[GRASS-SVN] r57418 - grass/trunk/lib/python/temporal
Mon Aug 5 12:43:48 PDT 2013
Author: huhabla
Date: 2013-08-05 12:43:48 -0700 (Mon, 05 Aug 2013)
New Revision: 57418
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/metadata.py
   grass/trunk/lib/python/temporal/temporal_extent.py
Map list resampling by granularity rewritten to gain massive speedup and have some test. Metadata test update. White space removal.
Temporal topology computation bugfix for time instances.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2013-08-05 17:18:34 UTC (rev 57417)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2013-08-05 19:43:48 UTC (rev 57418)
@@ -5,15 +5,7 @@
 Temporal GIS related functions to be used in temporal GIS Python library package.
-Usage:
- at code
->>> import grass.temporal as tgis
->>> ad = AbstractDataset()
- at endcode
 (C) 2011-2012 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
@@ -488,7 +480,7 @@
         else:
             return None
-    def _get_temporal_extent(self):
+    def get_temporal_extent(self):
         """!Return the temporal extent of the correct internal type
         if self.is_time_absolute():
@@ -497,7 +489,7 @@
             return self.relative_time
         return None
-    temporal_extent = property(fget=_get_temporal_extent)
+    temporal_extent = property(fget=get_temporal_extent)
     def temporal_relation(self, dataset):
         """!Return the temporal relation of self and the provided dataset
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-08-05 17:18:34 UTC (rev 57417)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-08-05 19:43:48 UTC (rev 57418)
@@ -516,12 +516,12 @@
            >>> import datetime
            >>> map      = tgis.RasterDataset(None)
-           >>> temp_ext = tgis.RelativeTemporalExtent(start_time=1, end_time=2, unit="years")
+           >>> temp_ext = tgis.RasterRelativeTime(start_time=1, end_time=2, unit="years")
            >>> map.set_temporal_extent(temp_ext)
            >>> print map.get_temporal_extent_as_tuple()
            (1, 2)
            >>> map      = tgis.VectorDataset(None)
-           >>> temp_ext = tgis.AbsoluteTemporalExtent(start_time=datetime.datetime(2000, 1, 1),
+           >>> temp_ext = tgis.VectorAbsoluteTime(start_time=datetime.datetime(2000, 1, 1),
            ...                                        end_time=datetime.datetime(2001, 1, 1))
@@ -530,14 +530,15 @@
            @endcode
-        if issubclass(RelativeTemporalExtent, type(temporal_extent)):
+        if issubclass(type(temporal_extent), RelativeTemporalExtent):
             start = temporal_extent.get_start_time()
             end = temporal_extent.get_end_time()
             unit = temporal_extent.get_unit()
             self.set_relative_time(start, end, unit)
-        elif issubclass(AbsoluteTemporalExtent, type(temporal_extent)):
+        elif issubclass(type(temporal_extent), AbsoluteTemporalExtent):
             tz = temporal_extent.get_timezone()
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-08-05 17:18:34 UTC (rev 57417)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-08-05 19:43:48 UTC (rev 57418)
@@ -3,7 +3,8 @@
 @brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS related functions to be used in temporal GIS Python library package.
+Temporal GIS related functions to be used in temporal GIS Python
+library package.
@@ -715,9 +716,14 @@
            with "gap" map objects (id==None) for spatio-temporal topological
            operations that require the temporal extent only.
-           Each list entry is a list of map objects
-           which are potentially located in the actual granule.
+           Each list entry is a list of AbstractMapDatasets objects
+           which are potentially equal the actual granule, contain the
+           actual granule or are located in the actual granule.
+           Hence for each granule a list of AbstractMapDatasets can be
+           expected.
+           Maps that overlap the granule are ignored.
            The granularity of the space time dataset is used as increment in
            case the granule is not user defined.
@@ -746,13 +752,12 @@
                        unit and can not be changed.
            @param dbif The database interface to be used
-           @return ordered object list, or None in case nothing found
+           @return ordered list of map lists. Each list represents a single
+                   granule, or None in case nothing found
         dbif, connected = init_dbif(dbif)
-        obj_list = []
         if gran is None:
             gran = self.get_granularity()
@@ -765,137 +770,194 @@
         if start is None or end is None:
             return None
-        # Time instances and mixed time
-        is_irregular = False
+        maps = self.get_registered_maps_as_objects(dbif=dbif,
+                                                   order="start_time")
+        if not maps:
+            return None
         # We need to adjust the end time in case the the dataset has no
         # interval time, so we can catch time instances at the end
         if self.get_map_time() != "interval":
-            is_irregular = True
                 end = increment_datetime_by_string(end, gran)
             else:
                 end = end + gran
-        while start < end:
-            if self.is_time_absolute():
-                next = increment_datetime_by_string(start, gran)
-            else:
-                next = start + gran
+        l = AbstractSpaceTimeDataset.resample_maplist_by_granularity(maps,
+        start,
+        end,
+        gran)
+        if connected:
+            dbif.close()
-            # First we search for intervals that are are equal the granule or
-            # contain it
-            where = create_temporal_relation_sql_where_statement(
-                    start=start, end=next, use_start=False, use_during=False,
-                    use_overlap=False, use_contain=True, use_equal=True,
-                    use_follows=False, use_precedes=False)
-            rows = self.get_registered_maps("id", where, "start_time", dbif)
+        return l
-            found_gap = False
+    @staticmethod
+    def resample_maplist_by_granularity(maps, start, end, gran):
+        """!Resample a list of AbstractMapDatasets by a given granularity
-            if rows is not None and len(rows) != 0:
-                if len(rows) > 1:
-                    core.warning(_("More than one map found in a granule. "
-                                   "Temporal granularity seems to be invalid "
-                                   "or the chosen granularity is not a "
-                                   "greatest common divider of all intervals "
-                                   "and gaps in the dataset."))
+           The provided map list must be sorted by start time.
+           A valid temporal topology (no overlapping or inclusion allowed)
+           is needed to receive correct results.
-                maplist = []
-                for row in rows:
+           Maps with interval time, time instances and mixed
+           time are supported.
-                    map = self.get_new_map_instance(row["id"])
+           The temporal topology search order is as follows:
+           1. Maps that are equal to the actual granule are used
+           2. If no euqal found then maps that contain the actual granule
+              are used
+           3. If no maps are found that contain the actual granule then maps
+              are used that overlaps the actual granule
+           4. If no overlaps maps found then overlapped maps are used
+           5. If no overlapped maps are found then maps are used that are
+              durin the actual granule
-                        map.set_absolute_time(start, next)
-                    elif self.is_time_relative():
-                        map.set_relative_time(start, next,
-                                              self.get_relative_time_unit())
+           Each entry in the resulting list is a list of
+           AbstractMapDatasets objects.
