered maps to stdout
The temporal relation matrix includes the temporal relations between
all registered maps. The relations are strings stored in a list of lists.
@param maps a ordered by start_time list of map objects
+ @param spatial This indicates if the spatial topology is created as well:
+ spatial can be None (no spatial topology), "2D" using west, east,
+ south, north or "3D" using west, east, south, north, bottom, top
@param dbif The database interface to be used
@@ -395,7 +398,8 @@
maps = self.get_registered_maps_as_objects(
where=None, order="start_time", dbif=dbif)
- print_temporal_topology_relationships(maps)
+ print_spatio_temporal_topology_relationships(maps1=maps, maps2=maps,
+ spatial=spatial, dbif=dbif)
def count_temporal_relations(self, maps=None, dbif=None):
"""!Count the temporal relations between the registered maps.
@@ -521,8 +525,8 @@
Gaps between maps are identified as unregistered maps with id==None.
- The map objects are initialized with the id and the temporal
- extent of the granule (temporal type, start time, end time).
+ The objects are initialized with their id's' and the spatio-temporal extent
+ (temporal type, start time, end time, west, east, south, north, bottom and top).
In case more map information are needed, use the select()
method for each listed object.
@@ -712,7 +716,7 @@
def get_registered_maps_as_objects_by_granularity(self, gran=None, dbif=None):
"""!Return all registered maps as ordered (by start_time) object list with
- "gap" map objects (id==None) for temporal topological operations
+ "gap" map objects (id==None) for spatio-temporal topological operations
that require the temporal extent only.
Each list entry is a list of map objects
@@ -729,8 +733,8 @@
- The objects are initialized with the id and the temporal
- extent (temporal type, start time, end time).
@@ -899,13 +903,13 @@
def get_registered_maps_as_objects_with_gaps(self, where=None, dbif=None):
"""!Return all or a subset of the registered maps as
- that require the temporal extent only.
+ that require the spatio-temporal extent only.
Gaps between maps are identified as maps with id==None
- temporal extent (temporal type, start time, end time).
@@ -954,10 +958,10 @@
def get_registered_maps_as_objects_with_temporal_topology(self, where=None, order="start_time",
dbif=None):
"""!Return all or a subset of the registered maps as ordered object list with
- temporal topological relationship informations.
+ spatio-temporal topological relationship informations.
- The objects are initialized with their id's' and the temporal extent
- (temporal type, start time, end time) and the temporal topological information.
@@ -984,10 +988,10 @@
def get_registered_maps_as_objects(self, where=None, order="start_time",
dbif=None):
"""!Return all or a subset of the registered maps as ordered object list for
- temporal topological operations that require the temporal extent only
+ spatio-temporal topological operations that require the spatio-temporal extent only
- (temporal type, start time, end time).
@@ -1004,8 +1008,24 @@
obj_list = []
- rows = self.get_registered_maps(
- "id,start_time,end_time", where, order, dbif)
+ # Older temporal databases have no bottom and top columns
+ # in their views so we need a work around to set the full
+ # spatial extent as well
+ has_bt_columns = True
+ try:
+ rows = self.get_registered_maps(
+ "id,start_time,end_time, west,east,south,north,bottom,top",
+ where, order, dbif)
+ except:
+ try:
+ "id,start_time,end_time",
+ has_bt_columns = False
+ core.warning(_("Old temporal database format. The top and bottom column"\
+ " is missing in the views, using a work around."))
+ except:
+ raise
if rows is not None:
for row in rows:
@@ -1015,6 +1035,15 @@
elif self.is_time_relative():
map.set_relative_time(row["start_time"], row["end_time"],
self.get_relative_time_unit())
+ # The fast way
+ if has_bt_columns:
+ map.set_spatial_extent(west=row["west"], east=row["east"],
+ south=row["south"],north=row["north"], bottom=row["bottom"],
+ top=row["top"])
+ # The slow work around
+ else:
+ map.spatial_extent.select(dbif)
obj_list.append(copy.copy(map))
if connected:
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/python/temporal/core.py 2013-04-27 16:08:47 UTC (rev 56014)
@@ -39,7 +39,7 @@
import sys
import grass.script.core as core
# Import all supported database backends
-# Ignore import errors sicne they are checked later
+# Ignore import errors since they are checked later
try:
import sqlite3
except ImportError:
@@ -56,17 +56,21 @@
# It can either be "sqlite" or "pg"
tgis_backed = None
+# The version of the temporal framework
+tgis_version="1.0"
-# This variable specifies if the ctypes interface to the grass
-# libraries should be used to read map specific data. If set to False
-# the grass scripting library will be used to get map informations.
-# The advantage of the ctypes inteface is speed, the disadvantage is that
-# the GRASS C functions may call G_fatal_error() which exits the process.
-# That is not catchable in Python.
