[GRASS-SVN] r57450 - grass/trunk/gui/wxpython/iclass
svn_grass at osgeo.org
Tue Aug 13 02:51:47 PDT 2013
Author: martinl
Date: 2013-08-13 02:51:46 -0700 (Tue, 13 Aug 2013)
New Revision: 57450
grass/trunk/gui/wxpython/iclass/digit.py
grass/trunk/gui/wxpython/iclass/frame.py
wxGUI/iclass: use temporary vector map for training areas
Modified: grass/trunk/gui/wxpython/iclass/digit.py
--- grass/trunk/gui/wxpython/iclass/digit.py 2013-08-13 09:49:29 UTC (rev 57449)
+++ grass/trunk/gui/wxpython/iclass/digit.py 2013-08-13 09:51:46 UTC (rev 57450)
@@ -122,6 +122,51 @@
for cat in cats:
Vedit_delete_areas_cat(self.poMapInfo, 1, cat)
+ def CopyMap(self, name, tmp = False):
+ """!Make a copy of open vector map
+ Note: Attributes are not copied
+ @param name name for a copy
+ @param tmp True for temporary map
+ @return number of copied features
+ @return -1 on error
+ if not self.poMapInfo:
+ # nothing to copy
+ return -1
+ poMapInfoNew = pointer(Map_info())
+ if not tmp:
+ open_fn = Vect_open_new
+ else:
+ open_fn = Vect_open_tmp_new
+ is3D = bool(Vect_is_3d(self.poMapInfo))
+ if open_fn(poMapInfoNew, name, is3D) == -1:
+ return -1
+ verbose = G_verbose()
+ G_set_verbose(-1) # be silent
+ if Vect_copy_map_lines(self.poMapInfo, poMapInfoNew) == 1:
+ G_set_verbose(verbose)
+ return -1
+ Vect_build(poMapInfoNew)
+ ret = Vect_get_num_lines(poMapInfoNew)
+ Vect_close(poMapInfoNew)
+ return ret
+ def GetMapInfo(self):
+ """!Returns Map_info() struct of open vector map"""
+ return self.poMapInfo
class IClassDisplayDriver(DisplayDriver):
"""! Class similar to DisplayDriver but specialized for wxIClass
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2013-08-13 09:49:29 UTC (rev 57449)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2013-08-13 09:51:46 UTC (rev 57450)
@@ -196,7 +196,7 @@
self.SendSizeEvent()
def OnCloseWindow(self, event):
- self.GetFirstWindow().digit.GetDisplay().CloseMap()
+ self.GetFirstWindow().GetDigit().CloseMap()
self.Destroy()
def __del__(self):
@@ -214,18 +214,25 @@
"""!Show help page"""
self._giface.Help(entry = 'wxGUI.iclass')
+ def _getTempVectorName(self):
+ """!Return new name for temporary vector map (training areas)"""
+ vectorPath = grass.tempfile(create = False)
+ return 'trAreas' + os.path.basename(vectorPath).replace('.','')
def CreateTempVector(self):
"""!Create temporary vector map for training areas"""
- vectorPath = grass.tempfile(create = False)
- vectorName = 'trAreas' + os.path.basename(vectorPath).replace('.','')
+ vectorName = self._getTempVectorName()
+ env = os.environ.copy()
+ env['GRASS_VECTOR_TEMPORARY'] = '1' # create temporary map
cmd = ('v.edit', {'tool': 'create',
'map': vectorName})
ret = RunCommand(prog = cmd[0],
- parent = self,
- overwrite = True,
+ parent = self, env = env,
**cmd[1])
if ret != 0:
return False
@@ -539,38 +546,31 @@
wx.BeginBusyCursor()
wx.Yield()
- mapLayer = self.toolbars['vdigit'].mapLayer
- # set mapLayer temporarily to None
- # to avoid 'save changes' code in vdigit.toolbars
- self.toolbars['vdigit'].mapLayer = None
+ # close, build, copy and open again the temporary vector
+ digitClass = self.GetFirstWindow().GetDigit()
- ret = self.toolbars['vdigit'].StopEditing()
- if not ret:
- wx.EndBusyCursor()
- return False
- # check if attribute table really exists (fix broken connections)
- for layer in grass.vector_db(vector):
- if 0 != RunCommand('v.db.select', flags = 'c', map = vector, where = "0 = 1"):
- GWarning(_("Vector map <%s>: no attribute table found") % vector,
- parent = self)
- RunCommand('v.db.connect', flags = 'd', map = vector, layer = layer,
- quiet = True)