+           expected.
-                    maplist.append(copy.copy(map))
+           Gaps between maps are identified as unregistered maps with id==None.
-                obj_list.append(copy.copy(maplist))
-            else:
-                # We may found a gap or a gap after a time instance
-                found_gap = True
+           @param maps An ordered list (by start time) of AbstractMapDatasets
+                   objects. All maps must have the same temporal type
+                   and the same unit in case of relative time.
+           @param start The start time of the provided map list
+           @param end   The end time of the provided map list
+           @param gran The granularity string to be used, if None the
+                   granularity of the space time dataset is used.
+                   Absolute time has the format "number unit", relative
+                   time has the format "number".
+                   The unit in case of absolute time can be one of "second,
+                   seconds, minute, minutes, hour, hours, day, days, week,
+                   weeks, month, months, year, years". The unit of the
+                   relative time granule is always the space time dataset
+                   unit and can not be changed.
-                # Searching for time instances and intervals that are during
-                # the current granule or overlapping it
-                        start=start, end=next, use_start=True, use_during=True,
-                        use_overlap=True, use_contain=False, use_equal=False,
-                rows = self.get_registered_maps("id,start_time,end_time",
-                                                where, "start_time", dbif)
+           Usage:
-                    # No gap if we found something in the granule with
-                    # intervaltime
-                    if len(rows) > 1:
-                                       "Temporal granularity seems to be "
-                                       "invalid or the chosen granularity is "
-                                       "not a greatest common divider of all "
-                                       "time instances in the dataset."))
+        @code
-                    maplist = []
-                    count = 0
-                    for row in rows:
-                        if count == 0:
-                            if row["end_time"] is not None or row["start_time"] != start:
-                                found_gap = False
-                        count += 1
+        >>> import grass.temporal as tgis
+        >>> maps = []
+        >>> for i in xrange(3):
+        ...     map = tgis.RasterDataset("map%i at PERMANENT"%i)
+        ...     check = map.set_relative_time(i + 2, i + 3, "days")
+        ...     maps.append(map)
+        >>> grans = tgis.AbstractSpaceTimeDataset.resample_maplist_by_granularity(maps,0,8,1)
+        >>> for map_list in grans:
+        ...    print map_list[0].get_id(), map_list[0].get_temporal_extent_as_tuple()
+        None (0, 1)
+        None (1, 2)
+        map0 at PERMANENT (2, 3)
+        map1 at PERMANENT (3, 4)
+        map2 at PERMANENT (4, 5)
+        None (5, 6)
+        None (6, 7)
+        None (7, 8)
+        >>> maps = []
+        >>> map1 = tgis.RasterDataset("map1 at PERMANENT")
+        >>> check = map1.set_relative_time(2, 6, "days")
+        >>> maps.append(map1)
+        >>> map2 = tgis.RasterDataset("map2 at PERMANENT")
+        >>> check = map2.set_relative_time(7, 13, "days")
+        >>> maps.append(map2)
+        >>> grans = tgis.AbstractSpaceTimeDataset.resample_maplist_by_granularity(maps,0,16,2)
+        None (0, 2)
+        map1 at PERMANENT (2, 4)
+        map1 at PERMANENT (4, 6)
+        map2 at PERMANENT (6, 8)
+        map2 at PERMANENT (8, 10)
+        map2 at PERMANENT (10, 12)
+        map2 at PERMANENT (12, 14)
+        None (14, 16)
-                            else:
-                                map.set_absolute_time(start, None)
-                            else:
-                                map.set_relative_time(start, None,
+        >>> maps = []
+        >>> check = map1.set_relative_time(2, None, "days")
+        >>> check = map2.set_relative_time(7, None, "days")
+        None (0, 2)
+        None (4, 6)
+        None (8, 10)
+        None (10, 12)
+        None (12, 14)
+        None (14, 16)
+        @endcode
+        if not maps:
+            return None
-                # In case of irregular time (point, mixed) the last granule
-                # does not belong to the dataset and will be ignored
-                if is_irregular:
-                    if next == end:
-                        found_gap = False
+        first = maps[0]
-            # Gap handling
-            if found_gap:
-                # Append a map object with None as id to indicate a gap
-                map = self.get_new_map_instance(None)
+        # Build the gaplist
+        gap_list = []
+        while start < end:
+            if first.is_time_absolute():
+                next = increment_datetime_by_string(start, gran)
+            else:
+                next = start + gran
+            map = first.get_new_instance(None)
+                map.set_absolute_time(start, next, None)
+            else:
+                map.set_relative_time(start, next, first.get_relative_time_unit())
-                maplist = []
+            gap_list.append(copy.copy(map))
+            start = next
+        tb = SpatioTemporalTopologyBuilder()
+        tb.build(gap_list, maps)
-            start = next
+        relations_order = ["EQUAL", "DURING", "OVERLAPS", "OVERLAPPED", "CONTAINS"]
-        if connected:
-            dbif.close()
+        gran_list = []
+        for gap in gap_list:
+            # If not temporal relations then gap
+            if not gap.get_temporal_relations():
+                gran_list.append([gap,])
+            else:
+                relations = gap.get_temporal_relations()
-        if obj_list:
-            return obj_list
+                map_list = []
+                for relation in relations_order:
+                    if relation in relations:
+                        map_list += relations[relation]
+                        break
+                if map_list:
+                    new_maps = []
+                    for map in map_list:
+                        new_map = map.get_new_instance(map.get_id())
+                        new_map.set_temporal_extent(gap.get_temporal_extent())
+                        new_map.set_spatial_extent(map.get_spatial_extent())
+                        new_maps.append(new_map)
+                    gran_list.append(new_maps)
+                else:
+        if gran_list:
+            return gran_list
         return None
     def get_registered_maps_as_objects_with_gaps(self, where=None, dbif=None):
@@ -1465,6 +1527,8 @@
            This method renames the space time dataset, the map register table
            and updates the entries in registered maps stds register.
+           Renaming does not work with Postgresql yet.
