[GRASS-SVN] r57432 - in grass/trunk/gui/wxpython: core lmgr mapdisp vnet
svn_grass at osgeo.org
Wed Aug 7 15:33:27 PDT 2013
Author: wenzeslaus
Date: 2013-08-07 15:33:26 -0700 (Wed, 07 Aug 2013)
New Revision: 57432
grass/trunk/gui/wxpython/core/giface.py
grass/trunk/gui/wxpython/lmgr/giface.py
grass/trunk/gui/wxpython/mapdisp/main.py
grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
grass/trunk/gui/wxpython/vnet/dialogs.py
grass/trunk/gui/wxpython/vnet/vnet_core.py
wxGUI/vnet: using giface instead of tree (fixes broken vnet, one usage of tree remains)
Modified: grass/trunk/gui/wxpython/core/giface.py
--- grass/trunk/gui/wxpython/core/giface.py 2013-08-07 21:08:10 UTC (rev 57431)
+++ grass/trunk/gui/wxpython/core/giface.py 2013-08-07 22:33:26 UTC (rev 57432)
@@ -49,7 +49,29 @@
raise NotImplementedError()
+ def GetSelectedLayer(self, checkedOnly=False):
+ """!Returns selected layer or None when there is no selected layer.
+ @note Parameter checkedOnly is here False by default. This might change
+ if we find the right way of handling unchecked layers.
+ raise NotImplementedError()
+ def AddLayer(self, ltype, name=None, checked=None,
+ opacity=1.0, cmd=None):
+ """!Adds a new layer to the layer list.
+ Launches property dialog if needed (raster, vector, etc.)
+ @param ltype layer type (raster, vector, 3d-raster, ...)
+ @param name layer name
+ @param checked if True layer is checked
+ @param opacity layer opacity level
+ @param cmd command (given as a list)
class GrassInterface:
"""!GrassInterface provides the functionality which should be available
to every GUI component.
@@ -208,7 +230,7 @@
os.environ["GRASS_MESSAGE_FORMAT"] = orig
def GetLayerList(self):
- return None
def GetMapDisplay(self):
"""!Get current map display.
@@ -221,7 +243,9 @@
return []
def GetMapWindow(self):
- return None
def GetProgress(self):
+ # TODO: implement some progress with same inface as gui one
+ # (probably using g.message or similarly to Write... functions)
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2013-08-07 21:08:10 UTC (rev 57431)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2013-08-07 22:33:26 UTC (rev 57432)
@@ -64,11 +64,37 @@
layers.append(layer)
return layers
+ # TODO: it is not clear if default of checkedOnly should be False or True
+ """!Returns selected layer or None when there is no selected layer."""
+ item = self._tree.GetSelectedLayer(multi=False,
+ checkedOnly=checkedOnly)
+ if item is None:
+ return None
+ else:
+ data = self._tree.GetPyData(item)
+ return Layer(data)
def GetLayerInfo(self, layer):
"""!For compatibility only, will be removed."""
return Layer(self._tree.GetPyData(layer))
+ self._tree.AddLayer(ltype=ltype, lname=name, lchecked=checked,
+ lopacity=opacity, lcmd=cmd)
class LayerManagerGrassInterface(object):
"""!@implements GrassInterface"""
def __init__(self, lmgr):
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2013-08-07 21:08:10 UTC (rev 57431)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2013-08-07 22:33:26 UTC (rev 57432)
@@ -248,8 +248,9 @@
class LayerList(object):
- def __init__(self, map):
+ def __init__(self, map, giface):
self._map = map
+ self._giface = giface
# def __iter__(self):
# for in :
@@ -264,7 +265,36 @@
return layers
+ layers = self.GetSelectedLayers()
+ if len(layers) > 0:
+ return layers[0]
+ else:
+ return None
+ self._map.AddLayer(ltype="vector", command=cmd,
+ name=name, active=True,
+ opacity=opacity, render=True,
+ pos=-1)
+ # TODO: this should be solved by signal
+ # (which should be introduced everywhere,
+ # alternative is some observer list)
+ self._giface.updateMap.emit(render=True, renderVector=True)
class DMonGrassInterface(StandaloneGrassInterface):
def __init__(self, mapframe):
@@ -272,9 +302,12 @@
self._mapframe = mapframe
- return LayerList(self._mapframe.GetMap())
+ return LayerList(self._mapframe.GetMap(), giface=self)
+ def GetMapWindow(self):
+ return self._mapframe.GetMapWindow()
class DMonFrame(MapFrame):
def OnZoomToMap(self, event):
layers = self.MapWindow.GetMap().GetListOfLayers()
Modified: grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py
--- grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py 2013-08-07 21:08:10 UTC (rev 57431)
+++ grass/trunk/gui/wxpython/mapdisp/test_mapdisp.py 2013-08-07 22:33:26 UTC (rev 57432)
@@ -61,7 +61,6 @@
if WXGUIBASE not in sys.path:
