[GRASS-SVN] r57385 - in grass/trunk/gui/wxpython: gui_core mapdisp nviz
Sat Aug 3 13:44:12 PDT 2013
Author: wenzeslaus
Date: 2013-08-03 13:44:12 -0700 (Sat, 03 Aug 2013)
New Revision: 57385
   grass/trunk/gui/wxpython/gui_core/mapwindow.py
   grass/trunk/gui/wxpython/mapdisp/mapwindow.py
   grass/trunk/gui/wxpython/nviz/mapwindow.py
wxGUI/mapwindow: unused parameters removed, depreciation warnings added
Modified: grass/trunk/gui/wxpython/gui_core/mapwindow.py
--- grass/trunk/gui/wxpython/gui_core/mapwindow.py	2013-08-03 20:29:18 UTC (rev 57384)
+++ grass/trunk/gui/wxpython/gui_core/mapwindow.py	2013-08-03 20:44:12 UTC (rev 57385)
@@ -103,10 +103,9 @@
      - Pixel2Cell
      - Cell2Pixel (if it is possible)
-    def __init__(self, parent, giface, Map, frame, **kwargs):
+    def __init__(self, parent, giface, Map):
         self.parent = parent
         self.Map = Map
-        self.frame = frame
         self._giface = giface
         # mouse attributes -- position on the screen, begin and end of
@@ -174,7 +173,12 @@
     def RegisterMouseEventHandler(self, event, handler, cursor = None):
         """!Binds event handler
+        @depreciated This method is depreciated. Use Signals or drawing API instead.
+        Signals do not cover all events but new Signals can be added when needed
+        consider also adding generic signal. However, more interesing and useful
+        is higher level API to create objects, graphics etc.
         Call event.Skip() in handler to allow default processing in MapWindow.
         If any error occures inside of handler, the handler is removed.
@@ -226,6 +230,8 @@
     def UnregisterAllHandlers(self):
         """!Unregisters all registered handlers
         Before each handler is unregistered it is called with string
         value "unregistered" of event parameter.
@@ -242,7 +248,9 @@
     def UnregisterMouseEventHandler(self, event, handler):
         """!Unbinds event handler for event
         Before handler is unregistered it is called with string value
@@ -301,7 +309,7 @@
     def GetLastEN(self):
         """!Returns last coordinates of mouse cursor.
-        This method is depreciated.
+        @depreciated This method is depreciated. Use Signal with coordinates as parameters.
         @see OnMotion
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-08-03 20:29:18 UTC (rev 57384)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-08-03 20:44:12 UTC (rev 57385)
@@ -67,8 +67,7 @@
         @param style wx window style
         @param kwargs keyword arguments passed to MapWindow and wx.Window
-        MapWindow.__init__(self, parent = parent, giface = giface, Map = Map,
-                           frame = frame, **kwargs)
+        MapWindow.__init__(self, parent=parent, giface=giface, Map=Map)
         wx.Window.__init__(self, parent = parent, id = id, style = style, **kwargs)
         self._properties = properties
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py	2013-08-03 20:29:18 UTC (rev 57384)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py	2013-08-03 20:44:12 UTC (rev 57385)
@@ -86,10 +86,8 @@
             glcanvas.GLCanvas.__init__(self, parent, id, attribList=attribs)
         else:
             glcanvas.GLCanvas.__init__(self, parent, id)
-        MapWindow.__init__(self, parent = parent, giface = giface, frame = frame,
-                           Map = Map)
         self.Hide()
         self.init = False