            @param ident The new identifier "name at mapset"
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py	2013-08-05 17:18:34 UTC (rev 57417)
+++ grass/trunk/lib/python/temporal/metadata.py	2013-08-05 19:43:48 UTC (rev 57418)
@@ -33,11 +33,11 @@
 class RasterMetadataBase(SQLDatabaseInterface):
     """!This is the metadata base class for time stamped raster and raster3d maps
         Usage:
         @code
         >>> init()
         >>> meta = RasterMetadataBase(table="metadata", ident="soil at PERMANENT",
         ... datatype="CELL", cols=100, rows=100, number_of_cells=10000, nsres=0.1,
@@ -76,11 +76,11 @@
         ewres=0.1
         min=0.0
         max=100.0
         @endcode
-    def __init__(self, table=None, ident=None, datatype=None, cols=None,
-		rows=None, number_of_cells=None, nsres=None, ewres=None,
+    def __init__(self, table=None, ident=None, datatype=None, cols=None,
+		rows=None, number_of_cells=None, nsres=None, ewres=None,
 		min=None, max=None):
         SQLDatabaseInterface.__init__(self, table, ident)
@@ -225,7 +225,7 @@
             return self.D["max"]
         else:
             return None
     # Properties
     datatype = property(fget=get_datatype, fset=set_datatype)
     cols = property(fget=get_cols, fset=set_cols)
@@ -235,7 +235,7 @@
     ewres = property(fget=get_ewres, fset=set_ewres)
     min = property(fget=get_min, fset=set_min)
     max = property(fget=get_max, fset=set_max)
     def print_info(self):
         """!Print information about this class in human readable style"""
         #      0123456789012345678901234567890
@@ -265,19 +265,19 @@
 class RasterMetadata(RasterMetadataBase):
     """!This is the raster metadata class
         This class is the interface to the raster_metadata table in the
         temporal database that stores the metadata of all registered raster maps.
         The metadata includes the datatype, number of cols, rows and cells and
-        the north-south and east west resolution of the map. Additionally the
+        the north-south and east west resolution of the map. Additionally the
         minimum and maximum values and the name of the space time raster dataset
         register table is stored.
         Usage:
         @code
         >>> init()
         >>> meta = RasterMetadata(ident="soil at PERMANENT",
@@ -320,15 +320,15 @@
         min=0.0
         max=100.0
         strds_register=None
         @endcode
-    def __init__(self, ident=None, strds_register=None, datatype=None,
-		 cols=None, rows=None, number_of_cells=None, nsres=None,
+    def __init__(self, ident=None, strds_register=None, datatype=None,
+		 cols=None, rows=None, number_of_cells=None, nsres=None,
 		 ewres=None, min=None, max=None):
         RasterMetadataBase.__init__(self, "raster_metadata", ident, datatype,
-                                      cols, rows, number_of_cells, nsres,
+                                      cols, rows, number_of_cells, nsres,
                                       ewres, min, max)
         self.set_strds_register(strds_register)
@@ -344,7 +344,7 @@
             return self.D["strds_register"]
         else:
             return None
     strds_register = property(fget=get_strds_register, fset=set_strds_register)
@@ -365,19 +365,19 @@
 class Raster3DMetadata(RasterMetadataBase):
     """!This is the raster3d metadata class
         This class is the interface to the raster3d_metadata table in the
-        temporal database that stores the metadata of all registered
+        temporal database that stores the metadata of all registered
         3D raster maps.
         The metadata includes all raster metadata variables and additional
         the number of depths, the top-bottom resolution and the space time 3D
         raster dataset register table is stored.
         Usage:
         @code
         >>> init()
         >>> meta = Raster3DMetadata(ident="soil at PERMANENT",
         ... datatype="FCELL", cols=100, rows=100, depths=100,
@@ -429,15 +429,15 @@
         str3ds_register=None
         depths=100
         tbres=0.1
         @endcode
-    def __init__(self, ident=None, str3ds_register=None, datatype=None,
-		 cols=None, rows=None, depths=None, number_of_cells=None,
+    def __init__(self, ident=None, str3ds_register=None, datatype=None,
+		 cols=None, rows=None, depths=None, number_of_cells=None,
 		 nsres=None, ewres=None, tbres=None, min=None, max=None):
-        RasterMetadataBase.__init__(self, "raster3d_metadata", ident,
-				datatype, cols, rows, number_of_cells, nsres,
+        RasterMetadataBase.__init__(self, "raster3d_metadata", ident,
+				datatype, cols, rows, number_of_cells, nsres,
 				ewres, min, max)
         self.set_str3ds_register(str3ds_register)
@@ -489,7 +489,7 @@
     depths = property(fget=get_depths, fset=set_depths)
     tbres = property(fget=get_tbres, fset=set_tbres)
     str3ds_register = property(fget=get_str3ds_register, fset=set_str3ds_register)
         print " +-------------------- Metadata information ----------------------------------+"
@@ -513,19 +513,19 @@
 class VectorMetadata(SQLDatabaseInterface):
     """!This is the vector metadata class
         This class is the interface to the vector_metadata table in the
         vector maps.
         Usage:
         @code
         >>> init()
-        >>> meta = VectorMetadata(ident="lidar at PERMANENT", is_3d=True,
+        >>> meta = VectorMetadata(ident="lidar at PERMANENT", is_3d=True,
         ... number_of_points=1, number_of_lines=2, number_of_boundaries=3,
-        ... number_of_centroids=4, number_of_faces=5, number_of_kernels=6,
+        ... number_of_centroids=4, number_of_faces=5, number_of_kernels=6,
         ... number_of_primitives=7, number_of_nodes=8, number_of_areas=9,
         ... number_of_islands=10, number_of_holes=11, number_of_volumes=12)
         >>> meta.id
@@ -587,13 +587,13 @@
         islands=10
         holes=11
         volumes=12
         @endcode
     def __init__(
-        self, ident=None, stvds_register=None, is_3d=False,
+        self, ident=None, stvds_register=None, is_3d=False,
         number_of_points=None, number_of_lines=None, number_of_boundaries=None,
-        number_of_centroids=None, number_of_faces=None, number_of_kernels=None,
+        number_of_centroids=None, number_of_faces=None, number_of_kernels=None,
         number_of_primitives=None, number_of_nodes=None, number_of_areas=None,
         number_of_islands=None, number_of_holes=None, number_of_volumes=None):
@@ -694,7 +694,7 @@
             return None
     def get_3d_info(self):
-        """!Return True if the map is three dimensional,
+        """!Return True if the map is three dimensional,
            False if not and None if not info was found"""
         if "is_3d" in self.D:
             return self.D["is_3d"]
@@ -796,37 +796,37 @@
             return self.D["volumes"]
         else:
             return None
     # Set the properties
     id  = property(fget=get_id, fset=set_id)
-    stvds_register  = property(fget=get_stvds_register,
+    stvds_register  = property(fget=get_stvds_register,
                                fset=set_stvds_register)
     is_3d  = property(fget=get_3d_info, fset=set_3d_info)
-    number_of_points = property(fget=get_number_of_points,
+    number_of_points = property(fget=get_number_of_points,
                                 fset=set_number_of_points)
-    number_of_lines = property(fget=get_number_of_lines,
+    number_of_lines = property(fget=get_number_of_lines,
                                fset=set_number_of_lines)
-    number_of_boundaries = property(fget=get_number_of_boundaries,
+    number_of_boundaries = property(fget=get_number_of_boundaries,
                                     fset=set_number_of_boundaries)
-    number_of_centroids = property(fget=get_number_of_centroids,
+    number_of_centroids = property(fget=get_number_of_centroids,
