[GRASS-SVN] r57492 - sandbox/turek/scatter_plot
Fri Aug 23 11:50:36 PDT 2013
Author: turek
Date: 2013-08-23 11:50:14 -0700 (Fri, 23 Aug 2013)
New Revision: 57492
   sandbox/turek/scatter_plot/testing_patch.diff
scatter plot: selection of intervals by polygon and confidence ellipses
Modified: sandbox/turek/scatter_plot/testing_patch.diff
--- sandbox/turek/scatter_plot/testing_patch.diff	2013-08-23 17:02:04 UTC (rev 57491)
+++ sandbox/turek/scatter_plot/testing_patch.diff	2013-08-23 18:50:14 UTC (rev 57492)
@@ -1,6 +1,1196 @@
+Index: lib/imagery/scatt.c
+--- lib/imagery/scatt.c	(revision 0)
++++ lib/imagery/scatt.c	(working copy)
+@@ -0,0 +1,746 @@
++   \file lib/imagery/scatt.c
++   \brief Imagery library - functions for wx Scatter Plot Tool.
++   Low level functions used by wx Scatter Plot Tool.
++   Copyright (C) 2013 by the GRASS Development Team
++   This program is free software under the GNU General Public License
++   (>=v2).  Read the file COPYING that comes with GRASS for details.
++   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
++#include <grass/raster.h>
++#include <grass/imagery.h>
++#include <grass/gis.h>
++#include <grass/glocale.h>
++#include <stdio.h>
++#include <stdlib.h>
++#include <math.h>
++#include <string.h>
++struct rast_row
++    CELL * row;
++    char * null_row;
++    struct Range rast_range; /*Range of whole raster.*/
++   \brief Create pgm header.
++   Scatter plot internally generates pgm files. These pgms have header in format created by this function.
++   \param region region to be pgm header generated for
++   \param [out] header header of pgm file
++static int get_cat_rast_header(struct Cell_head * region, char * header){
++    return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
++   \brief Create category raster conditions file.
++   \param cat_rast_region region to be file generated for
++   \param cat_rast path of generated category raster file
++int I_create_cat_rast(struct Cell_head * cat_rast_region,  const char * cat_rast)
++    FILE * f_cat_rast;
++    char cat_rast_header[1024];//TODO magic number
++    int i_row, i_col;
++    int head_nchars;
++    unsigned char * row_data;
++    f_cat_rast = fopen(cat_rast, "wb");
++    if(!f_cat_rast) {
++        G_warning("Unable to create category raster condition file <%s>.", cat_rast);
++        return -1;
++    head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
++    fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
++    if (ferror(f_cat_rast)){
++        fclose(f_cat_rast);
++        G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
++        return -1;
++    row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
++    for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
++        row_data[i_col] = 0 & 255;
++    for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
++        fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
++            G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
++            return -1;
++    return 0;
++static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
++    G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
++               intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
++   \brief Find intersection region of two regions.
++   \param A pointer to intersected region
++   \param B pointer to intersected region
++   \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
++   \return  0 if interection exists
++   \return -1 if regions does not intersect
++static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
++    if(B->north < A->south) return -1;
++    else if(B->north > A->north) intersec->north = A->north;
++    else intersec->north = B->north;
++    if(B->south > A->north) return -1;
++    else if(B->south < A->south) intersec->south = A->south;
++    else intersec->south = B->south;
++    if(B->east < A->west) return -1;
++    else if(B->east > A->east) intersec->east = A->east;
++    else intersec->east = B->east;
++    if(B->west > A->east) return -1;
++    else if(B->west < A->west) intersec->west = A->west;
++    else intersec->west = B->west;
++    if(intersec->north == intersec->south) return -1;
++    if(intersec->east == intersec->west) return -1;
++    return 0;
++   \brief Get rows and cols numbers, which defines intersection of the regions.
++   \param B pointer to intersected region (A and B must have same resolution)
++   \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
++   \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
++   \return -1 if regions do not intersect
++   \return -2 resolution of regions is not same
++static int get_rows_and_cols_bounds(struct Cell_head * A,  struct Cell_head * B, struct Cell_head * A_bounds,  struct Cell_head * B_bounds)
++    float ns_res, ew_res;
++    struct Cell_head intersec;
++    /* TODO is it right check? */
++    if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
++        G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
++        return -2;
++    if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
++        G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
++        return -2;
++    ns_res = A->ns_res;
++    ew_res = A->ew_res;
++    if(regions_intersecion(A, B, &intersec) == -1)
++        return -1;
++    A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
++    A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
++    A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
++    A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
++    B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
++    B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
++    B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
++    B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
++    return 0;
++   \brief Insert raster map patch into pgm file.
++   \param patch_rast name of raster map
++   \param cat_rast_region region of category raster file
++   \param cat_rast path to category raster file
++   \return  0 on success
++   \return -1 on failure
++int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region,  const char * cat_rast)
++    struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
++    int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
++    int head_nchars, ret;
++    int fd_patch_rast, init_shift, step_shift;
++    unsigned char * patch_data;
++    char * null_chunk_row;
++    const char *mapset;
++    struct Cell_head patch_lines, cat_rast_lines;
++    f_cat_rast = fopen(cat_rast, "rb+");
++        G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
++        return -1;
++    if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
++        G_warning(_("Unable to find patch raster <%s>."), patch_rast);
++        return -1;
++    Rast_get_cellhd(patch_rast, mapset, &patch_region);
++    Rast_set_window(&patch_region);
++    if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
++        return -1;
++    ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
++    if(ret == -2) {
++        G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
++        Rast_close(fd_patch_rast);
++        return -1;
++    else if (ret == -1){
++        return 0;
++    ncols = cat_rast_bounds.east - cat_rast_bounds.west;
++    nrows = cat_rast_bounds.south - cat_rast_bounds.north;
++    patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
++    init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
++    if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
++        G_warning(_("Corrupted  category raster conditions file <%s> (fseek failed)"), cat_rast);
++        G_free(null_chunk_row);
++        return -1;
++    step_shift = cat_rast_region->cols - ncols;
++    null_chunk_row =  Rast_allocate_null_buf();
++    for(i_row = 0; i_row < nrows; i_row++) {
++        Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
++        for(i_col = 0; i_col < ncols; i_col++) {
++            patch_col = patch_bounds.west + i_col;
++            if(null_chunk_row[patch_col] != 1)
++                patch_data[i_col] = 1 & 255;
++            else {
++                patch_data[i_col] = 0 & 255;
++        fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
++            G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
++            return -1;
++        if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
++            return -1;
++    return 0;
++   \brief Updates scatter plots data in category by pixels which meets category conditions.
++   \param bands_rows data represents data describig one row from raster band
++   \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
++   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
++static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
++    int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
++    CELL * b_1_row;
++    CELL * b_2_row;
++    char * b_1_null_row,* b_2_null_row;
++    struct rast_row b_1_rast_row, b_2_rast_row;
++    struct Range b_1_range, b_2_range;
++    int b_1_range_size;
++    int row_size = Rast_window_cols();
++    int * scatts_bands = scatts->scatts_bands;
++    for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
++        b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
++        b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
++        b_1_row = b_1_rast_row.row;
++        b_2_row = b_2_rast_row.row;
++        b_1_null_row =  b_1_rast_row.null_row;
++        b_2_null_row =  b_2_rast_row.null_row;
++        b_1_range = b_1_rast_row.rast_range;
++        b_2_range = b_2_rast_row.rast_range;
++        b_1_range_size = b_1_range.max - b_1_range.min + 1;
++        max_arr_idx = (b_1_range.max -  b_1_range.min + 1) * (b_2_range.max -  b_2_range.min + 1);
++        for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
++            /* pixel does not belongs to scatter plot or has null value in one of the bands */
++            if(!belongs_pix[i_chunk_rows_pix] ||
++                b_1_null_row[i_chunk_rows_pix] == 1 ||
++                b_2_null_row[i_chunk_rows_pix] == 1)
++                continue;
++            /* index in scatter plot array */
++            array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
++            if(array_idx < 0 || array_idx >= max_arr_idx) {
++                        G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
++                continue;
++            /* increment scatter plot value */
++            ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
++   \brief Computes scatter plots data from chunk_rows.
++   \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
++   \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
++   \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
++   \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
++   \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
++   \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
++   \param region analysis region
++static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
++                                                FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
++                                                struct scCats * scatts, int * fd_cats_rasts)
++    int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
++    int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
++    CELL * cat_rast_row;
++    struct scScatts * scatts_conds;
++    struct scScatts * scatts_scatt_plts;
++    struct scdScattData * conds;
++    int * scatts_bands;
++    struct scdScattData ** scatts_arr;
++    CELL * b_1_row;
++    CELL * b_2_row;
++    unsigned char * i_scatt_conds;
++    unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
++    unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
++    cat_rast_row =  Rast_allocate_c_buf();
++    for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
++        scatts_conds = scatt_conds->cats_arr[i_cat];
++        cat_id = scatt_conds->cats_ids[i_cat];
++        scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
++        if(scatt_plts_cat_idx < 0)
++            continue;
++        scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
++        G_zero(belongs_pix, row_size * sizeof(unsigned short));
++        /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
++        if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
++            for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
++                /* all pixels belongs */
++                for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
++                    belongs_pix[i_rows_pix] = 1;
++        /* compute belonging pixels for defined conditions */
++        else
++            scatts_bands = scatts_conds->scatts_bands;
++            /* check conditions from category raster condtitions file */
++            if(f_cats_rasts_conds[i_cat]) {
++                n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
++                if (ferror(f_cats_rasts_conds[i_cat]))
++                    G_free(rast_pixs);
++                    G_free(belongs_pix);
++                    G_warning(_("Unable to read from category raster condtition file."));
++                    return -1;
++                if (n_pixs != n_pixs) {
++                    G_warning(_("Invalid size of category raster conditions file."));
++                    return -1;
++                    if(rast_pixs[i_rows_pix] != 0 & 255)
++            /* check condtions defined in scatter plots*/
++            for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
++                i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
++                    /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
++                    if(belongs_pix[i_rows_pix] ||
++                       b_1_null_row[i_rows_pix] == 1 ||
++                       b_2_null_row[i_rows_pix] == 1)
++                        continue;
++                    array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
++                        continue;
++                    /* pixels meets condtion defined in scatter plot */
++                    if(i_scatt_conds[array_idx])
++        /* update category raster with belonging pixels */
++        if(fd_cats_rasts[i_cat] >= 0) {
++            Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
++                if(belongs_pix[i_rows_pix])
++                    cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
++            Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
++        /* update scatter plots with belonging pixels */
++        update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
++    G_free(cat_rast_row);
++    return 0;
++   \brief Get list if bands needed to be opened for analysis from scCats struct.
++static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
++    // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
++    int i_cat, i_scatt, cat_id;
++    for(i_cat = 0;  i_cat < cats->n_a_cats; i_cat++)
++        for(i_scatt = 0;  i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
++            G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
++            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
++            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
++    return;
++   \brief Helper function for clean up.
++static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
++                                     int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
++    int i, band_id;
++    for(i = 0; i < n_a_bands; i++)
++        band_id = bands_ids[i];
++        if(band_id >= 0) {
++            Rast_close(fd_bands[i]);
++            G_free(bands_rows[band_id].row);
++            G_free(bands_rows[band_id].null_row);
++    if(f_cats_rasts_conds)
++        for(i = 0; i < n_a_cats; i++)
++            if(f_cats_rasts_conds[i])
++                fclose(f_cats_rasts_conds[i]);
++    if(fd_cats_rasts)
++            if(fd_cats_rasts[i] >= 0)
++                Rast_close(fd_cats_rasts[i]);
++   \brief Compute scatter plots data.
++    If category has not defined no category raster condition file and no scatter plot with consdtion,
++    default scatter plot is computed.
++   \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
++   \param region function calls Rast_set_window for this region
++   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
++   \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
++   \param cats_rasts_conds index in array represents corresponding category id
++   \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
++   \param bands names of analyzed bands, order of bands is defined by their id
++   \param n_bands number of bands
++   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++   \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
++int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
++                     const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
++    char header[1024];
++    int fd_cats_rasts[scatt_conds->n_a_cats];
++    FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
++    struct rast_row bands_rows[n_bands];
++    RASTER_MAP_TYPE data_type;
++    int nrows, i_band, n_a_bands, band_id,
++        i, i_row, head_nchars, i_cat, id_cat;
++    int fd_bands[n_bands];
++    int bands_ids[n_bands];
++    int b_needed_bands[n_bands];
++    Rast_set_window(region);
++    for(i_band = 0; i_band < n_bands; i_band++)
++        fd_bands[i_band] = -1;
++        bands_ids[i_band] = -1;
++    if (n_bands != scatts->n_bands ||
++        n_bands != scatt_conds->n_bands)
++        return -1;
++    memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
++    get_needed_bands(scatt_conds, &b_needed_bands[0]);
++    get_needed_bands(scatts, &b_needed_bands[0]);
++    n_a_bands = 0;
++    /* open band rasters, which are needed for computation */
++    for(band_id = 0; band_id < n_bands; band_id++)
++        if(b_needed_bands[band_id])
++            G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
++            if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
++                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
++                                         bands_ids, NULL, NULL, scatt_conds->n_a_cats);
++                G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
++                return -1;
++            if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
++                G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
++                return -1;
++            data_type = Rast_get_map_type(fd_bands[n_a_bands]);
++            if(data_type != CELL_TYPE) {
++                G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
++                return -1;
++            bands_rows[band_id].row =  Rast_allocate_c_buf();
++            bands_rows[band_id].null_row =  Rast_allocate_null_buf();
++            if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
++                G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
++                return -1;
++            bands_ids[n_a_bands] = band_id;
++            ++n_a_bands;
++    /* open category rasters condition files and category rasters */
++    for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
++        id_cat = scatts->cats_ids[i_cat];
++        if(cats_rasts[id_cat]) {
++            fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
++        else
++            fd_cats_rasts[i_cat] = -1;
++        if(cats_rasts_conds[id_cat]) {
++            f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
++            if(!f_cats_rasts_conds[i_cat]) {
++                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
++                                         f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
++                G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
++                return -1;
++        else
++            f_cats_rasts_conds[i_cat] = NULL;
++    head_nchars =  get_cat_rast_header(region, header);
++            if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
++                G_warning(_("Corrupted category raster conditions file (fseek failed)"));
++                return -1;
++    nrows = Rast_window_rows();
++    /* analyze bands by rows */
++    for (i_row = 0; i_row < nrows; i_row++)
++        for(i_band = 0; i_band < n_a_bands; i_band++)
++            band_id = bands_ids[i_band];
++            Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
++            Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
++        if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
++            free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
++                                     f_cats_rasts_conds, scatt_conds->n_a_cats);
++            return -1;
++                             fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
++    return 0;
+\ No newline at end of file
+Index: lib/imagery/scatt_sccats.c
+--- lib/imagery/scatt_sccats.c	(revision 0)
++++ lib/imagery/scatt_sccats.c	(working copy)
+@@ -0,0 +1,405 @@
++   \file lib/imagery/scatt_cat_rast.c
++   \brief Imagery library - functions for manipulation with scatter plot structs.
++#include <math.h>
++   \brief Compute band ids from scatter plot id.
++    Scatter plot id describes which bands defines the scatter plot.
++    Let say we have 3 bands, their ids are 0, 1 and 2.
++    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
++    All scatter plots:
++    scatt_id b_1_id b_2_id
++    0        0      1
++    1        0      2
++    2        1      2
++   \param scatt_id scatter plot id
++   \param [out] b_1_id id of band1
++   \param[out] b_2_id id of band2
++   \return 0
++int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
++    int n_b1 = n_bands - 1;
++    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
++    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
++    return 0;
++   \brief Compute scatter plot id from band ids.
++    See also I_id_scatt_to_bands().
++   \param b_1_id id of band1
++   \param b_1_id id of band2
++   \param [out] scatt_id scatter plot id
++   \return 0
++int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
++    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
++    return 0;
++   \brief Initialize structure for storing scatter plots data.
++   \param cats pointer to scCats struct
++   \param type SC_SCATT_DATA - stores scatter plots
++   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
++void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
++    int i_cat;
++    cats->type = type;
++    cats->n_cats = 100;
++    cats->n_a_cats = 0;
++    cats->n_bands = n_bands;
++    cats->n_scatts = (n_bands - 1) * n_bands / 2;
++    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
++    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
++    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
++    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
++    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
++        cats->cats_idxs[i_cat] = -1;
++    return;
++   \brief Free data of struct scCats, the structure itself remains alocated.
++   \param cats pointer to existing scCats struct
++void I_sc_free_cats(struct scCats * cats)
++    int i_cat;
++        if(cats->cats_arr[i_cat])
++            G_free(cats->cats_arr[i_cat]->scatt_idxs);
++            G_free(cats->cats_arr[i_cat]->scatts_bands);
++            G_free(cats->cats_arr[i_cat]->scatts_arr);
++            G_free(cats->cats_arr[i_cat]);
++    G_free(cats->cats_ids);
++    G_free(cats->cats_idxs);
++    G_free(cats->cats_arr);
++    cats->n_cats = 0;
++    cats->n_bands = 0;
++    cats->n_scatts = 0;
++    cats->type = -1;
++    return;
++#if 0
++void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
++    a_cats_ids = cats->cats_ids;
++    * n_a_cats = cats->n_a_cats;
++#endif
++   \brief Add category.
++    Category represents group of scatter plots.
++   \return assigned category id (starts with 0)
++   \return -1 if maximum nuber of categories was reached
++int I_sc_add_cat(struct scCats * cats)
++    int i_scatt, i_cat_id, cat_id;
++    int n_a_cats = cats->n_a_cats;
++    if(cats->n_a_cats >= cats->n_cats)
++        return -1;
++    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
++        if(cats->cats_idxs[i_cat_id] < 0) {
++            cat_id = i_cat_id;
++            break;
++    cats->cats_ids[n_a_cats] = cat_id;
++    cats->cats_idxs[cat_id] = n_a_cats;
++    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
++    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
++    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
++    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
++    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
++    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
++    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
++        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
++    ++cats->n_a_cats;
++    return cat_id;
++#if 0
++int I_sc_delete_cat(struct scCats * cats, int cat_id)
++    int cat_idx, i_cat;
++    if(cat_id < 0 || cat_id >= cats->n_cats)
++        return -1;
++    cat_idx = cats->cats_idxs[cat_id];
++    if(cat_idx < 0)
++        return -1;
++    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
++    G_free(cats->cats_arr[cat_idx]->scatts_bands);
++    G_free(cats->cats_arr[cat_idx]->scatts_arr);
++    G_free(cats->cats_arr[cat_idx]);
++    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
++        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
++        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
++    cats->cats_idxs[cat_id] = -1;
++    --cats->n_a_cats;
++    return 0;
++#endif
++   \brief Insert scatter plot data .
++    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
++   \param cat_id id number of category.
++   \param scatt_id id number of scatter plot.
++int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++    int band_1, band_2, cat_idx, n_a_scatts;
++    struct scScatts * scatts;
++        return -1;
++    if(cat_idx < 0)
++        return -1;
++    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
++        return -1;
++    scatts = cats->cats_arr[cat_idx];
++    if(scatts->scatt_idxs[scatt_id] >= 0)
++        return -1;
++    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
++        return -1;
++    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
++        return -1;
++    n_a_scatts = scatts->n_a_scatts;
++    scatts->scatt_idxs[scatt_id] = n_a_scatts;
++    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
++    scatts->scatts_bands[n_a_scatts * 2] = band_1;
++    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
++    scatts->scatts_arr[n_a_scatts] = scatt_data;
++    ++scatts->n_a_scatts;
++    return 0;
++#if 0
++int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
++    if(cat_id < 0 && cat_id >= cats->n_cats)
++        return -1;
++    if(cat_idx < 0)
++        return -1;
++    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
++        return -1;
++    if(scatts->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_data = scatts->scatts_arr[scatt_idx];
++    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
++        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
++        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
++        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
++    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
++    scatts->scatt_idxs[scatt_id] = -1;
++    scatt_data = scatts->scatts_arr[scatt_id];
++    scatts->n_a_scatts--;
++    return 0;
++int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
++    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
++    int cat_idx, scatt_idx, ret;
++    if(cat_idx < 0)
++        return -1;
++    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
++    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
++    return 0;
++#endif
++   \brief Insert scatter plot data.
