[GRASS-SVN] r57383 - in grass/trunk/gui/wxpython: gui_core iclass mapdisp vdigit
svn_grass at osgeo.org
Sat Aug 3 12:43:49 PDT 2013
Author: wenzeslaus
Date: 2013-08-03 12:43:48 -0700 (Sat, 03 Aug 2013)
New Revision: 57383
grass/trunk/gui/wxpython/gui_core/mapdisp.py
grass/trunk/gui/wxpython/gui_core/mapwindow.py
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
grass/trunk/gui/wxpython/mapdisp/statusbar.py
grass/trunk/gui/wxpython/vdigit/mapwindow.py
wxGUI/mapwindow: removing mouse motion handlers, using signals for coordinates and for vdigit info
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py 2013-08-03 10:00:53 UTC (rev 57382)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py 2013-08-03 19:43:48 UTC (rev 57383)
@@ -264,10 +264,11 @@
def CoordinatesChanged(self):
"""!Shows current coordinates on statusbar.
- Used in BufferedWindow to report change of map coordinates (under mouse cursor).
- self.statusbarManager.ShowItem('coordinates')
+ # assuming that the first mode is coordinates
+ # probably shold not be here but good solution is not available now
+ if self.statusbarManager.GetMode() == 0:
+ self.statusbarManager.ShowItem('coordinates')
def StatusbarReposition(self):
"""!Reposition items in statusbar"""
@@ -326,6 +327,7 @@
mapWindow.zoomHistoryUnavailable.connect(
lambda:
self.GetMapToolbar().Enable('zoomBack', enable=False))
+ mapWindow.mouseMoving.connect(self.CoordinatesChanged)
def _prepareZoom(self, mapWindow, zoomType):
"""!Prepares MapWindow for zoom, toggles toolbar
Modified: grass/trunk/gui/wxpython/gui_core/mapwindow.py
--- grass/trunk/gui/wxpython/gui_core/mapwindow.py 2013-08-03 10:00:53 UTC (rev 57382)
+++ grass/trunk/gui/wxpython/gui_core/mapwindow.py 2013-08-03 19:43:48 UTC (rev 57383)
@@ -286,29 +286,23 @@
def OnMotion(self, event):
"""!Tracks mouse motion and update statusbar
+ @todo remove this method when lastEN is not used
@see GetLastEN
try:
self.lastEN = self.Pixel2Cell(event.GetPositionTuple())
except (ValueError):
self.lastEN = None
- # FIXME: special case for vdigit and access to statusbarManager
- if self.frame.statusbarManager.GetMode() == 0: # Coordinates
- updated = False
- if hasattr(self, "digit"):
- precision = int(UserSettings.Get(group = 'projection', key = 'format',
- subkey = 'precision'))
- updated = self._onMotion(self.lastEN, precision)
- if not updated:
- self.frame.CoordinatesChanged()
event.Skip()
def GetLastEN(self):
"""!Returns last coordinates of mouse cursor.
+ This method is depreciated.
@see OnMotion
return self.lastEN
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2013-08-03 10:00:53 UTC (rev 57382)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2013-08-03 19:43:48 UTC (rev 57383)
@@ -106,7 +106,13 @@
self._setUpMapWindow(self.secondMapWindow)
self.firstMapWindow.InitZoomHistory()
self.secondMapWindow.InitZoomHistory()
+ # TODO: for vdigit: it does nothing here because areas do not produce this info
+ self.firstMapWindow.digitizingInfo.connect(
+ lambda text:
+ self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(text))
+ self.firstMapWindow.digitizingInfoUnavailable.connect(
+ lambda:
+ self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(None))
self.SetSize(size)
# Add toolbars
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-03 10:00:53 UTC (rev 57382)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-03 19:43:48 UTC (rev 57383)
@@ -160,13 +160,7 @@
properties=self.mapWindowProperties,
overlays=self.decorations)
self.MapWindow2D.mapQueried.connect(self.Query)
- # enable or disable zoom history tool
- self.MapWindow2D.zoomHistoryAvailable.connect(
- lambda:
- self.GetMapToolbar().Enable('zoomBack', enable=True))
- self.MapWindow2D.zoomHistoryUnavailable.connect(
- lambda:
- self.GetMapToolbar().Enable('zoomBack', enable=False))
+ self._setUpMapWindow(self.MapWindow2D)
# manage the state of toolbars connected to mouse cursor
self.MapWindow2D.mouseHandlerRegistered.connect(
lambda:
@@ -253,6 +247,13 @@
Map = self.Map, tree = self.tree,
lmgr = self._layerManager)
+ self._setUpMapWindow(self.MapWindowVDigit)
+ self.MapWindowVDigit.digitizingInfo.connect(
+ lambda text:
+ self.MapWindowVDigit.digitizingInfoUnavailable.connect(
+ lambda:
self.MapWindowVDigit.Show()
self._mgr.AddPane(self.MapWindowVDigit, wx.aui.AuiPaneInfo().CentrePane().
Dockable(False).BestSize((-1,-1)).Name('vdigit').
