[GRASS-SVN] r57436 - in grass/trunk/gui/wxpython: gcp gui_core iclass mapdisp mapswipe mapwin psmap rlisetup vdigit vnet
Thu Aug 8 06:45:54 PDT 2013
Author: annakrat
Date: 2013-08-08 06:45:54 -0700 (Thu, 08 Aug 2013)
New Revision: 57436
   grass/trunk/gui/wxpython/gcp/mapdisplay.py
   grass/trunk/gui/wxpython/gcp/toolbars.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/gselect.py
   grass/trunk/gui/wxpython/gui_core/mapdisp.py
   grass/trunk/gui/wxpython/gui_core/toolbars.py
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/iclass/toolbars.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/mapdisp/toolbars.py
   grass/trunk/gui/wxpython/mapswipe/frame.py
   grass/trunk/gui/wxpython/mapswipe/toolbars.py
   grass/trunk/gui/wxpython/mapwin/decorations.py
   grass/trunk/gui/wxpython/psmap/frame.py
   grass/trunk/gui/wxpython/psmap/toolbars.py
   grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
   grass/trunk/gui/wxpython/vdigit/toolbars.py
   grass/trunk/gui/wxpython/vnet/dialogs.py
   grass/trunk/gui/wxpython/vnet/toolbars.py
wxGUI: improved system of switching tools in toolbars
Modified: grass/trunk/gui/wxpython/gcp/mapdisplay.py
--- grass/trunk/gui/wxpython/gcp/mapdisplay.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/gcp/mapdisplay.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -33,6 +33,7 @@
 from core.settings     import UserSettings
 from mapwin.buffered import BufferedMapWindow
 from mapwin.base import MapWindowProperties
+from gui_core.toolbars import ToolSwitcher
 import mapdisp.statusbar as sb
 import gcp.statusbar as sbgcp
@@ -141,6 +142,8 @@
         self._initMap(Map = self.SrcMap)
         self._initMap(Map = self.TgtMap)
+        self.GetMapToolbar().SelectDefault()
         # Bind various events
@@ -239,7 +242,7 @@
         # default toolbar
         if name == "map":
-            self.toolbars['map'] = MapToolbar(self, self.Map)
+            self.toolbars['map'] = MapToolbar(self, self._toolSwitcher)
             self._mgr.AddPane(self.toolbars['map'],
                               wx.aui.AuiPaneInfo().
@@ -252,7 +255,7 @@
         # GCP display
         elif name == "gcpdisp":
-            self.toolbars['gcpdisp'] = GCPDisplayToolbar(self)
+            self.toolbars['gcpdisp'] = GCPDisplayToolbar(self, self._toolSwitcher)
             self._mgr.AddPane(self.toolbars['gcpdisp'],
@@ -322,10 +325,7 @@
     def OnPointer(self, event):
         """!Pointer button clicked
-        self.toolbars['gcpdisp'].OnTool(event)
-        self.toolbars['gcpdisp'].action['desc'] = ''
         # change the cursor
         self.SrcMapWindow.SetNamedCursor('cross')
         self.SrcMapWindow.mouse['use'] = "pointer"
@@ -338,10 +338,7 @@
         Zoom in the map.
         Set mouse cursor, zoombox attributes, and zoom direction
         self.MapWindow.mouse['use'] = "zoom"
         self.MapWindow.mouse['box'] = "box"
         self.MapWindow.zoomtype = 1
@@ -368,9 +365,6 @@
         Zoom out the map.
         self.MapWindow.zoomtype = -1
@@ -395,10 +389,7 @@
     def OnPan(self, event):
         Panning, set mouse to drag
         self.MapWindow.mouse['use'] = "pan"
         self.MapWindow.mouse['box'] = "pan"
         self.MapWindow.zoomtype = 0
Modified: grass/trunk/gui/wxpython/gcp/toolbars.py
--- grass/trunk/gui/wxpython/gcp/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/gcp/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -78,12 +78,13 @@
 class GCPDisplayToolbar(BaseToolbar):
     """!GCP Display toolbar
-    def __init__(self, parent):
+    def __init__(self, parent, toolSwitcher):
         """!GCP Display toolbar constructor
-        BaseToolbar.__init__(self, parent)
+        BaseToolbar.__init__(self, parent, toolSwitcher)
         self.InitToolbar(self._toolbarData())
+        self._default = self.gcpset
         # add tool to toggle active map window
         self.togglemapid = wx.NewId()
@@ -96,15 +97,12 @@
                                                               BaseIcons["zoomBack"].GetLabel(),
                                                               _(' / Zoom to map')))
+        for tool in (self.gcpset, self.pan, self.zoomin, self.zoomout):
+            self.toolSwitcher.AddToolToGroup(group='mouseUse', toolbar=self, tool=tool)
         # realize the toolbar
         self.Realize()
-        self.action = { 'id' : self.gcpset }
-        self.defaultAction = { 'id' : self.gcpset,
-                               'bind' : self.parent.OnPointer }
-        self.OnTool(None)
         self.EnableTool(self.zoomback, False)
     def _toolbarData(self):
@@ -153,4 +151,3 @@
                                      ('quit', icons["quit"],
                                       self.parent.OnQuit))
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -394,6 +394,8 @@
             self.modeler = self.parent
         else:
             self.modeler = None
+        self.dialogClosing = Signal('TaskFrame.dialogClosing')