-use_ctypes_map_access = True
+def get_tgis_version():
+ """!Get the verion number of the temporal framework
+ @return The version number of the temporal framework as string
+ global tgis_version
+ return tgis_version
def get_temporal_dbmi_init_string():
kv = core.parse_command("t.connect", flags="pg")
grassenv = core.gisenv()
@@ -93,6 +97,14 @@
+# This variable specifies if the ctypes interface to the grass
+# libraries should be used to read map specific data. If set to False
+# the grass scripting library will be used to get map informations.
+# The advantage of the ctypes inteface is speed, the disadvantage is that
+# the GRASS C functions may call G_fatal_error() which exits the process.
+# That is not catchable in Python.
+use_ctypes_map_access = True
def set_use_ctypes_map_access(use_ctype = True):
"""!Define the map access method for the temporal GIS library
@@ -242,6 +254,13 @@
), "raster3d_metadata_table.sql"), 'r').read()
vector_metadata_sql = open(os.path.join(
get_sql_template_path(), "vector_metadata_table.sql"), 'r').read()
+ raster_views_sql = open(os.path.join(
+ get_sql_template_path(), "raster_views.sql"), 'r').read()
+ raster3d_views_sql = open(os.path.join(get_sql_template_path(
+ ), "raster3d_views.sql"), 'r').read()
+ vector_views_sql = open(os.path.join(
+ get_sql_template_path(), "vector_views.sql"), 'r').read()
stds_tables_template_sql = open(os.path.join(
get_sql_template_path(), "stds_tables_template.sql"), 'r').read()
strds_metadata_sql = open(os.path.join(
@@ -250,6 +269,12 @@
get_sql_template_path(), "str3ds_metadata_table.sql"), 'r').read()
stvds_metadata_sql = open(os.path.join(
get_sql_template_path(), "stvds_metadata_table.sql"), 'r').read()
+ strds_views_sql = open(os.path.join(
+ get_sql_template_path(), "strds_views.sql"), 'r').read()
+ str3ds_views_sql = open(os.path.join(
+ get_sql_template_path(), "str3ds_views.sql"), 'r').read()
+ stvds_views_sql = open(os.path.join(
+ get_sql_template_path(), "stvds_views.sql"), 'r').read()
# Create the raster, raster3d and vector tables
raster_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster")
@@ -281,17 +306,23 @@
# Create the global tables for the native grass datatypes
cursor.executescript(raster_tables_sql)
cursor.executescript(raster_metadata_sql)
+ cursor.executescript(raster_views_sql)
cursor.executescript(vector_tables_sql)
cursor.executescript(vector_metadata_sql)
+ cursor.executescript(vector_views_sql)
cursor.executescript(raster3d_tables_sql)
cursor.executescript(raster3d_metadata_sql)
+ cursor.executescript(raster3d_views_sql)
# Create the tables for the new space-time datatypes
cursor.executescript(strds_tables_sql)
cursor.executescript(strds_metadata_sql)
+ cursor.executescript(strds_views_sql)
cursor.executescript(stvds_tables_sql)
cursor.executescript(stvds_metadata_sql)
+ cursor.executescript(stvds_views_sql)
cursor.executescript(str3ds_tables_sql)
cursor.executescript(str3ds_metadata_sql)
+ cursor.executescript(str3ds_views_sql)
cursor.executescript(sqlite3_delete_trigger_sql)
elif tgis_backed == "pg":
# Connect to database
@@ -301,17 +332,23 @@
cursor.execute(raster_tables_sql)
cursor.execute(raster_metadata_sql)
+ cursor.execute(raster_views_sql)
cursor.execute(vector_tables_sql)
cursor.execute(vector_metadata_sql)
+ cursor.execute(vector_views_sql)
cursor.execute(raster3d_tables_sql)
cursor.execute(raster3d_metadata_sql)
+ cursor.execute(raster3d_views_sql)
cursor.execute(strds_tables_sql)
cursor.execute(strds_metadata_sql)
+ cursor.execute(strds_views_sql)
cursor.execute(stvds_tables_sql)
cursor.execute(stvds_metadata_sql)
+ cursor.execute(stvds_views_sql)
cursor.execute(str3ds_tables_sql)
cursor.execute(str3ds_metadata_sql)
+ cursor.execute(str3ds_views_sql)
connection.commit()
cursor.close()
Modified: grass/trunk/lib/python/temporal/pythontemporallib.dox
--- grass/trunk/lib/python/temporal/pythontemporallib.dox 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/python/temporal/pythontemporallib.dox 2013-04-27 16:08:47 UTC (rev 56014)
@@ -44,8 +44,9 @@
of time stamped maps and space time datasets, such as temporal and spatial
handling and representation:
+- python::temporal::spatial_topology_dataset_connector
+- python::temporal::temporal_topology_dataset_connector
- python::temporal::abstract_dataset
-- python::temporal::abstract_temporal_dataset
- python::temporal::abstract_map_dataset
- python::temporal::abstract_space_time_dataset
@@ -54,12 +55,12 @@
- python::temporal::space_time_datasets
-Helper functions to compute temporal granularity, handling of datetime objects
-and their conversion as well as topology computation are defined in these modules:
+Functions to compute temporal granularity, handling of datetime objects
+and their conversion as well as spatio-temporal topology computation are defined in these modules:
- python::temporal::datetime_math
+- python::temporal::spatio_temporal_relationships
- python::temporal::temporal_granularity
-- python::temporal::temporal_relationships
Functionality that is shared between different temporal GRASS modules, such as
map listing, space time dataset creation, map registration and unregistration,
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2013-04-27 16:08:47 UTC (rev 56014)
@@ -634,13 +634,13 @@
eW -= 360.0
# Edges of extent located outside of self are not allowed
- if E < eW:
+ if E <= eW:
return False
- if W > eE:
+ if W >= eE:
return False
- if N < eS:
+ if N <= eS:
return False
- if S > eN:
+ if S >= eN:
return False
# First we check that at least one edge of extent meets an edge of self
@@ -1094,23 +1094,42 @@
def disjoint_2d(self, extent):
"""!Return True if this extent (A) is disjoint with the provided spatial
extent (B) in three dimensions.