                                    fset=set_number_of_centroids)
-    number_of_faces = property(fget=get_number_of_faces,
+    number_of_faces = property(fget=get_number_of_faces,
                                fset=set_number_of_faces)
-    number_of_kernels = property(fget=get_number_of_kernels,
+    number_of_kernels = property(fget=get_number_of_kernels,
                                  fset=set_number_of_kernels)
-    number_of_primitives = property(fget=get_number_of_primitives,
+    number_of_primitives = property(fget=get_number_of_primitives,
                                     fset=set_number_of_primitives)
-    number_of_nodes = property(fget=get_number_of_nodes,
+    number_of_nodes = property(fget=get_number_of_nodes,
                                fset=set_number_of_nodes)
-    number_of_areas = property(fget=get_number_of_areas,
+    number_of_areas = property(fget=get_number_of_areas,
                                fset=set_number_of_areas)
-    number_of_islands = property(fget=get_number_of_islands,
+    number_of_islands = property(fget=get_number_of_islands,
                                  fset=set_number_of_islands)
-    number_of_holes = property(fget=get_number_of_holes,
+    number_of_holes = property(fget=get_number_of_holes,
                                fset=set_number_of_holes)
-    number_of_volumes = property(fget=get_number_of_volumes,
+    number_of_volumes = property(fget=get_number_of_volumes,
                                  fset=set_number_of_volumes)
@@ -868,14 +868,14 @@
 class STDSMetadataBase(SQLDatabaseInterface):
-    """!This is the space time dataset metadata base class for
+    """!This is the space time dataset metadata base class for
        strds, stvds and str3ds datasets
        setting/getting the id, the title and the description
         Usage:
         @code
         >>> init()
         >>> meta = STDSMetadataBase(ident="soils at PERMANENT",
         ... title="Soils", description="Soils 1950 - 2010")
@@ -888,14 +888,15 @@
         >>> meta.number_of_maps
         >>> meta.print_info()
          | Number of registered maps:.. None
          | Title:
          | Soils
          | Description:
          | Soils 1950 - 2010
-         | Commands of creation:
+         | Command history:
         >>> meta.print_shell_info()
         number_of_maps=None
         @endcode
     def __init__(self, table=None, ident=None, title=None, description=None, command=None):
@@ -925,7 +926,7 @@
     def set_command(self, command):
         """!Set the number of cols"""
         self.D["command"] = command
     def get_id(self):
         """!Convenient method to get the unique identifier (primary key)
            @return None if not found
@@ -958,9 +959,9 @@
             return self.D["command"]
         else:
             return None
     def get_number_of_maps(self):
-        """!Get the number of registered maps,
+        """!Get the number of registered maps,
            this value is set in the database
            automatically via SQL, so no setter exists
            @return None if not found"""
@@ -968,12 +969,12 @@
             return self.D["number_of_maps"]
         else:
             return None
     title  = property(fget=get_title, fset=set_title)
     description  = property(fget=get_description, fset=set_description)
     number_of_maps  = property(fget=get_number_of_maps)
@@ -991,7 +992,7 @@
                 print " | " + str(token)
     def print_history(self):
-        """!Print history information about this class in human readable
+        """!Print history information about this class in human readable
             shell style
@@ -1001,7 +1002,7 @@
         print "# " + str(self.get_description())
         print "# Command history:"
         command = self.get_command()
         if command:
             tokens = command.split("\n")
             print_list = []
@@ -1009,7 +1010,7 @@
                 token = str(token).rstrip().lstrip()
                 if len(token) > 1:
                     print_list.append(token)
             count = 0
             for token in print_list:
                 count += 1
@@ -1019,8 +1020,8 @@
                     elif count < len(print_list):
                         print token + " \\"
                     else:
-                        print token
+                        print token
     def print_shell_info(self):
         """!Print information about this class in shell style"""
         print "number_of_maps=" + str(self.get_number_of_maps())
@@ -1029,16 +1030,16 @@
 class STDSRasterMetadataBase(STDSMetadataBase):
         class for strds and str3ds datasets
         Most of the metadata values are set by SQL scripts in the database when
-        new maps are added. Therefor only some set- an many
+        new maps are added. Therefor only some set- an many
         get-functions are available.
         Usage:
         @code
         >>> init()
         >>> meta = STDSRasterMetadataBase(ident="soils at PERMANENT",
@@ -1059,12 +1060,6 @@
         >>> meta.ewres_min
         >>> meta.ewres_max
         >>> meta.print_info()
-         | Number of registered maps:.. None
-         | Title:
-         | Soils
-         | Description:
-         | Soils 1950 - 2010
          | North-South resolution min:. None
          | North-South resolution max:. None
          | East-west resolution min:... None
@@ -1073,6 +1068,13 @@
          | Minimum value max:.......... None
          | Maximum value min:.......... None
          | Maximum value max:.......... None
+         | Number of registered maps:.. None
+         | Title:
+         | Soils
+         | Description:
+         | Soils 1950 - 2010
         number_of_maps=None
         nsres_min=None
@@ -1083,7 +1085,7 @@
         min_max=None
         max_min=None
         max_max=None
         @endcode
     def __init__(self, table=None, ident=None, title=None, description=None):
@@ -1101,7 +1103,7 @@
         self.D["ewres_max"] = None
     def get_max_min(self):
-        """!Get the minimal maximum of all registered maps,
+        """!Get the minimal maximum of all registered maps,
@@ -1111,7 +1113,7 @@
             return None
     def get_min_min(self):
-        """!Get the minimal minimum of all registered maps,
+        """!Get the minimal minimum of all registered maps,
@@ -1121,7 +1123,7 @@
             return None
     def get_max_max(self):
-        """!Get the maximal maximum of all registered maps,
+        """!Get the maximal maximum of all registered maps,
@@ -1131,7 +1133,7 @@
             return None
     def get_min_max(self):
-        """!Get the maximal minimum of all registered maps,
+        """!Get the maximal minimum of all registered maps,
@@ -1141,7 +1143,7 @@
             return None
     def get_nsres_min(self):
-        """!Get the minimal north-south resolution of all registered maps,
+        """!Get the minimal north-south resolution of all registered maps,
@@ -1151,7 +1153,7 @@
             return None
     def get_nsres_max(self):
-        """!Get the maximal north-south resolution of all registered maps,
+        """!Get the maximal north-south resolution of all registered maps,
@@ -1161,7 +1163,7 @@
             return None
     def get_ewres_min(self):
-        """!Get the minimal east-west resolution of all registered maps,
+        """!Get the minimal east-west resolution of all registered maps,
@@ -1171,7 +1173,7 @@
             return None
     def get_ewres_max(self):
-        """!Get the maximal east-west resolution of all registered maps,
+        """!Get the maximal east-west resolution of all registered maps,
@@ -1179,7 +1181,7 @@
             return self.D["ewres_max"]
         else:
             return None
     nsres_min = property(fget=get_nsres_min)
     nsres_max = property(fget=get_nsres_max)
     ewres_min = property(fget=get_ewres_min)
@@ -1188,7 +1190,7 @@