         # module name + keywords
         title = self.task.get_name()
@@ -738,7 +740,7 @@
     def OnCancel(self, event):
         """!Cancel button pressed"""
         self.MakeModal(False)
+        self.dialogClosing.emit()
         if self.get_dcmd and \
                 self.parent and \
                 self.parent.GetName() in ('LayerTree',
@@ -1516,6 +1518,9 @@
                                                         param = p)
                         p['wxId'] = [win.GetTextWin().GetId()]
                         win.GetTextWin().Bind(wx.EVT_TEXT, self.OnSetValue)
+                        # bind closing event because destructor is not working properly
+                        if hasattr(self.parent, 'dialogClosing'):
+                            self.parent.dialogClosing.connect(win.OnClose)
                     # normal text field
                     else:
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -1993,6 +1993,10 @@
        size = globalvar.DIALOG_COLOR_SIZE)
         self.registered = False
         self.buttonInsCoords.Bind(wx.EVT_BUTTON, self._onClick)
+        switcher = self._giface.GetMapDisplay().GetToolSwitcher()
+        switcher.AddCustomToolToGroup(group='mouseUse',
+                                      btnId=self.buttonInsCoords.GetId(),
+                                      toggleHandler=self.buttonInsCoords.SetValue)
         self._doLayout()
     def _doLayout(self):
@@ -2005,12 +2009,13 @@
     def _onClick(self, event):
         """!Button for interacitve inserting of coordinates clicked"""
+        switcher.ToolChanged(self.buttonInsCoords.GetId())
         self.mapWin = self._giface.GetMapWindow()
         if self.buttonInsCoords.GetToggle() and self.mapWin:
             if self.mapWin.RegisterMouseEventHandler(wx.EVT_LEFT_DOWN,
                                                      self._onMapClickHandler,
                                                      'cross') == False:
-                self.buttonInsCoords.SetToggle(False)
                 return
             self.registered = True
@@ -2021,14 +2026,10 @@
                                                             self._onMapClickHandler):
                 return
     def _onMapClickHandler(self, event):
         """!Gets coordinates from mapwindow"""
         if event == "unregistered":
-            if self.buttonInsCoords:
             return
         e, n = self.mapWin.GetLastEN()
@@ -2041,9 +2042,11 @@
         value = prevCoords + str(e) + "," + str(n)
         self.coordsField.SetValue(value)
-    def __del__(self):
+    def OnClose(self):
         """!Unregistrates _onMapClickHandler from mapWin"""
+        switcher.RemoveCustomToolFromGroup(self.buttonInsCoords.GetId())
         if self.mapWin and self.registered:
             self.mapWin.UnregisterMouseEventHandler(wx.EVT_LEFT_DOWN,
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -28,9 +28,11 @@
 from core        import globalvar
 from core.debug  import Debug
 from core.utils import _
 from grass.script import core as grass
 class MapFrameBase(wx.Frame):
     """!Base class for map display window
@@ -94,6 +96,10 @@
         else:
             self._mgr = auimgr
+        # handles switching between tools in different toolbars
+        self._toolSwitcher = ToolSwitcher()
+        self._toolSwitcher.toggleToolChanged.connect(self._onToggleTool)
     def _initMap(self, Map):
         """!Initialize map display, set dimensions and map region
@@ -106,6 +112,9 @@
         Map.region = Map.GetRegion() # g.region -upgc
         # self.Map.SetRegion() # adjust region to match display window
+    def _onToggleTool(self):
+        self.GetWindow().UnregisterAllHandlers()
     def OnSize(self, event):
         """!Adjust statusbar on changing size"""
         # reposition checkbox in statusbar
@@ -114,6 +123,9 @@
         # update statusbar
         self.StatusbarUpdate()
+    def GetToolSwitcher(self):
+        return self._toolSwitcher
     def SetProperty(self, name, value):
         """!Sets property"""
         self.statusbarManager.SetProperty(name, value)
@@ -288,20 +300,14 @@
     def OnZoomIn(self, event):
         """!Zoom in the map.
-        toolbar = self.GetMapToolbar()
-        self.SwitchTool(toolbar, event)
         win = self.GetWindow()
         self._prepareZoom(mapWindow = win, zoomType = 1)
     def OnZoomOut(self, event):
         """!Zoom out the map.
         self._prepareZoom(mapWindow = win, zoomType = -1)
@@ -329,27 +335,15 @@
         # change the cursor
         mapWindow.SetNamedCursor('cross')
-    def SwitchTool(self, toolbar, event):
-        """!Helper function to switch tools"""
-        # unregistration of all registered mouse event handlers of
-        # Mapwindow
-        self.MapWindow.UnregisterAllHandlers()
-        if toolbar:
-            toolbar.OnTool(event)
-            toolbar.action['desc'] = ''
         """!Sets mouse mode to pointer."""