++   \param scatt_data pointer to existing struct scdScattData
++   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
++   \param n_vals number of data values
++   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
++void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
++    scatt_data->n_vals = n_vals;
++    if(type == SC_SCATT_DATA)
++        if(data)
++            scatt_data->scatt_vals_arr = (unsigned int *) data;
++        else {
++            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
++            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
++        scatt_data->b_conds_arr = NULL;
++    else if(type == SC_SCATT_CONDITIONS)
++        if(data)
++            scatt_data->b_conds_arr = (unsigned char *) data;
++        else {
++            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
++            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
++        scatt_data->scatt_vals_arr = NULL;
++    return;
++#if 0
++void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
++    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
++    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
++    return;
++s
++void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
++    if(!scatt_data->b_conds_arr)
++        return scatt_data->b_conds_arr;
++    else if(!scatt_data->scatt_vals_arr)
++        return scatt_data->scatt_vals_arr;
++    return NULL;
++int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
++    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
++        return -1;
++    if(scatt_data->b_conds_arr)
++        scatt_data->b_conds_arr[val_idx] = val;
++    else if(scatt_data->scatt_vals_arr)
++        scatt_data->scatt_vals_arr[val_idx] = val;
++    else
++        return -1;
++    return 0;
++#endif
+Index: lib/vector/Vlib/open.c
+--- lib/vector/Vlib/open.c	(revision 57491)
++++ lib/vector/Vlib/open.c	(working copy)
+@@ -240,7 +240,9 @@
+         else {
+             char file_path[GPATH_MAX];
++            /* reduce to current mapset if search path was set */
++            if(strcmp(Map->mapset, "") == 0)
++                Map->mapset = G_store(G_mapset());
+             /* temporary map: reduce to current mapset if search path
+              * was set */
+             if (strcmp(Map->mapset, "") == 0)
+Index: include/defs/vedit.h
+--- include/defs/vedit.h	(revision 57491)
++++ include/defs/vedit.h	(working copy)
+@@ -33,6 +33,8 @@
+ int Vedit_merge_lines(struct Map_info *, struct ilist *);
+ /* move.c */
++int Vedit_move_areas(struct Map_info *, struct Map_info **, int,
++		     		 struct ilist *, double, double, double, int, double);
+ int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
 Index: include/defs/imagery.h
---- include/defs/imagery.h	(revision 57457)
+--- include/defs/imagery.h	(revision 57491)
 +++ include/defs/imagery.h	(working copy)
 @@ -110,6 +110,23 @@
  FILE *I_fopen_subgroup_ref_new(const char *, const char *);
@@ -26,24 +1216,11 @@
  /* sig.c */
  int I_init_signatures(struct Signature *, int);
  int I_new_signature(struct Signature *);
-Index: include/defs/vedit.h
---- include/defs/vedit.h	(revision 57457)
-+++ include/defs/vedit.h	(working copy)
-@@ -33,6 +33,8 @@
- int Vedit_merge_lines(struct Map_info *, struct ilist *);
- /* move.c */
-+int Vedit_move_areas(struct Map_info *, struct Map_info **, int,
-+		     		 struct ilist *, double, double, double, int, double);
- int Vedit_move_lines(struct Map_info *, struct Map_info **, int,
- 		     struct ilist *, double, double, double, int, double);
 Index: include/imagery.h
---- include/imagery.h	(revision 57457)
+--- include/imagery.h	(revision 57491)
 +++ include/imagery.h	(working copy)
-@@ -135,6 +135,55 @@
+@@ -135,6 +135,56 @@
  } IClass_statistics;
@@ -90,15 +1267,901 @@
 +struct scdScattData
-+    int n_vals; /* Number of values in scatter plot. */
++    int n_vals; /*!< Number of values in scatter plot. */
-+    unsigned char  * b_conds_arr; /* array of selected areas (used for SC_SCATT_CONDITIONS type) otherwise NULL */
-+    unsigned int  * scatt_vals_arr; /* array of computed areas (used for SC_SCATT_DATA type) otherwise NULL */
++    unsigned char  * b_conds_arr; /*!< array of selected areas (used for SC_SCATT_CONDITIONS type) otherwise NULL */
++    unsigned int  * scatt_vals_arr; /*!< array of computed areas (used for SC_SCATT_DATA type) otherwise NULL */
  #define SIGNATURE_TYPE_MIXED 1
  #define GROUPFILE "CURGROUP"
+Index: gui/wxpython/vdigit/toolbars.py
+--- gui/wxpython/vdigit/toolbars.py	(revision 57491)
++++ gui/wxpython/vdigit/toolbars.py	(working copy)
+@@ -17,6 +17,7 @@
+ import wx
+ from grass.script import core as grass
++from grass.pydispatch.signal import Signal
+ from gui_core.toolbars  import BaseToolbar, BaseIcons
+ from gui_core.dialogs   import CreateNewVector
+@@ -42,6 +43,8 @@
+         self.digit         = None
+         self._giface       = giface
++        self.editingStarted = Signal("VDigitToolbar.editingStarted")
+         # currently selected map layer for editing (reference to MapLayer instance)
+         self.mapLayer = None
+         # list of vector layers from Layer Manager (only in the current mapset)
+@@ -860,6 +863,7 @@
+             alpha = int(opacity * 255)
+             self.digit.GetDisplay().UpdateSettings(alpha = alpha)
++        self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
+         return True
+     def StopEditing(self):
+Index: gui/wxpython/vdigit/wxdigit.py
+--- gui/wxpython/vdigit/wxdigit.py	(revision 57491)
++++ gui/wxpython/vdigit/wxdigit.py	(working copy)
+@@ -17,7 +17,7 @@
+ (and NumPy would be an excellent candidate for acceleration via
+ e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
+-(C) 2007-2011 by the GRASS Development Team
++(C) 2007-2011, 2013 by the GRASS Development Team
+@@ -27,6 +27,8 @@
+ import grass.script.core as grass
+ from core.gcmd        import GError
+ from core.debug       import Debug
+ from core.settings    import UserSettings
+@@ -176,7 +178,21 @@
+         if self.poMapInfo:
+             self.InitCats()
++        self.emit_signals = False
++        # signals which describes features changes during digitization,
++        # activate them using EmitSignals method
++        #TODO signal for errors?
++        self.featureAdded = Signal('IVDigit.featureAdded')
++        self.areasDeleted = Signal('IVDigit.areasDeleted')
++        self.vertexMoved = Signal('IVDigit.vertexMoved')
++        self.vertexAdded = Signal('IVDigit.vertexAdded')
++        self.vertexRemoved = Signal('IVDigit.vertexRemoved')
++        self.featuresDeleted = Signal('IVDigit.featuresDeleted')
++        self.featuresMoved = Signal('IVDigit.featuresMoved')
++        self.lineEdited = Signal('IVDigit.lineEdited')
+     def __del__(self):
+         Debug.msg(1, "IVDigit.__del__()")
+         Vect_destroy_line_struct(self.poPoints)
+@@ -188,7 +204,12 @@
+             Vect_close(self.poBgMapInfo)
+             self.poBgMapInfo = self.popoBgMapInfo = None
+             del self.bgMapInfo
++    def EmitSignals(self, emit):
++        """!Activate/deactivate signals which describes features changes during digitization.
++        self.emit_signals = emit
+     def CloseBackgroundMap(self):
+         """!Close background vector map"""
+         if not self.poBgMapInfo:
+@@ -394,7 +415,6 @@
+         @return tuple (number of added features, feature ids)
+         layer = self._getNewFeaturesLayer()
+         cat = self._getNewFeaturesCat()
+@@ -419,10 +439,14 @@
+             return (-1, None)
+         self.toolbar.EnableUndo()
+-        return self._addFeature(vtype, points, layer, cat,
+-                                self._getSnapMode(), self._display.GetThreshold())
++        ret = self._addFeature(vtype, points, layer, cat,
++                               self._getSnapMode(), self._display.GetThreshold())
++        if ret[0] > -1 and self.emit_signals:
++            self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
++        return ret
+     def DeleteSelectedLines(self):
+         """!Delete selected features
+@@ -434,16 +458,27 @@
+         # collect categories for deleting if requested
+         deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
+         catDict = dict()
++        old_bboxs = []
++        old_areas_cats = []
+         if deleteRec:
+             for i in self._display.selected['ids']:
+                 if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
+                     self._error.ReadLine(i)
+-                cats = self.poCats.contents
+-                for j in range(cats.n_cats):
+-                    if cats.field[j] not in catDict.keys():
+-                        catDict[cats.field[j]] = list()
+-                    catDict[cats.field[j]].append(cats.cat[j])
++                if self.emit_signals:
++                    ret = self._getLineAreaBboxCats(i)
++                    if ret:
++                        old_bboxs += ret[0]
++                        old_areas_cats += ret[1]
++                # catDict was not used -> put into comment
++                #cats = self.poCats.contents
++                #for j in range(cats.n_cats):
++                #    if cats.field[j] not in catDict.keys():
++                #        catDict[cats.field[j]] = list()
++                #    catDict[cats.field[j]].append(cats.cat[j])
+         poList = self._display.GetSelectedIList()
+         nlines = Vedit_delete_lines(self.poMapInfo, poList)
+@@ -456,7 +491,10 @@
+                 self._deleteRecords(catDict)
+             self._addChangeset()
++                self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
+         return nlines
+     def _deleteRecords(self, cats):
+@@ -512,22 +550,173 @@
+         @return number of deleted
++        if len(self._display.selected['ids']) < 1:
++            return 0
+         cList  = poList.contents
+         nareas = 0
++        old_bboxs = []
+         for i in range(cList.n_values):
+             if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
+                 continue
++                area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
++                if area > 0:
++                    bbox, cats = self._getaAreaBboxCats(area)
++                    old_bboxs += bbox
++                    old_areas_cats += cats
+             nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
+         if nareas > 0:
++                self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
++        return nareas
++    def _getLineAreaBboxCats(self, ln_id):
++        ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
++        if ltype == GV_CENTROID:
++            #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
++            return self._getCentroidAreaBboxCats(ln_id)
++        else:
++            return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
++    def _getCentroidAreaBboxCats(self, centroid):
++        if not Vect_line_alive(self.poMapInfo, centroid):
++            return None
++        area = Vect_get_centroid_area(self.poMapInfo, centroid)
++        if area > 0:
++            return self._getaAreaBboxCats(area)
++        else:
++            return None
++    def _getaAreaBboxCats(self, area):
++        po_b_list = Vect_new_list()
++        Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
++        b_list = po_b_list.contents
++        geoms = []
++        areas_cats = []
++        if b_list.n_values > 0:
++            for i_line in range(b_list.n_values):
++                line = b_list.value[i_line];
++                geoms.append(self._getBbox(abs(line)))
++                areas_cats.append(self._getLineAreasCategories(abs(line)))
+-        return nareas
++        Vect_destroy_list(po_b_list);
++        return geoms, areas_cats
++    def _getLineAreasCategories(self, ln_id):
++        if not Vect_line_alive (self.poMapInfo, ln_id):
++            return []
++        if ltype != GV_BOUNDARY:
++            return []
++        cats = [None, None]
++        left = c_int()
++        right = c_int()
++        if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
++            areas = [left.value, right.value]
++            for i, a in enumerate(areas):
++                if a > 0:
++                    centroid = Vect_get_area_centroid(self.poMapInfo, a)
++                    if centroid <= 0:
++                        continue
++                    c = self._getCategories(centroid)
++                    if c:
++                        cats[i] = c
++        return cats
++    def _getCategories(self, ln_id):
++            return none
++        poCats = Vect_new_cats_struct()
++        if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
++            Vect_destroy_cats_struct(poCats)
++            return None
++        cCats = poCats.contents
++        cats = {}
++        for j in range(cCats.n_cats):
++            if cats.has_key(cCats.field[j]):
++                cats[cCats.field[j]].append(cCats.cat[j])
++            else:
++                cats[cCats.field[j]] = [cCats.cat[j]]
++        return cats
++    def _getBbox(self, ln_id):
++            return None
++        poPoints = Vect_new_line_struct()
++        if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
++            Vect_destroy_line_struct(poPoints)
++            return []
++        geom = self._convertGeom(poPoints)
++        bbox = self._createBbox(geom)
++        return bbox
++    def _createBbox(self, points):
++        bbox = {}
++        for pt in points:
++            if not bbox.has_key('maxy'):
++                bbox['maxy'] = pt[1]
++                bbox['miny'] = pt[1]
++                bbox['maxx'] = pt[0]
++                bbox['minx'] = pt[0]
++                continue
++            if   bbox['maxy'] < pt[1]:
++            elif bbox['miny'] > pt[1]:
++            if   bbox['maxx'] < pt[0]:
++            elif bbox['minx'] > pt[0]:
++        return bbox
++    def _convertGeom(self, poPoints):
++        Points = poPoints.contents
++        pts_geom = []
++        for j in range(Points.n_points):
++            pts_geom.append((Points.x[j], Points.y[j]))
++        return pts_geom
+     def MoveSelectedLines(self, move):
+         """!Move selected features
+@@ -536,16 +725,45 @@
+         if not self._checkMap():
+             return -1
++        nsel = len(self._display.selected['ids'])
++        if nsel < 1:
++            return -1
+         thresh = self._display.GetThreshold()
+         snap   = self._getSnapMode()
++            old_bboxs = []
++            for sel_id in self._display.selected['ids']:
++                ret = self._getLineAreaBboxCats(sel_id)
++                if ret:
++            Vect_set_updated(self.poMapInfo, 1)
++            n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
+         nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+                                   poList,
+                                   move[0], move[1], 0,
+                                   snap, thresh)
+         Vect_destroy_list(poList)
++        if nlines > 0 and self.emit_signals:
++            new_bboxs = []
++            new_areas_cats = []
++            n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
++            for i in range(n_up_lines_old, n_up_lines):
++                new_id = Vect_get_updated_line(self.poMapInfo, i)
++                ret = self._getLineAreaBboxCats(new_id)
++                if ret:
++                    new_bboxs += ret[0]
++                    new_areas_cats += ret[1]
+         if nlines > 0 and self._settings['breakLines']:
+             for i in range(1, nlines):
+                 self._breakLineAtIntersection(nlines + i, None, changeset)
+@@ -553,7 +771,13 @@
+         if nlines > 0:
++                self.featuresMoved.emit(new_bboxs = new_bboxs,
++                                        old_bboxs = old_bboxs,
++                                        old_areas_cats = old_areas_cats,
++                                        new_areas_cats = new_areas_cats)
+         return nlines
+     def MoveSelectedVertex(self, point, move):
+@@ -571,12 +795,21 @@
+         if len(self._display.selected['ids']) != 1:
+             return -1
++        # move only first found vertex in bbox
++        poList = self._display.GetSelectedIList()
++            cList = poList.contents
++            old_bboxs = [self._getBbox(cList.value[0])]
++            old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
+         Vect_reset_line(self.poPoints)
+         Vect_append_point(self.poPoints, point[0], point[1], 0.0)
+-        # move only first found vertex in bbox
+-        poList = self._display.GetSelectedIList()
+         moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+                                   poList, self.poPoints,
+                                   self._display.GetThreshold(type = 'selectThresh'),
+@@ -584,7 +817,17 @@
+                                   move[0], move[1], 0.0,
+                                   1, self._getSnapMode())
++        if moved > 0 and self.emit_signals:
++            new_bboxs = []
++                new_bboxs.append(self._getBbox(new_id))
++                new_areas_cats.append(self._getLineAreasCategories(new_id))
+         if moved > 0 and self._settings['breakLines']:
+             self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
+                                           None)
+@@ -592,7 +835,13 @@
+         if moved > 0:
++                self.vertexMoved.emit(new_bboxs = new_bboxs,
++                                      new_areas_cats = new_areas_cats,
++                                      old_bboxs = old_bboxs)
+         return moved
+     def AddVertex(self, coords):
+@@ -681,6 +930,10 @@
+             self._error.ReadLine(line)
+             return -1
++            old_bboxs = [self._getBbox(line)]
++            old_areas_cats = [self._getLineAreasCategories(line)]
+         # build feature geometry
+         for p in coords:
+@@ -696,6 +949,9 @@
+         newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
+                                     self.poPoints, self.poCats)
++        if newline > 0 and self.emit_signals:
++            new_geom = [self._getBbox(newline)]
++            new_areas_cats = [self._getLineAreasCategories(newline)]
+         if newline > 0 and self._settings['breakLines']:
+             self._breakLineAtIntersection(newline, None)
+@@ -703,7 +959,13 @@
+         if newline > 0:
++                self.lineEdited.emit(old_bboxs = old_bboxs,
++                                     new_bboxs = new_bboxs,
+         return newline
+     def FlipLine(self):
+@@ -1514,6 +1776,16 @@
+             return 0
+         Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
+@@ -1525,15 +1797,35 @@
+         else:
+             ret = Vedit_remove_vertex(self.poMapInfo, poList,
+                                       self.poPoints, thresh)
++        if ret > 0 and self.emit_signals:
++            new_bboxs = []
+         if not add and ret > 0 and self._settings['breakLines']:
+                                           None)
+         if ret > 0:
++            if add:
++                self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
++            else:
++                self.vertexRemoved.emit(old_bboxs = old_bboxs,
+         return 1
+     def GetLineCats(self, line):
+Index: gui/wxpython/Makefile
+--- gui/wxpython/Makefile	(revision 57491)
++++ gui/wxpython/Makefile	(working copy)
+@@ -13,7 +13,7 @@
+ 	$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
+ 	gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
+ 	mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* vdigit/* \
+-	vnet/*.py web_services/*.py wxplot/*.py) \
++	vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
+ 	gis_set.py gis_set_error.py wxgui.py README
+ DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
+@@ -21,7 +21,7 @@
+ PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
+ 	gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
+-	mapswipe vdigit wxplot web_services rlisetup vnet)
++	mapswipe vdigit wxplot web_services rlisetup vnet scatt_plot)
+ DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
+Index: gui/wxpython/iclass/frame.py
+--- gui/wxpython/iclass/frame.py	(revision 57491)
++++ gui/wxpython/iclass/frame.py	(working copy)
+@@ -64,6 +64,8 @@
+                                IClassExportAreasDialog, IClassMapDialog
+ from iclass.plots       import PlotPanel
+ class IClassMapFrame(DoubleMapFrame):
+     """! wxIClass main frame
+@@ -114,6 +116,10 @@
+             lambda:
+             self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(None))
+         self.SetSize(size)
++        self.groupSet = Signal("IClassMapFrame.groupSet")
++        self.categoryChanged = Signal('IClassMapFrame.categoryChanged')
+         # Add toolbars
+@@ -177,7 +183,7 @@
+         self.dialogs['category']   = None
+         # PyPlot init
+-        self.plotPanel = PlotPanel(self, stats_data = self.stats_data)
++        self.plotPanel = PlotPanel(self, giface = self._giface, stats_data = self.stats_data)
+         self._addPanes()
+         self._mgr.Update()
+@@ -237,7 +243,7 @@
+             return False
+         return vectorName
+     def RemoveTempVector(self):
+         """!Removes temporary vector map with training areas"""
+         ret = RunCommand(prog = 'g.remove',
+@@ -477,7 +483,7 @@
+         self.Render(self.GetFirstWindow())
+-    def OnAddBands(self, event):
++    def AddBands(self):
+         """!Add imagery group"""
+         dlg = IClassGroupDialog(self, group = self.group)
+         if dlg.ShowModal() == wx.ID_OK:
+@@ -488,7 +494,8 @@
+         """!Set imagery group"""
+         group = grass.find_file(name = name, element = 'group')
+         if group['name']:
+-            self.group = group['name']
++           self.group = group['name']
++           self.groupSet.emit(group = group['name'])
+         else:
+             GError(_("Group <%s> not found") % name, parent = self)
+@@ -768,17 +775,20 @@
+         Updates number of stddev, histograms, layer in preview display.
+-        stat = self.stats_data.GetStatistics(currentCat)
+-        nstd = stat.nstd
+-        self.toolbars['iClass'].UpdateStddev(nstd)
+-        self.plotPanel.UpdateCategory(currentCat)
+-        self.plotPanel.OnPlotTypeSelected(None)
++        if currentCat:
++          stat = self.stats_data.GetStatistics(currentCat)
++          nstd = stat.nstd
++          self.toolbars['iClass'].UpdateStddev(nstd)
++          self.plotPanel.UpdateCategory(currentCat)
++          self.plotPanel.OnPlotTypeSelected(None)
+-        name = stat.rasterName
+-        name = self.previewMapManager.GetAlias(name)
+-        if name:
+-            self.previewMapManager.SelectLayer(name)
++          name = stat.rasterName
++          name = self.previewMapManager.GetAlias(name)
++          if name:
++              self.previewMapManager.SelectLayer(name)
++        self.categoryChanged.emit(cat = currentCat)
+     def DeleteAreas(self, cats):
+         """!Removes all training areas of given categories
+@@ -1105,27 +1115,6 @@
+         self.GetFirstWindow().SetModePointer()
+         self.GetSecondWindow().SetModePointer()
+-    def OnScatterplot(self, event):
+-        """!Init interactive scatterplot tools
+-        if self.dialogs['scatt_plot']:
+-            self.dialogs['scatt_plot'].Raise()
+-            return
+-        try:
+-          from scatt_plot.dialogs import ScattPlotMainDialog
+-        except:
+-          GError(parent  = self, message = _("The Scatter Plot Tool is not installed."))
