[GRASS-SVN] r57486 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Thu Aug 22 03:40:06 PDT 2013
Author: huhabla
Date: 2013-08-22 03:40:06 -0700 (Thu, 22 Aug 2013)
New Revision: 57486
grass/trunk/lib/python/temporal/datetime_math.py
grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
New relative time computation approach from time delta to minimize rounding errors
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py 2013-08-22 10:14:59 UTC (rev 57485)
+++ grass/trunk/lib/python/temporal/datetime_math.py 2013-08-22 10:40:06 UTC (rev 57486)
@@ -44,22 +44,45 @@
+def relative_time_to_time_delta_seconds(value):
+ """!Convert the double value representing seconds
+ into a timedelta object.
+ days = (value / 86400)
+ seconds = int(value % 86400)
+ return timedelta(days, seconds)
+def time_delta_to_relative_time_seconds(delta):
+ """!Convert the time delta into a
+ double value, representing seconds.
+ return float(delta.days * DAY_IN_SECONDS) + float(delta.seconds)
def decrement_datetime_by_string(mydate, increment, mult=1):
"""!Return a new datetime object decremented with the provided
relative dates specified as string.
Additional a multiplier can be specified to multiply the increment
before adding to the provided datetime object.
Usage:
@code
>>> dt = datetime(2001, 1, 1, 0, 0, 0)
>>> string = "31 days"
>>> decrement_datetime_by_string(dt, string)
datetime.datetime(2000, 12, 1, 0, 0)
>>> string = "1 month"
@@ -69,7 +92,7 @@
>>> string = "2 month"
datetime.datetime(2000, 11, 1, 0, 0)
>>> string = "24 months"
@@ -79,24 +102,24 @@
>>> string = "48 months"
datetime.datetime(1997, 1, 1, 0, 0)
>>> dt = datetime(2001, 6, 1, 0, 0, 0)
>>> string = "5 months"
datetime.datetime(2001, 1, 1, 0, 0)
>>> string = "7 months"
>>> string = "1 year"
datetime.datetime(2000, 1, 1, 0, 0)
@endcode
@param mydate A datetime object to incremented
@param increment A string providing increment information:
The string may include comma separated values of type seconds,
@@ -116,11 +139,11 @@
Usage:
@code
>>> dt = datetime(2001, 9, 1, 0, 0, 0)
>>> string = "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
>>> increment_datetime_by_string(dt, string)
@@ -135,39 +158,39 @@
>>> string = "13 months"
datetime.datetime(2002, 12, 1, 0, 0)
>>> string = "72 months"
datetime.datetime(2007, 1, 1, 0, 0)
>>> string = "5 minutes"
datetime.datetime(2001, 1, 1, 0, 5)
>>> string = "49 hours"
datetime.datetime(2001, 1, 3, 1, 0)
>>> string = "3600 seconds"
datetime.datetime(2001, 1, 1, 1, 0)
>>> string = "30 days"
datetime.datetime(2001, 1, 31, 0, 0)
@endcode
@@ -187,7 +210,7 @@
@@ -196,14 +219,14 @@
with "60 seconds, 4 minutes, 12 hours, 10 days, 1 weeks, 5 months, 1 years"
will result in the datetime 2003-02-18 12:05:00
@param mult A multiplier, default is 1
- @param sign Choose 1 for positive sign (incrementing) or -1 for negative
- sign (decrementing).
+ @param sign Choose 1 for positive sign (incrementing) or -1 for negative
+ sign (decrementing).