@verbatim
- _____
+ _____
| A |
- |_____|
- _______
+ |_____|
+ _______
| B |
|_______|
@endverbatim
@param extent The spatial extent
@return True or False
- if self.overlapping_2d(extent) or self.meet_2d(extent):
+ if self.is_in_2d(extent):
return False
+ if self.contain_2d(extent):
+ return False
+ if self.cover_2d(extent):
+ return False
+ if self.covered_2d(extent):
+ return False
+ if self.equivalent_2d(extent):
+ return False
+ if self.overlapping_2d(extent):
+ return False
+ if self.meet_2d(extent):
+ return False
return True
def disjoint(self, extent):
@@ -1121,8 +1140,27 @@
- if self.overlapping(extent) or self.meet(extent):
+ if self.is_in(extent):
return False
+ if self.contain(extent):
+ return False
+ if self.cover(extent):
+ return False
+ if self.covered(extent):
+ return False
+ if self.equivalent(extent):
+ return False
+ if self.overlapping(extent):
+ return False
+ if self.meet(extent):
+ return False
return True
def spatial_relation_2d(self, extent):
@@ -1331,6 +1369,14 @@
>>> B = SpatialExtent(north=70, south=30, east=50, west=10, bottom=0, top=50)
>>> A.spatial_relation(B)
'meet'
+ >>> A = SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+ >>> B = SpatialExtent(north=90, south=81, east=60, west=10, bottom=-50, top=50)
+ >>> A.spatial_relation(B)
+ 'disjoint'
+ >>> B = SpatialExtent(north=90, south=80, east=60, west=10, bottom=-50, top=50)
+ 'meet'
@endcode
Modified: grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
--- grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2013-04-27 16:08:47 UTC (rev 56014)
@@ -31,7 +31,7 @@
class SpatioTemporalTopologyBuilder(object):
"""!This class is designed to build the spatio-temporal topology
of spatio-temporally related abstract dataset objects.
The abstract dataset objects must be provided as a single list, or in two lists.
Example:
@@ -41,13 +41,13 @@
maps = strds.get_registered_maps_as_objects()
# Now lets build the temporal topology of the maps in the list
tb = SpatioTemporalTopologyBuilder()
tb.build(maps)
dbif, connected = init_dbif(None)
for _map in tb:
_map.select(dbif)
_map.print_info()
@@ -97,7 +97,7 @@
return self._first
- def _build_internal_iteratable(self, maps):
+ def _build_internal_iteratable(self, maps, spatial):
"""!Build an iteratable temporal topology structure for all maps in
the list and store the maps internally
@@ -109,7 +109,7 @@
@param maps A sorted (by start_time)list of abstract_dataset
objects with initiated temporal extent
- self._build_iteratable(maps)
+ self._build_iteratable(maps, spatial)
for _map in maps:
self._insert(_map)
@@ -117,7 +117,7 @@
# Detect the first map
self._detect_first()
- def _build_iteratable(self, maps):
+ def _build_iteratable(self, maps, spatial):
all maps in the list
@@ -141,7 +141,7 @@
# First we need to order the map list chronologically
sorted_maps = sorted(
maps, key=AbstractDatasetComparisonKeyStartTime)
for i in xrange(len(sorted_maps) - 1):
sorted_maps[i].set_next(sorted_maps[i + 1])
@@ -150,26 +150,27 @@
if next_:
next_.set_prev(map_)
map_.set_temporal_topology_build_true()
+ if spatial is not None:
+ map_.set_spatial_topology_build_true()
def _map_to_rect(self, tree, map_, spatial=None):
"""Use the temporal extent of a map to create and return a RTree rectange
#south, north or "3D" using west, east, south, north, bottom, top
rect = vector.RTreeAllocRect(tree)
start, end = map_.get_valid_time()
if not end:
end = start
if map_.is_time_absolute():
start = time_delta_to_relative_time(start - self._timeref)
end = time_delta_to_relative_time(end - self._timeref)
if spatial is None:
vector.RTreeSetRect1D(rect, tree, float(start), float(end))
elif spatial == "2D":
@@ -180,13 +181,13 @@
north, south, east, west, top, bottom = map_.get_spatial_extent()
vector.RTreeSetRect4D(rect, tree, west, east, south, north,
bottom, top, float(start), float(end))
return rect
def _build_rtree(self, maps, spatial=None):
"""Build and return the 1-4 dimensional R*-Tree
@@ -196,13 +197,14 @@
dim = 3
if spatial == "3D":
dim = 4
tree = vector.RTreeCreateTree(-1, 0, dim)
for i in xrange(len(maps)):
rect = self._map_to_rect(tree, maps[i], spatial)
vector.RTreeInsertRect(rect, i + 1, tree)
return tree
def build(self, mapsA, mapsB=None, spatial=None):
@@ -220,42 +222,33 @@
the chronological iteration over the mapsA.