+-          return
+-        self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface, iclass_mapwin = self.GetFirstWindow())
+-        scatt_mgr = self.dialogs['scatt_plot'].GetScattMgr()
+-        scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().GetDigit())
+-        self.dialogs['scatt_plot'].CenterOnScreen()
+-        self.dialogs['scatt_plot'].Show()
+ class MapManager:
+     """! Class for managing map renderer.
+Index: gui/wxpython/iclass/plots.py
+--- gui/wxpython/iclass/plots.py	(revision 57491)
++++ gui/wxpython/iclass/plots.py	(working copy)
+@@ -28,7 +28,7 @@
+     for each band and for one category. Coincidence plots show min max range
+     of classes for each band.
+-    def __init__(self, parent, stats_data):
++    def __init__(self, parent, giface, stats_data):
+         scrolled.ScrolledPanel.__init__(self, parent)
+         self.SetupScrolling(scroll_x = False, scroll_y = True)
+@@ -38,26 +38,64 @@
+         self.stats_data = stats_data
+         self.currentCat = None
++        self._giface = giface
+         self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+         self._createControlPanel()
++        self._createPlotPanel()
++        self._createScatterPlotPanel()
+         self.SetSizer(self.mainSizer)
+         self.mainSizer.Fit(self)
+         self.Layout()
++    def _createPlotPanel(self):
++        self.canvasPanel = wx.Panel(parent=self)
++        self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
++        self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
++        self.canvasPanel.SetSizer(self.canvasSizer)
+     def _createControlPanel(self):
+         self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
+                                      choices = [_("Histograms"),
+-                                                _("Coincident plots")])
++                                                _("Coincident plots"),
++                                                _("Scatter plots")])
+         self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
+         self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
++    def _createScatterPlotPanel(self):
++        """!Init interactive scatterplot tools
++        try:
++            from scatt_plot.frame import IClassScatterPlotsPanel
++            self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self, giface=self._giface, iclass_mapwin = self.parent.GetFirstWindow())
++            self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
++            self.scatt_plot_panel.Hide()
++        except ImportError as e:#TODO
++            print "ahoj"
++            print e
++            self.scatt_plot_panel = None
+     def OnPlotTypeSelected(self, event):
+         """!Plot type selected"""
++        if self.plotSwitch.GetSelection() in [0, 1]:
++            self.SetupScrolling(scroll_x = False, scroll_y = True)
++            self.canvasPanel.Show()
++            self.Layout()
++        elif self.plotSwitch.GetSelection() == 2:
++            self.SetupScrolling(scroll_x = False, scroll_y = False)
++            self.scatt_plot_panel.Show()
++            self.canvasPanel.Hide()
++            self.Layout()
+         if self.currentCat is None:
+             return
+         if self.plotSwitch.GetSelection() == 0:
+             stat = self.stats_data.GetStatistics(self.currentCat)
+             if not stat.IsReady():
+@@ -66,7 +104,10 @@
+             self.DrawHistograms(stat)
+         else:
+             self.DrawCoincidencePlots()
++        self.Layout()
+     def StddevChanged(self):
+         """!Standard deviation multiplier changed, redraw histograms"""
+@@ -89,7 +130,7 @@
+             panel.Destroy()
+         self.canvasList = []
+     def ClearPlots(self):
+         """!Clears plot canvases"""
+         for bandIdx in range(len(self.bandList)):
+@@ -104,15 +145,15 @@
+     def CreatePlotCanvases(self):
+         """!Create plot canvases according to the number of bands"""
+         for band in self.bandList:
+-            canvas = plot.PlotCanvas(self)
++            canvas = plot.PlotCanvas(self.canvasPanel)
+             canvas.SetMinSize((-1, 140))
+             canvas.SetFontSizeTitle(10)
+             canvas.SetFontSizeAxis(8)
+             self.canvasList.append(canvas)
+-            self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
+-        self.SetVirtualSize(self.GetBestVirtualSize())
++            self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
++        self.SetVirtualSize(self.GetBestVirtualSize())
+         self.Layout()
+     def UpdatePlots(self, group, currentCat, stats_data):
+@@ -138,7 +179,7 @@
+     def UpdateCategory(self, cat):
+         self.currentCat = cat
+     def DrawCoincidencePlots(self):
+         """!Draw coincidence plots"""
+Index: gui/wxpython/iclass/dialogs.py
+--- gui/wxpython/iclass/dialogs.py	(revision 57491)
++++ gui/wxpython/iclass/dialogs.py	(working copy)
+@@ -333,13 +333,19 @@
+         toolbar.SetCategories(catNames = catNames, catIdx = cats)
+         if name in catNames:
+             toolbar.choice.SetStringSelection(name)
++            cat = toolbar.GetSelectedCategoryIdx()
+         elif catNames:
+             toolbar.choice.SetSelection(0)
++        else:
++            cat = None
+         if toolbar.choice.IsEmpty():
+             toolbar.EnableControls(False)
+         else:
+             toolbar.EnableControls(True)
++        self.mapWindow.CategoryChanged(cat)
+         # don't forget to update maps, histo, ...
+     def GetSelectedIndices(self, state =  wx.LIST_STATE_SELECTED):
+Index: gui/wxpython/iclass/toolbars.py
+--- gui/wxpython/iclass/toolbars.py	(revision 57491)
++++ gui/wxpython/iclass/toolbars.py	(working copy)
+@@ -46,9 +46,7 @@
+         'importAreas' : MetaIcon(img = 'layer-import',
+                             label = _('Import training areas from vector map')),
+         'addRgb' : MetaIcon(img = 'layer-rgb-add',
+-                            label = _('Add RGB map layer')),
+-        'scatt_plot'    : MetaIcon(img = 'layer-raster-analyze',
+-                                   label = _('Open Scatter Plot Tool (EXPERIMENTAL GSoC 2013)')),
++                            label = _('Add RGB map layer'))
+ class IClassMapToolbar(BaseToolbar):
+@@ -117,10 +115,7 @@
+                                      ("zoomBack", icons["zoomBack"],
+                                       self.parent.OnZoomBack),
+                                      ("zoomToMap", icons["zoomExtent"],
+-                                      self.parent.OnZoomToMap),
+-                                     (None, ),
+-                                     ("scatt_plot", iClassIcons["scatt_plot"],
+-                                      self.parent.OnScatterplot)
++                                      self.parent.OnZoomToMap)
+ class IClassToolbar(BaseToolbar):
+     """!IClass toolbar
+@@ -156,7 +151,7 @@
+         """!Toolbar data"""
+         icons = iClassIcons
+         return self._getToolbarData((("selectGroup", icons['selectGroup'],
+-                                      self.parent.OnAddBands),
++                                      lambda event : self.parent.AddBands()),
+                                       (None, ),
+                                       ("classManager", icons['classManager'],
+                                       self.parent.OnCategoryManager),
 Index: gui/wxpython/scatt_plot/core_c.py
 --- gui/wxpython/scatt_plot/core_c.py	(revision 0)
@@ -270,25 +2333,505 @@
 +    output_queue.put(ret)
+Index: gui/wxpython/scatt_plot/frame.py
+--- gui/wxpython/scatt_plot/frame.py	(revision 0)
++++ gui/wxpython/scatt_plot/frame.py	(working copy)
+@@ -0,0 +1,473 @@
++ at package scatt_plot.dialogs
++ at brief GUI.
++Classes:
++(C) 2013 by the GRASS Development Team
++This program is free software under the GNU General Public License
++(>=v2). Read the file COPYING that comes with GRASS for details.
++ at author Stepan Turek <stepan.turek seznam.cz> (mentor: Martin Landa)
++import os
++import sys
++import wx
++import wx.lib.scrolledpanel as scrolled
++import wx.lib.mixins.listctrl as listmix
++import wx.lib.flatnotebook  as FN
++import wx.aui
++from core import globalvar
++from core.gcmd import GException, GError, RunCommand
++from gui_core.gselect import Select
++from scatt_plot.controllers import ScattsManager
++from scatt_plot.toolbars import MainToolbar, EditingToolbar
++from scatt_plot.scatt_core import idScattToidBands
++from scatt_plot.plots import ScatterPlotWidget
++try:
++    from agw import aui
++except ImportError:
++    import wx.lib.agw.aui as aui
++class IClassScatterPlotsPanel(wx.Panel):
++    def __init__(self, parent, giface, iclass_mapwin = None,
++                 id = wx.ID_ANY, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
++        #wx.SplitterWindow.__init__(self, parent = parent, id = id,
++        #                           style = wx.SP_LIVE_UPDATE)
++        wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY)
++        #self.head_panel = wx.Panel(parent = self, id = wx.ID_ANY)
++        self.scatt_mgr = ScattsManager(guiparent = self, giface = giface, iclass_mapwin = iclass_mapwin)
++        # toobars
++        self.toolbars = {}
++        self.toolbars['mainToolbar'] = MainToolbar(parent = self, scatt_mgr = self.scatt_mgr)
++        self.toolbars['editingToolbar'] = EditingToolbar(parent = self, scatt_mgr = self.scatt_mgr)
++        self._createCategoryPanel(self)
++        self.plot_panel = IClassPlotPanel(self, self.scatt_mgr)
++        mainsizer = wx.BoxSizer(wx.VERTICAL)
++        mainsizer.Add(item = self.toolbars['mainToolbar'], proportion = 0, flag = wx.EXPAND)
++        mainsizer.Add(item = self.toolbars['editingToolbar'], proportion = 0, flag = wx.EXPAND)
++        mainsizer.Add(item = self.catsPanel, proportion = 0, flag = wx.EXPAND | wx.LEFT | wx.RIGHT , border = 5)
++        mainsizer.Add(item = self.plot_panel, proportion = 1, flag = wx.EXPAND)
++        self.catsPanel.Hide()
++        self.toolbars['editingToolbar'].Hide()
++        self.SetSizer(mainsizer)
++        #self.SetSashGravity(0.5)
++        #self.SplitHorizontally(self.head_panel, self.plot_panel, -50)
++        self.Layout()
++        #self.SetAutoLayout(1)
++    def NewScatterPlot(self, scatt_id):
++        return self.plot_panel.NewScatterPlot(scatt_id)
++    def ShowPlotEditingToolbar(self, show):
++        self.toolbars["editingToolbar"].Show(show)
++        self.Layout()
++    def ShowCategoryPanel(self, show):
++        self.catsPanel.Show(show)
++        #if show:
++        #    self.SetSashSize(5)
++        #else:
++        #    self.SetSashSize(0)
++        self.plot_panel.SetVirtualSize(self.plot_panel.GetBestVirtualSize())
++        self.Layout()
++    def _createCategoryPanel(self, parent):
++        self.catsPanel = wx.Panel(parent = parent)
++        self.cats_list = CategoryListCtrl(parent = self.catsPanel,
++                                          cats_mgr = self.scatt_mgr.GetCategoriesManager())
++        self.catsPanel.SetMaxSize((-1, 150))
++        box_capt = wx.StaticBox(parent = self.catsPanel, id = wx.ID_ANY,
++                             label = ' %s ' % _("Classes manager for scatter plots"))
++        catsSizer = wx.StaticBoxSizer(box_capt, wx.VERTICAL)
++        catsSizer.Add(item = self.cats_list, proportion = 1, flag = wx.EXPAND | wx.ALL)
++        self.catsPanel.SetSizer(catsSizer)
++class IClassPlotPanel(scrolled.ScrolledPanel):
++    def __init__(self, parent, scatt_mgr, id = wx.ID_ANY):
++        scrolled.ScrolledPanel.__init__(self, parent)
++        self.scatt_mgr = scatt_mgr
++        self.mainPanel = wx.Panel(parent = self, id = wx.ID_ANY)
++        #self._createCategoryPanel()
++        # Fancy gui
++        self._mgr = aui.AuiManager(self.mainPanel)
++        #self._mgr.SetManagedWindow(self)
++        self._mgr.Update()
++        self._doLayout()
++        self.Bind(wx.EVT_SCROLLWIN, self.OnScroll)
++        self.Bind(aui.EVT_AUI_PANE_CLOSE, self.OnPlotPaneClosed)
++        dlgSize = (-1, 400)
++        #self.SetBestSize(dlgSize)
++        #self.SetInitialSize(dlgSize)
++        self.SetAutoLayout(1)
++        #fix goutput's pane size (required for Mac OSX)
++        #if self.gwindow:
++        #    self.gwindow.SetSashPosition(int(self.GetSize()[1] * .75))
++    def OnPlotPaneClosed(self, event):
++        if isinstance(event.pane.window, ScatterPlotWidget):
++            event.pane.window.CleanUp()
++    def OnScroll(self, event):
++        event.Skip()
++        wx.CallAfter(self._mgr.Update)
++        wx.CallAfter(self.Layout)
++    def _doLayout(self):
++        mainsizer.Add(item = self.mainPanel, proportion = 1, flag = wx.EXPAND)
++        self.Layout()
++        self.SetupScrolling()
++    def OnCloseDialog(self, event):
++        """!Close dialog"""
++        self.scatt_mgr.CleanUp()
++        self.Destroy()
++    def OnSettings(self, event):
++        pass
++        #TODO needs to be resolved (should be in this class)
++        scatt = ScatterPlotWidget(parent = self.mainPanel,
++                                  scatt_mgr = self.scatt_mgr,
++                                  scatt_id = scatt_id)
++        bands = self.scatt_mgr.GetBands()
++        #TODO too low level
++        b1_id, b2_id = idScattToidBands(scatt_id, len(bands))
++        self._mgr.AddPane(scatt,
++                           aui.AuiPaneInfo().Dockable(True).Floatable(True).
++                           Name("scatter plot %d" % scatt_id).MinSize((-1, 300)).Caption(("%s x: %s y: %s") % (_("scatter plot"), bands[b1_id], bands[b2_id])).
++                           Center().Position(1).MaximizeButton(True).
++                           MinimizeButton(True).CaptionVisible(True).
++                           CloseButton(True).Layer(0))
++        self.Layout()
++        return scatt
++    def GetScattMgr(self):
++        return  self.scatt_mgr
++class CategoryListCtrl(wx.ListCtrl,
++                       listmix.ListCtrlAutoWidthMixin,
++                       listmix.TextEditMixin):
++    def __init__(self, parent, cats_mgr, id = wx.ID_ANY):
++        wx.ListCtrl.__init__(self, parent, id,
++                             style = wx.LC_REPORT|wx.LC_VIRTUAL|wx.LC_HRULES|wx.LC_VRULES)
++        self.columns = ((_('Class name'), 'name'),
++                        (_('Color'), 'color'))
++        self.Populate(columns = self.columns)
++        self.cats_mgr = cats_mgr
++        self.SetItemCount(len(self.cats_mgr.GetCategories()))
++        self.rightClickedItemIdx = wx.NOT_FOUND
++        listmix.ListCtrlAutoWidthMixin.__init__(self)
++        listmix.TextEditMixin.__init__(self)
++        self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnEdit)
++        self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnSel)
++        self.cats_mgr.setCategoryAttrs.connect(self.Update)
++        self.cats_mgr.deletedCategory.connect(self.Update)
++        self.cats_mgr.addedCategory.connect(self.Update)
++    def Update(self, **kwargs):
++        self.RefreshItems(0, len(self.cats_mgr.GetCategories()))
++    def InitCoreCats(self):
++    def SetVirtualData(self, row, column, text):
++        attr = self.columns[column][1]
++        if attr == 'name':
++            try:
++                text.encode('ascii')
++            except UnicodeEncodeError:
++                GMessage(parent = self, message = _("Please use only ASCII characters."))
++                return
++        cat_id = self.cats_mgr.GetCategories()[row]
++        self.cats_mgr.setCategoryAttrs.disconnect(self.Update)
++        self.cats_mgr.SetCategoryAttrs(cat_id, {attr : text})
++        self.Select(row)
++    def Populate(self, columns):
++        for i, col in enumerate(columns):
++            self.InsertColumn(i, col[0])#wx.LIST_FORMAT_RIGHT
++        self.SetColumnWidth(0, 100)
++        self.SetColumnWidth(1, 100)
++    def AddCategory(self):
++        self.cats_mgr.addedCategory.disconnect(self.Update)
++        cat_id = self.cats_mgr.AddCategory()
++        if cat_id < 0:
++            GError(_("Maximum limit of categories number was reached."))
++            return
++    def DeleteCategory(self):
++        indexList = sorted(self.GetSelectedIndices(), reverse = True)
++        cats = []
++        for i in indexList:
++            # remove temporary raster
++            cat_id = self.cats_mgr.GetCategories()[i]
++            cats.append(cat_id)
++            self.cats_mgr.deletedCategory.disconnect(self.Update)
++            self.cats_mgr.DeleteCategory(cat_id)
++    def OnSel(self, event):
++        event.Skip()
++    def GetSelectedIndices(self, state =  wx.LIST_STATE_SELECTED):
++        indices = []
++        lastFound = -1
++        while True:
++            index = self.GetNextItem(lastFound, wx.LIST_NEXT_ALL, state)
++            if index == -1:
++                break
++            else:
++                lastFound = index
++                indices.append(index)
++        return indices
++    def OnEdit(self, event):
++        currentItem = event.m_itemIndex
++        currentCol = event.m_col
++        if currentCol == 1:
++            dlg = wx.ColourDialog(self)
++            dlg.GetColourData().SetChooseFull(True)
++            if dlg.ShowModal() == wx.ID_OK:
++                color = dlg.GetColourData().GetColour().Get()
++                color = ':'.join(map(str, color))
++                self.SetVirtualData(currentItem, currentCol, color)
++            dlg.Destroy()
++            wx.CallAfter(self.SetFocus)
++        event.Skip()
++    def DeselectAll(self):
++        """!Deselect all items"""
++        indexList = self.GetSelectedIndices()
++            self.Select(i, on = 0)
++        # no highlight
++        self.OnCategorySelected(None)
++    def OnGetItemText(self, item, col):
++        attr = self.columns[col][1]
++        cat_id = self.cats_mgr.GetCategories()[item]
++        return self.cats_mgr.GetCategoryAttrs(cat_id)[attr]
++    def OnGetItemImage(self, item):
++        return -1
++    def OnGetItemAttr(self, item):
++        return None
++    def OnClassRightUp(self, event):
++        """!Show context menu on right click"""
++        item, flags = self.HitTest((event.GetX(), event.GetY()))
++        if item != wx.NOT_FOUND and flags & wx.LIST_HITTEST_ONITEM:
++            self.rightClickedItemIdx = item
++        self.popupZoomtoAreas = wx.NewId()
++        self.Bind(wx.EVT_MENU, self.OnZoomToAreasByCat, id = self.popupZoomtoAreas)
++        # generate popup-menu
++        menu = wx.Menu()
++        menu.Append(self.popupZoomtoAreas, _("Zoom to training areas of selected class"))
++        self.PopupMenu(menu)
++        menu.Destroy()
++    def OnZoomToAreasByCat(self, event):
++        """!Zoom to areas of given category"""
++        cat = self.stats_data.GetCategories()[self.rightClickedItemIdx]
++        self.mapWindow.ZoomToAreasByCat(cat)
++class AddScattPlotDialog(wx.Dialog):
++    def __init__(self, parent, bands, id  = wx.ID_ANY):
++        wx.Dialog.__init__(self, parent, title = ("Add scatter plot"), id = id)
++        self.bands = bands
++        self.scatt_id = None
++        self._createWidgets()
++    def _createWidgets(self):
++        self.labels = {}
++        self.params = {}
++        self.band_1_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 1:"))
++        self.band_1_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
++                                     choices = self.bands,
++                                     style = wx.CB_READONLY, size = (350, 30))
++        self.band_2_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 2:"))
++        self.band_2_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
++        # buttons
++        self.btn_close = wx.Button(parent = self, id = wx.ID_CANCEL)
++        self.btn_ok = wx.Button(parent = self, id = wx.ID_OK, label = _("&OK"))
++        self._layout()
++    def _layout(self):
++        border = wx.BoxSizer(wx.VERTICAL)
++        dialogSizer = wx.BoxSizer(wx.VERTICAL)
++        regionSizer = wx.BoxSizer(wx.HORIZONTAL)
++        dialogSizer.Add(item = self._addSelectSizer(title = self.band_1_label,
++                                                    sel = self.band_1_ch))
++        dialogSizer.Add(item = self._addSelectSizer(title = self.band_2_label,
++                                                    sel = self.band_2_ch))
++        # buttons
++        self.btnsizer = wx.BoxSizer(orient = wx.HORIZONTAL)
++        self.btnsizer.Add(item = self.btn_close, proportion = 0,
++                          flag = wx.ALL | wx.ALIGN_CENTER,
++                          border = 10)
++        self.btnsizer.Add(item = self.btn_ok, proportion = 0,
++                          border = 10)
++        dialogSizer.Add(item = self.btnsizer, proportion = 0,
++                        flag = wx.ALIGN_CENTER)
++        border.Add(item = dialogSizer, proportion = 0,
++                   flag = wx.ALL, border = 5)
++        self.SetSizer(border)
++        self.Layout()
++        self.Fit()
++        # bindings
++        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
++        self.btn_ok.Bind(wx.EVT_BUTTON, self.OnOk)
++    def _addSelectSizer(self, title, sel):
++        """!Helper layout function.