@return The new datetime object or none in case of an error
sign = int(sign)
if sign != 1 and sign != -1:
return None
if increment:
seconds = 0
@@ -248,9 +271,9 @@
-def modify_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0,
+def modify_datetime(mydate, years=0, months=0, weeks=0, days=0, hours=0,
minutes=0, seconds=0):
- """!Return a new datetime object incremented with the provided
+ """!Return a new datetime object incremented with the provided
relative dates and times"""
tdelta_seconds = timedelta(seconds=seconds)
@@ -317,7 +340,7 @@
# Compute the number of days
dt1 = dt1.replace(year=mydate.year + int(years))
tdelta_years = dt1 - mydate
return mydate + tdelta_seconds + tdelta_minutes + tdelta_hours + \
tdelta_days + tdelta_weeks + tdelta_months + tdelta_years
@@ -325,52 +348,52 @@
def adjust_datetime_to_granularity(mydate, granularity):
- """!Modify the datetime object to fit the given granularity
+ """!Modify the datetime object to fit the given granularity
- Years will start at the first of Januar
- Months will start at the first day of the month
- Days will start at the first Hour of the day
- Hours will start at the first minute of an hour
- Minutes will start at the first second of a minute
Usage:
@code
>>> dt = datetime(2001, 8, 8, 12,30,30)
>>> adjust_datetime_to_granularity(dt, "5 seconds")
datetime.datetime(2001, 8, 8, 12, 30, 30)
>>> adjust_datetime_to_granularity(dt, "20 minutes")
datetime.datetime(2001, 8, 8, 12, 30)
>>> adjust_datetime_to_granularity(dt, "3 hours")
datetime.datetime(2001, 8, 8, 12, 0)
>>> adjust_datetime_to_granularity(dt, "5 days")
datetime.datetime(2001, 8, 8, 0, 0)
>>> adjust_datetime_to_granularity(dt, "2 weeks")
datetime.datetime(2001, 8, 6, 0, 0)
>>> adjust_datetime_to_granularity(dt, "6 months")
datetime.datetime(2001, 8, 1, 0, 0)
>>> adjust_datetime_to_granularity(dt, "2 years")
>>> adjust_datetime_to_granularity(dt, "2 years, 3 months, 5 days, 3 hours, 3 minutes, 2 seconds")
>>> adjust_datetime_to_granularity(dt, "3 months, 5 days, 3 minutes")
>>> adjust_datetime_to_granularity(dt, "3 weeks, 5 days")
@endcode
@@ -456,135 +479,135 @@
def compute_datetime_delta(start, end):
- """!Return a dictionary with the accumulated delta in year, month, day,
+ """!Return a dictionary with the accumulated delta in year, month, day,
hour, minute and second
Usage:
@code
>>> start = datetime(2001, 1, 1, 00,00,00)
>>> end = datetime(2001, 1, 1, 00,00,00)
{'hour': 0, 'month': 0, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
>>> start = datetime(2001, 1, 1, 00,00,14)
>>> end = datetime(2001, 1, 1, 00,00,44)
{'hour': 0, 'month': 0, 'second': 30, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
>>> start = datetime(2001, 1, 1, 00,00,44)
>>> end = datetime(2001, 1, 1, 00,01,14)
{'hour': 0, 'month': 0, 'second': 30, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 1}
>>> start = datetime(2001, 1, 1, 00,00,30)
>>> end = datetime(2001, 1, 1, 00,05,30)
{'hour': 0, 'month': 0, 'second': 300, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 5}
>>> end = datetime(2001, 1, 1, 00,01,00)
{'hour': 0, 'month': 0, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 1}
>>> start = datetime(2011,10,31, 00,45,00)
>>> end = datetime(2011,10,31, 01,45,00)
{'hour': 1, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 60}
>>> end = datetime(2011,10,31, 01,15,00)
{'hour': 1, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 30}
