[GRASS-SVN] r56048 - grass-addons/grass6/raster/r.tsunami
svn_grass at osgeo.org
Tue Apr 30 05:41:21 PDT 2013
Author: maxi
Date: 2013-04-30 05:41:21 -0700 (Tue, 30 Apr 2013)
New Revision: 56048
Removed:
grass-addons/grass6/raster/r.tsunami/r.tsunami.html
module r.tsunami
Deleted: grass-addons/grass6/raster/r.tsunami/r.tsunami.html
--- grass-addons/grass6/raster/r.tsunami/r.tsunami.html 2013-04-30 10:03:21 UTC (rev 56047)
+++ grass-addons/grass6/raster/r.tsunami/r.tsunami.html 2013-04-30 12:41:21 UTC (rev 56048)
@@ -1,115 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>GRASS GIS: r.tsunami</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>r.tsunami</b></em> - Calculation of flooded area due to tsunami event.
-<h2>KEYWORDS</h2>
-tsunami, modelling
-<h2>SYNOPSIS</h2>
-<b>r.tsunami</b><br>
-<b>r.tsunami help</b><br>
-<b>r.tsunami</b> <b>dtm</b>=<em>string</em> <b>rough</b>=<em>string</em> <b>size</b>=<em>value</em> <b>h</b>=<em>value</em> <b>ho</b>=<em>value</em>
-<b>Ho</b>=<em>value</em> [<b>runup</b>=<em>string</em>] <b>flood</b>=<em>string</em> <b>hflood</b>=<em>string</em> <b>x</b>=<em>value</em> <b>y</b>=<em>value</em> [--<b>overwrite</b>] [--<b>verbose</b>] [--<b>quiet</b>]
-<h3>Flags:</h3>
-<DL>
-<DT><b>-m</b></DT>
-<DD>Runup values [m]</DD>
-<DT><b>-a</b></DT>
-<DD>Calculation of total flooded area [mq]</DD>
-<DT><b>-i</b></DT>
-<DD>Flood height values [m]</DD>
-<DT><b>--overwrite</b></DT>
-<DD>Allow output files to overwrite existing files</DD>
-<DT><b>--verbose</b></DT>
-<DD>Verbose module output</DD>
-<DT><b>--quiet</b></DT>
-<DD>Quiet module output</DD>
-</DL>
-<h3>Parameters:</h3>
-<DL>
-<DT><b>dtm</b>=<em>string</em></DT>
-<DD>Digital terrain model raster map name</DD>
-<DT><b>rough</b>=<em>string</em></DT>
-<DD>Roughness raster map name</DD>
-<DT><b>size</b>=<em>value</em></DT>
-<DD>Size of the neighborhood [-]</DD>
-<DD>Options: <em> 1,3,5,7,9,11,13,15,17,19,21,23,25</em></DD>
-<DD>Default: <em>3</em></DD>
-<DT><b>h</b>=<em>value</em></DT>
-<DD> Sea depth at coastline [m]</DD>
-<DT><b>ho</b>=<em>value</em></DT>
-<DD>Sea depth at source point [m]</DD>
-<DT><b>Ho</b>=<em>value</em></DT>
-<DD>Wave height at source point [m]</DD>
-<DT><b>runup</b>=<em>string</em></DT>
-<DD>Output runup map name</DD>
-<DT><b>flood</b>=<em>string</em></DT>
-<DD>Output flooded area map name</DD>
-<DT><b>hflood</b>=<em>string</em></DT>
-<DD>Output flood height map name</DD>
-<DT><b>x</b>=<em>value</em></DT>
-<DD>X coordinate (sea point)</DD>
-<DT><b>y</b>=<em>value</em></DT>
-<DD>Y coordinate (sea point)</DD>
-</DL>
-<h2>DESCRIPTION</h2>
-<em>r.tsunami</em> allow to assess the maximum vertical height
-of the tsunami wave at the coast (run-up) and the subsequent
-inundation on the mainland.The procedure takes into account local
-morphological characteristics,vegetation and urbanization
-through the usage of digital terrain model and roughness raster
-maps.
-<h2>NOTES</h2>
-The digital terrain model raster map must contain null values at sea level.
-<p>
-<p>
-<h2>AUTHORS</h2>
-M.Molinari, M. Cannata (Earth Science Institute, http://istgeo.ist.supsi.ch).
-Implementation of the base method developed by B. Federici.
-<h2>REFERENCES</h2>
-<ul>
- <li>Federici, B & Cosso, T, 2006, 'Tsunami inundation maps and damage sceneries through the GIS GRASS',<a href="http://www.foss4g2006.org">
- proceedings of FOSS4G2006 </a>, Lausanne, Switzerland, viewed 13 August 2008. </li>
- <li>Cannata M., Federici B., Molinari M., - "Carte di inondazione dovute a tsunami mediante il GIS GRASS: applicazione all'isola di St. Lucia, Caraibi",proceedings of <a href ="http://gislab.dirap.unipa.it/grass_meeting/index.htm">VIII Italian GRASS user meeting</a>, Palermo, Italy, viewed 13 August 2008. </li>
-</ul>
-<p><i>Last changed: $Date: 2008-05-16 12:09:06 -0700 (Fri, 16 May 2008) $</i>
-<HR>
-<P><a href="index.html">Main index</a> - <a href="raster.html">raster index</a> - <a href="full_index.html">Full index</a></P>
-<P>© 2003-2008 <a href="http://grass.osgeo.org">GRASS Development Team</a></p>
-</body>
-</html>