++        selSizer = wx.BoxSizer(orient = wx.VERTICAL)
++        selTitleSizer = wx.BoxSizer(wx.HORIZONTAL)
++        selTitleSizer.Add(item = title, proportion = 1,
++                          flag = wx.LEFT | wx.TOP | wx.EXPAND, border = 5)
++        selSizer.Add(item = selTitleSizer, proportion = 0,
++                     flag = wx.EXPAND)
++        selSizer.Add(item = sel, proportion = 1,
++                     flag = wx.EXPAND | wx.ALL| wx.ALIGN_CENTER_VERTICAL,
++                     border = 5)
++        return selSizer
++    def OnClose(self, event):
++        """!Close dialog
++        if not self.IsModal():
++            self.Destroy()
++        event.Skip()
++    def OnOk(self, event):
++        band_1 = self.band_1_ch.GetSelection()
++        band_2 = self.band_2_ch.GetSelection()
++        if band_1 == band_2:
++            GError(_("Selected bands must be different."))
++            return
++        #TODO axes selection
++        if band_1 > band_2:
++            tmp_band = band_2
++            band_2 = band_1
++            band_1 = band_2
++        self.scatt_id = idBandsToidScatt(band_1, band_2, len(self.bands))
++        event.Skip()
++    def GetScattId(self):
++        return self.scatt_id
 Index: gui/wxpython/scatt_plot/__init__.py
 --- gui/wxpython/scatt_plot/__init__.py	(revision 0)
 +++ gui/wxpython/scatt_plot/__init__.py	(working copy)
-@@ -0,0 +1,9 @@
+@@ -0,0 +1,11 @@
 +all = [
 +    'dialogs',
-+    'gui_iclass',
++    'controllers',
++    'frame',
 +    'gthreading',
 +    'plots',
-+    'sc_pl_core',
++    'scatt_core',
 +    'toolbars',
++    'scatt_core',
 +    'core_c',
 Index: gui/wxpython/scatt_plot/plots.py
 --- gui/wxpython/scatt_plot/plots.py	(revision 0)
 +++ gui/wxpython/scatt_plot/plots.py	(working copy)
-@@ -0,0 +1,285 @@
+@@ -0,0 +1,504 @@
@@ -306,6 +2849,7 @@
 +import wx
 +import numpy as np
 +import random
++from copy import deepcopy
 +try:
 +    haveMatPlot = True
@@ -315,6 +2859,10 @@
 +    from matplotlib.backends.backend_wxagg import \
 +    FigureCanvasWxAgg as FigCanvas, \
 +    NavigationToolbar2WxAgg as NavigationToolbar
++    from matplotlib.lines import Line2D
++    from matplotlib.artist import Artist
++    from matplotlib.mlab import dist_point_to_segment
++    from matplotlib.patches import Polygon, Ellipse
 +    haveMatPlot = False
@@ -342,10 +2890,41 @@
 +        self.base_scale = 2.0
 +        self.Bind(wx.EVT_CLOSE,lambda event : self.CleanUp())
 +        self.plotClosed = Signal("ScatterPlotWidget.plotClosed")
 +        self.contex_menu = ScatterPlotContextMenu(plot = self)
++        self.ciddscroll = None
++        # Create the mpl Figure and FigCanvas objects.
++        # 5x4 inches, 100 dots-per-inch
++        self.dpi = 100
++        self.fig = Figure((1.0, 1.0), dpi=self.dpi)
++        self.canvas = FigCanvas(self, -1, self.fig)
++        # Since we have only one plot, we can use add_axes
++        # instead of add_subplot, but then the subplot
++        # configuration tool in the navigation toolbar wouldn't
++        # work.
++        #elf.axes = self.fig.add_subplot(111)
++        self.axes = self.fig.add_axes([0,0,1,1])
++        pol = Polygon(list(zip([0], [0])), animated=True)
++        self.axes.add_patch(pol)
++        self.polygon_drawer = PolygonDrawer(self.axes, pol = pol, empty_pol = True)
++        # Create the navigation toolbar, tied to the canvas
++        self.toolbar = NavigationToolbar(self.canvas)
++        #print  vars(self.toolbar)
++        #print [method for method in dir(self.toolbar) if callable(getattr(self.toolbar, method))]
 +    def ZoomToExtend(self):
 +        if self.full_extend:
 +            self.axes.axis(self.full_extend)
@@ -355,32 +2934,39 @@
 +        self._deactivateMode()
 +        if mode == 'zoom':
-+            self.canvas.mpl_connect('scroll_event', self.zoom)
++            self.ciddscroll = self.canvas.mpl_connect('scroll_event', self.zoom)
 +        elif mode == 'pan':
 +            self.toolbar.pan()
-+        elif mode in ["add", "remove"]:
-+            self._startCategoryEdit()
++    def FinishDrawing(self):
++        return self.polygon_drawer.FinishDrawing()
++    def SetEditingMode(self, mode):
++        self.polygon_drawer.SetMode(mode)
 +    def _deactivateMode(self):
 +        if self.toolbar._active == "PAN":
-+        elif self.toolbar._active == "ZOOM":
++        if self.ciddscroll:
 +            self.canvas.mpl_disconnect(self.ciddscroll)
 +        self._stopCategoryEdit()
-+    def _startCategoryEdit(self):
-+        self.cidpress = self.canvas.mpl_connect(
-+            'button_press_event', self.OnPress)
-+        self.cidrelease = self.canvas.mpl_connect(
-+            'button_release_event', self.OnRelease)
++    #def _startCategoryEdit(self):
++    #    self.cidpress = self.canvas.mpl_connect(
++    #        'button_press_event', self.OnPress)
++    #    self.cidrelease = self.canvas.mpl_connect(
++    #        'button_release_event', self.OnRelease)
 +        #self.cidmotion = self.canvas.mpl_connect(
 +        #    'motion_notify_event', self.OnRelease)
 +    def OnPress(self, event):
 +        'on button press we will see if the mouse is over us and store some data'
++        if not event.inaxes:
++            return
 +        if event.xdata and event.ydata:
 +            self.press_coords = { 'x' : event.xdata, 'y' : event.ydata}
 +        else:
@@ -417,33 +3003,6 @@
 +            self.canvas.mpl_disconnect(self.cidrelease)
 +        #self.canvas.mpl_disconnect(self.cidmotion)
-+    def _createWidgets(self):
-+        # Create the mpl Figure and FigCanvas objects.
-+        # 5x4 inches, 100 dots-per-inch
-+        self.dpi = 100
-+        self.fig = Figure((1.0, 1.0), dpi=self.dpi)
-+        self.canvas = FigCanvas(self, -1, self.fig)
-+        # Since we have only one plot, we can use add_axes
-+        # instead of add_subplot, but then the subplot
-+        # configuration tool in the navigation toolbar wouldn't
-+        # work.
-+        #elf.axes = self.fig.add_subplot(111)
-+        self.axes = self.fig.add_axes([0,0,1,1])
-+        # Bind the 'pick' event for clicking on one of the bars
-+        self.canvas.mpl_connect('button_press_event', self.on_pick)
-+        # Create the navigation toolbar, tied to the canvas
-+        self.toolbar = NavigationToolbar(self.canvas)
-+        #print  vars(self.toolbar)
-+        #print [method for method in dir(self.toolbar) if callable(getattr(self.toolbar, method))]
 +        self.main_sizer = wx.BoxSizer(wx.VERTICAL)
@@ -452,12 +3011,16 @@
 +        self.SetSizer(self.main_sizer)
 +        self.main_sizer.Fit(self)
-+    def Plot(self, scatts, styles):
++    def Plot(self, scatts, ellipses, styles):
 +        """ Redraws the figure
 +        self.axes.clear()
 +        for cat_id, scatt in scatts.iteritems():
++            b1_i = scatt['bands_info']['b1']
++            b2_i = scatt['bands_info']['b2']
++            self.full_extend = (b1_i['min'] - 0.5, b1_i['max'] + 0.5, b2_i['min'] - 0.5, b2_i['max'] + 0.5)
 +            if cat_id == 0:
 +                cmap = matplotlib.cm.jet
 +                cmap.set_bad('w',1.)
@@ -476,14 +3039,10 @@
 +            masked_cat = np.ma.masked_less_equal(scatt['np_vals'], 0)
-+            b1_i = scatt['bands_info']['b1']
-+            b2_i = scatt['bands_info']['b2']
-+            self.full_extend = (b1_i['min'] - 0.5, b1_i['max'] + 0.5, b2_i['min'] - 0.5, b2_i['max'] + 0.5)
 +            #self.axes.set_xlim((0, 270))
 +            #self.axes.set_ylim((0, 270))
 +            #np.savetxt("/home/ostepok/Desktop/data.txt", scatt['np_vals'], fmt = '%d')
 +            #TODO needs optimization
 +            self.axes.imshow(masked_cat, cmap = cmap,
@@ -493,40 +3052,32 @@
 +                                         aspect = "auto")
 +            self.canvas.draw()
++        self.fig.savefig("/home/ostepok/Desktop/data.png")
++        for cat_id, e in ellipses.iteritems():
++            if cat_id == 0 or not e:
++                continue
++            colors = styles[cat_id]['color'].split(":")
++            ellip = Ellipse(xy=e['pos'], width=e['width'], height=e['height'], angle=e['theta'], edgecolor = "r", facecolor = 'None')
++            self.axes.add_artist(ellip)
++        self.canvas.draw()
 +        #xy = np.array([[0, 0], [10, 10], [20, 0]])
 +        #pol = matplotlib.patches.Polygon(xy, closed=True, color = "g")
 +        #self.axes.add_patch(pol)
-+    def on_pick(self, event):
-+        pass
-+        # The event received here is of the type
-+        # matplotlib.backend_bases.PickEvent
-+        # It carries lots of information, of which we're using
-+        # only a small amount here.
-+        #box_points = event.x
-+        #msg = "You've clicked on a bar with coords:\n"
-+        #dlg = wx.MessageDialog(
-+        #    self,
-+        #    msg,
-+        #    "Click!",
-+        #    wx.OK | wx.ICON_INFORMATION)
-+        #dlg.ShowModal()
-+        #dlg.Destroy()
 +    def CleanUp(self):
 +        self.plotClosed.emit(scatt_id = self.scatt_id)
 +        self.Destroy()
 +    def zoom(self, event):
 +        # get the current x and y limits
++            return
++        # tcaswell
++        # http://stackoverflow.com/questions/11551049/matplotlib-plot-zooming-with-scroll-wheel
 +        cur_xlim = self.axes.get_xlim()
 +        cur_ylim = self.axes.get_ylim()
 +        cur_xrange = (cur_xlim[1] - cur_xlim[0])*.5
@@ -547,7 +3098,6 @@
 +class ScatterPlotContextMenu:
 +    def __init__(self, plot):
@@ -574,12 +3124,223 @@
 +        self.plot.PopupMenu(menu)
 +        menu.Destroy()
-\ No newline at end of file
++class PolygonDrawer:
++    An polygon editor.
++    showverts = True
++    epsilon = 5  #TODO settings max pixel distance to count as a vertex hit
++    def __init__(self, ax, pol, empty_pol):
++        if pol.figure is None:
++            raise RuntimeError('You must first add the polygon to a figure or canvas before defining the interactor')
++        self.ax = ax
++        self.canvas = pol.figure.canvas
++        self.pol = pol
++        self.empty_pol = empty_pol
++        x, y = zip(*self.pol.xy)
++        self.line = Line2D(x, y, marker='o', markerfacecolor='r', animated=True)
++        self.ax.add_line(self.line)
++        #self._update_line(pol)
++        cid = self.pol.add_callback(self.poly_changed)
++        self.moving_ver_idx = None # the active vert
++        self.mode = None
++        if self.empty_pol:
++            self.Show(False)
++        self.canvas.mpl_connect('draw_event', self.draw_callback)
++        self.canvas.mpl_connect('button_press_event', self.OnButtonPressed)
++        self.canvas.mpl_connect('button_release_event', self.button_release_callback)
++        self.canvas.mpl_connect('motion_notify_event', self.motion_notify_callback)
++    def SetMode(self, mode):
++        self.mode = mode
++            return None
++        self._setEmptyPol(True)
++        coords = deepcopy(self.pol.xy)
++        return coords
++    def _setEmptyPol(self, empty_pol):
++        self.Show(not empty_pol)
++    def Show(self, show):
++        self.show = show
++        self.line.set_visible(self.show)
++        self.pol.set_visible(self.show)
++        self.Redraw()
++    def Redraw(self):
++        if self.show:
++            self.ax.draw_artist(self.pol)
++            self.ax.draw_artist(self.line)
++        self.canvas.blit(self.ax.bbox)
++    def draw_callback(self, event):
++        self.background = self.canvas.copy_from_bbox(self.ax.bbox)
++    def poly_changed(self, pol):
++        'this method is called whenever the polygon object is called'
++        # only copy the artist props to the line (except visibility)
++        vis = self.line.get_visible()
++        Artist.update_from(self.line, pol)
++        self.line.set_visible(vis)  # don't use the pol visibility state
++    def get_ind_under_point(self, event):
++        'get the index of the vertex under point if within epsilon tolerance'
++        # display coords
++        xy = np.asarray(self.pol.xy)
++        xyt = self.pol.get_transform().transform(xy)
++        xt, yt = xyt[:, 0], xyt[:, 1]
++        d = np.sqrt((xt-event.x)**2 + (yt-event.y)**2)
++        indseq = np.nonzero(np.equal(d, np.amin(d)))[0]
++        ind = indseq[0]
++        if d[ind]>=self.epsilon:
++            ind = None
++        return ind
++    def OnButtonPressed(self, event):
++            return
++        if event.button == 2:
++            return
++        if self.mode == "delete_vertex":
++            self._deleteVertex(event)
++        elif self.mode == "add_boundary_vertex":
++            self._addVertexOnBoundary(event)
++        elif self.mode == "add_vertex":
++            self._addVertex(event)
++        self.moving_ver_idx = self.get_ind_under_point(event)
++    def button_release_callback(self, event):
++        'whenever a mouse button is released'
++        if not self.showverts: return
++        if event.button != 1: return
++    def ShowVertices(self, show):
++        self.showverts = show
++        self.line.set_visible(self.showverts)
++        if not self.showverts: self.moving_ver_idx = None
++    def _deleteVertex(self, event):
++        ind = self.get_ind_under_point(event)
++        if ind  is None or self.empty_pol:
++            return
++        if len(self.pol.xy) <= 2:
++            self.empty_pol = True
++            self.Show(False)
++        coords = []
++        #self.pol.xy = [tup for i,tup in enumerate(self.pol.xy) if i!=ind  (ind in [len(self.pol.xy) - 1, 0])]
++        for i,tup in enumerate(self.pol.xy):
++            if i == ind:
++                continue
++            elif i == 0 and ind == len(self.pol.xy) - 1:
++                continue
++            elif i == len(self.pol.xy) - 1 and ind == 0:
++                continue
++            coords.append(tup)
++        self.pol.xy = coords
++        self.line.set_data(zip(*self.pol.xy))
++        self.Redraw()
++    def _addVertexOnBoundary(self, event):
++            return
++        xys = self.pol.get_transform().transform(self.pol.xy)
++        p = event.x, event.y # display coords
++        for i in range(len(xys)-1):
++            s0 = xys[i]
++            s1 = xys[i+1]
++            d = dist_point_to_segment(p, s0, s1)
++            if d<=self.epsilon:
++                self.pol.xy = np.array(
++                    list(self.pol.xy[:i + 1]) +
++                    [(event.xdata, event.ydata)] +
++                    list(self.pol.xy[i + 1:]))
++                break
++        # TODO needed onlyredrawing of line
++        self.Redraw()
++    def _addVertex(self, event):
++            pt = (event.xdata, event.ydata)
++            self.pol.xy = np.array([pt, pt])
++            self.Show(True)
++            self.empty_pol = False
++        else:
++                        list(self.pol.xy[1:]) +
++                        [(event.xdata, event.ydata)])
++        self.Redraw()
++    def motion_notify_callback(self, event):
++        'on mouse movement'
++        if not self.mode == "move_vertex": return
++        if self.empty_pol: return
++        if self.moving_ver_idx is None: return
++        if event.inaxes is None: return
++        x,y = event.xdata, event.ydata
++        self.pol.xy[self.moving_ver_idx] = x,y
++        if self.moving_ver_idx == 0:
++            self.pol.xy[len(self.pol.xy) - 1] = x,y
++        elif self.moving_ver_idx == len(self.pol.xy) - 1:
++            self.pol.xy[0] = x,y
++        self.canvas.restore_region(self.background)
++        self.Redraw()
 Index: gui/wxpython/scatt_plot/controllers.py
 --- gui/wxpython/scatt_plot/controllers.py	(revision 0)
 +++ gui/wxpython/scatt_plot/controllers.py	(working copy)
-@@ -0,0 +1,566 @@
+@@ -0,0 +1,613 @@
 + at package scatt_plot.controllers
@@ -602,7 +3363,7 @@
 +from core.gcmd import GException, GError, GMessage, RunCommand
-+from scatt_plot.sc_pl_core import Core, idBandsToidScatt
++from scatt_plot.scatt_core import Core, idBandsToidScatt
 +from scatt_plot.plots import haveMatPlot
 +from scatt_plot.dialogs import AddScattPlotDialog
@@ -642,6 +3403,7 @@
 +        self.cats_to_update = []
 +        self.plot_mode =  None
++        self.pol_sel_mode = [False, None]
 +        self.data_set = False
@@ -696,12 +3458,30 @@
 +            GError(_('No data set.'))