@param mapsA A list of abstract_dataset
- objects with initiated temporal extent
+ objects with initiated spatio-temporal extent
@param mapsB An optional list of abstract_dataset
- if spatial is not None:
- dbif, connected = init_dbif(None)
identical = False
if mapsA == mapsB:
identical = True
if mapsB == None:
mapsB = mapsA
idetnical = True
for map_ in mapsA:
map_.reset_topology()
- # Spatial extent from the database
- map_.select(dbif)
if not identical:
for map_ in mapsB:
- map_.select(dbif)
tree = self. _build_rtree(mapsA, spatial)
- for j in xrange(len(mapsB)):
+ for j in xrange(len(mapsB)):
list_ = gis.ilist()
rect = self._map_to_rect(tree, mapsB[j], spatial)
num = vector.RTreeSearch2(tree, rect, byref(list_))
@@ -266,24 +259,20 @@
# Get the temporal relationship
relation = mapsB[j].temporal_relation(mapsA[i])
A = mapsA[i]
B = mapsB[j]
set_temoral_relationship(A, B, relation)
relation = mapsB[j].spatial_relation(mapsA[i])
set_spatial_relationship(A, B, relation)
- self._build_internal_iteratable(mapsA)
+ self._build_internal_iteratable(mapsA, spatial)
if not identical and mapsB != None:
- self._build_iteratable(mapsB)
+ self._build_iteratable(mapsB, spatial)
vector.RTreeDestroyTree(tree)
- if connected:
- dbif.close()
def __iter__(self):
start_ = self._first
@@ -407,8 +396,9 @@
A.append_overlaps(B)
def set_spatial_relationship(A, B, relation):
if relation == "equivalent":
if B != A:
if not B.get_equivalent() or \
@@ -486,24 +476,54 @@
tb.build(maps1, maps2)
dbif, connected = init_dbif(dbif)
for _map in tb:
_map.select(dbif)
_map.print_info()
if connected:
dbif.close()
return
+def print_spatio_temporal_topology_relationships(maps1, maps2=None, spatial="2D", dbif=None):
+ """!Print the temporal relationships of the
+ map lists maps1 and maps2 to stdout.