     min_max = property(fget=get_min_max)
     max_min = property(fget=get_max_min)
     max_max = property(fget=get_max_max)
@@ -1219,19 +1221,19 @@
 class STRDSMetadata(STDSRasterMetadataBase):
         This class is the interface to the strds_metadata table in the
         space time raster datasets
-        new raster maps are added. Therefor only some set- an many
+        new raster maps are added. Therefor only some set- an many
         Usage:
         @code
         >>> init()
         >>> meta = STRDSMetadata(ident="soils at PERMANENT",
@@ -1253,12 +1255,7 @@
         >>> meta.raster_register
         >>> meta.print_info()
-         | Title:
-         | Soils
-         | Description:
+         | Raster register table:...... None
@@ -1267,7 +1264,13 @@
-         | Raster register table:...... None
+         | Title:
+         | Soils
+         | Description:
         number_of_maps=None
         nsres_min=None
@@ -1279,7 +1282,7 @@
         max_min=None
         max_max=None
         raster_register=None
         @endcode
     def __init__(self, ident=None, raster_register=None, title=None, description=None):
@@ -1300,8 +1303,8 @@
             return self.D["raster_register"]
         else:
             return None
-    raster_register = property(fget=get_raster_register,
+    raster_register = property(fget=get_raster_register,
                                fset=set_raster_register)
@@ -1322,19 +1325,19 @@
 class STR3DSMetadata(STDSRasterMetadataBase):
     """!This is the space time 3D raster metadata class
         This class is the interface to the str3ds_metadata table in the
         space time 3D raster datasets
-        new 3D raster maps are added. Therefor only some set- an many
+        new 3D raster maps are added. Therefor only some set- an many
         Usage:
         @code
         >>> init()
         >>> meta = STR3DSMetadata(ident="soils at PERMANENT",
@@ -1358,12 +1361,9 @@
         >>> meta.raster3d_register
         >>> meta.print_info()
-         | Title:
-         | Soils
-         | Description:
+         | 3D raster register table:... None
+         | Top-bottom resolution min:.. None
+         | Top-bottom resolution max:.. None
@@ -1372,9 +1372,13 @@
-         | Top-bottom resolution min:.. None
-         | Top-bottom resolution max:.. None
-         | 3D raster register table:... None
+         | Title:
+         | Soils
+         | Description:
         number_of_maps=None
         nsres_min=None
@@ -1388,7 +1392,7 @@
         tbres_min=None
         tbres_max=None
         raster3d_register=None
         @endcode
     def __init__(self, ident=None, raster3d_register=None, title=None, description=None):
@@ -1423,7 +1427,7 @@
             return None
     def get_tbres_max(self):
-        """!Get the maximal top-bottom resolution of all registered maps,
+        """!Get the maximal top-bottom resolution of all registered maps,
@@ -1432,11 +1436,11 @@
         else:
             return None
-    raster3d_register = property(fget=get_raster3d_register,
+    raster3d_register = property(fget=get_raster3d_register,
                                fset=set_raster3d_register)
     tbres_min = property(fget=get_tbres_min)
     tbres_max = property(fget=get_tbres_max)
@@ -1459,19 +1463,19 @@
 class STVDSMetadata(STDSMetadataBase):
     """!This is the space time vector dataset metadata class
        This class is the interface to the stvds_metadata table in the
        space time vector datasets
        new vector maps are added. Therefor only some set- an many get-functions
        are available.
         Usage:
         @code
         >>> init()
         >>> meta = STVDSMetadata(ident="lidars at PERMANENT",
         ... title="LIDARS", description="LIDARS 2008 - 2010")
@@ -1496,12 +1500,6 @@
         >>> meta.number_of_volumes
         >>> meta.print_info()
-         | Title:
-         | LIDARS
-         | Description:
-         | LIDARS 2008 - 2010
          | Vector register table:...... None
          | Number of points ........... None
          | Number of lines ............ None
@@ -1515,6 +1513,13 @@
          | Number of islands .......... None
          | Number of holes ............ None
          | Number of volumes .......... None
+         | Title:
+         | LIDARS
+         | Description:
+         | LIDARS 2008 - 2010
         number_of_maps=None
         vector_register=None
@@ -1530,7 +1535,7 @@
         islands=None
         holes=None
         volumes=None
         @endcode
     def __init__(
@@ -1552,7 +1557,7 @@
         self.D["islands"] = None
         self.D["holes"] = None
         self.D["volumes"] = None
     def set_vector_register(self, vector_register):
         """!Set the vector map register table name"""
         self.D["vector_register"] = vector_register
@@ -1566,7 +1571,7 @@
             return None
     def get_number_of_points(self):
-        """!Get the number of points of all registered maps,
+        """!Get the number of points of all registered maps,
@@ -1576,7 +1581,7 @@
             return None
     def get_number_of_lines(self):
-        """!Get the number of lines of all registered maps,
+        """!Get the number of lines of all registered maps,
@@ -1586,7 +1591,7 @@
             return None
     def get_number_of_boundaries(self):
-        """!Get the number of boundaries of all registered maps,
+        """!Get the number of boundaries of all registered maps,
@@ -1596,7 +1601,7 @@
             return None
     def get_number_of_centroids(self):
-        """!Get the number of centroids of all registered maps,
+        """!Get the number of centroids of all registered maps,
@@ -1606,7 +1611,7 @@
             return None
     def get_number_of_faces(self):
-        """!Get the number of faces of all registered maps,
+        """!Get the number of faces of all registered maps,
@@ -1616,7 +1621,7 @@
             return None
     def get_number_of_kernels(self):
-        """!Get the number of kernels of all registered maps,
+        """!Get the number of kernels of all registered maps,
@@ -1626,7 +1631,7 @@
             return None
     def get_number_of_primitives(self):
-        """!Get the number of primitives of all registered maps,
+        """!Get the number of primitives of all registered maps,
@@ -1636,7 +1641,7 @@
             return None
     def get_number_of_nodes(self):
-        """!Get the number of nodes of all registered maps,
+        """!Get the number of nodes of all registered maps,
@@ -1646,7 +1651,7 @@
             return None
     def get_number_of_areas(self):
-        """!Get the number of areas of all registered maps,
+        """!Get the number of areas of all registered maps,
@@ -1656,7 +1661,7 @@
             return None
     def get_number_of_islands(self):
-        """!Get the number of islands of all registered maps,
+        """!Get the number of islands of all registered maps,
@@ -1666,7 +1671,7 @@
             return None
     def get_number_of_holes(self):
-        """!Get the number of holes of all registered maps,
+        """!Get the number of holes of all registered maps,
@@ -1676,7 +1681,7 @@
             return None
     def get_number_of_volumes(self):
-        """!Get the number of volumes of all registered maps,
+        """!Get the number of volumes of all registered maps,
@@ -1684,7 +1689,7 @@
         else:
             return None
     vector_register  = property(fget=get_vector_register,
                                 fset=set_vector_register)
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py	2013-08-05 17:18:34 UTC (rev 57417)
+++ grass/trunk/lib/python/temporal/temporal_extent.py	2013-08-05 19:43:48 UTC (rev 57418)
@@ -29,18 +29,18 @@
 class AbstractTemporalExtent(SQLDatabaseInterface):
     """!This is the abstract time base class for relative and absolute time objects
         It abstract class implements the interface to absolute and relative time.