 +            return
-+        dlg = AddScattPlotDialog(parent = self.guiparent, bands = self.core.GetBands())
-+        if dlg.ShowModal() == wx.ID_OK:
-+            self._addScattPlot(dlg.GetScattId())
++        #dlg = AddScattPlotDialog(parent = self.guiparent, bands = self.core.GetBands())
++        jj = len(self.core.GetBands()) - 1
++        max_k = 20
++        k = 0
++        for i in range(jj):
++            for j in range(i, jj):
++                print i * (len(self.core.GetBands())) + j
++                self._addScattPlot(i * len(self.core.GetBands()) + j)
++                k += 1
++                if k == max_k:
++                    break
++            if k == max_k:
++                break
++            jj -= 1
++        print "plots %d" % k
++        #if dlg.ShowModal() == wx.ID_OK:
++        #    self._addScattPlot(dlg.GetScattId())
-+        dlg.Destroy()
++        #dlg.Destroy()
 +    def _addScattPlot(self, scatt_id):
 +        if self.plots.has_key(scatt_id):
@@ -716,8 +3496,13 @@
 +        cats_attrs = self.cats_mgr.GetCategoriesAttrs()
 +        for scatt_id, scatt in self.plots.iteritems():
++            print "getting plots %d" % scatt_id
 +            scatt_dt = self.scatts_dt.GetScatt(scatt_id)
-+            scatt.Plot(scatt_dt, cats_attrs)
++            print "getting allipses"
++            ellipses_dt = self.scatts_dt.GetEllipses(scatt_id)
++            print "plotting %d" % scatt_id
++            print ellipses_dt
++            scatt.Plot(scatt_dt, ellipses_dt, cats_attrs)
 +    def AddScattPlotDone(self, event):
@@ -730,15 +3515,12 @@
 +        if self.plot_mode:
 +            self.plots[scatt_id].SetMode(self.plot_mode)
-+        scatt_dt = self.scatts_dt.GetScatt(scatt_id)
-+        cats_attrs = self.cats_mgr.GetCategoriesAttrs()
++        if self.tasks_pids['add_scatt']:
++            return
++        #TODO no need to render all
++        self.RenderScattPlts()
-+        self.plots[scatt_id].Plot(scatt_dt, cats_attrs)
-+        self.plots[scatt_id].GetParent().Show()
 +    def PlotClosed(self, scatt_id):
-+        print scatt_id
 +        del self.plots[scatt_id]
@@ -776,6 +3558,7 @@
 +            return
 +        if event.pid in self.tasks_pids['add_scatt']:
++            self.tasks_pids['add_scatt'].remove(event.pid)
 +            self.AddScattPlotDone(event)
 +            return
@@ -795,20 +3578,32 @@
 +    def SetPlotsMode(self, mode):
 +        self.plot_mode = mode
 +        for scatt in self.plots.itervalues():
 +            scatt.SetMode(mode)
-+    def SetEditCatData(self, scatt_id, bbox):
++    def ActivateSelectionPolygonMode(self, activate):
++        self.pol_sel_mode[0] = activate
++        return activate
++    def ProcessSelectionPolygons(self, process_mode):
++        scatts_polygons = {}
++        for scatt_id, scatt in self.plots.iteritems():
++            coords = scatt.FinishDrawing()
++            if coords is not None:
++                scatts_polygons[scatt_id] = coords
++        if not scatts_polygons:
++            return
++        print "scatts_polygons"
++        print scatts_polygons
 +        value = 1
-+        if self.plot_mode == 'remove':
++        if process_mode == 'remove':
 +            value = 0
-+        self.tasks_pids['set_edit_cat_data'] = self.thread.GetId()
 +        sel_cat_id = self.cats_mgr.GetSelectedCat()
 +        if not sel_cat_id:
 +            dlg = wx.MessageDialog(parent = self.guiparent,
 +                      message = _("In order to select arrea in scatter plot, "
@@ -819,13 +3614,25 @@
 +                      style = wx.YES_NO)
 +            if dlg.ShowModal() == wx.ID_YES:
 +                self.iclass_conn.EmptyCategories()
++        sel_cat_id = self.cats_mgr.GetSelectedCat()
++        if not sel_cat_id:
 +            return
-+        self.thread.Run(callable = self.core.SetEditCatData,
-+                        scatt_id = scatt_id,
++        self.tasks_pids['set_edit_cat_data'] = self.thread.GetId()
++        self.thread.Run(callable = self.core.UpdateCategoryWithPolygons,
 +                        cat_id = sel_cat_id,
-+                        bbox = bbox,
++                        scatts_pols = scatts_polygons,
 +                        value = value)
++    def SetPlotsEditingMode(self, mode):
++        self.pol_sel_mode[1] = mode
++        for scatt in self.plots.itervalues():
++            scatt.SetEditingMode(mode)
 +    def SetEditCatDataDone(self, event):
@@ -884,6 +3691,7 @@
 +    def GetCategoriesManager(self):
 +class CategoriesManager:
 +    def __init__(self, scatt_mgr, core):
@@ -1147,12 +3955,482 @@
 +            bands = res.split('\n')
 +            self.scatt_mgr.SetData(bands)
-Index: gui/wxpython/scatt_plot/sc_pl_core.py
+Index: gui/wxpython/scatt_plot/gthreading.py
---- gui/wxpython/scatt_plot/sc_pl_core.py	(revision 0)
-+++ gui/wxpython/scatt_plot/sc_pl_core.py	(working copy)
-@@ -0,0 +1,632 @@
+--- gui/wxpython/scatt_plot/gthreading.py	(revision 0)
++++ gui/wxpython/scatt_plot/gthreading.py	(working copy)
+@@ -0,0 +1,134 @@
++ at package scatt_plot.gthreading
++Classes:
++import os
++import sys
++import time
++import threading
++import Queue
++import wx
++from core.gconsole import wxCmdRun, wxCmdDone, wxCmdPrepare
++class gThread(threading.Thread):
++    """!Thread for GRASS commands"""
++    requestId = 0
++    def __init__(self, receiver, requestQ=None, resultQ=None, **kwds):
++        @param receiver event receiver (used in PostEvent)
++        threading.Thread.__init__(self, **kwds)
++        if requestQ is None:
++            self.requestQ = Queue.Queue()
++        else:
++            self.requestQ = requestQ
++        if resultQ is None:
++            self.resultQ = Queue.Queue()
++        else:
++            self.resultQ = resultQ
++        self.setDaemon(True)
++        self.receiver = receiver
++        self._want_abort_all = False
++        self.start()
++    def Run(self, *args, **kwds):
++        """!Run command in queue
++        @param args unnamed command arguments
++        @param kwds named command arguments
++        @return request id in queue
++        gThread.requestId += 1
++        self.requestQ.put((gThread.requestId, args, kwds))
++        return gThread.requestId
++    def GetId(self):
++         """!Get id for next command"""
++         return gThread.requestId + 1
++    def SetId(self, id):
++        """!Set starting id"""
++        gThread.requestId = id
++    def run(self):
++        os.environ['GRASS_MESSAGE_FORMAT'] = 'gui'
++        while True:
++            requestId, args, kwds = self.requestQ.get()
++            for key in ('callable', 'onDone', 'onPrepare', 'userData'):
++                if key in kwds:
++                    vars()[key] = kwds[key]
++                    del kwds[key]
++                else:
++                    vars()[key] = None
++            requestTime = time.time()
++            #if self._want_abort_all and self.requestCmd is not None:
++            #    self.requestCmd.abort()
++            #    if self.requestQ.empty():
++            #        self._want_abort_all = False
++            # prepare
++            if self.receiver:
++                event = wxCmdPrepare(type = 'method',
++                                     time=requestTime,
++                                     pid=requestId)
++                wx.PostEvent(self.receiver, event)
++                # run command
++                event = wxCmdRun(type = 'method',
++                                 pid=requestId)
++            time.sleep(.1)
++            ret = None
++            exception = None
++            #to
++            #try:
++            ret = vars()['callable'](*args, **kwds)
++            #except Exception as e:
++            #    exception  = e;
++            self.resultQ.put((requestId, ret))
++            time.sleep(.1)
++                event = wxCmdDone(type = 'cmd',
++                                  kwds = kwds,
++                                  args = args, #TODO expand args to kwds
++                                  ret=ret,
++                                  exception=exception,
++                                  pid=requestId)
++                # send event
++    def abort(self, abortall=True):
++        """!Abort command(s)"""
++        if abortall:
++            self._want_abort_all = True
++        if self.requestQ.empty():
+\ No newline at end of file
+Index: gui/wxpython/scatt_plot/dialogs.py
+--- gui/wxpython/scatt_plot/dialogs.py	(revision 0)
++++ gui/wxpython/scatt_plot/dialogs.py	(working copy)
+@@ -0,0 +1,142 @@
++ at brief GUI.
++Classes:
++import os
++import sys
++import wx
++from scatt_plot.scatt_core import idBandsToidScatt
++        self.labels = {}
++        self.params = {}
++        # buttons
++        self._layout()
++        # buttons
++                          border = 10)
++                          border = 10)
++        self.Layout()
++        self.Fit()
++        # bindings
++                     border = 5)
++        return selSizer
++        """!Close dialog
++            self.Destroy()
++        event.Skip()
++            return
++            band_2 = band_1
++            band_1 = band_2
++        event.Skip()
+Index: gui/wxpython/scatt_plot/toolbars.py
+--- gui/wxpython/scatt_plot/toolbars.py	(revision 0)
++++ gui/wxpython/scatt_plot/toolbars.py	(working copy)
+@@ -0,0 +1,178 @@
++ at package scatt_plot.toolbars
++ at brief Scatter plot - toolbars
++Classes:
++ - toolbars::MainToolbar
++import wx
++from icons.icon import MetaIcon
++from gui_core.toolbars import BaseToolbar, BaseIcons
++from core.gcmd import RunCommand
++class MainToolbar(BaseToolbar):
++    """!Main toolbar
++    def __init__(self, parent, scatt_mgr):
++        BaseToolbar.__init__(self, parent)
++        self.InitToolbar(self._toolbarData())
++        # realize the toolbar
++        self.Realize()
++    def _toolbarData(self):
++        icons = {
++                'settings'   : BaseIcons['settings'].SetLabel( _('Ssettings')),
++                'help'       : MetaIcon(img = 'help',
++                                         label = _('Show manual')),
++                'add_scatt_pl'  : MetaIcon(img = 'layer-raster-analyze',
++                                            label = _('Add scatter plot')),
++                'selCatPol'  : MetaIcon(img = 'polygon-create',
++                                      label = _('Select area with polygon')),
++                'pan'        : MetaIcon(img = 'pan',
++                                         label = _('Pan'),
++                                         desc = _('Pan scatter plot')),
++                'zoomIn'     : MetaIcon(img = 'zoom-in',
++                                          label = _('Zoom'),
++                                          desc = _('Zoom whith mouse wheel')),
++                'cats_mgr' : MetaIcon(img = 'table-manager',
++                                          label = _('Show/hide class manager'))
++        return self._getToolbarData((
++                                     ("cats_mgr", icons['cats_mgr'],
++                                     lambda event: self.parent.ShowCategoryPanel(event.Checked()), wx.ITEM_CHECK),
++                                     (None, ),
++                                     ("pan", icons["pan"],
++                                     lambda event: self.SetPloltsMode(event, 'pan'),
++                                      wx.ITEM_CHECK),
++                                     ("zoom", icons["zoomIn"],
++                                     lambda event: self.SetPloltsMode(event, 'zoom'),
++                                      wx.ITEM_CHECK),
++                                     ('sel_pol_mode', icons['selCatPol'],
++                                      self.ActivateSelectionPolygonMode,
++                                     wx.ITEM_CHECK),
++                                     (None, ),
++                                     ('add_scatt', icons["add_scatt_pl"],
++                                     lambda event : self.scatt_mgr.AddScattPlot())
++                                     #('settings', icon["settings"],
++                                     # self.parent.OnSettings),
++                                     #('help', icons["help"],
++                                     # self.OnHelp),
++    def GetToolId(self, toolName): #TODO can be useful in base
++        return vars(self)[toolName]
++    def SetPloltsMode(self, event, tool_name):
++        if event.Checked()  == True:
++            for i_tool_data in  self._data:
++                i_tool_name = i_tool_data[0]
++                if not i_tool_name or i_tool_name == "cats_mgr":
++                    continue
++                if i_tool_name == tool_name:
++                    continue
++                i_tool_id = vars(self)[i_tool_name]
++                self.ToggleTool(i_tool_id, False)
++            self.scatt_mgr.SetPlotsMode(mode = tool_name)
++        else:
++            self.scatt_mgr.SetPlotsMode(mode = None)
++    def ActivateSelectionPolygonMode(self, event):
++        activated = self.scatt_mgr.ActivateSelectionPolygonMode(event.Checked())
++        self.parent.ShowPlotEditingToolbar(activated)
++        i_tool_id = vars(self)['sel_pol_mode']
++        self.ToggleTool(i_tool_id, activated)
++class EditingToolbar(BaseToolbar):
++    """!Main toolbar
++        self.Realize()
++        """!Toolbar data
++        self.icons = {
++            'sel_add'         : MetaIcon(img = 'layer-add',
++                                         label = _('Include selected areas from category.'),
++                                         desc = _('Include selected areas from category.')),
++            'sel_remove'      : MetaIcon(img = 'layer-remove',
++                                         label = _('Exclude selected areas from category.'),
++                                         desc = _('Exclude selected areas from category.')),
++            'addVertex'       : MetaIcon(img = 'vertex-create',
++                                         label = _('Add new vertex'),
++                                         desc = _('Add new vertex to polygon boundary scatter plot')),
++            'editLine'        : MetaIcon(img = 'line-edit',
++                                         label = _('Edit line/boundary'),
++                                         desc = _('Add new vertex to last point of the boundary')),
++            'moveVertex'      : MetaIcon(img = 'vertex-move',
++                                         label = _('Move vertex'),
++                                         desc = _('Move boundary vertex')),
++            'removeVertex'    : MetaIcon(img = 'vertex-delete',
++                                         label = _('Remove vertex'),
++                                         desc = _('Remove vertex.')),
++                                    ("sel_add", self.icons["sel_add"],
++                                     lambda event: self.scatt_mgr.ProcessSelectionPolygons('add')),
++                                     ("sel_remove", self.icons['sel_remove'],
++                                     lambda event: self.scatt_mgr.ProcessSelectionPolygons('remove')),
++                                     (None, ),
++                                     ("add_vertex", self.icons["editLine"],
++                                     lambda event: self.SetMode(event, 'add_vertex'),
++                                     wx.ITEM_CHECK),
++                                     ("add_boundary_vertex", self.icons['addVertex'],
++                                     lambda event: self.SetMode(event, 'add_boundary_vertex'),
++                                     wx.ITEM_CHECK),
++                                     ("move_vertex", self.icons["moveVertex"],
++                                     lambda event: self.SetMode(event, 'move_vertex'),
++                                     wx.ITEM_CHECK),
++                                     ('delete_vertex', self.icons['removeVertex'],
++                                     lambda event: self.SetMode(event, 'delete_vertex'),
++                                     wx.ITEM_CHECK)
++    def SetMode(self, event, tool_name):
++                if not i_tool_name:
++                    continue
++                    continue
++            self.scatt_mgr.SetPlotsEditingMode(tool_name)
++        else:
++            self.scatt_mgr.SetPlotsEditingMode(None)
+Index: gui/wxpython/scatt_plot/scatt_core.py
+--- gui/wxpython/scatt_plot/scatt_core.py	(revision 0)
++++ gui/wxpython/scatt_plot/scatt_core.py	(working copy)
+@@ -0,0 +1,802 @@
 + at package scatt_plot.scatt_plot
 + at brief Non GUI functions.
@@ -1170,9 +4448,12 @@
 +import sys
 +#TODO
++import Image
 +import time
 +import numpy as np
++#TODO should use another function
++from matplotlib.nxutils import points_inside_poly
 +from math import sqrt, ceil, floor
@@ -1277,14 +4558,56 @@
 +        returncode, scatts = ComputeScatts(self.an_data.GetRegion(), scatt_conds, bands,
 +                                           len(self.GetBands()), scatts, cats_rasts_conds, cats_rasts)
++        print "ComputeScatts"
++        print returncode
 +        if returncode < 0:
 +            GException(_("Computing of scatter plots failed."))
 +        #self.scatts_dt.SetData(scatts)
 +    def CatRastUpdater(self):
 +        return self.cat_rast_updater
++    def UpdateCategoryWithPolygons(self, cat_id, scatts_pols, value):
++        print "scatt_plot core PolygonDrawn"
++        print cat_id
++        if cat_id not in self.scatts_dt.GetCategories():
++            raise GException(_("Select category for editing."))
++        for scatt_id, coords in scatts_pols.iteritems():
++            if self.scatt_conds_dt.AddScattPlot(cat_id, scatt_id) < 0:
++                return False
++            b1, b2 = idScattToidBands(scatt_id, len(self.an_data.GetBands()))
++            b1_info = self.an_data.GetBandInfo(b1)
++            b2_info = self.an_data.GetBandInfo(b2)
++            raster_pol = RasterizePolygon(coords, b1_info['range'], b2_info['range'])
++            rescaled = (255.0 / raster_pol.max() * (raster_pol - raster_pol.min())).astype(np.uint8)
++            im = Image.fromarray(rescaled)
++            im.save('/home/ostepok/Desktop/obrazek.png')
++            raster_ind = np.where(raster_pol > 0)
++            arr = self.scatt_conds_dt.GetValuesArr(cat_id, scatt_id)
++            arr[raster_ind] = value
++            arr.flush()
++        rescaled = (255.0 / arr.max() * (arr - arr.min())).astype(np.uint8)
++        im.save('/home/ostepok/Desktop/arr_obrazek.png')
++        self.ComputeCatsScatts([cat_id])
++        for scatt_id in scatts_pols.iterkeys():
++            print self.scatts_dt.GetEllipses(scatt_id)
 +    def _validExtend(self, val):
 +        #TODO do it general
 +        if  val > 255:
@@ -1483,6 +4806,7 @@
 +            raster_info[k] = v
++        raster_info['range'] = raster_info['max'] - raster_info['min'] + 1
 +        return raster_info
 +    def GetBands(self):
@@ -1585,7 +4909,7 @@
 +        np_vals.flush()
 +        self.cats[cat_id][scatt_id] = {
-+                                        'np_vals' : np_vals
++                                        'np_vals' : np_vals,
 +        return 1
@@ -1698,6 +5022,7 @@
 +        self.scatts_ids.append(scatt_id)
 +        for cat_id in self.cats.iterkeys():
 +                ScattPlotsCondsData.AddScattPlot(self, cat_id, scatt_id)
++                self.cats[cat_id][scatt_id]['ellipse'] = None
 +        return True
@@ -1723,6 +5048,95 @@
 +                              'bands_info' : self.GetBandsInfo(scatt_id)}
 +        return scatts
++    def GetEllipses(self, scatt_id):
++        if scatt_id not in self.scatts_ids:
++            return False
++        scatts = {}
++        for cat_id in self.cats.iterkeys():
++            if cat_id == 0:
++                continue
++            scatts[cat_id] = self._getEllipse(cat_id, scatt_id)
++        return scatts
++    def _getEllipse(self, cat_id, scatt_id):
++        # Joe Kington
++        # http://stackoverflow.com/questions/12301071/multidimensional-confidence-intervals
++        nstd = 2
++        data = np.copy(self.cats[cat_id][scatt_id]['np_vals'])
++        #b1, b2 = idScattToidBands(scatt_id, len(self.an_data.GetBands()))
++        #print "jedu"
++        #b1_range = self.an_data.GetBandInfo(b1)['range']
++        #b2_range = self.an_data.GetBandInfo(b2)['range']
++        #print "ranges done"
++        sel_pts = np.where(data > 0)
++        x = sel_pts[1]
++        y = sel_pts[0]
++        print "sel pts done"
++        #sel_pts = np.array(sel_pts).T
++        #print sel_pts
++        #print "jedu"
++        #pos = sel_pts.mean(axis=0)
++        #cov = np.cov(sel_pts, rowvar=False)
++        flatten_data = data.reshape([-1])
++        flatten_sel_pts = np.nonzero(flatten_data)
++        weights = flatten_data[flatten_sel_pts]
++        if len(weights) == 0:
++            return None
++        x_avg = np.average(x, weights=weights)
++        y_avg = np.average(y, weights=weights)
++        pos = np.array([x_avg, y_avg])
++        x_diff = (x - x_avg)
++        y_diff = (y - y_avg)
++        diffs = x_diff * y_diff.T
++        cov = np.dot(diffs, weights) / (np.sum(weights) - 1)
++        diffs = x_diff * x_diff.T
++        var_x = np.dot(diffs, weights) /  (np.sum(weights) - 1)
++        diffs = y_diff * y_diff.T
++        var_y = np.dot(diffs, weights) /  (np.sum(weights) - 1)
++        cov = np.array([[var_x, cov],[cov, var_y]])
++        def eigsorted(cov):
++            vals, vecs = np.linalg.eigh(cov)
++            order = vals.argsort()[::-1]
++            return vals[order], vecs[:,order]
++        vals, vecs = eigsorted(cov)
++        theta = np.degrees(np.arctan2(*vecs[:,0][::-1]))
++        # Width and height are "full" widths, not radius
++        width, height = 2 * nstd * np.sqrt(vals)
++        ellipse = {'pos' : pos,
++                   'width' : width,
++                   'height' : height,
++                   'theta' : theta}
++        del data
++        del flatten_data
++        del flatten_sel_pts
++        del weights
++        del sel_pts
++        return ellipse
 +        ScattPlotsCondsData.CleanUp(self)
@@ -1759,6 +5173,41 @@
 +        return cats_rasts
++def RasterizePolygon(pol, height, width):
++    # Joe Kington
++    # http://stackoverflow.com/questions/3654289/scipy-create-2d-polygon-mask
++    #poly_verts = [(1,1), (1,4), (4,4),(4,1), (1,1)]
++    nx = width + 1
++    ny = height + 1
++    x, y = np.meshgrid(np.arange(nx), np.arange(ny))
++    x, y = x.flatten(), y.flatten()
++    points = np.vstack((x,y)).T
++    grid = points_inside_poly(points, pol)
++    grid = grid.reshape((ny,nx))
++    raster = np.zeros((height, width), dtype=np.uint8)#TODO bool
++    #TODO this part is very inefficient, replace it with better solution
++    for (y, x), value in np.ndenumerate(grid):
++        if x >= width - 1: continue
++        if y >= height - 1: continue
++        if grid[y, x]:
++            raster[y, x] = 1
++            raster[y + 1, x] = 1
++            raster[y, x + 1] = 1
++            raster[y + 1, x + 1] = 1
++    return raster
 +#TODO move to utils?
