[GRASS-SVN] r57424 - in grass/trunk/gui/wxpython: gcp iclass mapdisp mapswipe vdigit
svn_grass at osgeo.org
Tue Aug 6 03:32:07 PDT 2013
Author: annakrat
Date: 2013-08-06 03:32:07 -0700 (Tue, 06 Aug 2013)
New Revision: 57424
grass/trunk/gui/wxpython/gcp/mapdisplay.py
grass/trunk/gui/wxpython/iclass/digit.py
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
grass/trunk/gui/wxpython/mapswipe/frame.py
grass/trunk/gui/wxpython/mapswipe/mapwindow.py
grass/trunk/gui/wxpython/vdigit/mapwindow.py
wxGUI: remove frame parameter from BufferedWindow
Modified: grass/trunk/gui/wxpython/gcp/mapdisplay.py
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -116,12 +116,12 @@
self.grwiz.SwitchEnv('source')
self.SrcMapWindow = BufferedWindow(parent=self, giface=self._giface, id=wx.ID_ANY,
properties=self.mapWindowProperties,
- Map=self.SrcMap, frame=self)
+ Map=self.SrcMap)
self.grwiz.SwitchEnv('target')
self.TgtMapWindow = BufferedWindow(parent=self, giface=self._giface, id=wx.ID_ANY,
- Map=self.TgtMap, frame=self)
+ Map=self.TgtMap)
self.MapWindow = self.SrcMapWindow
self.Map = self.SrcMap
self._setUpMapWindow(self.SrcMapWindow)
Modified: grass/trunk/gui/wxpython/iclass/digit.py
--- grass/trunk/gui/wxpython/iclass/digit.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/iclass/digit.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -34,7 +34,7 @@
class IClassVDigitWindow(VDigitWindow):
"""! Class similar to VDigitWindow but specialized for wxIClass."""
- def __init__(self, parent, giface, map, frame, properties):
+ def __init__(self, parent, giface, map, properties):
@a parent should has toolbar providing current class (category).
@@ -43,7 +43,7 @@
@param map map renderer instance
VDigitWindow.__init__(self, parent=parent, giface=giface,
- Map=map, frame=frame, properties=properties)
+ Map=map, properties=properties)
def _onLeftDown(self, event):
action = self.toolbar.GetAction()
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -95,10 +95,10 @@
self.firstMapWindow = IClassVDigitWindow(parent = self, giface = self._giface,
- map = self.firstMap, frame = self)
+ map = self.firstMap)
self.secondMapWindow = BufferedWindow(parent = self, giface = self._giface,
- Map = self.secondMap, frame = self)
+ Map = self.secondMap)
self.MapWindow = self.firstMapWindow # current by default
self._bindWindowsActivation()
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -154,8 +154,8 @@
# Init map display (buffered DC & set default cursor)
- self.MapWindow2D = BufferedWindow(self, giface = self._giface, id = wx.ID_ANY,
- Map=self.Map, frame=self,
+ self.MapWindow2D = BufferedWindow(self, giface = self._giface,
+ Map=self.Map,
overlays=self.decorations)
self.MapWindow2D.mapQueried.connect(self.Query)
@@ -244,11 +244,10 @@
if not self.MapWindowVDigit:
from vdigit.mapwindow import VDigitWindow
- self.MapWindowVDigit = VDigitWindow(parent = self, giface = self._giface,
- id = wx.ID_ANY, frame = self,
- Map = self.Map, tree = self.tree,
+ self.MapWindowVDigit = VDigitWindow(parent=self, giface=self._giface,
- lmgr = self._layerManager,
+ Map=self.Map, tree=self.tree,
+ lmgr=self._layerManager,
self._setUpMapWindow(self.MapWindowVDigit)
self.MapWindowVDigit.digitizingInfo.connect(
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -57,23 +57,22 @@
can also save the drawing to file by calling the
SaveToFile() method.
- def __init__(self, parent, giface, Map, frame, properties,
+ def __init__(self, parent, giface, Map, properties,
id=wx.ID_ANY, overlays=None,
style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
@param parent parent window
@param giface grass interface instance
@param Map map instance
- @param frame map frame instance (to be removed)
+ @param properties instance of MapWindowProperties
@param id wx window id
@param style wx window style
@param kwargs keyword arguments passed to MapWindow and wx.Window
MapWindow.__init__(self, parent=parent, giface=giface, Map=Map)
- wx.Window.__init__(self, parent = parent, id = id, style = style, **kwargs)
+ wx.Window.__init__(self, parent=parent, id=id, style=style, **kwargs)
self._properties = properties
- self.frame = frame # remove including a frame parameter
# flags
self.resize = False # indicates whether or not a resize event has taken place
Modified: grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
--- grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -175,7 +175,7 @@
width, height = self.frame.GetClientSize()
copyOfInitMap(map_, width, height)
window = BufferedWindow(parent=panel, giface=giface, Map=map_,
- properties=mapWindowProperties, frame=self.frame)
+ properties=mapWindowProperties)
sizer.Add(item=window, proportion=1, flag=wx.EXPAND | wx.ALL, border=5)
panel.SetSizer(sizer)
panel.Layout()
@@ -205,7 +205,7 @@
giface.mapWindow = window
@@ -235,7 +235,7 @@
@@ -266,7 +266,7 @@
Modified: grass/trunk/gui/wxpython/mapswipe/frame.py
--- grass/trunk/gui/wxpython/mapswipe/frame.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/mapswipe/frame.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -66,10 +66,10 @@
self.mapWindowProperties.autoRenderChanged.connect(self.OnAutoRenderChanged)
self.firstMapWindow = SwipeBufferedWindow(parent = self.splitter, giface = self._giface,
- Map = self.firstMap, frame = self)
+ Map = self.firstMap)
self.secondMapWindow = SwipeBufferedWindow(parent = self.splitter, giface = self._giface,
self.firstMapWindow.zoomhistory = self.secondMapWindow.zoomhistory
self.SetBindRegions(True)
Modified: grass/trunk/gui/wxpython/mapswipe/mapwindow.py
--- grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -36,9 +36,8 @@
Enables to draw the image translated.
Special mouse events with changed coordinates are used.
- def __init__(self, parent, giface, Map, properties, frame, **kwargs):
- BufferedWindow.__init__(self, parent = parent, giface = giface,
- Map=Map, frame=frame,
+ def __init__(self, parent, giface, Map, properties, **kwargs):
+ BufferedWindow.__init__(self, parent=parent, giface=giface, Map=Map,
properties=properties, **kwargs)
Debug.msg(2, "SwipeBufferedWindow.__init__()")
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-08-06 09:15:59 UTC (rev 57423)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-08-06 10:32:07 UTC (rev 57424)
@@ -32,12 +32,12 @@
class VDigitWindow(BufferedWindow):
"""!A Buffered window extended for vector digitizer.
- def __init__(self, parent, giface, Map, frame, properties, tree=None,
+ def __init__(self, parent, giface, Map, properties, tree=None,
id=wx.ID_ANY, lmgr=None,
- BufferedWindow.__init__(self, parent = parent, giface = giface, id = id, Map = Map,
- frame=frame, style=style, **kwargs)
+ style=style, **kwargs)
self.lmgr = lmgr
self.tree = tree
self.pdcVector = wx.PseudoDC()