         self.MapWindow.mouse['use'] = 'pointer'
+        self.MapWindow.mouse['box'] = 'point'
         """!Panning, set mouse to drag
         self._preparePan(mapWindow = win)
@@ -359,7 +353,7 @@
         @param mapWindow MapWindow to prepare
         mapWindow.mouse['use'] = "pan"
-        mapWindow.mouse['box'] = "pan"
+        mapWindow.mouse['box'] = "box"
         mapWindow.zoomtype = 0
         # change the cursor
@@ -503,6 +497,10 @@
         self.GetFirstWindow().Bind(wx.EVT_ENTER_WINDOW, self.ActivateFirstMap)
         self.GetSecondWindow().Bind(wx.EVT_ENTER_WINDOW, self.ActivateSecondMap)
+        self.GetFirstWindow().UnregisterAllHandlers()
+        self.GetSecondWindow().UnregisterAllHandlers()
     def GetFirstMap(self):
         """!Returns first Map instance
@@ -606,10 +604,7 @@
         win = self.GetFirstWindow()
@@ -619,10 +614,7 @@
@@ -631,10 +623,7 @@
@@ -643,12 +632,11 @@
         """!Set pointer mode (dragging overlays)"""
         self.GetFirstWindow().mouse['use'] = 'pointer'
+        self.GetFirstWindow().mouse['box'] = 'point'
         self.GetFirstWindow().SetNamedCursor('default')
         self.GetSecondWindow().mouse['use'] = 'pointer'
+        self.GetSecondWindow().mouse['box'] = 'point'
         self.GetSecondWindow().SetNamedCursor('default')
     def OnRender(self, event):
Modified: grass/trunk/gui/wxpython/gui_core/toolbars.py
--- grass/trunk/gui/wxpython/gui_core/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/gui_core/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -20,11 +20,15 @@
 import wx
-from core               import globalvar
-from core.debug         import Debug
+from core import globalvar
+from core.debug import Debug
-from icons.icon         import MetaIcon
+from icons.icon import MetaIcon
+from collections import defaultdict
+from grass.pydispatch.signal import Signal
 BaseIcons = {
     'display'    : MetaIcon(img = 'show',
                             label = _('Display map'),
@@ -94,17 +98,18 @@
     @endcode
-    def __init__(self, parent, style=wx.NO_BORDER|wx.TB_HORIZONTAL):
+    def __init__(self, parent, toolSwitcher=None, style=wx.NO_BORDER|wx.TB_HORIZONTAL):
         self.parent = parent
         wx.ToolBar.__init__(self, parent=self.parent, id=wx.ID_ANY,
                             style=style)
-        self.action = dict()
+        self._default = None
+        self.SetToolBitmapSize(globalvar.toolbarSize)
-        self.Bind(wx.EVT_TOOL, self.OnTool)
+        self.toolSwitcher = toolSwitcher
+        self.handlers = {}
-        self.SetToolBitmapSize(globalvar.toolbarSize)
     def InitToolbar(self, toolData):
         """!Initialize toolbar, add tools to the toolbar
@@ -138,12 +143,14 @@
                 toolWin = self.InsertLabelTool(pos, tool, label, bitmap,
                                             bmpDisabled, kind,
                                             shortHelp, longHelp)
+            self.handlers[tool] = handler
             self.Bind(wx.EVT_TOOL, handler, toolWin)
+            self.Bind(wx.EVT_TOOL, self.OnTool, toolWin)
         else: # separator
             self.AddSeparator()
         return tool
     def EnableLongHelp(self, enable = True):
         """!Enable/disable long help
@@ -152,7 +159,7 @@
         for tool in self._data:
             if tool[0] == '': # separator
                 continue
             if enable:
                 self.SetToolLongHelp(vars(self)[tool[0]], tool[4])
             else:
@@ -161,33 +168,20 @@
     def OnTool(self, event):
         """!Tool selected
+        if self.toolSwitcher:
+            Debug.msg(3, "BaseToolbar.OnTool(): id = %s" % event.GetId())
+            self.toolSwitcher.ToolChanged(event.GetId())
+        event.Skip()
+    def SelectTool(self, id):
+        self.ToggleTool(id, True)
+        self.toolSwitcher.ToolChanged(id)
-        id = self.action.get('id', -1)
-        if event:
-            # deselect previously selected tool
-            if id != -1 and id != event.GetId() :
-                self.ToggleTool(self.action['id'], False)
-            elif id != -1:
-                self.ToggleTool(self.action['id'], True)
-            self.action['id'] = event.GetId()
-            event.Skip()
-        elif id != -1:
-            # initialize toolbar
-    def GetAction(self, type = 'desc'):
-        """!Get current action info"""
-        return self.action.get(type, '')
-    def SelectDefault(self, event):
+        self.handlers[id](event=None)
+    def SelectDefault(self):
         """!Select default tool"""
-        self.ToggleTool(self.defaultAction['id'], True)
-        self.defaultAction['bind'](event)
-        self.action = { 'id' : self.defaultAction['id'],
-                        'desc' : self.defaultAction.get('desc', '') }
+        self.SelectTool(self._default)
     def FixSize(self, width):
         """!Fix toolbar width on Windows
@@ -253,3 +247,80 @@
         self.PopupMenu(menu)
         menu.Destroy()
+class ToolSwitcher:
+    """!Class handling switching tools in toolbar and custom toggle buttons."""
+    def __init__(self):
+        self._groups = defaultdict(lambda: defaultdict(list))
+        self._toolsGroups = defaultdict(list)
+        # emitted when tool is changed
+        self.toggleToolChanged = Signal('ToolSwitcher.toggleToolChanged')
+    def AddToolToGroup(self, group, toolbar, tool):
+        """!Adds tool from toolbar to group of exclusive tools.
+        @param group name of group (e.g. 'mouseUse')
+        @param toolbar instance of toolbar
+        @param tool id of a tool from the toolbar
+        self._groups[group][toolbar].append(tool)
+        self._toolsGroups[tool].append(group)
+    def AddCustomToolToGroup(self, group, btnId, toggleHandler):
+        """!Adds custom tool from to group of exclusive tools (some toggle button).
+        @param btnId id of a tool (typically button)
+        @param toggleHandler handler to be called to switch the button
+        self._groups[group]['custom'].append((btnId, toggleHandler))
+        self._toolsGroups[btnId].append(group)
+    def RemoveCustomToolFromGroup(self, tool):
+        """!Removes custom tool from group.
+        @param tool id of the button
+        if not tool in self._toolsGroups:
+            return
+        for group in self._toolsGroups[tool]:
+            self._groups[group]['custom'] = \
+                [(bid, hdlr) for (bid, hdlr)
+                in self._groups[group]['custom'] if bid != tool]
+    def RemoveToolbarFromGroup(self, group, toolbar):
+        """!Removes toolbar from group.
+        Before toolbar is destroyed, it must be removed from group, too.
+        Otherwise we can expect some DeadObject errors.
+        for tb in self._groups[group]:
+            if tb == toolbar:
+                del self._groups[group][tb]
+                break
+    def ToolChanged(self, tool):
+        """!When any tool/button is pressed, other tools from group must be unchecked.