+ @param maps1 A list of abstract_dataset
+ objects with initiated temporal extent
+ @param maps2 An optional list of abstract_dataset
+ @param spatial The dimension of the spatial extent to be used: "2D" using west, east,
+ @param dbif The database interface to be used
+ tb = SpatioTemporalTopologyBuilder()
+ tb.build(maps1, maps2, spatial)
+ dbif, connected = init_dbif(dbif)
+ for _map in tb:
+ _map.select(dbif)
+ _map.print_info()
+ if connected:
+ dbif.close()
+ return
def count_temporal_topology_relationships(maps1, maps2=None, dbif=None):
"""!Count the temporal relations of a single list of maps or between two lists of maps
@@ -516,14 +536,14 @@
@return A dictionary with counted temporal relationships
relations = None
for _map in tb:
if relations != None:
r = _map.get_number_of_relations()
@@ -534,7 +554,7 @@
if connected:
dbif.close()
return relations
@@ -599,9 +619,9 @@
@endverbatim
Usage:
@code
>>> # Relative time
>>> start = 1
>>> end = 2
@@ -667,7 +687,7 @@
... use_start=True, use_during=True, use_overlap=True, use_contain=True,
... use_equal=True, use_follows=True, use_precedes=True)
"((start_time >= '2001-01-01 12:30:00' and start_time < '2001-03-31 14:30:00') OR ((start_time > '2001-01-01 12:30:00' and end_time < '2001-03-31 14:30:00') OR (start_time >= '2001-01-01 12:30:00' and end_time < '2001-03-31 14:30:00') OR (start_time > '2001-01-01 12:30:00' and end_time <= '2001-03-31 14:30:00')) OR ((start_time < '2001-01-01 12:30:00' and end_time > '2001-01-01 12:30:00' and end_time < '2001-03-31 14:30:00') OR (start_time < '2001-03-31 14:30:00' and start_time > '2001-01-01 12:30:00' and end_time > '2001-03-31 14:30:00')) OR ((start_time < '2001-01-01 12:30:00' and end_time > '2001-03-31 14:30:00') OR (start_time <= '2001-01-01 12:30:00' and end_time > '2001-03-31 14:30:00') OR (start_time < '2001-01-01 12:30:00' and end_time >= '2001-03-31 14:30:00')) OR (start_time = '2001-01-01 12:30:00' and end_time = '2001-03-31 14:30:00') OR (start_time = '2001-03-31 14:30:00') OR (end_time = '2001-01-01 12:30:00'))"
@endcode
@@ -682,7 +702,7 @@
if use_during:
if use_start:
where += " OR "
if isinstance(start, datetime):
where += "((start_time > '%s' and end_time < '%s') OR " % (start, end)
where += "(start_time >= '%s' and end_time < '%s') OR " % (start, end)
@@ -751,7 +771,6 @@
where = None
return where
Modified: grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -1,7 +1,6 @@
-- This SQL script generates the raster3d metadata table to store
--- and metadata for SQL queries and temporal GIS support. Additionally two views
--- are created to access all map specific tables
+-- and metadata for SQL queries and temporal GIS support.
-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
@@ -27,44 +26,6 @@
FOREIGN KEY (id) REFERENCES raster3d_base (id) ON DELETE CASCADE
--- Create the views to access all cols for the absolute and relative time
-CREATE VIEW raster3d_view_abs_time AS SELECT
- A1.id, A1.mapset,
- A1.name, A1.temporal_type,
- A1.creation_time,
--- Uncommented due to performance issues
--- A1.modification_time, A1.revision,
- A1.creator,
- A2.start_time, A2.end_time, A2.timezone,
- A3.north, A3.south, A3.east, A3.west, A3.proj,
- A4.datatype, A4.cols, A4.rows, A4.depths,
- A4.nsres, A4.ewres, A4.tbres,
- A4.min, A4.max,
- A4.str3ds_register,
- A4.number_of_cells
- FROM raster3d_base A1, raster3d_absolute_time A2,
- raster3d_spatial_extent A3, raster3d_metadata A4
- WHERE A1.id = A2.id AND A1.id = A3.id AND A1.id = A4.id;
-CREATE VIEW raster3d_view_rel_time AS SELECT
- A1.id, A1.mapset,
- A1.creation_time,
- A1.creator,
- A4.min, A4.max,
- FROM raster3d_base A1, raster3d_relative_time A2,
-- Create a trigger to update the modification time and revision number in case the metadata have been updated
--CREATE TRIGGER update_raster3d_metadata AFTER UPDATE ON raster3d_metadata
Added: grass/trunk/lib/temporal/SQL/raster3d_views.sql
--- grass/trunk/lib/temporal/SQL/raster3d_views.sql (rev 0)
+++ grass/trunk/lib/temporal/SQL/raster3d_views.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -0,0 +1,44 @@
+-- This SQL script generates two views to access all map specific tables.