 +def idScattToidBands(scatt_id, n_bands):
@@ -1770,7 +5219,6 @@
 +    return band_1, band_2
 +def idBandsToidScatt(band_1_id, band_2_id, n_bands):
 +    if band_2_id <  band_1_id:
@@ -1784,1560 +5232,9 @@
 +    return scatt_id
-Index: gui/wxpython/scatt_plot/gthreading.py
---- gui/wxpython/scatt_plot/gthreading.py	(revision 0)
-+++ gui/wxpython/scatt_plot/gthreading.py	(working copy)
-@@ -0,0 +1,134 @@
-+ at package scatt_plot.gthreading
-+Classes:
-+(C) 2013 by the GRASS Development Team
-+This program is free software under the GNU General Public License
-+(>=v2). Read the file COPYING that comes with GRASS for details.
-+ at author Stepan Turek <stepan.turek seznam.cz> (mentor: Martin Landa)
-+import os
-+import sys
-+import time
-+import threading
-+import Queue
-+import wx
-+from core.gconsole import wxCmdRun, wxCmdDone, wxCmdPrepare
-+class gThread(threading.Thread):
-+    """!Thread for GRASS commands"""
-+    requestId = 0
-+    def __init__(self, receiver, requestQ=None, resultQ=None, **kwds):
-+        @param receiver event receiver (used in PostEvent)
-+        threading.Thread.__init__(self, **kwds)
-+        if requestQ is None:
-+            self.requestQ = Queue.Queue()
-+        else:
-+            self.requestQ = requestQ
-+        if resultQ is None:
-+            self.resultQ = Queue.Queue()
-+        else:
-+            self.resultQ = resultQ
-+        self.setDaemon(True)
-+        self.receiver = receiver
-+        self._want_abort_all = False
-+        self.start()
-+    def Run(self, *args, **kwds):
-+        """!Run command in queue
-+        @param args unnamed command arguments
-+        @param kwds named command arguments
-+        @return request id in queue
-+        gThread.requestId += 1
-+        self.requestQ.put((gThread.requestId, args, kwds))
-+        return gThread.requestId
-+    def GetId(self):
-+         """!Get id for next command"""
-+         return gThread.requestId + 1
-+    def SetId(self, id):
-+        """!Set starting id"""
-+        gThread.requestId = id
-+    def run(self):
-+        os.environ['GRASS_MESSAGE_FORMAT'] = 'gui'
-+        while True:
-+            requestId, args, kwds = self.requestQ.get()
-+            for key in ('callable', 'onDone', 'onPrepare', 'userData'):
-+                if key in kwds:
-+                    vars()[key] = kwds[key]
-+                    del kwds[key]
-+                else:
-+                    vars()[key] = None
-+            requestTime = time.time()
-+            #if self._want_abort_all and self.requestCmd is not None:
-+            #    self.requestCmd.abort()
-+            #    if self.requestQ.empty():
-+            #        self._want_abort_all = False
-+            # prepare
-+            if self.receiver:
-+                event = wxCmdPrepare(type = 'method',
-+                                     time=requestTime,
-+                                     pid=requestId)
-+                wx.PostEvent(self.receiver, event)
-+                # run command
-+                event = wxCmdRun(type = 'method',
-+                                 pid=requestId)
-+            time.sleep(.1)
-+            ret = None
-+            exception = None
-+            #to
-+            #try:
-+            ret = vars()['callable'](*args, **kwds)
-+            #except Exception as e:
-+            #    exception  = e;
-+            self.resultQ.put((requestId, ret))
-+            time.sleep(.1)
-+                event = wxCmdDone(type = 'cmd',
-+                                  kwds = kwds,
-+                                  args = args, #TODO expand args to kwds
-+                                  ret=ret,
-+                                  exception=exception,
-+                                  pid=requestId)
-+                # send event
-+    def abort(self, abortall=True):
-+        """!Abort command(s)"""
-+        if abortall:
-+            self._want_abort_all = True
-+        if self.requestQ.empty():
-Index: gui/wxpython/scatt_plot/dialogs_iclass.py
---- gui/wxpython/scatt_plot/dialogs_iclass.py	(revision 0)
-+++ gui/wxpython/scatt_plot/dialogs_iclass.py	(working copy)
-@@ -0,0 +1,464 @@
-+ at package scatt_plot.dialogs
-+ at brief GUI.
-+Classes:
-+import os
-+import sys
-+import wx
-+import wx.lib.scrolledpanel as scrolled
-+import wx.lib.mixins.listctrl as listmix
-+import wx.lib.flatnotebook  as FN
-+import wx.aui
-+from core import globalvar
-+from core.gcmd import GException, GError, RunCommand
-+from gui_core.gselect import Select
-+from scatt_plot.controllers import ScattsManager
-+from scatt_plot.toolbars_iclass import MainToolbar
-+from scatt_plot.sc_pl_core import idScattToidBands
-+from scatt_plot.plots import ScatterPlotWidget
-+try:
-+    from agw import aui
-+except ImportError:
-+    import wx.lib.agw.aui as aui
-+class IClassScatterPlotsPanel(wx.Panel):
-+    def __init__(self, parent, giface, iclass_mapwin = None,
-+                 id = wx.ID_ANY, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
-+        #wx.SplitterWindow.__init__(self, parent = parent, id = id,
-+        #                           style = wx.SP_LIVE_UPDATE)
-+        wx.Panel.__init__(self, parent = parent, id = wx.ID_ANY)
-+        #self.head_panel = wx.Panel(parent = self, id = wx.ID_ANY)
-+        self.scatt_mgr = ScattsManager(guiparent = self, giface = giface, iclass_mapwin = iclass_mapwin)
-+        # toobars
-+        self.toolbars = {}
-+        self.toolbars['mainToolbar'] = MainToolbar(parent = self, scatt_mgr = self.scatt_mgr)
-+        self._createCategoryPanel(self)
-+        self.plot_panel = IClassPlotPanel(self, self.scatt_mgr)
-+        mainsizer = wx.BoxSizer(wx.VERTICAL)
-+        mainsizer.Add(item = self.toolbars['mainToolbar'], proportion = 0, flag = wx.EXPAND)
-+        mainsizer.Add(item = self.catsPanel, proportion = 0, flag = wx.EXPAND | wx.LEFT | wx.RIGHT , border = 5)
-+        mainsizer.Add(item = self.plot_panel, proportion = 1, flag = wx.EXPAND)
-+        self.catsPanel.Hide()
-+        self.SetSizer(mainsizer)
-+        #self.SetSashGravity(0.5)
-+        #self.SplitHorizontally(self.head_panel, self.plot_panel, -50)
-+        self.Layout()
-+        #self.SetAutoLayout(1)
-+    def NewScatterPlot(self, scatt_id):
-+        return self.plot_panel.NewScatterPlot(scatt_id)
-+    def ShowCategoryPanel(self, show):
-+        self.catsPanel.Show(show)
-+        #if show:
-+        #    self.SetSashSize(5)
-+        #else:
-+        #    self.SetSashSize(0)
-+        self.plot_panel.SetVirtualSize(self.plot_panel.GetBestVirtualSize())
-+        self.Layout()
-+    def _createCategoryPanel(self, parent):
-+        self.catsPanel = wx.Panel(parent = parent)
-+        self.cats_list = CategoryListCtrl(parent = self.catsPanel,
-+                                          cats_mgr = self.scatt_mgr.GetCategoriesManager())
-+        self.catsPanel.SetMaxSize((-1, 150))
-+        box_capt = wx.StaticBox(parent = self.catsPanel, id = wx.ID_ANY,
-+                             label = ' %s ' % _("Classes manager for scatter plots"))
-+        catsSizer = wx.StaticBoxSizer(box_capt, wx.VERTICAL)
-+        catsSizer.Add(item = self.cats_list, proportion = 1, flag = wx.EXPAND | wx.ALL)
-+        self.catsPanel.SetSizer(catsSizer)
-+class IClassPlotPanel(scrolled.ScrolledPanel):
-+    def __init__(self, parent, scatt_mgr, id = wx.ID_ANY):
-+        scrolled.ScrolledPanel.__init__(self, parent)
-+        self.SetupScrolling(scroll_x = False, scroll_y = True)
-+        self.scatt_mgr = scatt_mgr
-+        self.mainPanel = wx.Panel(parent = self, id = wx.ID_ANY)
-+        #self._createCategoryPanel()
-+        # Fancy gui
-+        self._mgr = aui.AuiManager(self.mainPanel)
-+        #self._mgr.SetManagedWindow(self)
-+        self._mgr.Update()
-+        self._doLayout()
-+        self.Bind(wx.EVT_SCROLLWIN, self.OnScroll)
-+        self.Bind(aui.EVT_AUI_PANE_CLOSE, self.OnPlotPaneClosed)
-+        dlgSize = (-1, 400)
-+        #self.SetBestSize(dlgSize)
-+        #self.SetInitialSize(dlgSize)
-+        self.SetAutoLayout(1)
-+        #fix goutput's pane size (required for Mac OSX)
-+        #if self.gwindow:
-+        #    self.gwindow.SetSashPosition(int(self.GetSize()[1] * .75))
-+    def OnPlotPaneClosed(self, event):
-+        if isinstance(event.pane.window, ScatterPlotWidget):
-+            event.pane.window.CleanUp()
-+    def OnScroll(self, event):
-+        event.Skip()
-+        wx.CallAfter(self._mgr.Update)
-+        wx.CallAfter(self.Layout)
-+    def _doLayout(self):
-+        mainsizer.Add(item = self.mainPanel, proportion = 1, flag = wx.EXPAND)
-+        self.Layout()
-+        self.SetupScrolling()
-+    def OnCloseDialog(self, event):
-+        """!Close dialog"""
-+        self.scatt_mgr.CleanUp()
-+        self.Destroy()
-+    def OnSettings(self, event):
-+        pass
-+        #TODO needs to be resolved (should be in this class)
-+        scatt = ScatterPlotWidget(parent = self.mainPanel,
-+                                  scatt_mgr = self.scatt_mgr,
-+                                  scatt_id = scatt_id)
-+        bands = self.scatt_mgr.GetBands()
-+        #TODO too low level
-+        b1_id, b2_id = idScattToidBands(scatt_id, len(bands))
-+        self._mgr.AddPane(scatt,
-+                           aui.AuiPaneInfo().Dockable(True).Floatable(True).
-+                           Name("scatter plot %d" % scatt_id).MinSize((-1, 300)).Caption(("%s x: %s y: %s") % (_("scatter plot"), bands[b1_id], bands[b2_id])).
-+                           Center().Position(1).MaximizeButton(True).
-+                           MinimizeButton(True).CaptionVisible(True).
-+                           CloseButton(True).Layer(0))
-+        self.SetVirtualSize(self.GetBestVirtualSize())
-+        self.Layout()
-+        return scatt
-+    def GetScattMgr(self):
-+        return  self.scatt_mgr
-+class CategoryListCtrl(wx.ListCtrl,
-+                       listmix.ListCtrlAutoWidthMixin,
-+                       listmix.TextEditMixin):
-+    def __init__(self, parent, cats_mgr, id = wx.ID_ANY):
-+        wx.ListCtrl.__init__(self, parent, id,
-+                             style = wx.LC_REPORT|wx.LC_VIRTUAL|wx.LC_HRULES|wx.LC_VRULES)
-+        self.columns = ((_('Class name'), 'name'),
-+                        (_('Color'), 'color'))
-+        self.Populate(columns = self.columns)
-+        self.cats_mgr = cats_mgr
-+        self.SetItemCount(len(self.cats_mgr.GetCategories()))
-+        self.rightClickedItemIdx = wx.NOT_FOUND
-+        listmix.ListCtrlAutoWidthMixin.__init__(self)
-+        listmix.TextEditMixin.__init__(self)
-+        self.Bind(wx.EVT_LIST_BEGIN_LABEL_EDIT, self.OnEdit)
-+        self.Bind(wx.EVT_LIST_ITEM_SELECTED, self.OnSel)
-+        self.cats_mgr.setCategoryAttrs.connect(self.Update)
-+        self.cats_mgr.deletedCategory.connect(self.Update)
-+        self.cats_mgr.addedCategory.connect(self.Update)
-+    def Update(self, **kwargs):
-+        self.RefreshItems(0, len(self.cats_mgr.GetCategories()))
-+    def InitCoreCats(self):
-+    def SetVirtualData(self, row, column, text):
-+        attr = self.columns[column][1]
-+        if attr == 'name':
-+            try:
-+                text.encode('ascii')
-+            except UnicodeEncodeError:
-+                GMessage(parent = self, message = _("Please use only ASCII characters."))
-+                return
-+        cat_id = self.cats_mgr.GetCategories()[row]
-+        self.cats_mgr.setCategoryAttrs.disconnect(self.Update)
-+        self.cats_mgr.SetCategoryAttrs(cat_id, {attr : text})
-+        self.Select(row)
-+    def Populate(self, columns):
-+        for i, col in enumerate(columns):
-+            self.InsertColumn(i, col[0])#wx.LIST_FORMAT_RIGHT
-+        self.SetColumnWidth(0, 100)
-+        self.SetColumnWidth(1, 100)
-+    def AddCategory(self):
-+        self.cats_mgr.addedCategory.disconnect(self.Update)
-+        cat_id = self.cats_mgr.AddCategory()
-+        if cat_id < 0:
-+            GError(_("Maximum limit of categories number was reached."))
-+            return
-+    def DeleteCategory(self):
-+        indexList = sorted(self.GetSelectedIndices(), reverse = True)
-+        cats = []
-+        for i in indexList:
-+            # remove temporary raster
-+            cat_id = self.cats_mgr.GetCategories()[i]
-+            cats.append(cat_id)
-+            self.cats_mgr.deletedCategory.disconnect(self.Update)
-+            self.cats_mgr.DeleteCategory(cat_id)
-+    def OnSel(self, event):
-+        event.Skip()
-+    def GetSelectedIndices(self, state =  wx.LIST_STATE_SELECTED):
-+        indices = []
-+        lastFound = -1
-+        while True:
-+            index = self.GetNextItem(lastFound, wx.LIST_NEXT_ALL, state)
-+            if index == -1:
-+                break
-+            else:
-+                lastFound = index
-+                indices.append(index)
-+        return indices
-+    def OnEdit(self, event):
-+        currentItem = event.m_itemIndex
-+        currentCol = event.m_col
-+        if currentCol == 1:
-+            dlg = wx.ColourDialog(self)
-+            dlg.GetColourData().SetChooseFull(True)
-+                color = dlg.GetColourData().GetColour().Get()
-+                color = ':'.join(map(str, color))
-+                self.SetVirtualData(currentItem, currentCol, color)
-+            dlg.Destroy()
-+            wx.CallAfter(self.SetFocus)
-+        event.Skip()
-+    def DeselectAll(self):
-+        """!Deselect all items"""
-+        indexList = self.GetSelectedIndices()
-+            self.Select(i, on = 0)
-+        # no highlight
-+        self.OnCategorySelected(None)
-+    def OnGetItemText(self, item, col):
-+        attr = self.columns[col][1]
-+        cat_id = self.cats_mgr.GetCategories()[item]
-+        return self.cats_mgr.GetCategoryAttrs(cat_id)[attr]
-+    def OnGetItemImage(self, item):
-+        return -1
-+    def OnGetItemAttr(self, item):
-+        return None
-+    def OnClassRightUp(self, event):
-+        """!Show context menu on right click"""
-+        item, flags = self.HitTest((event.GetX(), event.GetY()))
-+        if item != wx.NOT_FOUND and flags & wx.LIST_HITTEST_ONITEM:
-+            self.rightClickedItemIdx = item
-+        self.popupZoomtoAreas = wx.NewId()
-+        self.Bind(wx.EVT_MENU, self.OnZoomToAreasByCat, id = self.popupZoomtoAreas)
-+        # generate popup-menu
-+        menu = wx.Menu()
-+        menu.Append(self.popupZoomtoAreas, _("Zoom to training areas of selected class"))
-+        self.PopupMenu(menu)
-+        menu.Destroy()
-+    def OnZoomToAreasByCat(self, event):
-+        """!Zoom to areas of given category"""
-+        cat = self.stats_data.GetCategories()[self.rightClickedItemIdx]
-+        self.mapWindow.ZoomToAreasByCat(cat)
-+class AddScattPlotDialog(wx.Dialog):
-+    def __init__(self, parent, bands, id  = wx.ID_ANY):
-+        wx.Dialog.__init__(self, parent, title = ("Add scatter plot"), id = id)
-+        self.bands = bands
-+        self.scatt_id = None
-+        self._createWidgets()
-+        self.labels = {}
-+        self.params = {}
-+        self.band_1_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 1:"))
-+        self.band_1_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
-+                                     choices = self.bands,
-+                                     style = wx.CB_READONLY, size = (350, 30))
-+        self.band_2_label = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Band 2:"))
-+        self.band_2_ch = wx.ComboBox(parent = self, id = wx.ID_ANY,
-+        # buttons
-+        self.btn_close = wx.Button(parent = self, id = wx.ID_CANCEL)
-+        self.btn_ok = wx.Button(parent = self, id = wx.ID_OK, label = _("&OK"))
-+        self._layout()
-+    def _layout(self):
-+        border = wx.BoxSizer(wx.VERTICAL)
-+        dialogSizer = wx.BoxSizer(wx.VERTICAL)
-+        regionSizer = wx.BoxSizer(wx.HORIZONTAL)
-+        dialogSizer.Add(item = self._addSelectSizer(title = self.band_1_label,
-+                                                    sel = self.band_1_ch))
-+        dialogSizer.Add(item = self._addSelectSizer(title = self.band_2_label,
-+                                                    sel = self.band_2_ch))
-+        # buttons
-+        self.btnsizer = wx.BoxSizer(orient = wx.HORIZONTAL)
-+        self.btnsizer.Add(item = self.btn_close, proportion = 0,
-+                          flag = wx.ALL | wx.ALIGN_CENTER,
-+                          border = 10)
-+        self.btnsizer.Add(item = self.btn_ok, proportion = 0,
-+                          border = 10)
-+        dialogSizer.Add(item = self.btnsizer, proportion = 0,
-+                        flag = wx.ALIGN_CENTER)
-+        border.Add(item = dialogSizer, proportion = 0,
-+                   flag = wx.ALL, border = 5)
-+        self.SetSizer(border)
-+        self.Layout()
-+        self.Fit()
-+        # bindings
-+        self.btn_close.Bind(wx.EVT_BUTTON, self.OnClose)
-+        self.btn_ok.Bind(wx.EVT_BUTTON, self.OnOk)
-+    def _addSelectSizer(self, title, sel):
-+        """!Helper layout function.
-+        selSizer = wx.BoxSizer(orient = wx.VERTICAL)
-+        selTitleSizer = wx.BoxSizer(wx.HORIZONTAL)
-+        selTitleSizer.Add(item = title, proportion = 1,
-+                          flag = wx.LEFT | wx.TOP | wx.EXPAND, border = 5)
-+        selSizer.Add(item = selTitleSizer, proportion = 0,
-+                     flag = wx.EXPAND)
-+        selSizer.Add(item = sel, proportion = 1,
-+                     flag = wx.EXPAND | wx.ALL| wx.ALIGN_CENTER_VERTICAL,
-+                     border = 5)
-+        return selSizer
-+    def OnClose(self, event):
-+        """!Close dialog
-+        if not self.IsModal():
-+            self.Destroy()
-+        event.Skip()
-+    def OnOk(self, event):
-+        band_1 = self.band_1_ch.GetSelection()
-+        band_2 = self.band_2_ch.GetSelection()
-+        if band_1 == band_2:
-+            GError(_("Selected bands must be different."))
-+            return
-+        #TODO axes selection
-+        if band_1 > band_2:
-+            tmp_band = band_2
-+            band_2 = band_1
-+            band_1 = band_2
-+        self.scatt_id = idBandsToidScatt(band_1, band_2, len(self.bands))
-+        event.Skip()
-+    def GetScattId(self):
-+        return self.scatt_id
-Index: gui/wxpython/scatt_plot/dialogs.py
---- gui/wxpython/scatt_plot/dialogs.py	(revision 0)
-+++ gui/wxpython/scatt_plot/dialogs.py	(working copy)
-@@ -0,0 +1,142 @@
-+ at brief GUI.