+        @param tool id of a tool/button
+                if tb == 'custom':
+                    for btnId, handler in self._groups[group][tb]:
+                        if btnId != tool:
+                            handler(False)
+                else:
+                    for tl in self._groups[group][tb]:
+                        if tb.FindById(tl):  # check if still exists
+                            if tl != tool:
+                                tb.ToggleTool(tl, False)
+                            else:
+                                tb.ToggleTool(tool, True)
+        self.toggleToolChanged.emit(id=tool)
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -53,6 +53,7 @@
 from gui_core.dialogs   import SetOpacityDialog
 from dbmgr.vinfo        import VectorDBInfo
 import grass.script as grass
 from iclass.digit       import IClassVDigitWindow, IClassVDigit
@@ -186,7 +187,7 @@
         self.previewMapManager.SetToolbar(self.toolbars['iClassPreviewMapManager'])
         # default action
-        self.OnPan(event = None)
         wx.CallAfter(self.AddTrainingAreaMap)
@@ -263,7 +264,7 @@
          Toolbars 'iClassPreviewMapManager' are added in _addPanes().
         if name == "iClassMap":
-            self.toolbars[name] = IClassMapToolbar(self)
+            self.toolbars[name] = IClassMapToolbar(self, self._toolSwitcher)
             self._mgr.AddPane(self.toolbars[name],
@@ -299,13 +300,13 @@
                               BestSize((self.toolbars[name].GetBestSize())))
         if name == "vdigit":
-            self.toolbars[name] = VDigitToolbar(parent = self, MapWindow = self.GetFirstWindow(),
-                                                digitClass = IClassVDigit, giface = self._giface,
+            self.toolbars[name] = VDigitToolbar(parent=self, toolSwitcher=self._toolSwitcher,
+                                                MapWindow=self.GetFirstWindow(),
+                                                digitClass=IClassVDigit, giface=self._giface,
                                                 tools = ['addArea', 'moveVertex', 'addVertex',
                                                          'removeVertex', 'editLine', 'moveLine',
                                                          'deleteLine', 'deleteArea',
                                                          'undo', 'redo'])
                               Name(name).Caption(_("Digitization Toolbar")).
@@ -1119,24 +1120,6 @@
-        """!Calls UpdateTools to manage connected toolbars"""
-        self.UpdateTools(event)
-        super(IClassMapFrame, self).SwitchTool(toolbar, event)
-    def UpdateTools(self, event):
-        """!Method deals with relations of toolbars and other
-        elements"""
-        # untoggles button in other toolbars
-        for toolbar in self.toolbars.itervalues():
-            if hasattr(event, 'GetEventObject') == True:
-                if event.GetEventObject() == toolbar:
-                    continue
-                if toolbar.action:
-                    toolbar.ToggleTool(toolbar.action['id'], False)
-                    toolbar.action['id'] = -1
-                    toolbar.OnTool(None)
     def OnScatterplot(self, event):
         """!Init interactive scatterplot tools
Modified: grass/trunk/gui/wxpython/iclass/toolbars.py
--- grass/trunk/gui/wxpython/iclass/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/iclass/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -54,12 +54,13 @@
 class IClassMapToolbar(BaseToolbar):
     """!IClass Map toolbar
         """!IClass Map toolbar constructor
+        self._default = self.pan
@@ -72,15 +73,11 @@
                                                               _('/ Zoom to map')))
+        for tool in (self.pan, self.zoomIn, self.zoomOut):
         self.Realize()
-        self.action = { 'id' : self.pan }
-        self.defaultAction = { 'id' : self.pan,
-                               'bind' : self.parent.OnPan }
-        self.OnTool(None)
         self.EnableTool(self.zoomBack, False)
     def GetActiveMapTool(self):
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -49,6 +49,7 @@
 from gui_core.mapdisp   import SingleMapFrame
 from gui_core.query     import QueryDialog, PrepareQueryResults
 from mapwin.decorations import DecorationDialog, TextLayerDialog, \
     LegendController, BarscaleController, \
@@ -119,7 +120,7 @@
         for toolb in toolbars:
             self.AddToolbar(toolb)
         # Add statusbar
@@ -179,10 +180,7 @@
         self.MapWindow2D.mapQueried.connect(self.Query)
         self.MapWindow2D.overlayActivated.connect(self._activateOverlay)
         self._setUpMapWindow(self.MapWindow2D)
-        # manage the state of toolbars connected to mouse cursor
-        self.MapWindow2D.mouseHandlerRegistered.connect(
-            lambda:
-            self.UpdateTools(None))
         self.MapWindow2D.mouseHandlerUnregistered.connect(self.ResetPointer)
         self.MapWindow2D.InitZoomHistory()
@@ -202,6 +200,7 @@
         self._initMap(Map = self.Map)
+        self.toolbars['map'].SelectDefault()
@@ -281,7 +280,8 @@
         elif self._mgr.GetPane('3d').IsShown():
             self._mgr.GetPane('3d').Hide()
         self._mgr.GetPane('vdigit').Show()
-        self.toolbars['vdigit'] = VDigitToolbar(parent = self, MapWindow = self.MapWindow,
+        self.toolbars['vdigit'] = VDigitToolbar(parent=self, toolSwitcher=self._toolSwitcher,
+                                                MapWindow = self.MapWindow,
                                                 digitClass=VDigit, giface=self._giface,
                                                 layerTree=self.tree)
         self.MapWindowVDigit.SetToolbar(self.toolbars['vdigit'])
@@ -320,8 +320,12 @@
         # add rotate tool to map toolbar
         self.toolbars['map'].InsertTool((('rotate', NvizIcons['rotate'],
                                           self.OnRotate, wx.ITEM_CHECK, 7),)) # 7 is position
+        self._toolSwitcher.AddToolToGroup(group='mouseUse', toolbar=self.toolbars['map'],
+                                          tool=self.toolbars['map'].rotate)
         self.toolbars['map'].InsertTool((('flyThrough', NvizIcons['flyThrough'],
