[GRASS-SVN] r56044 - grass/trunk/mswindows
svn_grass at osgeo.org
Tue Apr 30 02:48:48 PDT 2013
Author: hamish
Date: 2013-04-30 02:48:48 -0700 (Tue, 30 Apr 2013)
New Revision: 56044
grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
merge updates from devbr6
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-04-30 09:18:36 UTC (rev 56043)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-04-30 09:48:48 UTC (rev 56044)
@@ -893,21 +893,32 @@
SectionEnd
-Function DownloadDataSet
+Function DownloadInstallMSRuntime
IntOp $ARCHIVE_SIZE_MB $ARCHIVE_SIZE_KB / 1024
- StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME.$\r$\n"
StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_These system libraries from Microsoft are needed for programs"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ built with Microsoft's Visual C++ compiler, such as Python and"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ GDAL which ship with GRASS, since MS does not include them by"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ default. You might already have them installed by other software,"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ if so you don't need to install them again, but if not GRASS will"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ fail to start and you will see errors like 'Missing MSVCR71.dll"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ or MSVCP100.dll'.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The archive is about $ARCHIVE_SIZE_MB MB and may take"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to be downloaded.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ several minutes to download.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copyed to:$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME will be copied to:$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$TEMP\$CUSTOM_UNTAR_FOLDER.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue and install the runtimes, or Cancel"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ to skip the download and complete the GRASS"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME.$\r$\n"
MessageBox MB_OKCANCEL "$DOWNLOAD_MESSAGE_" IDOK download IDCANCEL cancel_download
download:
@@ -919,22 +930,28 @@
download_ok:
InitPluginsDir
- untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
+ untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME"
Pop $0
StrCmp $0 "success" untar_ok untar_failed
- untar_ok:
- Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
+ untar_ok:
+ ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe /q"
+ ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe /q"
+ ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe /q"
+ CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTDIR\extralib"
Delete "$TEMP\$ARCHIVE_NAME"
+ RMDir /r "$TEMP\$ORIGINAL_UNTAR_FOLDER"
+ ;the following doesn't work. Maybe because the installer is still running?
+ RMDir "$TEMP\$ORIGINAL_UNTAR_FOLDER"
Goto end
download_failed:
DetailPrint "$0" ;print error message to log
- MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+ MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME."
Goto end
cancel_download:
- MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
+ MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME."
Goto end
untar_failed:
@@ -944,69 +961,38 @@
FunctionEnd
-Section /O "North Carolina (Wake County) Data Set" SecNorthCarolinaSDB
+Section /O "Important Microsoft Runtime DLLs" SecMSRuntime
;Set the size (in KB) of the archive file
- StrCpy $ARCHIVE_SIZE_KB 144213
+ StrCpy $ARCHIVE_SIZE_KB 12521
;Set the size (in KB) of the unpacked archive file
- AddSize 254521
- StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata/north_carolina/"
- StrCpy $ARCHIVE_NAME "nc_spm_08_grass7.tar.gz"
- StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina (Wake County)"
- StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08_grass7"
- StrCpy $CUSTOM_UNTAR_FOLDER "North-Carolina"
+ AddSize 13500
- Call DownloadDataSet
+ StrCpy $HTTP_PATH "http://download.osgeo.org/osgeo4w/release/msvcrt/"
+ StrCpy $ARCHIVE_NAME "msvcrt-1.0.1-7.tar.bz2"
+ StrCpy $EXTENDED_ARCHIVE_NAME "Microsoft Visual C++ Redistributable Packages"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "install_msruntime"
-SectionEnd
+ Call DownloadInstallMSRuntime
-Section /O "South Dakota (Spearfish County) Data Set" SecSpearfishSDB
- ;Set the size (in KB) of the archive file
- StrCpy $ARCHIVE_SIZE_KB 20803
- ;Set the size (in KB) of the unpacked archive file
- AddSize 42171
- StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
- StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
- StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish County)"
- StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
- StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
SectionEnd
+Function DownloadDataSet
-Function DownloadInstallMSRuntime
- StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "The installer will download the $EXTENDED_ARCHIVE_NAME sample data set.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_These system libraries from Microsoft are needed for programs"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ built with Microsoft's Visual C++ compiler, such as Python and"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ GDAL which ship with GRASS, since MS does not include them by"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ default. You might already have them installed by other software,"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ if so you don't need to install them again, but if not GRASS will"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ fail to start and you will see errors like 'Missing MSVCR71.dll"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ or MSVCP100.dll'.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$TEMP\$CUSTOM_UNTAR_FOLDER.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_The $EXTENDED_ARCHIVE_NAME dataset will be copied to:$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER.$\r$\n"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue and install the runtimes, or Cancel"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ to skip the download and complete the GRASS"
- StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME.$\r$\n"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_Press OK to continue or Cancel to skip the download and complete the GRASS"
+ StrCpy $DOWNLOAD_MESSAGE_ "$DOWNLOAD_MESSAGE_ installation without the $EXTENDED_ARCHIVE_NAME data set.$\r$\n"
download:
@@ -1018,26 +1004,22 @@
download_ok:
InitPluginsDir
- untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME"
+ untgz::extract "-d" "$GIS_DATABASE" "$TEMP\$ARCHIVE_NAME"
Pop $0
- untar_ok:
- ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe /q"
- ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe /q"
- ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe /q"
- CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTDIR\extralib"
+ untar_ok:
+ Rename "$GIS_DATABASE\$ORIGINAL_UNTAR_FOLDER" "$GIS_DATABASE\$CUSTOM_UNTAR_FOLDER"
- Delete "$TEMP\$ORIGINAL_UNTAR_FOLDER"
Goto end
download_failed:
- MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME."
