[GRASS-SVN] r57403 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Sun Aug 4 12:39:26 PDT 2013
Author: annakrat
Date: 2013-08-04 12:39:25 -0700 (Sun, 04 Aug 2013)
New Revision: 57403
grass/trunk/gui/wxpython/gui_core/forms.py
wxGUI/forms: fix #2054 (merge from releasebranch, r57401)
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2013-08-04 19:32:05 UTC (rev 57402)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2013-08-04 19:39:25 UTC (rev 57403)
@@ -1383,8 +1383,9 @@
this_sizer = which_sizer
colorSize = 150
# For color selectors, this is a three-member array, holding the IDs of
- # the text control for multiple colors (or None),
- # the selector proper and either a "transparent" checkbox or None
+ # the color picker, the text control for multiple colors (or None),
+ # and either a "transparent" checkbox or None
+ p['wxId'] = [None] * 3
if p.get('multiple', False):
txt = wx.TextCtrl(parent = which_panel, id = wx.ID_ANY)
this_sizer.Add(item = txt, proportion = 1,
@@ -1392,10 +1393,8 @@
txt.Bind(wx.EVT_TEXT, self.OnSetValue)
colorSize = 40
label_color = ''
- p['wxId'] = [txt.GetId(),]
+ p['wxId'][1] = txt.GetId()
which_sizer.Add(this_sizer, flag = wx.EXPAND | wx.RIGHT, border = 5)
- else:
- p['wxId'] = [None,]
btn_colour = csel.ColourSelect(parent = which_panel, id = wx.ID_ANY,
label = label_color, colour = default_color,
@@ -1403,7 +1402,7 @@
this_sizer.Add(item = btn_colour, proportion = 0,
flag = wx.ADJUST_MINSIZE | wx.BOTTOM | wx.LEFT, border = 5)
btn_colour.Bind(csel.EVT_COLOURSELECT, self.OnColorChange)
- p['wxId'].append(btn_colour.GetId())
+ p['wxId'][0] = btn_colour.GetId()
if p.get('element', '') == 'color_none':
none_check = wx.CheckBox(which_panel, wx.ID_ANY, _("Transparent"))
@@ -1415,10 +1414,9 @@
flag = wx.ADJUST_MINSIZE | wx.LEFT | wx.RIGHT | wx.TOP, border = 5)
which_sizer.Add(this_sizer)
none_check.Bind(wx.EVT_CHECKBOX, self.OnColorChange)
- p['wxId'].append(none_check.GetId())
- else:
- p['wxId'].append(None)
+ p['wxId'][2] = none_check.GetId()
# file selector
elif p.get('prompt','') != 'color' and p.get('prompt', '') == 'file':
if p.get('age', 'new') == 'new':
@@ -1951,14 +1949,14 @@
myId = event.GetId()
for p in self.task.params:
if 'wxId' in p and myId in p['wxId']:
- multiple = p['wxId'][0] is not None # multiple colors
+ multiple = p['wxId'][1] is not None # multiple colors
hasTansp = p['wxId'][2] is not None
if multiple:
# selected color is added at the end of textCtrl
- colorchooser = wx.FindWindowById(p['wxId'][1])
+ colorchooser = wx.FindWindowById(p['wxId'][0])
new_color = colorchooser.GetValue()[:]
new_label = utils.rgb2str.get(new_color, ':'.join(map(str, new_color)))
- textCtrl = wx.FindWindowById(p['wxId'][0])
+ textCtrl = wx.FindWindowById(p['wxId'][1])
val = textCtrl.GetValue()
sep = ','
if val and val[-1] != sep:
@@ -1969,7 +1967,7 @@
elif hasTansp and wx.FindWindowById(p['wxId'][2]).GetValue():
p[ 'value' ] = 'none'
else:
# This is weird: new_color is a 4-tuple and new_color[:] is a 3-tuple
# under wx2.8.1