-                                          self.OnFlyThrough, wx.ITEM_CHECK, 8),))
+                                          self.OnFlyThrough, wx.ITEM_CHECK, 8),))
+                                          tool=self.toolbars['map'].flyThrough)
         self.toolbars['map'].ChangeToolsDesc(mode2d = False)
         # update status bar
@@ -424,6 +428,7 @@
         self.MapWindow.UpdateMap()
         self._mgr.Update()
     def AddToolbar(self, name, fixed = False):
         """!Add defined toolbar to the window
@@ -437,7 +442,7 @@
         # default toolbar
         if name == "map":
+            self.toolbars['map'] = MapToolbar(self, toolSwitcher=self._toolSwitcher)
@@ -468,6 +473,7 @@
             return
         self._mgr.DetachPane(self.toolbars[name])
+        self._toolSwitcher.RemoveToolbarFromGroup('mouseUse', self.toolbars[name])
         self.toolbars[name].Destroy()
         self.toolbars.pop(name)
@@ -511,43 +517,20 @@
-        if self.GetMapToolbar():
-            if event:
-                self.SwitchTool(self.toolbars['map'], event)
-            self.toolbars['map'].action['desc'] = ''
         self.MapWindow.mouse['use'] = "pointer"
         self.MapWindow.mouse['box'] = "point"
         # change the cursor
         if self.GetToolbar('vdigit'):
-            # digitization tool activated
-            self.MapWindow.SetNamedCursor('cross')
+            self.toolbars['vdigit'].action['id'] = -1
+            self.toolbars['vdigit'].action['desc']=''
-            # reset mouse['box'] if needed
-            if self.toolbars['vdigit'].GetAction() in ['addLine']:
-                if self.toolbars['vdigit'].GetAction('type') in ['point', 'centroid']:
-                    self.MapWindow.mouse['box'] = 'point'
-                else: # line, boundary
-                    self.MapWindow.mouse['box'] = 'line'
-            elif self.toolbars['vdigit'].GetAction() in ['addVertex', 'removeVertex', 'splitLine',
-                                                         'editLine', 'displayCats', 'queryMap',
-                                                         'copyCats']:
-            else: # moveLine, deleteLine
-                self.MapWindow.mouse['box'] = 'box'
-        else:
-            self.MapWindow.SetNamedCursor('default')
+        self.MapWindow.SetNamedCursor('default')
     def OnRotate(self, event):
         """!Rotate 3D view
         self.MapWindow.mouse['use'] = "rotate"
         # change the cursor
@@ -556,10 +539,6 @@
     def OnFlyThrough(self, event):
         """!Fly-through mode
         self.MapWindow.mouse['use'] = "fly"
         # change the cursor
@@ -803,10 +782,6 @@
     def OnQuery(self, event):
         """!Query tools menu"""
-        self.toolbars['map'].action['desc'] = 'queryMap'
         self.MapWindow.mouse['use'] = "query"
@@ -1030,7 +1005,6 @@
     def OnAddText(self, event):
         """!Handler for text decoration menu selection.
         if self.MapWindow.dragid > -1:
             id = self.MapWindow.dragid
             self.MapWindow.dragid = -1
@@ -1210,47 +1184,11 @@
         self.dialogs['vnet'] = VNETDialog(parent=self, giface=self._giface)
         self.dialogs['vnet'].CenterOnScreen()
         self.dialogs['vnet'].Show()
-        SingleMapFrame.SwitchTool(self, toolbar, event)
-        elements"""
-                    continue
-        # mouse settings
-        self.MapWindow.mouse['use'] = 'pointer'
-        # untoggles button in add legend dialog
-        # FIXME: remove this mess
-        if self.dialogs['legend']:
-            btn = self.dialogs['legend'].resizeBtn
-            if btn.GetValue():
-                btn.SetValue(0)
-                self.dialogs['legend'].DisconnectResizing()
-        if self.measureDistController and self.measureDistController.IsActive():
-            self.measureDistController.Stop(restore=False)
     def ResetPointer(self):
         """Sets pointer mode.
         Sets pointer and toggles it (e.g. after unregistration of mouse
         handler).
-        Somehow related to UpdateTools.
-        # sets pointer mode
-        toolbar = self.toolbars['map']
-        toolbar.action['id'] = vars(toolbar)["pointer"]
-        self.OnPointer(event=None)
Modified: grass/trunk/gui/wxpython/mapdisp/toolbars.py
--- grass/trunk/gui/wxpython/mapdisp/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/mapdisp/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -66,16 +66,15 @@
 class MapToolbar(BaseToolbar):
     """!Map Display toolbar
-    def __init__(self, parent, mapcontent):
         """!Map Display constructor
         @param parent reference to MapFrame
-        @param mapcontent reference to render.Map (registred by MapFrame)
-        self.mapcontent = mapcontent # render.Map
-        BaseToolbar.__init__(self, parent = parent) # MapFrame
+        BaseToolbar.__init__(self, parent=parent, toolSwitcher=toolSwitcher) # MapFrame
+        self._default = self.pointer
         # optional tools
         choices = [ _('2D view'), ]
@@ -127,12 +126,9 @@
         self.combo.Hide()
         self.combo.Show()
-        self.action = { 'id' : self.pointer }
-        self.defaultAction = { 'id' : self.pointer,
+        for tool in (self.pointer, self.query, self.pan, self.zoomIn, self.zoomOut):
-        self.OnTool(None)
         self.FixSize(width = 90)
Modified: grass/trunk/gui/wxpython/mapswipe/frame.py
--- grass/trunk/gui/wxpython/mapswipe/frame.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/mapswipe/frame.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -23,6 +23,7 @@
 from gui_core.mapdisp   import DoubleMapFrame
 from gui_core.dialogs   import GetImageHandlers
 from core.render        import Map
 from mapdisp            import statusbar as sb
@@ -98,7 +99,7 @@
         self.rasters = {'first': None, 'second': None}
         # default action in map toolbar
         self.resize = False
@@ -256,7 +257,7 @@
          - 'swipeMain'         - swipe functionality
         if name == "swipeMap":
-            self.toolbars[name] = SwipeMapToolbar(self)
+            self.toolbars[name] = SwipeMapToolbar(self, self._toolSwitcher)
                       Name(name).Caption(_("Map Toolbar")).
