[GRASS-SVN] r57387 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Sat Aug 3 14:57:45 PDT 2013
Author: wenzeslaus
Date: 2013-08-03 14:57:44 -0700 (Sat, 03 Aug 2013)
New Revision: 57387
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
wxGUI/mapwindow: frame parameter added to the BufferedWindow (fixing r57385), todos added
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-03 21:46:19 UTC (rev 57386)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-03 21:57:44 UTC (rev 57387)
@@ -559,7 +559,8 @@
# change the cursor
self.MapWindow.SetCursor(self.cursors["hand"])
self.MapWindow.SetFocus()
+ # TODO: can be replaced/merged by ZoomToWind
def OnZoomRegion(self, event):
"""!Zoom to region
@@ -568,6 +569,7 @@
self.UpdateMap()
# event.Skip()
+ # TODO: delete this here and in gcp
def OnAlignRegion(self, event):
"""!Align region
@@ -979,6 +981,7 @@
# the desired raster) is selected to be profiled
win.OnSelectRaster(None)
+ # TODO: move somewhere where can be reused (utils?), remove from gcp
def FormatDist(self, dist):
"""!Format length numbers and units in a nice way,
as a function of length. From code by Hamish Bowman
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-03 21:46:19 UTC (rev 57386)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-03 21:57:44 UTC (rev 57387)
@@ -71,6 +71,7 @@
wx.Window.__init__(self, parent = parent, id = id, style = style, **kwargs)
self._properties = properties
+ self.frame = frame # remove including a frame parameter
# flags
self.resize = False # indicates whether or not a resize event has taken place
@@ -782,6 +783,7 @@
# draw region extent
self.DrawLines(pdc=self.pdcDec, polycoords=regionCoords)
+ # TODO: move to utils
def IsInRegion(self, region, refRegion):
Test if 'region' is inside of 'refRegion'
