[GRASS-SVN] r57396 - in grass/trunk/gui/wxpython: gui_core mapdisp nviz
svn_grass at osgeo.org
Sun Aug 4 09:13:57 PDT 2013
Author: wenzeslaus
Date: 2013-08-04 09:13:56 -0700 (Sun, 04 Aug 2013)
New Revision: 57396
grass/trunk/gui/wxpython/gui_core/toolbars.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
wxGUI/mapwindow: implementing mouse moving signal (r57383) and zoom history signals (r57078) for nviz
Modified: grass/trunk/gui/wxpython/gui_core/toolbars.py
--- grass/trunk/gui/wxpython/gui_core/toolbars.py 2013-08-04 15:07:32 UTC (rev 57395)
+++ grass/trunk/gui/wxpython/gui_core/toolbars.py 2013-08-04 16:13:56 UTC (rev 57396)
@@ -206,7 +206,9 @@
try:
id = getattr(self, tool)
except AttributeError:
- # this should raise an error
+ # TODO: test everything that this is not raised
+ # this error was ignored for a long time
+ raise AttributeError("Toolbar does not have a tool %s." % tool)
return
self.EnableTool(id, enable)
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-04 15:07:32 UTC (rev 57395)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-04 16:13:56 UTC (rev 57396)
@@ -329,6 +329,7 @@
if not self.MapWindow3D:
self.MapWindow3D = GLWindow(self, giface = self._giface, id = wx.ID_ANY, frame = self,
Map = self.Map, tree = self.tree, lmgr = self._layerManager)
+ self._setUpMapWindow(self.MapWindow3D)
self.MapWindow = self.MapWindow3D
self.MapWindow.SetCursor(self.cursors["default"])
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2013-08-04 15:07:32 UTC (rev 57395)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2013-08-04 16:13:56 UTC (rev 57396)
@@ -33,6 +33,7 @@
from wx.glcanvas import WX_GL_DEPTH_SIZE
import grass.script as grass
+from grass.pydispatch.signal import Signal
from core.gcmd import GMessage, GException, GError
from core.debug import Debug
@@ -89,7 +90,20 @@
MapWindow.__init__(self, parent=parent, giface=giface, Map=Map)
self.Hide()
+ # TODO: same signals as in BufferedWindow
+ # same interface is good, but how to ensure same names
+ # or avoid duplication, define in map window base class?
+ # Emitted when mouse us moving (mouse motion event)
+ # Parametres are x and y of the mouse position in map (cell) units
+ self.mouseMoving = Signal('GLWindow.mouseMoving')
+ # Emitted when the zoom history stack is emptied
+ self.zoomHistoryUnavailable = Signal('GLWindow.zoomHistoryUnavailable')
+ # Emitted when the zoom history stack is not empty
+ self.zoomHistoryAvailable = Signal('GLWindow.zoomHistoryAvailable')
self.init = False
self.initView = False
self.context = None
@@ -658,7 +672,15 @@
# double click
elif event.ButtonDClick():
self.OnDClick(event)
+ elif event.Moving():
+ pixelCoordinates = event.GetPositionTuple()[:]
+ coordinates = self.Pixel2Cell(pixelCoordinates)
+ # coordinates are none when no map is loaded
+ # TODO: handle in more clever way: check the state
+ if coordinates is not None:
+ self.mouseMoving.emit(x=coordinates[0], y=coordinates[1])
event.Skip()
def OnMouseWheel(self, event):
@@ -670,7 +692,7 @@
return
wheel = event.GetWheelRotation()
- Debug.msg (5, "GLWindow.OnMouseMotion(): wheel = %d" % wheel)
+ Debug.msg (5, "GLWindow.OnMouseWheel(): wheel = %d" % wheel)
if self.timerFly.IsRunning() and self.fly['mouseControl']:
if wheel > 0:
self.ChangeFlySpeed(increase = True)
@@ -972,8 +994,7 @@
# disable tool if stack is empty
if len(self.viewhistory) < 2: # disable tool
- toolbar = self.parent.GetMapToolbar()
- toolbar.Enable('zoomback', enable = False)
+ self.zoomHistoryUnavailable.emit()
# set view and update nviz view page
self.lmgr.nviz.UpdateState(view = view[0], iview = view[1])
@@ -1008,13 +1029,10 @@
# update toolbar
if len(self.viewhistory) > 1:
- enable = True
+ self.zoomHistoryAvailable.emit()
else:
- enable = False
- toolbar.Enable('zoomback', enable)
return removed
def ResetViewHistory(self):
