[GRASS-SVN] r57421 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Mon Aug 5 13:56:31 PDT 2013
Author: wenzeslaus
Date: 2013-08-05 13:56:31 -0700 (Mon, 05 Aug 2013)
New Revision: 57421
Added:
grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
wxGUI/mapdisp: test module for mapdisplay and mapwindow
Added: grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
--- grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py (rev 0)
+++ grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py 2013-08-05 20:56:31 UTC (rev 57421)
@@ -0,0 +1,363 @@
+#!/usr/bin/env python
+# MODULE: Map window and mapdisplay test module
+# AUTHOR(S): Vaclav Petras
+# PURPOSE: Test functionality using small GUI applications.
+# COPYRIGHT: (C) 2013 by Vaclav Petras, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%module
+#% description: Georectifies a map and allows to manage Ground Control Points.
+#% keywords: general
+#% keywords: GUI
+#% keywords: georectification
+#%end
+#%option
+#% key: test
+#% description: Test to run
+#% options: mapwindow,mapdisplay,apitest,distance,profile
+#% descriptions: mapwindow;Opens map window ;mapdisplay;Opens map display; apitest;Open an application to test API of map window; distance;Starts map window with distance measurement activated; profile;Starts map window with profile tool activated
+#% required: yes
+#%end
+#%option G_OPT_R_INPUT
+#% key: raster
+#% multiple: yes
+#% required: no
+#%end
+#%option G_OPT_V_INPUT
+#% key: vector
+#% multiple: yes
+#% required: no
+#%end
+Module to run test map window (BufferedWidnow) and map display (MapFrame).
+ at author Vaclav Petras <wenzeslaus gmail.com>
+import os
+import sys
+import wx
+import grass.script as grass
+# adding a path to wxGUI modules
+if __name__ == '__main__':
+ WXGUIBASE = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
+ if WXGUIBASE not in sys.path:
+ sys.path.append(WXGUIBASE)
+import core.utils as utils
+from core.utils import _
+from core.settings import UserSettings
+from core.globalvar import CheckWxVersion
+from core.giface import StandaloneGrassInterface
+from gui_core.mapwindow import MapWindowProperties
+from mapdisp.mapwindow import BufferedWindow
+from mapdisp.frame import MapFrame
+from core.render import Map
+# TODO: same classes as in dmon
+class Layer(object):
+ def __init__(self, maplayer):
+ self._maplayer = maplayer
+ def __getattr__(self, name):
+ if name == 'cmd':
+ return utils.CmdTupleToList(self._maplayer.GetCmd())
+ elif hasattr(self._maplayer, name):
+ return getattr(self._maplayer, name)
+ elif name == 'maplayer':
+ return self._maplayer
+ elif name == 'type':
+ return self._maplayer.GetType()
+ #elif name == 'ctrl':
+ elif name == 'label':
+ return self._maplayer.GetName()
+ #elif name == 'maplayer' : None,
+ #elif name == 'propwin':
+class LayerList(object):
+ def __init__(self, map_):
+ self._map = map_
+ def GetSelectedLayers(self, checkedOnly=True):
+ # hidden and selected vs checked and selected
+ items = self._map.GetListOfLayers()
+ layers = []
+ for item in items:
+ layer = Layer(item)
+ layers.append(layer)
+ return layers
+class MapdispGrassInterface(StandaloneGrassInterface):
+ """!@implements GrassInterface"""
+ StandaloneGrassInterface.__init__(self)
+ self._map = map_
+ self.mapWindow = None
+ def GetLayerList(self):
+ return LayerList(self._map)
+ def GetMapWindow(self):
+ return self.mapWindow
+# this is a copy of method from some frame class
+def copyOfInitMap(map_, width, height):
+ """!Initialize map display, set dimensions and map region
+ if not grass.find_program('g.region', '--help'):
+ sys.exit(_("GRASS module '%s' not found. Unable to start map "
+ "display window.") % 'g.region')
+ map_.ChangeMapSize((width, height))
+ map_.region = map_.GetRegion() # g.region -upgc
+ # self.Map.SetRegion() # adjust region to match display window
+class TextShower(object):
+ def __init__(self, parent, title):
+ self._cf = wx.Frame(parent=parent, title=title)
+ self._cp = wx.Panel(parent=self._cf, id=wx.ID_ANY)
+ self._cs = wx.BoxSizer(wx.VERTICAL)
+ self._cl = wx.StaticText(parent=self._cp, id=wx.ID_ANY, label="No text set yet")
+ self._cs.Add(item=self._cl, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+ self._cp.SetSizer(self._cs)
+ self._cp.Layout()
+ self._cf.Show()
+ def SetLabel(self, text):
+ self._cl.SetLabel(text)
+class Tester(object):
+ def _listenToAllMapWindowSignals(self, window):
+ output = sys.stderr
+ # will make bad thigs after it is closed but who cares
+ coordinatesShower = TextShower(window, "Coordinates")
+ window.zoomChanged.connect(lambda: output.write("zoomChanged\n"))
+ window.zoomHistoryUnavailable.connect(lambda: output.write("zoomHistoryUnavailable\n"))
+ window.zoomHistoryAvailable.connect(lambda: output.write("zoomHistoryAvailable\n"))
+ window.mapQueried.connect(lambda: output.write("mapQueried\n"))