Modified: grass/trunk/gui/wxpython/mapswipe/toolbars.py
--- grass/trunk/gui/wxpython/mapswipe/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/mapswipe/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -32,19 +32,19 @@
 class SwipeMapToolbar(BaseToolbar):
     """!Map toolbar (to control map zoom and rendering)
         """!Map toolbar constructor
         self.Realize()
+        for tool in (self.pointer, self.pan, self.zoomIn, self.zoomOut):
Modified: grass/trunk/gui/wxpython/mapwin/decorations.py
--- grass/trunk/gui/wxpython/mapwin/decorations.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/mapwin/decorations.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -22,7 +22,9 @@
 from core.utils import GetLayerNameFromCmd, _
 from gui_core.forms import GUI
+from grass.pydispatch.errors import DispatcherKeyError
 class OverlayController(object):
     """!Base class for decorations (barscale, legend) controller."""
@@ -187,9 +189,6 @@
         self._ddstyle = ddstyle
         self._giface = giface
-        self._oldMouseUse = None
-        self._oldCursor = None
         sizer = wx.BoxSizer(wx.VERTICAL)
         box = wx.BoxSizer(wx.HORIZONTAL)
@@ -218,7 +217,12 @@
             self.resizeBtn.SetToolTipString(_("Click and drag on the map display to set legend "
                                               "size and position and then press OK"))
             self.resizeBtn.Disable()
-            self.resizeBtn.Bind(wx.EVT_TOGGLEBUTTON, self.OnResize)
+            toolSwitcher = self._giface.GetMapDisplay().GetToolSwitcher()
+            toolSwitcher.AddCustomToolToGroup(group='mouseUse', btnId=self.resizeBtn.GetId(),
+                                              toggleHandler=self.resizeBtn.SetValue)
+            toolSwitcher.toggleToolChanged.connect(self._toolChanged)
+            self.resizeBtn.Bind(wx.EVT_TOGGLEBUTTON, lambda evt: toolSwitcher.ToolChanged(evt.GetId()))
             box.Add(item=self.resizeBtn, proportion=0,
                     flag=wx.ALIGN_CENTRE | wx.ALL, border=5)
             sizer.Add(item=box, proportion=0,
@@ -294,38 +298,37 @@
             else:
                 self._overlay.propwin.Show()
-    def OnResize(self, event):
-        window = self._giface.GetMapWindow()
-        if event.GetInt():
-            self._oldMouseUse = window.mouse['use']
-            self._oldCursor = window.GetNamedCursor()
-            window.SetNamedCursor('cross')
-            window.mouse['use'] = None
-            window.mouse['box'] = 'box'
-            window.pen = wx.Pen(colour='Black', width=2, style=wx.SHORT_DASH)
-            window.mouseLeftUp.connect(self._resizeLegend)
+    def _toolChanged(self, id):
+        """!Tool in toolbar or button itself were pressed"""
+        if id == self.resizeBtn.GetId():
+            if self.resizeBtn.GetValue():
+                # prepare for resizing
+                window = self._giface.GetMapWindow()
+                window.SetNamedCursor('cross')
+                window.mouse['use'] = None
+                window.mouse['box'] = 'box'
+                window.pen = wx.Pen(colour='Black', width=2, style=wx.SHORT_DASH)
+                window.mouseLeftUp.connect(self._resizeLegend)
+            else:
+                # stop resizing mode
+                self.DisconnectResizing()
+                self._giface.GetMapDisplay().GetMapToolbar().SelectDefault()
         else:
-            self.Restore()
+            # any other tool was pressed -> stop resizing mode
-    def Restore(self):
-        """!Restore conditions before resizing"""
-        if self._oldCursor:
-            window.SetNamedCursor(self._oldCursor)
-        if self._oldMouseUse:
-            window.mouse['use'] = self._oldMouseUse
     def DisconnectResizing(self):
-        self._giface.GetMapWindow().mouseLeftUp.disconnect(self._resizeLegend)
+        try:
+            self._giface.GetMapWindow().mouseLeftUp.disconnect(self._resizeLegend)
+        except DispatcherKeyError:
+            pass
     def _resizeLegend(self, x, y):
         """!Update legend after drawing new legend size (moved from BufferedWindow)"""
-        self.resizeBtn.SetValue(False)
-        self.Restore()
         # resize legend
         screenSize = window.GetClientSizeTuple()
         self._overlay.ResizeLegend(window.mouse["begin"], window.mouse["end"], screenSize)
         # redraw
@@ -334,8 +337,6 @@
     def CloseDialog(self):
         """!Hide dialog"""
         if self._ddstyle == DECOR_DIALOG_LEGEND and self.resizeBtn.GetValue():
-            self.Restore()
         self.Hide()
Modified: grass/trunk/gui/wxpython/psmap/frame.py
--- grass/trunk/gui/wxpython/psmap/frame.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/psmap/frame.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -40,6 +40,7 @@
 from gui_core.dialogs   import HyperlinkDialog
 from gui_core.ghelp     import ShowAboutDialog
 from psmap.menudata     import PsMapMenuData
 from psmap.dialogs      import *
 from psmap.instructions import *
@@ -65,10 +66,10 @@
         self.SetMenuBar(self.menubar)
         #toolbar
-        self.toolbar = PsMapToolbar(parent = self)
+        self.toolbar = PsMapToolbar(parent=self, toolSwitcher=self._toolSwitcher)
         self.SetToolBar(self.toolbar)
-        self.actionOld = self.toolbar.action['id']
         self.iconsize = (16, 16)
         #satusbar
         self.statusbar = self.CreateStatusBar(number = 1)
@@ -154,7 +155,9 @@
         # set WIND_OVERRIDE
         grass.use_temp_region()
+        self.toolbar.SelectDefault()
         # create queues
         self.requestQ = Queue.Queue()
         self.resultQ = Queue.Queue()
@@ -457,25 +460,21 @@
         dlg.Destroy()
-        self.toolbar.OnTool(event)
         self.mouse["use"] = "pointer"
         self.canvas.SetCursor(self.cursors["default"])
         self.previewCanvas.SetCursor(self.cursors["default"])
         self.mouse["use"] = "pan"
         self.canvas.SetCursor(self.cursors["hand"])
         self.previewCanvas.SetCursor(self.cursors["hand"])
         self.mouse["use"] = "zoomin"
         self.canvas.SetCursor(self.cursors["cross"])
         self.previewCanvas.SetCursor(self.cursors["cross"])
         self.mouse["use"] = "zoomout"
@@ -500,14 +499,7 @@
     def OnAddMap(self, event, notebook = False):
-        """!Add or edit map frame"""
-        if event is not None:
