[GRASS-SVN] r57415 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Mon Aug 5 04:07:37 PDT 2013
Author: huhabla
Date: 2013-08-05 04:07:37 -0700 (Mon, 05 Aug 2013)
New Revision: 57415
grass/trunk/lib/python/temporal/temporal_granularity.py
Fixed granularity check
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2013-08-05 01:39:31 UTC (rev 57414)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2013-08-05 11:07:37 UTC (rev 57415)
@@ -24,16 +24,16 @@
from datetime_math import *
def check_granularity_string(granularity, temporal_type):
"""!Check if the granularity string is valid
@param granularity The granularity string
@param temporal_type The temporal type of the granularity relative or absolute
@return True if valid, False if invalid
@code
>>> check_granularity_string("1 year", "absolute")
True
>>> check_granularity_string("1 month", "absolute")
@@ -62,25 +62,30 @@
False
>>> check_granularity_string("bla second", "absolute")
False
+ >>> check_granularity_string("bla", "absolute")
+ False
>>> check_granularity_string(1, "relative")
True
>>> check_granularity_string("bla", "relative")
False
@endcode
temporal_type
if granularity is None:
return False
if temporal_type == "absolute":
- num, unit = granularity.split(" ")
- if unit not in ["second", "seconds", "minute", "minutes", "hour",
+ try:
+ num, unit = granularity.split(" ")
+ except:
+ return False
+ if unit not in ["second", "seconds", "minute", "minutes", "hour",
"hours", "day", "days", "week", "weeks", "month",
"months", "year", "years"]:
return False
try:
integer = int(num)
except:
@@ -92,7 +97,7 @@
return False
else:
return False
return True
@@ -100,16 +105,16 @@
def compute_relative_time_granularity(maps):
"""!Compute the relative time granularity
- Attention: The computation of the granularity
- is only correct in case of not overlapping intervals.
+ Attention: The computation of the granularity
+ is only correct in case of not overlapping intervals.
Hence a correct temporal topology is required for computation.
@param maps a ordered by start_time list of map objects
@return An integer
@code
>>> import grass.temporal as tgis
>>> tgis.init()
>>> maps = []
@@ -120,7 +125,7 @@
... maps.append(map)
>>> tgis.compute_relative_time_granularity(maps)
1
>>> maps = []
>>> count = 0
>>> timelist = ((0,3), (3,6), (6,9))
@@ -132,7 +137,7 @@
... count += 1
3
>>> maps = []
>>> count = 0
>>> timelist = ((0,3), (4,6), (8,11))
@@ -144,7 +149,7 @@
... count += 1
1
>>> maps = []
>>> count = 0
>>> timelist = ((0,8), (2,6), (5,9))
@@ -156,7 +161,7 @@
... count += 1
4
>>> maps = []
>>> count = 0
>>> timelist = ((0,8), (8,12), (12,18))
@@ -168,7 +173,7 @@
... count += 1
2
>>> maps = []
>>> count = 0
>>> timelist = ((0,None), (8,None), (12,None), (24,None))
@@ -180,7 +185,7 @@
... count += 1
4
>>> maps = []
>>> count = 0
>>> timelist = ((0,None), (8,14), (18,None), (24,None))
@@ -192,7 +197,7 @@
... count += 1
2
@endcode
@@ -214,7 +219,7 @@
if relation == "after":
start1, end1 = maps[i].get_temporal_extent_as_tuple()
start2, end2 = maps[i + 1].get_temporal_extent_as_tuple()
- # Gaps are between intervals, intervals and
+ # Gaps are between intervals, intervals and
# points, points and points
if end1 and start2:
t = abs(end1 - start2)
@@ -241,16 +246,16 @@
def compute_absolute_time_granularity(maps):
"""!Compute the absolute time granularity
The computed granularity is returned as number of seconds or minutes or hours
- or days or months or years.
+ or days or months or years.
@return The temporal topology as string "integer unit"
@code
@@ -268,7 +273,7 @@
... count += 1
>>> tgis.compute_absolute_time_granularity(maps)
'1 month'
>>> maps = []
>>> count = 0
>>> timelist = ((dt(2000,01,01),None), (dt(2000,01,02),None), (dt(2000,01,03),None))
@@ -280,7 +285,7 @@
... count += 1
'1 day'
>>> maps = []
>>> count = 0
>>> timelist = ((dt(2000,01,01),None), (dt(2000,01,02),None), (dt(2000,05,04,0,5,30),None))
@@ -292,7 +297,7 @@
... count += 1
'30 seconds'
>>> maps = []
>>> count = 0
>>> timelist = ((dt(2000,01,01),dt(2000,05,02)), (dt(2000,05,04,2),None))
@@ -308,7 +313,7 @@
>>> maps = []
>>> count = 0
>>> timelist = ((dt(2000,01,01),dt(2000,02,01)), (dt(2005,05,04,12),dt(2007,05,20,6)))
- >>> for t in timelist:
+ >>> for t in timelist:
... map = tgis.RasterDataset("a%i at P"%count)
... check = map.set_absolute_time(t[0],t[1])
... if check:
@@ -316,7 +321,7 @@
... count += 1
'6 hours'
@endcode
@@ -350,7 +355,7 @@
if end1 and start2:
delta.append(end1 - start2)
@@ -507,7 +512,7 @@
Returns: GCD of all numbers
return reduce(gcd, list)
if __name__ == "__main__":