+-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
+-- Create the views to access all cols for the absolute and relative time
+CREATE VIEW raster3d_view_abs_time AS SELECT
+ A1.id, A1.mapset,
+ A1.name, A1.temporal_type,
+ A1.creation_time,
+-- Uncommented due to performance issues
+-- A1.modification_time, A1.revision,
+ A1.creator,
+ A2.start_time, A2.end_time, A2.timezone,
+ A3.north, A3.south, A3.east, A3.west, A3.bottom, A3.top, A3.proj,
+ A4.datatype, A4.cols, A4.rows, A4.depths,
+ A4.nsres, A4.ewres, A4.tbres,
+ A4.min, A4.max,
+ A4.str3ds_register,
+ A4.number_of_cells
+ FROM raster3d_base A1, raster3d_absolute_time A2,
+ raster3d_spatial_extent A3, raster3d_metadata A4
+ WHERE A1.id = A2.id AND A1.id = A3.id AND A1.id = A4.id;
+CREATE VIEW raster3d_view_rel_time AS SELECT
+ A1.id, A1.mapset,
+ A1.creation_time,
+ A1.creator,
+ A4.min, A4.max,
+ FROM raster3d_base A1, raster3d_relative_time A2,
\ No newline at end of file
Modified: grass/trunk/lib/temporal/SQL/raster_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/raster_metadata_table.sql 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/temporal/SQL/raster_metadata_table.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -1,7 +1,6 @@
-- This SQL script generates the raster metadata table to store
@@ -25,42 +24,6 @@
FOREIGN KEY (id) REFERENCES raster_base (id) ON DELETE CASCADE
-CREATE VIEW raster_view_abs_time AS SELECT
- A1.id, A1.mapset,
- A1.creation_time,
- A1.creator,
- A4.nsres, A4.ewres, A4.min, A4.max,
- A4.strds_register,
- FROM raster_base A1, raster_absolute_time A2,
- raster_spatial_extent A3, raster_metadata A4
-CREATE VIEW raster_view_rel_time AS SELECT
- A1.id, A1.mapset,
- A1.creation_time,
- A1.creator,
- FROM raster_base A1, raster_relative_time A2,
--CREATE TRIGGER update_raster_metadata AFTER UPDATE ON raster_metadata
Added: grass/trunk/lib/temporal/SQL/raster_views.sql
--- grass/trunk/lib/temporal/SQL/raster_views.sql (rev 0)
+++ grass/trunk/lib/temporal/SQL/raster_views.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -0,0 +1,42 @@
+CREATE VIEW raster_view_abs_time AS SELECT
+ A1.id, A1.mapset,
+ A1.creation_time,
+ A1.creator,
+ A4.nsres, A4.ewres, A4.min, A4.max,
+ A4.strds_register,
+ FROM raster_base A1, raster_absolute_time A2,
+ raster_spatial_extent A3, raster_metadata A4
+CREATE VIEW raster_view_rel_time AS SELECT
+ A1.id, A1.mapset,
+ A1.creation_time,
+ A1.creator,
+ FROM raster_base A1, raster_relative_time A2,
Modified: grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -1,6 +1,5 @@
--- This SQL script generates the space time 3D raster dataset metadata table,
--- view and trigger
+-- This SQL script generates the space time 3D raster dataset metadata table.
@@ -27,51 +26,7 @@
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES str3ds_base (id) ON DELETE CASCADE
--- Create the views to access all cols for absolute or relative time
-CREATE VIEW str3ds_view_abs_time AS SELECT
- A1.id, A1.name, A1.mapset, A1.temporal_type,
- A1.semantic_type,
- A1.creation_time,
- A1.creator,
- A2.start_time, A2.end_time, A2.timezone, A2.granularity,
- A4.raster3d_register,
- A4.number_of_maps,
- A4.nsres_min, A4.ewres_min,
- A4.nsres_max, A4.ewres_max,
- A4.tbres_min, A4.tbres_max,
- A4.min_min, A4.min_max,
- A4.max_min, A4.max_max,
- A4.title, A4.description, A4.command
- FROM str3ds_base A1, str3ds_absolute_time A2,
- str3ds_spatial_extent A3, str3ds_metadata A4 WHERE A1.id = A2.id AND
- A1.id = A3.id AND A1.id = A4.id;
-CREATE VIEW str3ds_view_rel_time AS SELECT
- A1.semantic_type,
- A1.creation_time,
- A1.creator,
- A2.start_time, A2.end_time, A2.granularity,
- FROM str3ds_base A1, str3ds_relative_time A2,
-- Create a trigger to update the modification time and revision number in case the metadata or timestanps have been updated
--CREATE TRIGGER update_str3ds_metadata AFTER UPDATE ON str3ds_metadata
Added: grass/trunk/lib/temporal/SQL/str3ds_views.sql
--- grass/trunk/lib/temporal/SQL/str3ds_views.sql (rev 0)
+++ grass/trunk/lib/temporal/SQL/str3ds_views.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -0,0 +1,49 @@
+-- This SQL script generates the space time 3D raster dataset views.
+-- Create the views to access all cols for absolute or relative time
+CREATE VIEW str3ds_view_abs_time AS SELECT
+ A1.id, A1.name, A1.mapset, A1.temporal_type,
+ A1.semantic_type,
+ A1.creation_time,
+ A1.creator,
+ A2.start_time, A2.end_time, A2.timezone, A2.granularity,
+ A4.raster3d_register,
+ A4.number_of_maps,
+ A4.nsres_min, A4.ewres_min,
+ A4.nsres_max, A4.ewres_max,
+ A4.tbres_min, A4.tbres_max,
+ A4.min_min, A4.min_max,
+ A4.max_min, A4.max_max,
+ A4.title, A4.description, A4.command
+ FROM str3ds_base A1, str3ds_absolute_time A2,
+ str3ds_spatial_extent A3, str3ds_metadata A4 WHERE A1.id = A2.id AND
+ A1.id = A3.id AND A1.id = A4.id;
+CREATE VIEW str3ds_view_rel_time AS SELECT
+ A1.semantic_type,
+ A1.creation_time,
+ A1.creator,
+ A2.start_time, A2.end_time, A2.granularity,
+ FROM str3ds_base A1, str3ds_relative_time A2,
Modified: grass/trunk/lib/temporal/SQL/strds_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/strds_metadata_table.sql 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/temporal/SQL/strds_metadata_table.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -1,6 +1,5 @@
--- This SQL script generates the space time raster dataset metadata table,
+-- This SQL script generates the space time raster dataset metadata table.
