[GRASS-SVN] r57411 - grass/trunk/raster/r.stream.extract
svn_grass at osgeo.org
Sun Aug 4 14:31:14 PDT 2013
Author: martinl
Date: 2013-08-04 14:31:13 -0700 (Sun, 04 Aug 2013)
New Revision: 57411
grass/trunk/raster/r.stream.extract/main.c
r.stream.extract: description cosmetics
Modified: grass/trunk/raster/r.stream.extract/main.c
--- grass/trunk/raster/r.stream.extract/main.c 2013-08-04 21:22:52 UTC (rev 57410)
+++ grass/trunk/raster/r.stream.extract/main.c 2013-08-04 21:31:13 UTC (rev 57411)
@@ -75,26 +75,26 @@
module = G_define_module();
G_add_keyword(_("raster"));
G_add_keyword(_("hydrology"));
- module->description = _("Stream network extraction");
+ G_add_keyword(_("stream network"));
+ module->description = _("Performs stream network extraction.");
- input.ele = G_define_standard_option(G_OPT_R_INPUT);
- input.ele->key = "elevation";
- input.ele->label = _("Elevation map");
- input.ele->description = _("Elevation on which entire analysis is based");
+ input.ele = G_define_standard_option(G_OPT_R_ELEV);
input.acc = G_define_standard_option(G_OPT_R_INPUT);
input.acc->key = "accumulation";
- input.acc->label = _("Accumulation map");
+ input.acc->label = _("Name of input accumulation raster map");
input.acc->required = NO;
input.acc->description =
- _("Stream extraction will use provided accumulation instead of calculating it anew");
+ _("Stream extraction will use provided accumulation instead of calculating it a new");
+ input.acc->guisection = _("Input options");
input.depression = G_define_standard_option(G_OPT_R_INPUT);
input.depression->key = "depression";
- input.depression->label = _("Map with real depressions");
+ input.depression->label = _("Name of raster map with real depressions");
input.depression->required = NO;
input.depression->description =
_("Streams will not be routed out of real depressions");
+ input.depression->guisection = _("Input options");
input.threshold = G_define_option();
input.threshold->key = "threshold";
@@ -143,21 +143,21 @@
output.stream_rast = G_define_standard_option(G_OPT_R_OUTPUT);
output.stream_rast->key = "stream_rast";
output.stream_rast->description =
- _("Output raster map with unique stream ids");
+ _("Name for output raster map with unique stream ids");
output.stream_rast->required = NO;
output.stream_rast->guisection = _("Output options");
output.stream_vect = G_define_standard_option(G_OPT_V_OUTPUT);
output.stream_vect->key = "stream_vect";
output.stream_vect->description =
- _("Output vector with unique stream ids");
+ _("Name for output vector map with unique stream ids");
output.stream_vect->required = NO;
output.stream_vect->guisection = _("Output options");
output.dir_rast = G_define_standard_option(G_OPT_R_OUTPUT);
output.dir_rast->key = "direction";
output.dir_rast->description =
- _("Output raster map with flow direction");
+ _("Name for output raster map with flow direction");
output.dir_rast->required = NO;
output.dir_rast->guisection = _("Output options");
