[GRASS-SVN] r56030 - grass/branches/develbranch_6/gui/wxpython/docs
Mon Apr 29 00:10:08 PDT 2013
Author: annakrat
Date: 2013-04-29 00:10:07 -0700 (Mon, 29 Apr 2013)
New Revision: 56030
   grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
wxGUI/nviz: note problem related to r55967 in documentation (merge from trunk, r56028)
Modified: grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2013-04-29 07:06:19 UTC (rev 56029)
+++ grass/branches/develbranch_6/gui/wxpython/docs/wxGUI.Nviz.html	2013-04-29 07:10:07 UTC (rev 56030)
@@ -359,9 +359,19 @@
   <li>...</li>
 </ul>
+<h2>NOTE</h2>
+wxNviz is under active development and
+distributed as "Experimental Prototype".
 <p>
-<b>Please note that wxNviz is under active development and
-distributed as "Experimental Prototype".</b>
+Please note that with wxGTK port of wxPython (Linux systems),
+a problem might appear during wxNviz initialization (nothing is rendered at all)
+or when rendering vectors (bad order of rendering surfaces and vectors).
+If you encounter such problems, try to change a depth buffer number
+in GUI Settings > Map Display  > Advanced (possible numbers are 0, 16, 24, 32).
+It is currently not possible to automatically find out the right number which is working for your computer.
+</p>
 <h2>SEE ALSO</h2>