@@ -25,49 +24,7 @@
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES strds_base (id) ON DELETE CASCADE
-CREATE VIEW strds_view_abs_time AS SELECT
- A1.semantic_type,
- A1.creation_time,
- A1.creator,
- A4.raster_register,
- FROM strds_base A1, strds_absolute_time A2,
- strds_spatial_extent A3, strds_metadata A4 WHERE A1.id = A2.id AND
-CREATE VIEW strds_view_rel_time AS SELECT
- A1.semantic_type,
- A1.creation_time,
- A1.creator,
- FROM strds_base A1, strds_relative_time A2,
--CREATE TRIGGER update_strds_metadata AFTER UPDATE ON strds_metadata
Added: grass/trunk/lib/temporal/SQL/strds_views.sql
--- grass/trunk/lib/temporal/SQL/strds_views.sql (rev 0)
+++ grass/trunk/lib/temporal/SQL/strds_views.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -0,0 +1,47 @@
+-- This SQL script generates the space time raster dataset view.
+CREATE VIEW strds_view_abs_time AS SELECT
+ A1.semantic_type,
+ A1.creation_time,
+ A1.creator,
+ A4.raster_register,
+ FROM strds_base A1, strds_absolute_time A2,
+ strds_spatial_extent A3, strds_metadata A4 WHERE A1.id = A2.id AND
+CREATE VIEW strds_view_rel_time AS SELECT
+ A1.semantic_type,
+ A1.creation_time,
+ A1.creator,
+ FROM strds_base A1, strds_relative_time A2,
Modified: grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -1,6 +1,5 @@
--- This SQL script generates the space time vector dataset metadata table,
+-- This SQL script generates the space time vector dataset metadata table.
@@ -29,48 +28,7 @@
PRIMARY KEY (id),
FOREIGN KEY (id) REFERENCES stvds_base (id) ON DELETE CASCADE
--- Create the views to access all columns for absolute or relative time
-CREATE VIEW stvds_view_abs_time AS SELECT
- A1.semantic_type,
- A1.creation_time,
- A1.creator,
- A2.granularity,
- A4.vector_register,
- A4.title, A4.description, A4.command, A4.points, A4.lines,
- A4.boundaries, A4.centroids, A4.faces, A4.kernels,
- A4.primitives, A4.nodes, A4.areas, A4.islands,
- A4.holes, A4.volumes
- FROM stvds_base A1, stvds_absolute_time A2,
- stvds_spatial_extent A3, stvds_metadata A4 WHERE A1.id = A2.id AND
-CREATE VIEW stvds_view_rel_time AS SELECT
- A1.semantic_type,
- A1.creation_time,
- A1.creator,
- FROM stvds_base A1, stvds_relative_time A2,
--CREATE TRIGGER update_stvds_metadata AFTER UPDATE ON stvds_metadata
Added: grass/trunk/lib/temporal/SQL/stvds_views.sql
--- grass/trunk/lib/temporal/SQL/stvds_views.sql (rev 0)
+++ grass/trunk/lib/temporal/SQL/stvds_views.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -0,0 +1,46 @@
+-- This SQL script generates the space time vector dataset view.
