[GRASS-SVN] r56050 - grass/trunk/vector/v.in.ascii
Tue Apr 30 13:37:55 PDT 2013
Author: martinl
Date: 2013-04-30 13:37:54 -0700 (Tue, 30 Apr 2013)
New Revision: 56050
   grass/trunk/vector/v.in.ascii/main.c
v.in.ascii: be translators friendly
            no need for Vect_delete() - already using standard i/o error handler which deletes output map automatically
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c	2013-04-30 12:41:49 UTC (rev 56049)
+++ grass/trunk/vector/v.in.ascii/main.c	2013-04-30 20:37:54 UTC (rev 56050)
@@ -268,39 +268,35 @@
 	/* check column numbers */
 	if (xcol >= minncols) {
-	    Vect_delete(new->answer);
-	    G_fatal_error(_("x column number > minimum last column number\n(incorrect field separator?)"));
+	    G_fatal_error(_("'%s' column number > minimum last column number "
+                            "(incorrect field separator or format?)"), "x");
 	if (ycol >= minncols) {
-	    G_fatal_error(_("y column number > minimum last column number\n(incorrect field separator?)"));
+                            "(incorrect field separator or format?)"), "y");
 	if (zcol >= minncols) {
-	    G_fatal_error(_("z column number > minimum last column number "
-			    "(incorrect field separator?)"));
+                            "(incorrect field separator or format?)"), "z");
 	if (catcol >= minncols) {
-	    G_fatal_error(_("cat column number > minimum last column number "
+                            "(incorrect field separator or format?)"), "cat");
 	if (coltype[xcol] == DB_C_TYPE_STRING) {
-	    G_fatal_error(_("x column is not of number type"));
+	    G_fatal_error(_("'%s' column is not of number type"), "x");
 	if (coltype[ycol] == DB_C_TYPE_STRING) {
-	    G_fatal_error(_("y column is not of number type"));
+	    G_fatal_error(_("'%s' column is not of number type"), "y");
 	if (zcol >= 0 && coltype[zcol] == DB_C_TYPE_STRING) {
-	    G_fatal_error(_("z column is not of number type"));
+	    G_fatal_error(_("'%s' column is not of number type"), "z");
 	if (catcol >= 0 && coltype[catcol] == DB_C_TYPE_STRING) {
-	    G_fatal_error(_("cat column is not of number type"));
+	    G_fatal_error(_("'%s' column is not of number type"), "cat");
 	/* Create table */
@@ -322,7 +318,6 @@
 					      Vect_subst_var(Fi->database,
 							     &Map));
 	    if (driver == NULL) {
 		G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			      Vect_subst_var(Fi->database, &Map), Fi->driver);
@@ -341,7 +336,6 @@
 		    db_append_string(&sql, ", ");
 		if (catcol == i && coltype[i] != DB_C_TYPE_INT) {
 		    G_fatal_error(_("Category column is not of integer type"));
@@ -391,7 +385,6 @@
 	    /* Create table */
 	    G_debug(3, db_get_string(&sql));
 	    if (db_execute_immediate(driver, &sql) != DB_OK) {
 		G_fatal_error(_("Unable to create table: %s"),
@@ -400,7 +393,6 @@
 	    if (db_grant_on_table
 		(driver, Fi->table, DB_PRIV_SELECT,
 		 DB_GROUP | DB_PUBLIC) != DB_OK) {
 		G_fatal_error(_("Unable to grant privileges on table <%s>"),
 			      Fi->table);
@@ -413,7 +405,6 @@
 		db_set_string(&sql, Fi->table);
 		if (db_describe_table(driver, &sql, &table) != DB_OK) {
 		    G_fatal_error(_("Unable to describe table <%s>"),
 				  Fi->table);
@@ -422,7 +413,6 @@
 		if ((catcol >= 0 && nc != ncols) ||
 		    (catcol < 0 && (nc - 1) != ncols)) {
 		    G_fatal_error(_("Number of columns defined (%d) does not match number "
 				   "of columns (%d) in input"),
 				  catcol < 0 ? nc - 1 : nc, ncols);
@@ -463,7 +453,6 @@
 			break;
 		    case DB_C_TYPE_DOUBLE:
 			if (ctype == DB_C_TYPE_INT) {
 			    G_fatal_error(_("Column number %d <%s> defined as integer "
 					   "has double values"), i + 1,
 					  db_get_column_name(column));
@@ -476,19 +465,16 @@
 			break;
 		    case DB_C_TYPE_STRING:
 					   "has string values"), i + 1,
 			else if (ctype == DB_C_TYPE_DOUBLE) {
 			    G_fatal_error(_("Column number %d <%s> defined as double "
 			if (length < collen[i]) {
 			    G_fatal_error(_("Length of column %d <%s> (%d) is less than "
 					   "maximum value " "length (%d)"),
 					  i + 1, db_get_column_name(column),