>>> end = datetime(2011,10,31, 12,15,00)
{'hour': 12, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 690}
>>> start = datetime(2011,10,31, 00,00,00)
>>> end = datetime(2011,10,31, 01,00,00)
{'hour': 1, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
>>> end = datetime(2011,11,01, 01,00,00)
{'hour': 25, 'second': 0, 'max_days': 1, 'year': 0, 'day': 1, 'minute': 0}
>>> start = datetime(2011,10,31, 12,00,00)
>>> end = datetime(2011,11,01, 06,00,00)
{'hour': 18, 'second': 0, 'max_days': 0, 'year': 0, 'day': 0, 'minute': 0}
>>> start = datetime(2011,11,01, 00,00,00)
>>> end = datetime(2011,12,01, 01,00,00)
{'hour': 721, 'month': 1, 'second': 0, 'max_days': 30, 'year': 0, 'day': 0, 'minute': 0}
>>> end = datetime(2011,11,05, 00,00,00)
{'hour': 0, 'second': 0, 'max_days': 4, 'year': 0, 'day': 4, 'minute': 0}
>>> start = datetime(2011,10,06, 00,00,00)
{'hour': 0, 'second': 0, 'max_days': 30, 'year': 0, 'day': 30, 'minute': 0}
>>> start = datetime(2011,12,02, 00,00,00)
>>> end = datetime(2012,01,01, 00,00,00)
{'hour': 0, 'second': 0, 'max_days': 30, 'year': 1, 'day': 30, 'minute': 0}
>>> start = datetime(2011,01,01, 00,00,00)
>>> end = datetime(2011,02,01, 00,00,00)
{'hour': 0, 'month': 1, 'second': 0, 'max_days': 31, 'year': 0, 'day': 0, 'minute': 0}
>>> start = datetime(2011,12,01, 00,00,00)
{'hour': 0, 'month': 1, 'second': 0, 'max_days': 31, 'year': 1, 'day': 0, 'minute': 0}
>>> end = datetime(2012,06,01, 00,00,00)
{'hour': 0, 'month': 6, 'second': 0, 'max_days': 183, 'year': 1, 'day': 0, 'minute': 0}
>>> start = datetime(2011,06,01, 00,00,00)
>>> end = datetime(2021,06,01, 00,00,00)
{'hour': 0, 'month': 120, 'second': 0, 'max_days': 3653, 'year': 10, 'day': 0, 'minute': 0}
>>> end = datetime(2012,06,01, 12,00,00)
{'hour': 8796, 'month': 12, 'second': 0, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 0}
>>> end = datetime(2012,06,01, 12,30,00)
{'hour': 8796, 'month': 12, 'second': 0, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 527790}
>>> end = datetime(2012,06,01, 12,00,05)
{'hour': 8796, 'month': 12, 'second': 31665605, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 0}
>>> end = datetime(2012,06,01, 00,30,00)
{'hour': 0, 'month': 12, 'second': 0, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 527070}
>>> end = datetime(2012,06,01, 00,00,05)
{'hour': 0, 'month': 12, 'second': 31622405, 'max_days': 366, 'year': 1, 'day': 0, 'minute': 0}
@endcode
@return A dictionary with year, month, day, hour, minute and second as keys()
comp = {}
@@ -672,14 +695,14 @@
def string_to_datetime(time_string):
- """!Convert a string into a datetime object
- Supported ISO string formats are:
+ """!Convert a string into a datetime object
+ Supported ISO string formats are:
- YYYY-mm-dd
- YYYY-mm-dd HH:MM:SS
Time zones are not supported
@param time_string The time string to convert
@return datetime object or None in case of an error
@@ -695,12 +718,12 @@
core.error("Time zones are not supported "
"in the temporal database")
return None
if time_string.find(":") > 0:
time_format = "%Y-%m-%d %H:%M:%S"
else:
time_format = "%Y-%m-%d"
try:
return datetime.strptime(time_string, time_format)
except:
@@ -720,7 +743,7 @@
# Check for time zone info in the datetime object
if dt.tzinfo is not None:
- string = "%.2i %s %.2i %.2i:%.2i:%.2i %+.4i" % (dt.day,
+ string = "%.2i %s %.2i %.2i:%.2i:%.2i %+.4i" % (dt.day,
month_names[dt.month], dt.year,
dt.hour, dt.minute, dt.second, dt.tzinfo._offset.seconds / 60)