+ window.mouseEntered.connect(lambda: output.write("mouseEntered\n"))
+ window.mouseLeftUpPointer.connect(lambda: output.write("mouseLeftUpPointer\n"))
+ window.mouseLeftUp.connect(lambda: output.write("mouseLeftUp\n"))
+ window.mouseMoving.connect(lambda x, y: coordinatesShower.SetLabel("%s , %s" % (x, y)))
+ window.mouseHandlerRegistered.connect(lambda: output.write("mouseHandlerRegistered\n"))
+ window.mouseHandlerUnregistered.connect(lambda: output.write("mouseHandlerUnregistered\n"))
+ def testMapWindow(self, giface, map_):
+ self.frame = wx.Frame(parent=None, title=_("Map window test frame"))
+ panel = wx.Panel(parent=self.frame, id=wx.ID_ANY)
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ mapWindowProperties = MapWindowProperties()
+ mapWindowProperties.setValuesFromUserSettings()
+ width, height = self.frame.GetClientSize()
+ copyOfInitMap(map_, width, height)
+ window = BufferedWindow(parent=panel, giface=giface, Map=map_,
+ properties=mapWindowProperties, frame=self.frame)
+ sizer.Add(item=window, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
+ panel.SetSizer(sizer)
+ panel.Layout()
+ self.frame.Show()
+ def testMapDisplay(self, giface, map_):
+ # known issues (should be similar with d.mon):
+ # * opening map in digitizer ends with: vdigit/toolbars.py:723: 'selection' referenced before assignment
+ # * nviz start fails (closes window? segfaults?) after mapdisp/frame.py:306: 'NoneType' object has no attribute 'GetLayerNotebook'
+ frame = MapFrame(parent=None, title=_("Map display test"),
+ giface=giface, Map=map_)
+ # this is questionable: how complete the giface when creating objects
+ # which are in giface
+ giface.mapWindow = frame.GetMapWindow()
+ frame.GetMapWindow().ZoomToMap()
+ frame.Show()
+ def testMapWindowApi(self, giface, map_):
+ self.frame = wx.Frame(parent=None, title=_("Map window API test frame"))
+ mapWindowProperties.showRegion = True
+ giface.mapWindow = window
+ panel.Layout()
+ window.ZoomToWind()
+ from mapdisp.frame import MeasureController
+ self.measureController = MeasureController(giface)
+ self.measureController.StartMeasurement()
+ self._listenToAllMapWindowSignals(window)
+ self.frame.Show()
+ def testMapWindowDistance(self, giface, map_):
+ title=_("Map window distance measurement test frame"))
+ panel.Layout()
+ self.frame.Show()
+ from mapdisp.analysis import MeasureDistanceController
+ self.controller = MeasureDistanceController(giface, window)
+ self.controller.Start()
+ def testMapWindowProfile(self, giface, map_):
+ title=_("Map window profile tool test frame"))
+ panel.Layout()
+ self.frame.Show()
+ from mapdisp.analysis import ProfileController
+ self.controller = ProfileController(giface, window)
+ rasters = []
+ for layer in giface.GetLayerList().GetSelectedLayers():
+ if layer.maplayer.GetType() == 'raster':
+ rasters.append(layer.maplayer.GetName())
+ from wxplot.profile import ProfileFrame
+ profileWindow = ProfileFrame(parent=self.frame,
+ controller=self.controller,
+ units=map_.projinfo['units'],
+ rasterList=rasters)
+ profileWindow.CentreOnParent()
+ profileWindow.Show()
+ # Open raster select dialog to make sure that a raster (and
+ # the desired raster) is selected to be profiled
+ profileWindow.OnSelectRaster(None)
+def main():
+ """!Sets the GRASS display driver
+ driver = UserSettings.Get(group='display', key='driver', subkey='type')
+ if driver == 'png':
+ os.environ['GRASS_RENDER_IMMEDIATE'] = 'png'
+ else:
+ os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+ # TODO: message format should not be GUI
+ # TODO: should messages here be translatable?
+ # (for test its great, for translator not)
+ options, flags = grass.parser()
+ test = options['test']
+ app = wx.PySimpleApp()
+ if not CheckWxVersion([2, 9]):
+ wx.InitAllImageHandlers()
+ map_ = Map()
+ if options['raster']:
+ names = options['raster']
+ for name in names.split(','):
+ cmdlist = ['d.rast', 'map=%s' % name]
+ map_.AddLayer(ltype='raster', command=cmdlist, active=True,
+ name=name, hidden=False, opacity=1.0,
+ render=True)
+ if options['vector']:
+ names = options['vector']
+ cmdlist = ['d.vect', 'map=%s' % name]
+ map_.AddLayer(ltype='vector', command=cmdlist, active=True,
+ render=True)
+ giface = MapdispGrassInterface(map_=map_)
+ tester = Tester()
+ if test == 'mapwindow':
+ tester.testMapWindow(giface, map_)
+ elif test == 'mapdisplay':
+ tester.testMapDisplay(giface, map_)
+ elif test == 'apitest':
+ tester.testMapWindowApi(giface, map_)
+ elif test == 'distance':
+ tester.testMapWindowDistance(giface, map_)
+ elif test == 'profile':
+ tester.testMapWindowProfile(giface, map_)
+ else:
+ # TODO: this should not happen but happens
+ import grass.script as sgrass
+ sgrass.fatal(_("Unknown value %s of test parameter." % test))
+ app.MainLoop()
+ main()
Property changes on: grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