+ MessageBox MB_OK "Download Failed.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
Goto end
cancel_download:
- MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME."
+ MessageBox MB_OK "Download Cancelled.$\r$\nGRASS will be installed without the $EXTENDED_ARCHIVE_NAME sample data set."
Goto end
untar_failed:
@@ -1047,24 +1029,43 @@
FunctionEnd
-Section /O "Important Microsoft Runtime DLLs" SecMSRuntime
+Section /O "North Carolina (Wake County) Data Set" SecNorthCarolinaSDB
- StrCpy $ARCHIVE_SIZE_KB 12521
+ StrCpy $ARCHIVE_SIZE_KB 144213
- AddSize 13500
+ AddSize 254521
+ StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata/north_carolina/"
+ StrCpy $ARCHIVE_NAME "nc_spm_08_grass7.tar.gz"
+ StrCpy $EXTENDED_ARCHIVE_NAME "North Carolina (Wake County)"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "nc_spm_08_grass7"
+ StrCpy $CUSTOM_UNTAR_FOLDER "North_Carolina"
- StrCpy $HTTP_PATH "http://download.osgeo.org/osgeo4w/release/msvcrt/"
- StrCpy $ARCHIVE_NAME "msvcrt-1.0.1-7.tar.bz2"
- StrCpy $EXTENDED_ARCHIVE_NAME "Microsoft Visual C++ Redistributable Packages"
- StrCpy $ORIGINAL_UNTAR_FOLDER "install_msruntime"
+ Call DownloadDataSet
- Call DownloadInstallMSRuntime
+SectionEnd
+Section /O "South Dakota (Spearfish County) Data Set" SecSpearfishSDB
+ ;Set the size (in KB) of the archive file
+ StrCpy $ARCHIVE_SIZE_KB 20803
+ ;Set the size (in KB) of the unpacked archive file
+ AddSize 42171
+ StrCpy $HTTP_PATH "http://grass.osgeo.org/sampledata"
+ StrCpy $ARCHIVE_NAME "spearfish_grass60data-0.3.tar.gz"
+ StrCpy $EXTENDED_ARCHIVE_NAME "South Dakota (Spearfish County)"
+ StrCpy $ORIGINAL_UNTAR_FOLDER "spearfish60"
+ StrCpy $CUSTOM_UNTAR_FOLDER "Spearfish60"
SectionEnd
;Uninstaller Section
@@ -1098,14 +1099,14 @@
${unregisterExtension} ".pyw" "Python File (no console)"
SectionEnd
;Installer Section Descriptions
!insertmacro MUI_FUNCTION_DESCRIPTION_BEGIN
!insertmacro MUI_DESCRIPTION_TEXT ${SecGRASS} "Install GRASS ${VERSION_NUMBER}"
- !insertmacro MUI_DESCRIPTION_TEXT ${SecMSRuntime} "Some software included in this installer (e.g. GDAL, Python) may need Microsoft's Visual C++ redistributable system libraries.$\r$\nDownload and install the Redistributable Package"
- !insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set"
- !insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecMSRuntime} "Some software included in this installer (e.g. GDAL, Python) may need Microsoft's Visual C++ redistributable system libraries.$\r$\nDownload and install the Redistributable Package. (12 MB)"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecNorthCarolinaSDB} "Download and install the North Carolina (Wake County) sample data set. (135 MB)"
+ !insertmacro MUI_DESCRIPTION_TEXT ${SecSpearfishSDB} "Download and install the South Dakota (Spearfish County) sample data set. (20 MB)"
!insertmacro MUI_FUNCTION_DESCRIPTION_END