-+Classes:
-+import os
-+import sys
-+import wx
-+from scatt_plot.sc_pl_core import idBandsToidScatt
-+        self.labels = {}
-+        self.params = {}
-+        # buttons
-+        self._layout()
-+        # buttons
-+                          border = 10)
-+                          border = 10)
-+        self.Layout()
-+        self.Fit()
-+        # bindings
-+                     border = 5)
-+        return selSizer
-+        """!Close dialog
-+            self.Destroy()
-+        event.Skip()
-+            return
-+            band_2 = band_1
-+            band_1 = band_2
-+        event.Skip()
-Index: gui/wxpython/scatt_plot/toolbars_iclass.py
---- gui/wxpython/scatt_plot/toolbars_iclass.py	(revision 0)
-+++ gui/wxpython/scatt_plot/toolbars_iclass.py	(working copy)
-@@ -0,0 +1,106 @@
-+ at package scatt_plot.toolbars
-+ at brief Scatter plot - toolbars
-+Classes:
-+ - toolbars::MainToolbar
-+import wx
-+from icons.icon import MetaIcon
-+from gui_core.toolbars import BaseToolbar, BaseIcons
-+from core.gcmd import RunCommand
-+class MainToolbar(BaseToolbar):
-+    """!Main toolbar
-+    def __init__(self, parent, scatt_mgr):
-+        BaseToolbar.__init__(self, parent)
-+        self.InitToolbar(self._toolbarData())
-+        # realize the toolbar
-+        self.Realize()
-+    def _toolbarData(self):
-+        icons = {
-+                 'settings'   : BaseIcons['settings'].SetLabel( _('Ssettings')),
-+                 'help'       : MetaIcon(img = 'help',
-+                                         label = _('Show manual')),
-+                 'add_scatt_pl'  : MetaIcon(img = 'layer-raster-analyze',
-+                                            label = _('Add scatter plot')),
-+                 'editCatAdd'  : MetaIcon(img = 'polygon-create',
-+                                          label = _('Add region from scatter plot')),
-+                 'editCatRemove'  : MetaIcon(img = 'polygon-delete',
-+                                             label = _('Remove region from scatter plot')),
-+                 'pan'        : MetaIcon(img = 'pan',
-+                                         label = _('Pan'),
-+                                         desc = _('Pan scatter plot')),
-+                'zoomIn'     : MetaIcon(img = 'zoom-in',
-+                                          label = _('Zoom'),
-+                                          desc = _('Zoom whith mouse wheel')),
-+                'cats_mgr' : MetaIcon(img = 'table-manager',
-+                                          label = _('Show/hide class manager'))
-+        return self._getToolbarData((
-+                                     ("cats_mgr", icons['cats_mgr'],
-+                                     lambda event: self.parent.ShowCategoryPanel(event.Checked()), wx.ITEM_CHECK),
-+                                     (None, ),
-+                                     ("pan", icons["pan"],
-+                                     lambda event: self.SetPloltsMode(event, 'pan'),
-+                                      wx.ITEM_CHECK),
-+                                     ("zoom", icons["zoomIn"],
-+                                     lambda event: self.SetPloltsMode(event, 'zoom'),
-+                                      wx.ITEM_CHECK),
-+                                     ('add', icons['editCatAdd'],
-+                                     lambda event: self.SetPloltsMode(event, 'add'),
-+                                     wx.ITEM_CHECK),
-+                                     ('remove', icons['editCatRemove'],
-+                                     lambda event: self.SetPloltsMode(event, 'remove'),
-+                                     wx.ITEM_CHECK),
-+                                     (None, ),
-+                                     ('add_scatt', icons["add_scatt_pl"],
-+                                     lambda event : self.scatt_mgr.AddScattPlot())
-+                                     #('settings', icon["settings"],
-+                                     # self.parent.OnSettings),
-+                                     #('help', icons["help"],
-+                                     # self.OnHelp),
-+    def GetToolId(self, toolName): #TODO can be useful in base
-+        return vars(self)[toolName]
-+    def SetPloltsMode(self, event, tool_name):
-+        #TODO move to toolbars
-+        if  event.Checked()  == True:
-+            for i_tool_data in  self._data:
-+                i_tool_name = i_tool_data[0]
-+                if  not i_tool_name or i_tool_name == "cats_mgr":
-+                    continue
-+                if i_tool_name == tool_name:
-+                    continue
-+                i_tool_id = vars(self)[i_tool_name]
-+                self.ToggleTool(i_tool_id, False)
-+            self.scatt_mgr.SetPlotsMode(mode = tool_name)
-+            return
-+        self.scatt_mgr.SetPlotsMode(mode = None)
-Index: gui/wxpython/scatt_plot/toolbars.py
---- gui/wxpython/scatt_plot/toolbars.py	(revision 0)
-+++ gui/wxpython/scatt_plot/toolbars.py	(working copy)
-@@ -0,0 +1,106 @@
-+Classes:
-+import wx
-+    """!Main toolbar
-+    def __init__(self, parent):
-+        self.Realize()
-+        icons = {
-+                 'set_data'    : MetaIcon(img = 'layer-raster-add',
-+                                         label = _('Set input raster data for plots')),
-+                                     ('sat_data', icons["set_data"],
-+                                      self.parent.OnSetData),
-+                                     (None, ),
-+                                      self.parent.OnAddScattPl),
-+                                     #('settings', icons["settings"],
-+                                     # self.OnHelp),
-+                                     ("quit", BaseIcons['quit'],
-+                                      self.parent.OnCloseDialog)
-+    def OnHelp(self, event) :
-+            RunCommand('g.manual',
-+                       entry = 'wxGUI.scatt_plot')
-+class CategoriesToolbar(BaseToolbar):
-+    def __init__(self, parent, cats_list, scatts_dlg):
-+        self.cats_list = cats_list
-+        self.scatts_dlg = scatts_dlg
-+        self.Realize()
-+        icons = {
-+                                     label = _('Add region to category mode')),
-+                                        label = _('Remove region to category mode')),
-+            'addCat'     : MetaIcon(img = 'layer-add',
-+                                    label = _('Add category')),
-+            'deleteCat'  : MetaIcon(img = 'layer-remove',
-+                                    label = _('Delete category'))
-+        return  self._getToolbarData((('editCatAdd', icons['editCatAdd'],
-+                                        lambda event: self.scatts_dlg.EditCatAdd(),
-+                                        wx.ITEM_CHECK),
-+                                      ('editCatRemove', icons['editCatRemove'],
-+                                        lambda event: self.scatts_dlg.EditCatRemove(),
-+                                        wx.ITEM_CHECK),
-+                                     (None, ),
-+                                     ('addCat', icons["addCat"],
-+                                        lambda event: self.cats_list.AddCategory()),
-+                                     ('deleteCat', icons["deleteCat"],
-+                                        lambda event: self.cats_list.DeleteCategory())))
-Index: gui/wxpython/Makefile
---- gui/wxpython/Makefile	(revision 57457)
-+++ gui/wxpython/Makefile	(working copy)
-@@ -13,7 +13,7 @@
- 	$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
- 	gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
- 	mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* vdigit/* \
--	vnet/*.py web_services/*.py wxplot/*.py) \
-+	vnet/*.py web_services/*.py wxplot/*.py scatt_plot/*.py) \
- 	gis_set.py gis_set_error.py wxgui.py README
- DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) \
-@@ -21,7 +21,7 @@
- PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
- 	gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
--	mapswipe vdigit wxplot web_services rlisetup vnet)
-+	mapswipe vdigit wxplot web_services rlisetup vnet scatt_plot)
- DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
-Index: gui/wxpython/vdigit/wxdigit.py
---- gui/wxpython/vdigit/wxdigit.py	(revision 57457)
-+++ gui/wxpython/vdigit/wxdigit.py	(working copy)
-@@ -17,7 +17,7 @@
- (and NumPy would be an excellent candidate for acceleration via
- e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
--(C) 2007-2011 by the GRASS Development Team
-+(C) 2007-2011, 2013 by the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
-@@ -27,6 +27,8 @@
- import grass.script.core as grass
-+from grass.pydispatch.signal import Signal
- from core.gcmd        import GError
- from core.debug       import Debug
- from core.settings    import UserSettings
-@@ -176,7 +178,21 @@
-         if self.poMapInfo:
-             self.InitCats()
-+        self.emit_signals = False
-+        # signals which describes features changes during digitization,
-+        # activate them using EmitSignals method
-+        #TODO signal for errors?
-+        self.featureAdded = Signal('IVDigit.featureAdded')
-+        self.areasDeleted = Signal('IVDigit.areasDeleted')
-+        self.vertexMoved = Signal('IVDigit.vertexMoved')
-+        self.vertexAdded = Signal('IVDigit.vertexAdded')
-+        self.vertexRemoved = Signal('IVDigit.vertexRemoved')
-+        self.featuresDeleted = Signal('IVDigit.featuresDeleted')
-+        self.featuresMoved = Signal('IVDigit.featuresMoved')
-+        self.lineEdited = Signal('IVDigit.lineEdited')
-     def __del__(self):
-         Debug.msg(1, "IVDigit.__del__()")
-         Vect_destroy_line_struct(self.poPoints)
-@@ -188,7 +204,12 @@
-             Vect_close(self.poBgMapInfo)
-             self.poBgMapInfo = self.popoBgMapInfo = None
-             del self.bgMapInfo
-+    def EmitSignals(self, emit):
-+        """!Activate/deactivate signals which describes features changes during digitization.
-+        self.emit_signals = emit
-     def CloseBackgroundMap(self):
-         """!Close background vector map"""
-         if not self.poBgMapInfo:
-@@ -394,7 +415,6 @@
-         @return tuple (number of added features, feature ids)
-         layer = self._getNewFeaturesLayer()
-         cat = self._getNewFeaturesCat()
-@@ -419,10 +439,14 @@
-             return (-1, None)
-         self.toolbar.EnableUndo()
--        return self._addFeature(vtype, points, layer, cat,
--                                self._getSnapMode(), self._display.GetThreshold())
-+        ret = self._addFeature(vtype, points, layer, cat,
-+                               self._getSnapMode(), self._display.GetThreshold())
-+        if ret[0] > -1 and self.emit_signals:
-+            self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
-+        return ret
-     def DeleteSelectedLines(self):
-         """!Delete selected features
-@@ -434,16 +458,27 @@
-         # collect categories for deleting if requested
-         deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
-         catDict = dict()
-+        old_bboxs = []
-+        old_areas_cats = []
-         if deleteRec:
-             for i in self._display.selected['ids']:
-                 if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
-                     self._error.ReadLine(i)
--                cats = self.poCats.contents
--                for j in range(cats.n_cats):
--                    if cats.field[j] not in catDict.keys():
--                        catDict[cats.field[j]] = list()
--                    catDict[cats.field[j]].append(cats.cat[j])
-+                if self.emit_signals:
-+                    ret = self._getLineAreaBboxCats(i)
-+                    if ret:
-+                        old_bboxs += ret[0]
-+                        old_areas_cats += ret[1]
-+                # catDict was not used -> put into comment
-+                #cats = self.poCats.contents
-+                #for j in range(cats.n_cats):
-+                #    if cats.field[j] not in catDict.keys():
-+                #        catDict[cats.field[j]] = list()
-+                #    catDict[cats.field[j]].append(cats.cat[j])
-         poList = self._display.GetSelectedIList()
-         nlines = Vedit_delete_lines(self.poMapInfo, poList)
-@@ -456,7 +491,10 @@
-                 self._deleteRecords(catDict)
-             self._addChangeset()
-+                self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-         return nlines
-     def _deleteRecords(self, cats):
-@@ -512,22 +550,173 @@
-         @return number of deleted
-+        if len(self._display.selected['ids']) < 1:
-+            return 0
-         cList  = poList.contents
-         nareas = 0
-+        old_bboxs = []
-         for i in range(cList.n_values):
-             if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
-                 continue
-+                area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
-+                if area > 0:
-+                    bbox, cats = self._getaAreaBboxCats(area)
-+                    old_bboxs += bbox
-+                    old_areas_cats += cats
-             nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
-         if nareas > 0:
-+                self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-+        return nareas
-+    def _getLineAreaBboxCats(self, ln_id):
-+        ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
-+        if ltype == GV_CENTROID:
-+            #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
-+            return self._getCentroidAreaBboxCats(ln_id)
-+        else:
-+            return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
-+    def _getCentroidAreaBboxCats(self, centroid):
-+        if not Vect_line_alive(self.poMapInfo, centroid):
-+            return None
-+        area = Vect_get_centroid_area(self.poMapInfo, centroid)
-+        if area > 0:
-+            return self._getaAreaBboxCats(area)
-+        else:
-+            return None
-+    def _getaAreaBboxCats(self, area):
-+        po_b_list = Vect_new_list()
-+        Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
-+        b_list = po_b_list.contents
-+        geoms = []
-+        areas_cats = []
-+        if b_list.n_values > 0:
-+            for i_line in range(b_list.n_values):
-+                line = b_list.value[i_line];
-+                geoms.append(self._getBbox(abs(line)))
-+                areas_cats.append(self._getLineAreasCategories(abs(line)))
--        return nareas
-+        Vect_destroy_list(po_b_list);
-+        return geoms, areas_cats
-+    def _getLineAreasCategories(self, ln_id):
-+        if not Vect_line_alive (self.poMapInfo, ln_id):
-+            return []
-+        if ltype != GV_BOUNDARY:
-+            return []
-+        cats = [None, None]
-+        left = c_int()
-+        right = c_int()
-+        if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
-+            areas = [left.value, right.value]
-+            for i, a in enumerate(areas):
-+                if a > 0:
-+                    centroid = Vect_get_area_centroid(self.poMapInfo, a)
-+                    if centroid <= 0:
-+                        continue
-+                    c = self._getCategories(centroid)
-+                    if c:
-+                        cats[i] = c
-+        return cats
-+    def _getCategories(self, ln_id):
-+            return none
-+        poCats = Vect_new_cats_struct()
-+        if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
-+            Vect_destroy_cats_struct(poCats)
-+            return None
-+        cCats = poCats.contents
-+        cats = {}
-+        for j in range(cCats.n_cats):
-+            if cats.has_key(cCats.field[j]):
-+                cats[cCats.field[j]].append(cCats.cat[j])
-+            else:
-+                cats[cCats.field[j]] = [cCats.cat[j]]
-+        return cats
-+    def _getBbox(self, ln_id):
-+            return None
-+        poPoints = Vect_new_line_struct()
-+        if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
-+            Vect_destroy_line_struct(poPoints)
-+            return []
-+        geom = self._convertGeom(poPoints)
-+        bbox = self._createBbox(geom)
-+        return bbox
-+    def _createBbox(self, points):
-+        bbox = {}
-+        for pt in points:
-+            if not bbox.has_key('maxy'):
-+                bbox['maxy'] = pt[1]
-+                bbox['miny'] = pt[1]
-+                bbox['maxx'] = pt[0]
-+                bbox['minx'] = pt[0]
-+                continue
-+            if   bbox['maxy'] < pt[1]:
-+            elif bbox['miny'] > pt[1]:
-+            if   bbox['maxx'] < pt[0]:
-+            elif bbox['minx'] > pt[0]:
-+        return bbox
-+    def _convertGeom(self, poPoints):
-+        Points = poPoints.contents
-+        pts_geom = []
-+        for j in range(Points.n_points):
-+            pts_geom.append((Points.x[j], Points.y[j]))
-+        return pts_geom
-     def MoveSelectedLines(self, move):
-         """!Move selected features
-@@ -536,16 +725,45 @@
-         if not self._checkMap():
-             return -1
-+        nsel = len(self._display.selected['ids'])
-+        if nsel < 1:
-+            return -1
-         thresh = self._display.GetThreshold()
-         snap   = self._getSnapMode()
-+            old_bboxs = []
-+            for sel_id in self._display.selected['ids']:
-+                ret = self._getLineAreaBboxCats(sel_id)
-+                if ret:
-+            Vect_set_updated(self.poMapInfo, 1)
-+            n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
-         nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
-                                   poList,
-                                   move[0], move[1], 0,
-                                   snap, thresh)
-         Vect_destroy_list(poList)
-+        if nlines > 0 and self.emit_signals:
-+            new_bboxs = []
-+            new_areas_cats = []
-+            n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
-+            for i in range(n_up_lines_old, n_up_lines):
-+                new_id = Vect_get_updated_line(self.poMapInfo, i)
-+                ret = self._getLineAreaBboxCats(new_id)
-+                if ret:
-+                    new_bboxs += ret[0]
-+                    new_areas_cats += ret[1]
-         if nlines > 0 and self._settings['breakLines']:
-             for i in range(1, nlines):
-                 self._breakLineAtIntersection(nlines + i, None, changeset)
-@@ -553,7 +771,13 @@
-         if nlines > 0:
-+                self.featuresMoved.emit(new_bboxs = new_bboxs,
-+                                        old_bboxs = old_bboxs,
-+                                        old_areas_cats = old_areas_cats,
-+                                        new_areas_cats = new_areas_cats)
-         return nlines
-     def MoveSelectedVertex(self, point, move):
-@@ -571,12 +795,21 @@
-         if len(self._display.selected['ids']) != 1:
-             return -1
-+        # move only first found vertex in bbox
-+        poList = self._display.GetSelectedIList()
-+            cList = poList.contents
-+            old_bboxs = [self._getBbox(cList.value[0])]
-+            old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
-         Vect_reset_line(self.poPoints)
-         Vect_append_point(self.poPoints, point[0], point[1], 0.0)
--        # move only first found vertex in bbox
--        poList = self._display.GetSelectedIList()
-         moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
-                                   poList, self.poPoints,
-                                   self._display.GetThreshold(type = 'selectThresh'),
-@@ -584,7 +817,17 @@
-                                   move[0], move[1], 0.0,
-                                   1, self._getSnapMode())
-+        if moved > 0 and self.emit_signals:
-+            new_bboxs = []
-+                new_bboxs.append(self._getBbox(new_id))
-+                new_areas_cats.append(self._getLineAreasCategories(new_id))
-         if moved > 0 and self._settings['breakLines']:
-             self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
-                                           None)
-@@ -592,7 +835,13 @@
-         if moved > 0:
-+                self.vertexMoved.emit(new_bboxs = new_bboxs,
-+                                      new_areas_cats = new_areas_cats,
-+                                      old_bboxs = old_bboxs)
-         return moved
-     def AddVertex(self, coords):
-@@ -681,6 +930,10 @@
-             self._error.ReadLine(line)
-             return -1
-+            old_bboxs = [self._getBbox(line)]
-+            old_areas_cats = [self._getLineAreasCategories(line)]
-         # build feature geometry
-         for p in coords:
-@@ -696,6 +949,9 @@
-         newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
-                                     self.poPoints, self.poCats)
-+        if newline > 0 and self.emit_signals:
-+            new_geom = [self._getBbox(newline)]
-+            new_areas_cats = [self._getLineAreasCategories(newline)]
-         if newline > 0 and self._settings['breakLines']:
-             self._breakLineAtIntersection(newline, None)
-@@ -703,7 +959,13 @@
-         if newline > 0:
-+                self.lineEdited.emit(old_bboxs = old_bboxs,
-+                                     new_bboxs = new_bboxs,
-         return newline
-     def FlipLine(self):
-@@ -1514,6 +1776,16 @@
-             return 0
-         Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
-@@ -1525,15 +1797,35 @@
-         else:
-             ret = Vedit_remove_vertex(self.poMapInfo, poList,
-                                       self.poPoints, thresh)
-+        if ret > 0 and self.emit_signals:
-+            new_bboxs = []
-         if not add and ret > 0 and self._settings['breakLines']:
-                                           None)
-         if ret > 0:
-+            if add:
-+                self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
-+            else:
-+                self.vertexRemoved.emit(old_bboxs = old_bboxs,
-         return 1
-     def GetLineCats(self, line):
-Index: gui/wxpython/vdigit/toolbars.py
---- gui/wxpython/vdigit/toolbars.py	(revision 57457)
-+++ gui/wxpython/vdigit/toolbars.py	(working copy)
-@@ -17,6 +17,7 @@
- import wx
- from grass.script import core as grass
- from gui_core.toolbars  import BaseToolbar, BaseIcons
- from gui_core.dialogs   import CreateNewVector
-@@ -42,6 +43,8 @@
-         self.digit         = None
-         self._giface       = giface
-+        self.editingStarted = Signal("VDigitToolbar.editingStarted")
-         # currently selected map layer for editing (reference to MapLayer instance)
-         self.mapLayer = None
-         # list of vector layers from Layer Manager (only in the current mapset)
-@@ -860,6 +863,7 @@
-             alpha = int(opacity * 255)
-             self.digit.GetDisplay().UpdateSettings(alpha = alpha)
-+        self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
-         return True
-     def StopEditing(self):
 Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/mapdisp/toolbars.py	(revision 57457)
+--- gui/wxpython/mapdisp/toolbars.py	(revision 57491)
 +++ gui/wxpython/mapdisp/toolbars.py	(working copy)
 @@ -239,7 +239,8 @@
                        (MapIcons["scatter"],     self.parent.OnScatterplot),
@@ -3351,7 +5248,7 @@
          """!Decorations overlay menu
 Index: gui/wxpython/mapdisp/frame.py
---- gui/wxpython/mapdisp/frame.py	(revision 57457)
+--- gui/wxpython/mapdisp/frame.py	(revision 57491)
 +++ gui/wxpython/mapdisp/frame.py	(working copy)
 @@ -225,6 +225,7 @@
@@ -3381,1492 +5278,3 @@
      def OnVNet(self, event):
          """!Dialog for v.net* modules
-Index: gui/wxpython/iclass/dialogs.py
---- gui/wxpython/iclass/dialogs.py	(revision 57457)
-+++ gui/wxpython/iclass/dialogs.py	(working copy)
-@@ -333,13 +333,19 @@
-         toolbar.SetCategories(catNames = catNames, catIdx = cats)
-         if name in catNames:
-             toolbar.choice.SetStringSelection(name)
-+            cat = toolbar.GetSelectedCategoryIdx()
-         elif catNames:
-             toolbar.choice.SetSelection(0)
-+        else:
-+            cat = None
-         if toolbar.choice.IsEmpty():
-             toolbar.EnableControls(False)
-         else:
-             toolbar.EnableControls(True)
-+        self.mapWindow.CategoryChanged(cat)
-         # don't forget to update maps, histo, ...