-            if event.GetId() != self.toolbar.action['id']:
-                self.mouseOld = self.mouse['use']
-                self.cursorOld = self.canvas.GetCursor()
+        """!Add or edit map frame"""
         if self.instruction.FindInstructionByType('map'):
             mapId = self.instruction.FindInstructionByType('map').id
         else: mapId = None
@@ -524,19 +516,9 @@
             id[2] = vectorId
-        if mapId: # map exists
-            self.toolbar.ToggleTool(self.actionOld, True)
-            self.toolbar.ToggleTool(self.toolbar.action['id'], False)
-            self.toolbar.action['id'] = self.actionOld
-            try:
-                self.canvas.SetCursor(self.cursorOld)
-            except AttributeError:
-                pass
-##            dlg = MapDialog(parent = self, id  = id, settings = self.instruction,
-##                            notebook = notebook)
-##            dlg.ShowModal()
+        if mapId: # map exists
             if notebook:
                 #check map, raster, vector and save, destroy them
                 if 'map' in self.openDialogs:
@@ -1450,12 +1432,7 @@
             self.openDialogs['map'] = dlg
             self.openDialogs['map'].Show()
-            self.mouse['use'] = self.parent.mouseOld
-            self.SetCursor(self.parent.cursorOld)
-            self.parent.toolbar.ToggleTool(self.parent.actionOld, True)
-            self.parent.toolbar.ToggleTool(self.parent.toolbar.action['id'], False)
-            self.parent.toolbar.action['id'] = self.parent.actionOld
+            self.parent.toolbar.SelectDefault()
             return
         # resize resizable objects (map, line, rectangle)
Modified: grass/trunk/gui/wxpython/psmap/toolbars.py
--- grass/trunk/gui/wxpython/psmap/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/psmap/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -26,14 +26,19 @@
 from core.globalvar    import ETCIMGDIR
 class PsMapToolbar(BaseToolbar):
         """!Toolbar Cartographic Composer (psmap.py)
         @param parent parent window
+        for tool in (self.pointer, self.pan, self.zoomin, self.zoomout,
+                     self.drawGraphics, self.addMap):
         # custom button for graphics mode selection
         # TODO: could this be somehow generalized?
@@ -46,11 +51,6 @@
         self.Realize()
-        self.OnTool(None)
         from psmap.frame import havePILImage
         if not havePILImage:
             self.EnableTool(self.preview, False)
@@ -169,7 +169,6 @@
     def OnDrawGraphics(self, event):
         """!Graphics tool activated."""
-        self.OnTool(event)
         # we need the previous id
         if self.drawGraphicsAction == 'pointAdd':
             self.parent.OnAddPoint(event)
Modified: grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
--- grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/rlisetup/sampling_frame.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -33,7 +33,7 @@
-from gui_core.toolbars import BaseToolbar, BaseIcons
+from gui_core.toolbars import BaseToolbar, BaseIcons, ToolSwitcher
@@ -65,7 +65,9 @@
                           Dockable(True).BestSize((-1, -1)).Name('mapwindow').
                           CloseButton(False).DestroyOnClose(True).
                           Layer(0))
-        self.toolbar = RLiSetupToolbar(self)
+        self._toolSwitcher.toggleToolChanged.connect(self._onToolChanged)
+        self.toolbar = RLiSetupToolbar(self, self._toolSwitcher)
         self._mgr.AddPane(self.toolbar,
@@ -75,18 +77,12 @@
                           BestSize((self.toolbar.GetBestSize())))
         self._mgr.Update()
-        self._initTool()
         self._registeredGraphics = self.mapWindow.RegisterGraphicsToDraw(graphicsType='rectangle')
         self._registeredGraphics.AddPen('rlisetup', wx.Pen(wx.GREEN, width=3, style=wx.SOLID))
         self._registeredGraphics.AddItem(coords=[[0, 0], [0, 0]], penName='rlisetup', hide=True)
-    def _initTool(self):
-        """!Initialize draw mode"""
-        self.toolbar.ToggleTool(self.toolbar.draw, True)
-        self.toolbar.action['id'] = self.toolbar.draw
-        self.OnDraw(None)
     def GetMap(self):
         return self.map_
@@ -97,13 +93,11 @@
-        self.SwitchTool(event)
         self._prepareZoom(mapWindow=self.mapWindow, zoomType=1)
         self._prepareZoom(mapWindow=self.mapWindow, zoomType=-1)
     def _prepareZoom(self, mapWindow, zoomType):
@@ -120,10 +114,8 @@
         # change the cursor
-    def SwitchTool(self, event):
-        self.toolbar.action['desc'] = ''
+    def _onToolChanged(self):
+        """!Helper function to disconnect drawing"""
         try:
             self.mapWindow.mouseLeftUp.disconnect(self._rectangleDrawn)
@@ -132,8 +124,6 @@
         self.mapWindow.mouse['use'] = "pan"
         self.mapWindow.mouse['box'] = "pan"
         self.mapWindow.zoomtype = 0
@@ -147,8 +137,6 @@
     def OnDraw(self, event):
         """!Start draw mode"""
         self.mapWindow.mouse['use'] = None
         self.mapWindow.mouse['box'] = "box"
         self.mapWindow.pen = wx.Pen(colour=wx.RED, width=2, style=wx.SHORT_DASH)
@@ -182,12 +170,17 @@
 class RLiSetupToolbar(BaseToolbar):
     """!IClass toolbar
         """!RLiSetup toolbar constructor
-        BaseToolbar.__init__(self, parent, style=wx.NO_BORDER | wx.TB_VERTICAL)
+        BaseToolbar.__init__(self, parent, toolSwitcher, style=wx.NO_BORDER | wx.TB_VERTICAL)
+        self._default = self.draw
+        for tool in (self.draw, self.pan, self.zoomIn, self.zoomOut):
         self.Realize()
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -31,14 +31,14 @@
 class VDigitToolbar(BaseToolbar):
     """!Toolbar for digitization
-    def __init__(self, parent, MapWindow, digitClass, giface,
+    def __init__(self, parent, toolSwitcher, MapWindow, digitClass, giface,
                  tools=[], layerTree=None):
         self.MapWindow     = MapWindow
         self.Map           = MapWindow.GetMap() # Map class instance
         self.layerTree     = layerTree  # reference to layer tree associated to map display
         self.tools         = tools
         self.digitClass    = digitClass
         self.digit         = None
@@ -53,11 +53,11 @@
         # only one dialog can be open
         self.settingsDialog   = None
         # create toolbars (two rows optionally)
-        self.Bind(wx.EVT_TOOL, self._toolChosen)