sys.path.append(WXGUIBASE)
-import core.utils as utils
from core.utils import _
from core.settings import UserSettings
from core.globalvar import CheckWxVersion
@@ -70,43 +69,9 @@
from mapwin.buffered import BufferedMapWindow
from core.render import Map
from rlisetup.sampling_frame import RLiSetupMapPanel
+from mapdisp.main import LayerList
-# TODO: same classes as in dmon
-class Layer(object):
- def __init__(self, maplayer):
- self._maplayer = maplayer
- def __getattr__(self, name):
- if name == 'cmd':
- return utils.CmdTupleToList(self._maplayer.GetCmd())
- elif hasattr(self._maplayer, name):
- return getattr(self._maplayer, name)
- elif name == 'maplayer':
- return self._maplayer
- elif name == 'type':
- return self._maplayer.GetType()
- #elif name == 'ctrl':
- elif name == 'label':
- return self._maplayer.GetName()
- #elif name == 'maplayer' : None,
- #elif name == 'propwin':
-class LayerList(object):
- def __init__(self, map_):
- self._map = map_
- def GetSelectedLayers(self, checkedOnly=True):
- # hidden and selected vs checked and selected
- items = self._map.GetListOfLayers()
- layers = []
- for item in items:
- layer = Layer(item)
- layers.append(layer)
- return layers
class MapdispGrassInterface(StandaloneGrassInterface):
@@ -115,7 +80,7 @@
self.mapWindow = None
- return LayerList(self._map)
+ return LayerList(self._map, giface=self)
return self.mapWindow
Modified: grass/trunk/gui/wxpython/vnet/dialogs.py
--- grass/trunk/gui/wxpython/vnet/dialogs.py 2013-08-07 21:08:10 UTC (rev 57431)
+++ grass/trunk/gui/wxpython/vnet/dialogs.py 2013-08-07 22:33:26 UTC (rev 57432)
@@ -444,13 +444,12 @@
def _createInputDbMgrPage(self):
"""!Tab with attribute tables of analysis input layers"""
self.inpDbMgrData['dbMgr'] = DbMgrBase()
- selMapName = None
+ selMapName = None
# if selected vector map is in layer tree then set it
- if self.mapWin.tree and self.mapWin.tree.layer_selected:
- selMapData = self.mapWin.tree.GetPyData(self.mapWin.tree.layer_selected)[0]
- if selMapData['type'] == 'vector': # wrap somehow in LayerTree
- selMapName = selMapData['maplayer'].name
+ layer = self.giface.GetLayerList().GetSelectedLayer()
+ if layer is not None and layer.type == 'vector':
+ selMapName = layer.maplayer.name
self.inpDbMgrData['browse'] = self.inpDbMgrData['dbMgr'].CreateDbMgrPage(parent = self.notebook,
pageName = 'browse')
@@ -591,21 +590,13 @@
cmd = ['d.vect',
'map=' + vectorMap]
- if self.mapWin.tree and \
- self.mapWin.tree.FindItemByData(key = 'name', value = vectorMap) is None:
- self.mapWin.tree.AddLayer(ltype = "vector",
- lcmd = cmd,
- lname =vectorMap,
- lchecked = True)
- #d.mon case
- else:
- self.renderLayer = self.mapWin.Map.AddLayer(ltype = "vector", command = cmd,
- name = vectorMap, active = True,
- opacity = 1.0, render = True,
- pos = -1)
+ if True:
+ self.giface.GetLayerList().AddLayer(ltype="vector",
+ cmd=cmd,
+ name=vectorMap,
+ checked=True)
+ # d.mon case is not need giface implementation should solve it for us
- self.giface.updateMap.emit(render=True, renderVector=True)
def UseTurns(self):
if self.useTurns.IsChecked():
self.inputData["tlayer"].GetParent().Show()
Modified: grass/trunk/gui/wxpython/vnet/vnet_core.py
--- grass/trunk/gui/wxpython/vnet/vnet_core.py 2013-08-07 21:08:10 UTC (rev 57431)
+++ grass/trunk/gui/wxpython/vnet/vnet_core.py 2013-08-07 22:33:26 UTC (rev 57432)
@@ -349,20 +349,29 @@
overwrite = True,
vect = [self.results["vect_map"].GetVectMapName(), mapName])
+ # TODO: this is a workaround: usage of parent
+ # use giface/LayerList instead (needs to be extended first, please do,
+ # don't forget on abstract giface in core/giface.py and dmon's giface)
+ tree = None
+ try:
+ # map display (MapFrame) should still have tree
+ tree = self.mapWin.parent.tree
+ except:
+ pass
- if not self.mapWin.tree:
+ if tree is None:
return
- if self.mapWin.tree.FindItemByData(key = 'name', value = mapName) is None:
- cmd, cmd_colors = self.vnet_data.GetLayerStyle()#TODO get rid of insert
+ if tree.FindItemByData(key='name', value=mapName) is None:
+ # TODO: get rid of insert
+ cmd, cmd_colors = self.vnet_data.GetLayerStyle()
cmd.insert(0, 'd.vect')
cmd.append('map=%s' % mapName)
- lname = mapName,
- lcmd = cmd,
- lchecked = True)
+ tree.AddLayer(ltype = "vector",
+ lname = mapName,
+ lcmd = cmd,
+ lchecked = True)
if cmd_colors:
layerStyleVnetColors = utils.CmdToTuple(cmd_colors)