+ # open vector map to be imported
+ if digitClass.OpenMap(vector) is None:
+ GError(parent = self, message = _("Unable to open vector map <%s>") % vector)
+ return
- if 0 != RunCommand('g.copy',
- vect = [vector, self.trainingAreaVector],
- overwrite = True, quiet = True,
- parent = self):
- return False
- ret = self.toolbars['vdigit'].StartEditing(mapLayer)
- if not ret:
- return False
- self.poMapInfo = self.GetFirstWindow().digit.GetDisplay().poMapInfo
+ # copy features to the temporary map
+ vname = self._getTempVectorName()
+ os.environ['GRASS_VECTOR_TEMPORARY'] = '1' # avoid deleting temporary map
+ if digitClass.CopyMap(vname, tmp = True) == -1:
+ GError(parent = self, message = _("Unable to copy vector features from <%s>") % vector)
+ return
+ del os.environ['GRASS_VECTOR_TEMPORARY']
+ # close map
+ digitClass.CloseMap()
+ # open temporary map (copy of imported map)
+ self.poMapInfo = digitClass.OpenMap(vname, tmp = True)
+ if self.poMapInfo is None:
+ GError(parent = self, message = _("Unable to open temporary vector map"))
+ return
# remove temporary rasters
for cat in self.stats_data.GetCategories():
self.RemoveTempRaster(self.stats_data.GetStatistics(cat).rasterName)
@@ -684,26 +684,12 @@
wx.Yield()
- displayDriver = self.GetFirstWindow().digit.GetDisplay()
- displayDriver.CloseMap()
if '@' in vectorName:
vectorName = vectorName.split('@')[0]
- vect = [self.trainingAreaVector, vectorName],
- overwrite = True, quiet = True, parent = self):
+ if digitClass.CopyMap(vectorName) < 0:
return False
- # remove connection if exists
- dbinfo = grass.vector_db(vectorName)
- if dbinfo:
- for layer in dbinfo.keys():
- RunCommand('v.db.connect', flags = 'd', map = vectorName, layer = layer)
- mapset = grass.gisenv()['MAPSET']
- self.poMapInfo = displayDriver.OpenMap(name = self.trainingAreaVector, mapset = mapset)
if not withTable:
wx.EndBusyCursor()
return False
@@ -799,17 +785,17 @@
@param cats list of categories to be deleted
- self.firstMapWindow.digit.DeleteAreasByCat(cats)
+ self.firstMapWindow.GetDigit().DeleteAreasByCat(cats)
self.firstMapWindow.UpdateMap(render=False, renderVector=True)
def HighlightCategory(self, cats):
"""!Highlight araes given by category"""
- self.firstMapWindow.digit.GetDisplay().SetSelected(cats, layer = 1)
+ self.firstMapWindow.GetDigit().GetDisplay().SetSelected(cats, layer = 1)
def ZoomToAreasByCat(self, cat):
"""!Zoom to areas given by category"""
- n, s, w, e = self.GetFirstWindow().digit.GetDisplay().GetRegionSelected()
+ n, s, w, e = self.GetFirstWindow().GetDigit().GetDisplay().GetRegionSelected()
self.GetFirstMap().GetRegion(n = n, s = s, w = w, e = e, update = True)
self.GetFirstMap().AdjustRegion()
self.GetFirstMap().AlignExtentFromDisplay()
@@ -867,13 +853,14 @@
else:
GMessage(parent = self, message = _("Failed to create temporary vector map."))
return
+ # use 'hidden' for temporary maps (TODO: do it better)
mapLayer = self.GetFirstMap().AddLayer(ltype = 'vector',
command = ['d.vect', 'map=%s' % vname],
- name = vname, active = False)
+ name = vname, active = False, hidden = True)
+ self.poMapInfo = self.GetFirstWindow().GetDigit().GetMapInfo()
self.Render(self.GetFirstWindow())
def OnRunAnalysis(self, event):
@@ -1134,7 +1121,7 @@
self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface, iclass_mapwin = self.GetFirstWindow())
scatt_mgr = self.dialogs['scatt_plot'].GetScattMgr()
- scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().digit)
+ scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().GetDigit())
self.dialogs['scatt_plot'].CenterOnScreen()
self.dialogs['scatt_plot'].Show()
