[GRASS-SVN] r57448 - grass/trunk/gui/wxpython/vdigit
svn_grass at osgeo.org
Tue Aug 13 02:48:15 PDT 2013
Author: martinl
Date: 2013-08-13 02:48:14 -0700 (Tue, 13 Aug 2013)
New Revision: 57448
grass/trunk/gui/wxpython/vdigit/mapwindow.py
grass/trunk/gui/wxpython/vdigit/toolbars.py
grass/trunk/gui/wxpython/vdigit/wxdigit.py
grass/trunk/gui/wxpython/vdigit/wxdisplay.py
wxGUI/vdigit: allow to open temporary vector map for editing
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-08-11 21:34:24 UTC (rev 57447)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-08-13 09:48:14 UTC (rev 57448)
@@ -65,6 +65,10 @@
return self.digit.GetDisplay()
return None
+ def GetDigit(self):
+ """!Get digit class"""
+ return self.digit
def SetToolbar(self, toolbar):
"""!Set up related toolbar
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py 2013-08-11 21:34:24 UTC (rev 57447)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py 2013-08-13 09:48:14 UTC (rev 57448)
@@ -758,8 +758,8 @@
self.digit = self.MapWindow.digit = self.digitClass(mapwindow = self.MapWindow)
self.mapLayer = mapLayer
- # open vector map
- if self.digit.OpenMap(mapLayer.GetName()) is None:
+ # open vector map (assume that 'hidden' map layer is temporary vector map)
+ if self.digit.OpenMap(mapLayer.GetName(), tmp = mapLayer.IsHidden()) is None:
self.mapLayer = None
self.StopEditing()
return False
Modified: grass/trunk/gui/wxpython/vdigit/wxdigit.py
--- grass/trunk/gui/wxpython/vdigit/wxdigit.py 2013-08-11 21:34:24 UTC (rev 57447)
+++ grass/trunk/gui/wxpython/vdigit/wxdigit.py 2013-08-13 09:48:14 UTC (rev 57448)
@@ -1281,10 +1281,11 @@
"""!Get display driver instance"""
return self._display
- def OpenMap(self, name):
+ def OpenMap(self, name, tmp = False):
"""!Open vector map for editing
@param map name of vector map to be set up
+ @param tmp True to open temporary vector map
Debug.msg (3, "AbstractDigit.SetMapName map=%s" % name)
@@ -1293,7 +1294,7 @@
else:
mapset = grass.gisenv()['MAPSET']
- self.poMapInfo = self._display.OpenMap(str(name), str(mapset), True)
+ self.poMapInfo = self._display.OpenMap(str(name), str(mapset), True, tmp)
if self.poMapInfo:
self.InitCats()
Modified: grass/trunk/gui/wxpython/vdigit/wxdisplay.py
--- grass/trunk/gui/wxpython/vdigit/wxdisplay.py 2013-08-11 21:34:24 UTC (rev 57447)
+++ grass/trunk/gui/wxpython/vdigit/wxdisplay.py 2013-08-13 09:48:14 UTC (rev 57448)
@@ -857,12 +857,14 @@
return ret
- def OpenMap(self, name, mapset, update = True):
+ def OpenMap(self, name, mapset, update = True, tmp = False):
"""!Open vector map by the driver
@param name name of vector map to be open
@param mapset name of mapset where the vector map lives
+ @param update True to open vector map in update mode
@return map_info
@return None on error
@@ -874,16 +876,24 @@
# open existing map
if update:
- ret = Vect_open_update(self.poMapInfo, name, mapset)
- Vect_set_updated(self.poMapInfo, True) # track updated lines
+ if tmp:
+ open_fn = Vect_open_tmp_update
+ else:
+ open_fn = Vect_open_update
else:
- ret = Vect_open_old(self.poMapInfo, name, mapset)
- self.is3D = Vect_is_3d(self.poMapInfo)
+ if tmp:
+ open_fn = Vect_open_tmp_old
+ else:
+ open_fn = Vect_open_old
- if ret == -1: # error
+ ret = open_fn(self.poMapInfo, name, mapset)
+ if ret == -1:
+ # fatal error detected
del self.mapInfo
self.poMapInfo = self.mapInfo = None
elif ret < 2:
+ # map open at level 1, try to build topology
dlg = wx.MessageDialog(parent = self.window,
message = _("Topology for vector map <%s> is not available. "
"Topology is required by digitizer. Do you want to "
@@ -898,8 +908,13 @@
else:
Vect_build(self.poMapInfo)
+ if update:
+ Vect_set_updated(self.poMapInfo, True) # track updated lines at update mode
+ self.is3D = Vect_is_3d(self.poMapInfo)
return self.poMapInfo
def GetMapBoundingBox(self):
"""!Get bounding box of (opened) vector map layer