         Absolute time is represented by datetime time stamps,
         relative time is represented by a unit an integer value.
         This class implements temporal topology relationships computation
         after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic].
         Usage:
         @code
         >>> init()
         >>> A = AbstractTemporalExtent(table="raster_absolute_time",
         ... ident="soil at PERMANENT", start_time=datetime(2001, 01, 01),
@@ -72,7 +72,7 @@
         >>> A.print_shell_info()
         start_time=0
         end_time=1
         @endcode
     def __init__(self, table=None, ident=None, start_time=None, end_time=None):
@@ -86,13 +86,13 @@
     def intersect(self, extent):
         """!Intersect this temporal extent with the provided temporal extent and
            return a new temporal extent with the new start and end time
            @param extent The temporal extent to intersect with
-           @return The new temporal extent with start and end time,
+           @return The new temporal extent with start and end time,
                    or None in case of no intersection
            Usage:
            @code
            >>> A = AbstractTemporalExtent(start_time=5, end_time=6 )
@@ -100,7 +100,7 @@
            >>> inter.print_info()
             | Start time:................. 5
             | End time:................... 6
            >>> B = AbstractTemporalExtent(start_time=5, end_time=7 )
            >>> inter = A.intersect(B)
@@ -111,7 +111,7 @@
            >>> inter.print_info()
            >>> A = AbstractTemporalExtent(start_time=3, end_time=6 )
@@ -122,7 +122,7 @@
            >>> inter.print_info()
            >>> A = AbstractTemporalExtent(start_time=3, end_time=8 )
            >>> B = AbstractTemporalExtent(start_time=5, end_time=6 )
@@ -133,7 +133,7 @@
            >>> inter.print_info()
            >>> A = AbstractTemporalExtent(start_time=5, end_time=8 )
            >>> B = AbstractTemporalExtent(start_time=3, end_time=6 )
@@ -155,56 +155,56 @@
            >>> inter.print_info()
             | End time:................... None
            >>> B = AbstractTemporalExtent(start_time=3, end_time=4 )
            >>> print inter
            None
            >>> B = AbstractTemporalExtent(start_time=3, end_time=None )
            >>> print inter
            None
            @endcode
         relation = self.temporal_relation(extent)
         if relation == "after" or relation == "before":
             return None
         if self.D["end_time"] is None:
             return AbstractTemporalExtent(start_time=self.D["start_time"])
         if extent.D["end_time"] is None:
             return AbstractTemporalExtent(start_time=extent.D["start_time"])
         start = None
         end = None
         if self.D["start_time"] > extent.D["start_time"]:
             start = self.D["start_time"]
         else:
             start = extent.D["start_time"]
         if self.D["end_time"] > extent.D["end_time"]:
             end = extent.D["end_time"]
         else:
             end = self.D["end_time"]
         return AbstractTemporalExtent(start_time=start, end_time=end)
     def disjoint_union(self, extent):
         """!Creates a disjoint union with this temporal extent and the provided one.
            Return a new temporal extent with the new start and end time.
            @param extent The temporal extent to create a union with
            Usage:
            @code
@@ -212,7 +212,7 @@
            >>> inter.print_info()
            >>> inter = A.disjoint_union(B)
@@ -223,7 +223,7 @@
            >>> inter.print_info()
             | End time:................... 7
@@ -234,7 +234,7 @@
            >>> inter.print_info()
             | Start time:................. 3
@@ -245,7 +245,7 @@
            >>> inter.print_info()
             | End time:................... 8
@@ -267,7 +267,7 @@
            >>> inter.print_info()
@@ -308,18 +308,18 @@
            >>> inter.print_info()
             | End time:................... 5
            @endcoe
         start = None
         end = None
         if self.D["start_time"] < extent.D["start_time"]:
         else:
         # End time handling
         if self.D["end_time"] is None and extent.D["end_time"] is None:
@@ -340,62 +340,62 @@
         else:
     def union(self, extent):
         """!Creates a union with this temporal extent and the provided one.