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-03 10:00:53 UTC (rev 57382)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-03 19:43:48 UTC (rev 57383)
@@ -115,6 +115,9 @@
self.mouseLeftUpPointer = Signal('BufferedWindow.mouseLeftUpPointer')
# Emitted when left mouse button is released
self.mouseLeftUp = Signal('BufferedWindow.mouseLeftUp')
+ # Emitted when mouse us moving (mouse motion event)
+ # Parametres are x and y of the mouse position in map (cell) units
+ self.mouseMoving = Signal('BufferedWindow.mouseMoving')
# event bindings
self.Bind(wx.EVT_PAINT, self.OnPaint)
@@ -1045,6 +1048,9 @@
self.OnMouseEnter(event)
elif event.Moving():
+ pixelCoordinates = event.GetPositionTuple()[:]
+ coordinates = self.Pixel2Cell(pixelCoordinates)
+ self.mouseMoving.emit(x=coordinates[0], y=coordinates[1])
self.OnMouseMoving(event)
def OnMouseWheel(self, event):
Modified: grass/trunk/gui/wxpython/mapdisp/statusbar.py
--- grass/trunk/gui/wxpython/mapdisp/statusbar.py 2013-08-03 10:00:53 UTC (rev 57382)
+++ grass/trunk/gui/wxpython/mapdisp/statusbar.py 2013-08-03 19:43:48 UTC (rev 57383)
@@ -860,8 +860,14 @@
SbTextItem.__init__(self, mapframe, statusbar, position)
self.name = 'coordinates'
self.label = _("Coordinates")
+ self._additionalInfo = None
+ self._basicValue = None
def Show(self):
+ """Show the last map window coordinates.
+ @todo remove last EN call and use coordinates comming from signal
format = UserSettings.Get(group = 'projection', key = 'format',
@@ -869,15 +875,35 @@
projection = self.mapFrame.GetProperty('projection')
try:
e, n = self.mapFrame.GetWindow().GetLastEN()
- self.SetValue(self.ReprojectENFromMap(e, n, projection, precision, format))
+ self._basicValue = self.ReprojectENFromMap(e, n, projection, precision, format)
+ if self._additionalInfo:
+ value = "{coords} ({additionalInfo})".format(coords=self._basicValue,
+ additionalInfo=self._additionalInfo)
+ else:
+ value = self._basicValue
+ self.SetValue(value)
except SbException, e:
self.SetValue(e)
+ # TODO: remove these excepts, they just hide errors, solve problems differently
except TypeError, e:
self.SetValue("")
except AttributeError:
self.SetValue("") # during initialization MapFrame has no MapWindow
SbTextItem.Show(self)
+ def SetAdditionalInfo(self, text):
+ """Sets additional info to be shown together with coordinates.
+ The format is translation dependent but the default is
+ "coordinates (additional info)"
+ It does not show the changed text immediately, it waits for the Show()
+ method to be called.
+ @param text string to be shown
+ self._additionalInfo = text
def ReprojectENFromMap(self, e, n, useDefinedProjection, precision, format):
"""!Reproject east, north to user defined projection.
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-08-03 10:00:53 UTC (rev 57382)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-08-03 19:43:48 UTC (rev 57383)
@@ -17,6 +17,8 @@
import wx
import tempfile
+from grass.pydispatch.signal import Signal
from dbmgr.dialogs import DisplayAttributesDialog
from core.gcmd import RunCommand, GMessage, GError
from core.debug import Debug
@@ -41,9 +43,23 @@
self.pdcVector = wx.PseudoDC()
self.toolbar = self.parent.GetToolbar('vdigit')
self.digit = None # wxvdigit.IVDigit
+ self._digitizingInfo = False # digitizing with info
+ # Emitted when info about digitizing updated
+ # Parameter text is a string with information
+ # currently used only for coordinates of mouse cursor + segmnt and
+ # total feature length
+ self.digitizingInfo = Signal('BufferedWindow.digitizingInfo')
+ # Emitted when some info about digitizing is or will be availbale
+ self.digitizingInfoAvailable = Signal('BufferedWindow.digitizingInfo')
+ # digitizingInfo signal is emmited only between digitizingInfoAvailable
+ # and digitizingInfoUnavailable signals
+ self.digitizingInfoUnavailable = Signal('BufferedWindow.digitizingInfo')
self.Bind(wx.EVT_KEY_DOWN, self.OnKeyDown)
+ self.mouseMoving.connect(self._mouseMovingToDigitizingInfo)
def GetDisplay(self):
if self.digit:
return self.digit.GetDisplay()
@@ -53,35 +69,36 @@
"""!Set up related toolbar
self.toolbar = toolbar
- def _onMotion(self, coord, precision):
- """!Track mouse motion and update statusbar (see self.Motion)
- @parem coord easting, northing
- @param precision formatting precision
- e, n = coord
+ def _mouseMovingToDigitizingInfo(self, x, y):
+ e, n = x, y
+ precision = int(UserSettings.Get(group='projection', key='format',
+ subkey='precision'))
if self.toolbar.GetAction() != 'addLine' or \
self.toolbar.GetAction('type') not in ('line', 'boundary') or \
len(self.polycoords) == 0:
- return False
+ # we cannot provide info, so find out if it is something new
+ if self._digitizingInfo:
+ self.digitizingInfoUnavailable.emit()
+ return
+ # else, we can provide info, so find out if it is first time
+ if not self._digitizingInfo:
+ self._digitizingInfo = True
+ self.digitizingInfoAvailable.emit()
# for linear feature show segment and total length
distance_seg = self.Distance(self.polycoords[-1],
- (e, n), screen = False)[0]
+ (e, n), screen=False)[0]
distance_tot = distance_seg
for idx in range(1, len(self.polycoords)):
distance_tot += self.Distance(self.polycoords[idx-1],
self.polycoords[idx],
- screen = False)[0]
- self.parent.SetStatusText("%.*f, %.*f (seg: %.*f; tot: %.*f)" % \
- (precision, e, precision, n,
- precision, distance_seg,
- precision, distance_tot), 0)
- return True
+ screen=False)[0]
+ text = "seg: %.*f; tot: %.*f" % (precision, distance_seg,
+ precision, distance_tot)
+ self.digitizingInfo.emit(text=text)
def OnKeyDown(self, event):
"""!Key pressed"""
shift = event.ShiftDown()