else:
Modified: grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
--- grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2013-08-22 10:14:59 UTC (rev 57485)
+++ grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2013-08-22 10:40:06 UTC (rev 57486)
@@ -277,6 +277,49 @@
('STARTS', (datetime.datetime(2003, 1, 1, 0, 0), datetime.datetime(2006, 1, 1, 0, 0)))
('FOLLOWS', (datetime.datetime(2000, 1, 1, 0, 0), datetime.datetime(2003, 1, 1, 0, 0)))
+ >>> mapsA = []
+ >>> mapsB = []
+ >>> for i in range(4):
+ ... idA = "a%i at B"%(i)
+ ... mapA = tgis.RasterDataset(idA)
+ ... idB = "b%i at B"%(i)
+ ... mapB = tgis.RasterDataset(idB)
+ ... start = datetime.datetime(2000, 1, 1, 0, 0, i)
+ ... end = datetime.datetime(2000, 1, 1, 0, 0, i + 2)
+ ... check = mapA.set_absolute_time(start, end)
+ ... start = datetime.datetime(2000, 1, 1, 0, 0, i + 1)
+ ... end = datetime.datetime(2000, 1, 1, 0, 0, i + 3)
+ ... check = mapB.set_absolute_time(start, end)
+ ... mapsA.append(mapA)
+ ... mapsB.append(mapB)
+ >>> # Build the topology between the two map lists
+ >>> tb = SpatioTemporalTopologyBuilder()
+ >>> tb.build(mapsA, mapsB, None)
+ >>> # Check relations of mapsA
+ >>> for map in mapsA:
+ ... print(map.get_temporal_extent_as_tuple())
+ ... m = map.get_temporal_relations()
+ ... for key in m.keys():
+ ... if key not in ["NEXT", "PREV"]:
+ ... print(key, m[key][0].get_temporal_extent_as_tuple())
+ (datetime.datetime(2000, 1, 1, 0, 0), datetime.datetime(2000, 1, 1, 0, 0, 2))
+ ('OVERLAPS', (datetime.datetime(2000, 1, 1, 0, 0, 1), datetime.datetime(2000, 1, 1, 0, 0, 3)))
+ ('PRECEDES', (datetime.datetime(2000, 1, 1, 0, 0, 2), datetime.datetime(2000, 1, 1, 0, 0, 4)))
+ (datetime.datetime(2000, 1, 1, 0, 0, 1), datetime.datetime(2000, 1, 1, 0, 0, 3))
+ ('OVERLAPS', (datetime.datetime(2000, 1, 1, 0, 0, 2), datetime.datetime(2000, 1, 1, 0, 0, 4)))
+ ('PRECEDES', (datetime.datetime(2000, 1, 1, 0, 0, 3), datetime.datetime(2000, 1, 1, 0, 0, 5)))
+ ('EQUAL', (datetime.datetime(2000, 1, 1, 0, 0, 1), datetime.datetime(2000, 1, 1, 0, 0, 3)))
+ (datetime.datetime(2000, 1, 1, 0, 0, 2), datetime.datetime(2000, 1, 1, 0, 0, 4))
+ ('OVERLAPS', (datetime.datetime(2000, 1, 1, 0, 0, 3), datetime.datetime(2000, 1, 1, 0, 0, 5)))
+ ('OVERLAPPED', (datetime.datetime(2000, 1, 1, 0, 0, 1), datetime.datetime(2000, 1, 1, 0, 0, 3)))
+ ('PRECEDES', (datetime.datetime(2000, 1, 1, 0, 0, 4), datetime.datetime(2000, 1, 1, 0, 0, 6)))
+ ('EQUAL', (datetime.datetime(2000, 1, 1, 0, 0, 2), datetime.datetime(2000, 1, 1, 0, 0, 4)))
+ (datetime.datetime(2000, 1, 1, 0, 0, 3), datetime.datetime(2000, 1, 1, 0, 0, 5))
+ ('OVERLAPS', (datetime.datetime(2000, 1, 1, 0, 0, 4), datetime.datetime(2000, 1, 1, 0, 0, 6)))
+ ('FOLLOWS', (datetime.datetime(2000, 1, 1, 0, 0, 1), datetime.datetime(2000, 1, 1, 0, 0, 3)))
+ ('OVERLAPPED', (datetime.datetime(2000, 1, 1, 0, 0, 2), datetime.datetime(2000, 1, 1, 0, 0, 4)))
+ ('EQUAL', (datetime.datetime(2000, 1, 1, 0, 0, 3), datetime.datetime(2000, 1, 1, 0, 0, 5)))
@endcode
@@ -383,8 +426,8 @@
end = start
if map_.is_time_absolute():
- start = time_delta_to_relative_time(start - self._timeref)
- end = time_delta_to_relative_time(end - self._timeref)
+ start = time_delta_to_relative_time_seconds(start - self._timeref)
+ end = time_delta_to_relative_time_seconds(end - self._timeref)
if spatial is None:
vector.RTreeSetRect1D(rect, tree, float(start), float(end))