+-- Create the views to access all columns for absolute or relative time
+CREATE VIEW stvds_view_abs_time AS SELECT
+ A1.semantic_type,
+ A1.creation_time,
+ A1.creator,
+ A2.granularity,
+ A4.vector_register,
+ A4.title, A4.description, A4.command, A4.points, A4.lines,
+ A4.boundaries, A4.centroids, A4.faces, A4.kernels,
+ A4.primitives, A4.nodes, A4.areas, A4.islands,
+ A4.holes, A4.volumes
+ FROM stvds_base A1, stvds_absolute_time A2,
+ stvds_spatial_extent A3, stvds_metadata A4 WHERE A1.id = A2.id AND
+CREATE VIEW stvds_view_rel_time AS SELECT
+ A1.semantic_type,
+ A1.creation_time,
+ A1.creator,
+ FROM stvds_base A1, stvds_relative_time A2,
Modified: grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -29,42 +29,6 @@
FOREIGN KEY (id) REFERENCES vector_base (id) ON DELETE CASCADE
--- Create the views to access all columns for the absolute and relative time
-CREATE VIEW vector_view_abs_time AS SELECT
- A1.id, A1.mapset,
- A1.name, A1.layer, A1.temporal_type,
- A1.creation_time,
- A1.creator,
- A4.stvds_register, A4.is_3d, A4.points, A4.lines,
- FROM vector_base A1, vector_absolute_time A2,
- vector_spatial_extent A3, vector_metadata A4
-CREATE VIEW vector_view_rel_time AS SELECT
- A1.id, A1.mapset,
- A1.creation_time,
- A1.creator,
- FROM vector_base A1, vector_relative_time A2,
--CREATE TRIGGER update_vector_metadata AFTER UPDATE ON vector_metadata
Added: grass/trunk/lib/temporal/SQL/vector_views.sql
--- grass/trunk/lib/temporal/SQL/vector_views.sql (rev 0)
+++ grass/trunk/lib/temporal/SQL/vector_views.sql 2013-04-27 16:08:47 UTC (rev 56014)
@@ -0,0 +1,41 @@
+-- Create the views to access all columns for the absolute and relative time
+CREATE VIEW vector_view_abs_time AS SELECT
+ A1.id, A1.mapset,
+ A1.name, A1.layer, A1.temporal_type,
+ A1.creation_time,
+ A1.creator,
+ A4.stvds_register, A4.is_3d, A4.points, A4.lines,
+ FROM vector_base A1, vector_absolute_time A2,
+ vector_spatial_extent A3, vector_metadata A4
+CREATE VIEW vector_view_rel_time AS SELECT
+ A1.id, A1.mapset,
+ A1.creation_time,
+ A1.creator,
+ FROM vector_base A1, vector_relative_time A2,
Modified: grass/trunk/temporal/t.topology/t.topology.py
--- grass/trunk/temporal/t.topology/t.topology.py 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/temporal/t.topology/t.topology.py 2013-04-27 16:08:47 UTC (rev 56014)
@@ -36,6 +36,11 @@
#% description: Print temporal relationships and exit
#%end
+#%flag
+#% key: s
+#% description: Print spatio-temporal relationships and exit
+#%end
import grass.script as grass
import grass.temporal as tgis
@@ -48,7 +53,8 @@
name = options["input"]
type = options["type"]
where = options["where"]
- tmatrix = flags['m']
+ temporal_relations = flags['m']
+ spatio_temporal_relations = flags['s']
# Make sure the temporal database exists
tgis.init()
@@ -72,9 +78,17 @@
# Get ordered map list
maps = sp.get_registered_maps_as_objects(
where=where, order="start_time", dbif=None)
+ spatial = None
+ if spatio_temporal_relations:
+ if sp.get_type() == "strds":
+ spatial = "2D"
+ else:
+ spatial = "3D"
- if tmatrix:
- sp.print_temporal_relationships(maps)
+ if temporal_relations or spatio_temporal_relations:
+ sp.print_spatio_temporal_relationships(maps=maps, spatial=spatial)
return
sp.base.print_info()
Modified: grass/trunk/temporal/t.topology/test.t.topology.abstime.sh
--- grass/trunk/temporal/t.topology/test.t.topology.abstime.sh 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/temporal/t.topology/test.t.topology.abstime.sh 2013-04-27 16:08:47 UTC (rev 56014)
@@ -12,9 +12,14 @@
r.mapcalc --o expr="prec_4 = rand(0, 510)"
r.mapcalc --o expr="prec_5 = rand(0, 300)"
r.mapcalc --o expr="prec_6 = rand(0, 650)"
+# Different spatial extents
r.mapcalc --o expr="A = 1"
+g.region s=20 n=70 w=10 e=110 b=10 t=40 res=10 res3=10 -p3 # in A, covered by C
r.mapcalc --o expr="B = 2"
+g.region s=20 n=80 w=10 e=130 b=10 t=50 res=10 res3=10 -p3 # cover B
r.mapcalc --o expr="C = 3"
+g.region s=70 n=90 w=10 e=130 b=10 t=50 res=10 res3=10 -p3 # overlap B
r.mapcalc --o expr="D = 3"
n1=`g.tempfile pid=1 -d`
@@ -111,7 +116,7 @@
t.register --o type=rast -i input=maps file="${n6}"
cat "${n6}"
t.topology input=maps
-t.topology -m input=maps
+t.topology -ms input=maps
t.remove type=strds input=precip_abs,maps
t.unregister type=rast file="${n1}"
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh 2013-04-27 11:24:23 UTC (rev 56013)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.layer_bug.sh 2013-04-27 16:08:47 UTC (rev 56014)
@@ -12,7 +12,7 @@
rm ${MAP_LIST}
count=1
-while [ $count -lt 500 ]; do
+while [ $count -lt 270 ]; do
name="test_prec_${count}"
r.mapcalc --o expr="${name} = ${count}"
echo ${name} >> ${MAP_LIST}
@@ -36,5 +36,5 @@
t.remove type=strds input=precip_abs1
t.remove type=stvds input=prec_observer
-g.remove vect=prec_observer
+#g.remove vect=prec_observer
g.mremove -f rast=test_prec_*
