[GRASS-SVN] r57466 - grass/trunk/temporal/t.rast.import
Sat Aug 17 15:28:01 PDT 2013
Author: huhabla
Date: 2013-08-17 15:28:01 -0700 (Sat, 17 Aug 2013)
New Revision: 57466
Added:
   grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh
Test the import of a space time raster dataset into a new location.
Added: grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh
--- grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh	                        (rev 0)
+++ grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh	2013-08-17 22:28:01 UTC (rev 57466)
@@ -0,0 +1,69 @@
+#!/bin/sh
+# Test the import of space time raster datasets creating new locations
+# We need to set a specific region in the
+# @preprocess step of this test. We generate
+# raster with r.mapcalc and create a space time raster datasets
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+mkdir test
+r.mapcalc --o expr="prec_1 = rand(0, 550)"
+r.mapcalc --o expr="prec_2 = rand(0, 450)"
+r.mapcalc --o expr="prec_3 = rand(0, 320)"
+r.mapcalc --o expr="prec_4 = rand(0, 510)"
+r.mapcalc --o expr="prec_5 = rand(0, 300)"
+r.mapcalc --o expr="prec_6 = rand(0, 650)"
+n1=`g.tempfile pid=1 -d`
+cat > "${n1}" << EOF
+prec_1|2001-01-01|2001-07-01
+prec_2|2001-02-01|2001-04-01
+prec_3|2001-03-01|2001-04-01
+prec_4|2001-04-01|2001-06-01
+prec_5|2001-05-01|2001-06-01
+prec_6|2001-06-01|2001-07-01
+EOF
+eval `g.gisenv`
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test with input files" descr="A test with input files"
+# The first @test
+t.register -i type=rast input=precip_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.rast.export input=precip_abs1 output=strds_export.tar.bz2 compression=bzip2 format=GTiff workdir=test
+t.rast.export input=precip_abs1 output=strds_export_pack.tar.gz compression=gzip format=pack workdir=test
+g.proj -p
+# Import the data into a new location
+t.rast.import --o location=new_test_1 input=strds_export.tar.bz2 output=precip_abs1 extrdir=test\
+              title="A test" description="Description of a test"
+ls -la $GISDBASE/new_test_1/PERMANENT
+t.rast.import --o location=new_test_2 input=strds_export.tar.bz2 output=precip_abs1 extrdir=test\
+          -l  title="A test" description="Description of a test"
+ls -la $GISDBASE/new_test_2/PERMANENT
+t.rast.import --o location=new_test_3 input=strds_export.tar.bz2 output=precip_abs1 extrdir=test\
+          -c  title="A test" description="Description of a test"
+ls -la $GISDBASE/new_test_3/PERMANENT
+t.rast.import --o location=new_test_4 input=strds_export_pack.tar.gz output=precip_abs1 extrdir=test\
+ls -la $GISDBASE/new_test_4/PERMANENT
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.remove type=strds input=precip_abs1
+g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+rm -rf test
+rm strds_export.tar.bz2
+rm strds_export_pack.tar.gz
+# Remove the newly created locations
+rm -rf $GISDBASE/new_test_1
+rm -rf $GISDBASE/new_test_2
+rm -rf $GISDBASE/new_test_3
+rm -rf $GISDBASE/new_test_4
Property changes on: grass/trunk/temporal/t.rast.import/test.t.rast.import_locations.sh
___________________________________________________________________
Added: svn:executable