                    or None in case the temporal extents are unrelated (before or after)
            @code
            >>> print inter
            None
            >>> print inter
            None
            @endcode
             return None
         return self.disjoint_union(extent)
     def starts(self, extent):
-        """!Return True if this temporal extent (A) starts at the start of the
+        """!Return True if this temporal extent (A) starts at the start of the
            provided temporal extent (B) and finishes within it
            @verbatim
            A  |-----|
            B  |---------|
            @endverbatim
            @param extent The temporal extent object with which this extent starts
            Usage:
            @code
            >>> A.starts(B)
            True
            >>> B.starts(A)
            False
            @endcode
         if  self.D["end_time"] is None or extent.D["end_time"] is None:
@@ -408,26 +408,26 @@
             return False
     def started(self, extent):
-        """!Return True if this temporal extent (A) started at the start of the
+        """!Return True if this temporal extent (A) started at the start of the
            provided temporal extent (B) and finishes after it
            @verbatim
            A  |---------|
            B  |-----|
            @endverbatim
            @param extent The temporal extent object with which this extent started
            Usage:
            @code
            >>> A = AbstractTemporalExtent(start_time=5, end_time=7 )
            >>> A.started(B)
            True
            >>> B.started(A)
            False
            @endcode
@@ -440,26 +440,26 @@
             return False
     def finishes(self, extent):
-        """!Return True if this temporal extent (A) starts after the start of the
+        """!Return True if this temporal extent (A) starts after the start of the
            provided temporal extent (B) and finishes with it
            @verbatim
            A      |-----|
            B  |---------|
            @endverbatim
            @param extent The temporal extent object with which this extent finishes
            Usage:
            @code
            >>> A = AbstractTemporalExtent(start_time=6, end_time=7 )
            >>> A.finishes(B)
            True
            >>> B.finishes(A)
            False
            @endcode
@@ -472,26 +472,26 @@
             return False
     def finished(self, extent):
-        """!Return True if this temporal extent (A) starts before the start of the
+        """!Return True if this temporal extent (A) starts before the start of the
            @verbatim
            A  |---------|
            B      |-----|
            @endverbatim
            Usage:
            @code
            >>> B = AbstractTemporalExtent(start_time=6, end_time=7 )
            >>> A.finished(B)
            True
            >>> B.finished(A)
            False
            @endcode
@@ -504,26 +504,26 @@
             return False
     def after(self, extent):
-        """!Return True if this temporal extent (A) is located after the
+        """!Return True if this temporal extent (A) is located after the
            @verbatim
            A             |---------|
            B  |---------|
            @endverbatim
            @param extent The temporal extent object that is located before this extent
            Usage:
            @code
            >>> A = AbstractTemporalExtent(start_time=8, end_time=9 )
            >>> A.after(B)
            True
            >>> B.after(A)
            False
            @endcode
@@ -538,26 +538,26 @@
             return False
     def before(self, extent):
-        """!Return True if this temporal extent (A) is located before the
+        """!Return True if this temporal extent (A) is located before the
            @verbatim
            A  |---------|
            B             |---------|
            @endverbatim
            @param extent The temporal extent object that is located after this extent
            Usage:
            @code
            >>> B = AbstractTemporalExtent(start_time=8, end_time=9 )
            >>> A.before(B)
            True
            >>> B.before(A)
            False
            @endcode
@@ -572,7 +572,7 @@
             return False
     def adjacent(self, extent):
-        """!Return True if this temporal extent (A) is a meeting neighbor the
+        """!Return True if this temporal extent (A) is a meeting neighbor the
            @verbatim
            A            |---------|
@@ -580,14 +580,14 @@
            A  |---------|
            B            |---------|
            @endverbatim
            @param extent The temporal extent object that is a meeting neighbor
                           of this extent
            Usage:
            @code
            >>> B = AbstractTemporalExtent(start_time=7, end_time=9 )
            >>> A.adjacent(B)
@@ -600,7 +600,7 @@
            True
            >>> B.adjacent(A)
            True
            @endcode
@@ -613,27 +613,27 @@
             return False
     def follows(self, extent):
-        """!Return True if this temporal extent (A) follows the
+        """!Return True if this temporal extent (A) follows the
            @verbatim
            A            |---------|
            B  |---------|
            @endverbatim
            @param extent The temporal extent object that is the predecessor
                           of this extent
            Usage:
            @code
            >>> B = AbstractTemporalExtent(start_time=3, end_time=5 )
            >>> A.follows(B)
            True
            >>> B.follows(A)
            False
            @endcode
@@ -645,27 +645,27 @@
             return False
     def precedes(self, extent):
-        """!Return True if this temporal extent (A) precedes the provided
+        """!Return True if this temporal extent (A) precedes the provided
            temporal extent (B)
            @verbatim
            A  |---------|
            B            |---------|
            @endverbatim
            @param extent The temporal extent object that is the successor
                           of this extent
            Usage:
            @code
            >>> A.precedes(B)
            True
            >>> B.precedes(A)
            False
            @endcode
@@ -677,26 +677,26 @@
             return False
     def during(self, extent):
-        """!Return True if this temporal extent (A) is located during the provided
+        """!Return True if this temporal extent (A) is located during the provided
            temporal extent (B)
            @verbatim
            A   |-------|
            B  |---------|
            @endverbatim
            @param extent The temporal extent object that contains this extent
            Usage:
            @code
            >>> B = AbstractTemporalExtent(start_time=4, end_time=9 )
            >>> A.during(B)
            True
            >>> B.during(A)
            False
            @endcode
         # Check single point of time in interval
@@ -705,7 +705,7 @@
-            if self.D["start_time"] > extent.D["start_time"] and \
+            if self.D["start_time"] >= extent.D["start_time"] and \
                self.D["start_time"] < extent.D["end_time"]:
                 return True
             else:
@@ -718,27 +718,27 @@
             return False
     def contains(self, extent):
-        """!Return True if this temporal extent (A) contains the provided
+        """!Return True if this temporal extent (A) contains the provided
            temporal extent (B)
            @verbatim
            A  |---------|
            B   |-------|
            @endverbatim
-           @param extent The temporal extent object that is located
+           @param extent The temporal extent object that is located
                           during this extent
            Usage:
            @code
            >>> A = AbstractTemporalExtent(start_time=4, end_time=9 )
            >>> B = AbstractTemporalExtent(start_time=5, end_time=8 )
            >>> A.contains(B)
            True
            >>> B.contains(A)
            False
            @endcode
@@ -747,7 +747,7 @@
-            if self.D["start_time"] < extent.D["start_time"] and \
+            if self.D["start_time"] <= extent.D["start_time"] and \
                self.D["end_time"] > extent.D["start_time"]:
                 return True
             else:
@@ -760,27 +760,27 @@
             return False
     def equal(self, extent):
-        """!Return True if this temporal extent (A) is equal to the provided
+        """!Return True if this temporal extent (A) is equal to the provided
            temporal extent (B)
            @verbatim
            A  |---------|
            B  |---------|
            @endverbatim
-           @param extent The temporal extent object that is equal
+           @param extent The temporal extent object that is equal
                           during this extent
            Usage:
            @code
            >>> A.equal(B)
            True
            >>> B.equal(A)
            True
            @endcode
@@ -799,26 +799,26 @@
             return False
     def overlapped(self, extent):
-        """!Return True if this temporal extent (A) overlapped the provided
+        """!Return True if this temporal extent (A) overlapped the provided
            temporal extent (B)
            @verbatim
            A  |---------|
            B    |---------|
            @endverbatim
-           @param extent The temporal extent object that is overlaps
+           @param extent The temporal extent object that is overlaps
                           this extent
            Usage:
            @code
            >>> B = AbstractTemporalExtent(start_time=6, end_time=8 )
            >>> A.overlapped(B)
            True
            >>> B.overlapped(A)
            False
            @endcode
@@ -832,27 +832,27 @@
             return False
     def overlaps(self, extent):
-        """!Return True if this temporal extent (A) overlapps the provided
+        """!Return True if this temporal extent (A) overlapps the provided
            temporal extent (B)
            @verbatim
            A    |---------|
            B  |---------|
            @endverbatim
-           @param extent The temporal extent object that is overlapped
+           @param extent The temporal extent object that is overlapped
                           this extent
            Usage:
            @code
            >>> A = AbstractTemporalExtent(start_time=6, end_time=8 )
            >>> A.overlaps(B)
            True
            >>> B.overlaps(A)
            False
            @endcode
@@ -867,11 +867,11 @@
     def temporal_relation(self, extent):
         """!Returns the temporal relation between temporal objects
-           Temporal relationships are implemented after
+           Temporal relationships are implemented after
            The following temporal relationships are supported:
                - equal
                - during
                - contains
@@ -885,8 +885,8 @@
                - finished
                - follows
                - precedes
            @return The name of the temporal relation or None if no relation found
@@ -968,7 +968,7 @@
             return self.D["end_time"]
         else:
             return None
     start_time = property(fget=get_start_time, fset=set_start_time)
@@ -993,7 +993,7 @@
         start_time and end_time must be of type datetime
-    def __init__(self, table=None, ident=None, start_time=None, end_time=None,
+    def __init__(self, table=None, ident=None, start_time=None, end_time=None,
                  timezone=None):
         AbstractTemporalExtent.__init__(
@@ -1003,23 +1003,23 @@
     def set_timezone(self, timezone):
         """!Set the timezone of the map, the timezone is of type string.