+        self._default = -1
         # default action (digitize new point, line, etc.)
         self.action = { 'desc' : '',
                         'type' : '',
@@ -66,6 +66,13 @@
         # list of available vector maps
         self.UpdateListOfLayers(updateTool = True)
+        for tool in ('addPoint', 'addLine', 'addBoundary', 'addCentroid', 'addArea',
+                     'addVertex', 'deleteLine', 'deleteArea', 'displayAttr', 'displayCats',
+                     'editLine', 'moveLine', 'moveVertex', 'removeVertex', 'additionalTools'):
+            if hasattr(self, tool):
+                tool = getattr(self, tool)
         # realize toolbar
         self.Realize()
         # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
@@ -78,12 +85,9 @@
             self.EnableTool(self.undo, False)
         if self.redo > 0:
             self.EnableTool(self.redo, False)
-        # toogle to pointer by default
-        self.OnTool(None)
         self.FixSize(width = 105)
         """!Toolbar data
@@ -235,27 +239,15 @@
                          self.OnExit))
         return self._getToolbarData(data)
-    def _toolChosen(self, event):
-        """!Tool selected -> untoggles selected tools in other
-        toolbars
-        @todo implement iclass front-end
-        self.parent.MapWindow.UnregisterAllHandlers()
-        if hasattr(self.parent, "UpdateTools"):
-            self.parent.UpdateTools(event)
         """!Tool selected -> untoggles previusly selected tool in
         toolbar"""
+        Debug.msg(3, "VDigitToolbar.OnTool(): id = %s" % event.GetId())
         # set cursor
-        # pointer
-        self.parent.OnPointer(None)
+        self.MapWindow.mouse['use'] = 'pointer'
         aId = self.action.get('id', -1)
         BaseToolbar.OnTool(self, event)
@@ -316,7 +308,7 @@
     def OnAddArea(self, event):
         """!Add area to the vector map layer"""
-        Debug.msg (2, "VDigitToolbar.OnAddCentroid()")
+        Debug.msg (2, "VDigitToolbar.OnAddArea()")
         self.action = { 'desc' : "addLine",
                         'type' : "area",
                         'id'   : self.addArea }
@@ -333,8 +325,7 @@
             self.settingsDialog.OnCancel(None)
         # set default mouse settings
-        self.MapWindow.mouse['use'] = "pointer"
-        self.MapWindow.mouse['box'] = "point"
+        self.parent.GetMapToolbar().SelectDefault()
         self.MapWindow.polycoords = []
         # TODO: replace this by binding wx event in parent (or use signals...)
@@ -443,7 +434,11 @@
         else:
             if self.GetToolEnabled(tool) is True:
                 self.EnableTool(tool, False)
+    def GetAction(self, type = 'desc'):
+        """!Get current action info"""
+        return self.action.get(type, '')
     def OnSettings(self, event):
         """!Show settings dialog"""
         if self.digit is None:
Modified: grass/trunk/gui/wxpython/vnet/dialogs.py
--- grass/trunk/gui/wxpython/vnet/dialogs.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/vnet/dialogs.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -207,9 +207,11 @@
                               name = 'points')
         self.list = PtsList(parent = pointsPanel, vnet_mgr = self.vnet_mgr)
-        self.toolbars['pointsList'] = PointListToolbar(parent = pointsPanel,
-                                                       dialog = self,
-                                                       vnet_mgr = self.vnet_mgr)
+        toolSwitcher=self.giface.GetMapDisplay().GetToolSwitcher()
+        self.toolbars['pointsList'] = PointListToolbar(parent=pointsPanel,
+                                                       toolSwitcher=toolSwitcher,
+                                                       dialog=self,
+                                                       vnet_mgr=self.vnet_mgr)
         anSettingsPanel = wx.Panel(parent = pointsPanel)
Modified: grass/trunk/gui/wxpython/vnet/toolbars.py
--- grass/trunk/gui/wxpython/vnet/toolbars.py	2013-08-08 11:26:44 UTC (rev 57435)
+++ grass/trunk/gui/wxpython/vnet/toolbars.py	2013-08-08 13:45:54 UTC (rev 57436)
@@ -29,14 +29,15 @@
     @param parent reference to VNETDialog
-    def __init__(self, parent, dialog, vnet_mgr):
+    def __init__(self, parent, toolSwitcher, dialog, vnet_mgr):
         self.vnet_mgr = vnet_mgr
         self.vnet_pts_mgr = self.vnet_mgr.GetPointsManager()
         self.dialog = dialog
+        self.toolSwitcher.AddToolToGroup('mouseUse', self, self.insertPoint)
         self.Realize()