-           Timezones are not supported yet, instead the timezone
+           Timezones are not supported yet, instead the timezone
            is set in the datetime string as offset in minutes.
         self.D["timezone"] = timezone
     def get_timezone(self):
         """!Get the timezone of the map
         if "timezone" in self.D:
             return self.D["timezone"]
         else:
             return None
     timezone = property(fget=get_timezone, fset=set_timezone)
@@ -1035,19 +1035,19 @@
 class RasterAbsoluteTime(AbsoluteTemporalExtent):
-    def __init__(self, ident=None, start_time=None, end_time=None,
+    def __init__(self, ident=None, start_time=None, end_time=None,
                  timezone=None):
         AbsoluteTemporalExtent.__init__(self, "raster_absolute_time",
             ident, start_time, end_time, timezone)
 class Raster3DAbsoluteTime(AbsoluteTemporalExtent):
                  timezone=None):
         AbsoluteTemporalExtent.__init__(self, "raster3d_absolute_time",
 class VectorAbsoluteTime(AbsoluteTemporalExtent):
                  timezone=None):
         AbsoluteTemporalExtent.__init__(self, "vector_absolute_time",
@@ -1056,14 +1056,14 @@
 class STDSAbsoluteTime(AbsoluteTemporalExtent):
     """!This class implements the absolute time extent for space time dataset
-        In addition to the existing functionality the granularity and the
+        In addition to the existing functionality the granularity and the
         map_time are added.
         Usage:
         @code
         >>> init()
         >>> A = STDSAbsoluteTime(table="strds_absolute_time",
         ... ident="strds at PERMANENT", start_time=datetime(2001, 01, 01),
@@ -1090,10 +1090,10 @@
         end_time=2005-01-01 00:00:00
         granularity=1 days
         map_time=interval
         @endcode
                  granularity=None, timezone=None, map_time=None):
             self, table, ident, start_time, end_time, timezone)
@@ -1139,11 +1139,11 @@
             return self.D["map_time"]
         else:
             return None
     # Properties
     granularity = property(fget=get_granularity, fset=set_granularity)
     map_time = property(fget=get_map_time, fset=set_map_time)
         AbsoluteTemporalExtent.print_info(self)
@@ -1160,21 +1160,21 @@
 class STRDSAbsoluteTime(STDSAbsoluteTime):
                  granularity=None, timezone=None):
         STDSAbsoluteTime.__init__(self, "strds_absolute_time",
             ident, start_time, end_time, granularity, timezone)
 class STR3DSAbsoluteTime(STDSAbsoluteTime):
         STDSAbsoluteTime.__init__(self, "str3ds_absolute_time",
 class STVDSAbsoluteTime(STDSAbsoluteTime):
         STDSAbsoluteTime.__init__(self, "stvds_absolute_time",
@@ -1185,11 +1185,11 @@
     """!This is the relative time class for all maps and space time datasets
         start_time and end_time must be of type integer
         Usage:
         @code
         >>> init()
         >>> A = RelativeTemporalExtent(table="raster_relative_time",
         ... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years")
@@ -1210,10 +1210,10 @@
         start_time=0
         end_time=1
         unit=years
         @endcode
                  unit=None):
@@ -1222,7 +1222,7 @@
     def set_unit(self, unit):
         """!Set the unit of the relative time. Valid units are:
            - years
            - months
            - days
@@ -1242,7 +1242,7 @@
     def temporal_relation(self, map):
@@ -1257,7 +1257,7 @@
             return None
         return AbstractTemporalExtent.temporal_relation(self, map)
     # Properties
     unit = property(fget=get_unit, fset=set_unit)
@@ -1276,21 +1276,24 @@
 class RasterRelativeTime(RelativeTemporalExtent):
-    def __init__(self, ident=None, start_time=None, end_time=None):
+                 unit=None):
         RelativeTemporalExtent.__init__(
-            self, "raster_relative_time", ident, start_time, end_time)
+            self, "raster_relative_time", ident, start_time, end_time, unit)
 class Raster3DRelativeTime(RelativeTemporalExtent):
+                 unit=None):
         RelativeTemporalExtent.__init__(self,
-            "raster3d_relative_time", ident, start_time, end_time)
+            "raster3d_relative_time", ident, start_time, end_time, unit)
 class VectorRelativeTime(RelativeTemporalExtent):
+                 unit=None):
-            self, "vector_relative_time", ident, start_time, end_time)
+            self, "vector_relative_time", ident, start_time, end_time, unit)
@@ -1298,11 +1301,11 @@
         Usage:
         @code
         >>> init()
         >>> A = STDSRelativeTime(table="strds_relative_time",
         ... ident="strds at PERMANENT", start_time=0, end_time=1, unit="years",
@@ -1332,10 +1335,10 @@
         unit=years
         granularity=5
         map_time=interval
         @endcode
                  unit=None, granularity=None, map_time=None):
             self, table, ident, start_time, end_time, unit)
@@ -1381,11 +1384,11 @@
         else:
             return None
     # Properties
         RelativeTemporalExtent.print_info(self)
@@ -1402,24 +1405,24 @@
 class STRDSRelativeTime(STDSRelativeTime):
-                 granularity=None):
+                 unit=None, granularity=None, map_time=None):
         STDSRelativeTime.__init__(self, "strds_relative_time",
-            ident, start_time, end_time, granularity)
+            ident, start_time, end_time, unit, granularity, map_time)
 class STR3DSRelativeTime(STDSRelativeTime):
         STDSRelativeTime.__init__(self, "str3ds_relative_time",
 class STVDSRelativeTime(STDSRelativeTime):
         STDSRelativeTime.__init__(self, "stvds_relative_time",