-     def GetSelectedIndices(self, state =  wx.LIST_STATE_SELECTED):
-Index: gui/wxpython/iclass/toolbars.py
---- gui/wxpython/iclass/toolbars.py	(revision 57457)
-+++ gui/wxpython/iclass/toolbars.py	(working copy)
-@@ -46,9 +46,7 @@
-         'importAreas' : MetaIcon(img = 'layer-import',
-                             label = _('Import training areas from vector map')),
-         'addRgb' : MetaIcon(img = 'layer-rgb-add',
--                            label = _('Add RGB map layer')),
--        'scatt_plot'    : MetaIcon(img = 'layer-raster-analyze',
--                                   label = _('Open Scatter Plot Tool (EXPERIMENTAL GSoC 2013)')),
-+                            label = _('Add RGB map layer'))
- class IClassMapToolbar(BaseToolbar):
-@@ -117,10 +115,7 @@
-                                      ("zoomBack", icons["zoomBack"],
-                                       self.parent.OnZoomBack),
-                                      ("zoomToMap", icons["zoomExtent"],
--                                      self.parent.OnZoomToMap),
--                                     (None, ),
--                                     ("scatt_plot", iClassIcons["scatt_plot"],
--                                      self.parent.OnScatterplot)
-+                                      self.parent.OnZoomToMap)
- class IClassToolbar(BaseToolbar):
-     """!IClass toolbar
-@@ -156,7 +151,7 @@
-         """!Toolbar data"""
-         icons = iClassIcons
-         return self._getToolbarData((("selectGroup", icons['selectGroup'],
--                                      self.parent.OnAddBands),
-+                                      lambda event : self.parent.AddBands()),
-                                       (None, ),
-                                       ("classManager", icons['classManager'],
-                                       self.parent.OnCategoryManager),
-Index: gui/wxpython/iclass/frame.py
---- gui/wxpython/iclass/frame.py	(revision 57457)
-+++ gui/wxpython/iclass/frame.py	(working copy)
-@@ -64,6 +64,8 @@
-                                IClassExportAreasDialog, IClassMapDialog
- from iclass.plots       import PlotPanel
- class IClassMapFrame(DoubleMapFrame):
-     """! wxIClass main frame
-@@ -114,6 +116,10 @@
-             lambda:
-             self.statusbarManager.statusbarItems['coordinates'].SetAdditionalInfo(None))
-         self.SetSize(size)
-+        self.groupSet = Signal("IClassMapFrame.groupSet")
-+        self.categoryChanged = Signal('IClassMapFrame.categoryChanged')
-         # Add toolbars
-@@ -177,7 +183,7 @@
-         self.dialogs['category']   = None
-         # PyPlot init
--        self.plotPanel = PlotPanel(self, stats_data = self.stats_data)
-+        self.plotPanel = PlotPanel(self, giface = self._giface, stats_data = self.stats_data)
-         self._addPanes()
-         self._mgr.Update()
-@@ -237,7 +243,7 @@
-             return False
-         return vectorName
-     def RemoveTempVector(self):
-         """!Removes temporary vector map with training areas"""
-         ret = RunCommand(prog = 'g.remove',
-@@ -477,7 +483,7 @@
-         self.Render(self.GetFirstWindow())
--    def OnAddBands(self, event):
-+    def AddBands(self):
-         """!Add imagery group"""
-         dlg = IClassGroupDialog(self, group = self.group)
-         if dlg.ShowModal() == wx.ID_OK:
-@@ -488,7 +494,8 @@
-         """!Set imagery group"""
-         group = grass.find_file(name = name, element = 'group')
-         if group['name']:
--            self.group = group['name']
-+           self.group = group['name']
-+           self.groupSet.emit(group = group['name'])
-         else:
-             GError(_("Group <%s> not found") % name, parent = self)
-@@ -768,17 +775,20 @@
-         Updates number of stddev, histograms, layer in preview display.
--        stat = self.stats_data.GetStatistics(currentCat)
--        nstd = stat.nstd
--        self.toolbars['iClass'].UpdateStddev(nstd)
--        self.plotPanel.UpdateCategory(currentCat)
--        self.plotPanel.OnPlotTypeSelected(None)
-+        if currentCat:
-+          stat = self.stats_data.GetStatistics(currentCat)
-+          nstd = stat.nstd
-+          self.toolbars['iClass'].UpdateStddev(nstd)
-+          self.plotPanel.UpdateCategory(currentCat)
-+          self.plotPanel.OnPlotTypeSelected(None)
--        name = stat.rasterName
--        name = self.previewMapManager.GetAlias(name)
--        if name:
--            self.previewMapManager.SelectLayer(name)
-+          name = stat.rasterName
-+          name = self.previewMapManager.GetAlias(name)
-+          if name:
-+              self.previewMapManager.SelectLayer(name)
-+        self.categoryChanged.emit(cat = currentCat)
-     def DeleteAreas(self, cats):
-         """!Removes all training areas of given categories
-@@ -1105,27 +1115,6 @@
-         self.GetFirstWindow().SetModePointer()
-         self.GetSecondWindow().SetModePointer()
--    def OnScatterplot(self, event):
--        """!Init interactive scatterplot tools
--        if self.dialogs['scatt_plot']:
--            self.dialogs['scatt_plot'].Raise()
--            return
--        try:
--          from scatt_plot.dialogs import ScattPlotMainDialog
--        except:
--          GError(parent  = self, message = _("The Scatter Plot Tool is not installed."))
--          return
--        self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface, iclass_mapwin = self.GetFirstWindow())
--        scatt_mgr = self.dialogs['scatt_plot'].GetScattMgr()
--        scatt_mgr.DigitDataChanged(self.toolbars['vdigit'].mapLayer.GetName(), self.GetFirstWindow().GetDigit())
--        self.dialogs['scatt_plot'].CenterOnScreen()
--        self.dialogs['scatt_plot'].Show()
- class MapManager:
-     """! Class for managing map renderer.
-Index: gui/wxpython/iclass/plots.py
---- gui/wxpython/iclass/plots.py	(revision 57457)
-+++ gui/wxpython/iclass/plots.py	(working copy)
-@@ -28,7 +28,7 @@
-     for each band and for one category. Coincidence plots show min max range
-     of classes for each band.
--    def __init__(self, parent, stats_data):
-+    def __init__(self, parent, giface, stats_data):
-         scrolled.ScrolledPanel.__init__(self, parent)
-         self.SetupScrolling(scroll_x = False, scroll_y = True)
-@@ -38,26 +38,62 @@
-         self.stats_data = stats_data
-         self.currentCat = None
-+        self._giface = giface
-         self.mainSizer = wx.BoxSizer(wx.VERTICAL)
-         self._createControlPanel()
-+        self._createPlotPanel()
-+        self._createScatterPlotPanel()
-         self.SetSizer(self.mainSizer)
-         self.mainSizer.Fit(self)
-         self.Layout()
-+    def _createPlotPanel(self):
-+        self.canvasPanel = wx.Panel(parent=self)
-+        self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
-+        self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
-+        self.canvasPanel.SetSizer(self.canvasSizer)
-     def _createControlPanel(self):
-         self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
-                                      choices = [_("Histograms"),
--                                                _("Coincident plots")])
-+                                                _("Coincident plots"),
-+                                                _("Scatter plots")])
-         self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
-         self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
-+    def _createScatterPlotPanel(self):
-+        """!Init interactive scatterplot tools
-+        try:
-+            from scatt_plot.dialogs_iclass import IClassScatterPlotsPanel
-+            self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self, giface=self._giface, iclass_mapwin = self.parent.GetFirstWindow())
-+            self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
-+            self.scatt_plot_panel.Hide()
-+        except ImportError as e:
-+            self.scatt_plot_panel = None
-     def OnPlotTypeSelected(self, event):
-         """!Plot type selected"""
-+        if self.plotSwitch.GetSelection() in [0, 1]:
-+            self.canvasPanel.Show()
-+            self.Layout()
-+        elif self.plotSwitch.GetSelection() == 2:
-+            self.SetupScrolling(scroll_x = False, scroll_y = False)
-+            self.scatt_plot_panel.Show()
-+            self.canvasPanel.Hide()
-+            self.Layout()
-         if self.currentCat is None:
-             return
-         if self.plotSwitch.GetSelection() == 0:
-             stat = self.stats_data.GetStatistics(self.currentCat)
-             if not stat.IsReady():
-@@ -66,7 +102,10 @@
-             self.DrawHistograms(stat)
-         else:
-             self.DrawCoincidencePlots()
-+        self.Layout()
-     def StddevChanged(self):
-         """!Standard deviation multiplier changed, redraw histograms"""
-@@ -89,7 +128,7 @@
-             panel.Destroy()
-         self.canvasList = []
-     def ClearPlots(self):
-         """!Clears plot canvases"""
-         for bandIdx in range(len(self.bandList)):
-@@ -104,15 +143,15 @@
-     def CreatePlotCanvases(self):
-         """!Create plot canvases according to the number of bands"""
-         for band in self.bandList:
--            canvas = plot.PlotCanvas(self)
-+            canvas = plot.PlotCanvas(self.canvasPanel)
-             canvas.SetMinSize((-1, 140))
-             canvas.SetFontSizeTitle(10)
-             canvas.SetFontSizeAxis(8)
-             self.canvasList.append(canvas)
--            self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
--        self.SetVirtualSize(self.GetBestVirtualSize())
-+            self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
-         self.Layout()
-     def UpdatePlots(self, group, currentCat, stats_data):
-@@ -138,7 +177,7 @@
-     def UpdateCategory(self, cat):
-         self.currentCat = cat
-     def DrawCoincidencePlots(self):
-         """!Draw coincidence plots"""
-Index: lib/vector/Vlib/open.c
---- lib/vector/Vlib/open.c	(revision 57457)
-+++ lib/vector/Vlib/open.c	(working copy)
-@@ -240,7 +240,9 @@
-         else {
-             char file_path[GPATH_MAX];
-+            /* reduce to current mapset if search path was set */
-+            if(strcmp(Map->mapset, "") == 0)
-+                Map->mapset = G_store(G_mapset());
-             if (strcmp(Map->mapset, G_mapset()) != 0) {
-                 G_warning(_("Temporary vector maps can be accessed only in the current mapset"));
-                 return -1;
-Index: lib/imagery/scatt.c
---- lib/imagery/scatt.c	(revision 0)
-+++ lib/imagery/scatt.c	(working copy)
-@@ -0,0 +1,746 @@
-+   \file lib/imagery/scatt.c
-+   \brief Imagery library - functions for wx Scatter Plot Tool.
-+   Low level functions used by wx Scatter Plot Tool.
-+   Copyright (C) 2013 by the GRASS Development Team
-+   This program is free software under the GNU General Public License
-+   (>=v2).  Read the file COPYING that comes with GRASS for details.
-+   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
-+#include <grass/raster.h>
-+#include <grass/imagery.h>
-+#include <grass/gis.h>
-+#include <grass/glocale.h>
-+#include <stdio.h>
-+#include <stdlib.h>
-+#include <math.h>
-+#include <string.h>
-+struct rast_row
-+    CELL * row;
-+    char * null_row;
-+    struct Range rast_range; /*Range of whole raster.*/
-+   \brief Create pgm header.
-+   Scatter plot internally generates pgm files. These pgms have header in format created by this function.
-+   \param region region to be pgm header generated for
-+   \param [out] header header of pgm file
-+static int get_cat_rast_header(struct Cell_head * region, char * header){
-+    return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
-+   \brief Create category raster conditions file.
-+   \param cat_rast_region region to be file generated for
-+   \param cat_rast path of generated category raster file
-+int I_create_cat_rast(struct Cell_head * cat_rast_region,  const char * cat_rast)
-+    FILE * f_cat_rast;
-+    char cat_rast_header[1024];//TODO magic number
-+    int i_row, i_col;
-+    int head_nchars;
-+    unsigned char * row_data;
-+    f_cat_rast = fopen(cat_rast, "wb");
-+    if(!f_cat_rast) {
-+        G_warning("Unable to create category raster condition file <%s>.", cat_rast);
-+        return -1;
-+    head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
-+    fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
-+    if (ferror(f_cat_rast)){
-+        fclose(f_cat_rast);
-+        G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
-+        return -1;
-+    row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
-+    for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
-+        row_data[i_col] = 0 & 255;
-+    for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
-+        fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
-+            G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
-+            return -1;
-+    return 0;
-+static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
-+    G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
-+               intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
-+   \brief Find intersection region of two regions.
-+   \param A pointer to intersected region
-+   \param B pointer to intersected region
-+   \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
-+   \return  0 if interection exists
-+   \return -1 if regions does not intersect
-+static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
-+    if(B->north < A->south) return -1;
-+    else if(B->north > A->north) intersec->north = A->north;
-+    else intersec->north = B->north;
-+    if(B->south > A->north) return -1;
-+    else if(B->south < A->south) intersec->south = A->south;
-+    else intersec->south = B->south;
-+    if(B->east < A->west) return -1;
-+    else if(B->east > A->east) intersec->east = A->east;
-+    else intersec->east = B->east;
-+    if(B->west > A->east) return -1;
-+    else if(B->west < A->west) intersec->west = A->west;
-+    else intersec->west = B->west;
-+    if(intersec->north == intersec->south) return -1;
-+    if(intersec->east == intersec->west) return -1;
-+    return 0;
-+   \brief Get rows and cols numbers, which defines intersection of the regions.
-+   \param B pointer to intersected region (A and B must have same resolution)
-+   \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
-+   \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
-+   \return -1 if regions do not intersect
-+   \return -2 resolution of regions is not same
-+static int get_rows_and_cols_bounds(struct Cell_head * A,  struct Cell_head * B, struct Cell_head * A_bounds,  struct Cell_head * B_bounds)
-+    float ns_res, ew_res;
-+    struct Cell_head intersec;
-+    /* TODO is it right check? */
-+    if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
-+        G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
-+        return -2;
-+    if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
-+        G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
-+        return -2;
-+    ns_res = A->ns_res;
-+    ew_res = A->ew_res;
-+    if(regions_intersecion(A, B, &intersec) == -1)
-+        return -1;
-+    A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
-+    A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
-+    A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
-+    A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
-+    B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
-+    B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
-+    B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
-+    B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
-+    return 0;
-+   \brief Insert raster map patch into pgm file.
-+   \param patch_rast name of raster map
-+   \param cat_rast_region region of category raster file
-+   \param cat_rast path to category raster file
-+   \return  0 on success
-+   \return -1 on failure
-+int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region,  const char * cat_rast)
-+    struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
-+    int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
-+    int head_nchars, ret;
-+    int fd_patch_rast, init_shift, step_shift;
-+    unsigned char * patch_data;
-+    char * null_chunk_row;
-+    const char *mapset;
-+    struct Cell_head patch_lines, cat_rast_lines;
-+    f_cat_rast = fopen(cat_rast, "rb+");
-+        G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
-+        return -1;
-+    if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
-+        G_warning(_("Unable to find patch raster <%s>."), patch_rast);
-+        return -1;
-+    Rast_get_cellhd(patch_rast, mapset, &patch_region);
-+    Rast_set_window(&patch_region);
-+    if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
-+        return -1;
-+    ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
-+    if(ret == -2) {
-+        G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
-+        Rast_close(fd_patch_rast);
-+        return -1;
-+    else if (ret == -1){
-+        return 0;
-+    ncols = cat_rast_bounds.east - cat_rast_bounds.west;
-+    nrows = cat_rast_bounds.south - cat_rast_bounds.north;
-+    patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
-+    init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
-+    if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
-+        G_warning(_("Corrupted  category raster conditions file <%s> (fseek failed)"), cat_rast);
-+        G_free(null_chunk_row);
-+        return -1;
-+    step_shift = cat_rast_region->cols - ncols;
-+    null_chunk_row =  Rast_allocate_null_buf();
-+    for(i_row = 0; i_row < nrows; i_row++) {
-+        Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
-+        for(i_col = 0; i_col < ncols; i_col++) {
-+            patch_col = patch_bounds.west + i_col;
-+            if(null_chunk_row[patch_col] != 1)
-+                patch_data[i_col] = 1 & 255;
-+            else {
-+                patch_data[i_col] = 0 & 255;
-+        fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
-+            G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
-+            return -1;
-+        if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
-+            return -1;
-+    return 0;
-+   \brief Updates scatter plots data in category by pixels which meets category conditions.
-+   \param bands_rows data represents data describig one row from raster band
-+   \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
-+   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
-+static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
-+    int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
-+    CELL * b_1_row;
-+    CELL * b_2_row;
-+    char * b_1_null_row,* b_2_null_row;
-+    struct rast_row b_1_rast_row, b_2_rast_row;
-+    struct Range b_1_range, b_2_range;
-+    int b_1_range_size;
-+    int row_size = Rast_window_cols();
-+    int * scatts_bands = scatts->scatts_bands;
-+    for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
-+        b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
-+        b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
-+        b_1_row = b_1_rast_row.row;
-+        b_2_row = b_2_rast_row.row;
-+        b_1_null_row =  b_1_rast_row.null_row;
-+        b_2_null_row =  b_2_rast_row.null_row;
-+        b_1_range = b_1_rast_row.rast_range;
-+        b_2_range = b_2_rast_row.rast_range;
-+        b_1_range_size = b_1_range.max - b_1_range.min + 1;
-+        max_arr_idx = (b_1_range.max -  b_1_range.min + 1) * (b_2_range.max -  b_2_range.min + 1);
-+        for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
-+            /* pixel does not belongs to scatter plot or has null value in one of the bands */
-+            if(!belongs_pix[i_chunk_rows_pix] ||
-+                b_1_null_row[i_chunk_rows_pix] == 1 ||
-+                b_2_null_row[i_chunk_rows_pix] == 1)
-+                continue;
-+            /* index in scatter plot array */
-+            array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
-+            if(array_idx < 0 || array_idx >= max_arr_idx) {
-+                        G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
-+                continue;
-+            /* increment scatter plot value */
-+            ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
-+   \brief Computes scatter plots data from chunk_rows.
-+   \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
-+   \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
-+   \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
-+   \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
-+   \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
-+   \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
-+   \param region analysis region
-+static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
-+                                                FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
-+                                                struct scCats * scatts, int * fd_cats_rasts)
-+    int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
-+    int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
-+    CELL * cat_rast_row;
-+    struct scScatts * scatts_conds;
-+    struct scScatts * scatts_scatt_plts;
-+    struct scdScattData * conds;
-+    int * scatts_bands;
-+    struct scdScattData ** scatts_arr;
-+    CELL * b_1_row;
-+    CELL * b_2_row;
-+    unsigned char * i_scatt_conds;
-+    unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
-+    unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
-+    cat_rast_row =  Rast_allocate_c_buf();
-+    for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
-+        scatts_conds = scatt_conds->cats_arr[i_cat];
-+        cat_id = scatt_conds->cats_ids[i_cat];
-+        scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
-+        if(scatt_plts_cat_idx < 0)
-+            continue;
-+        scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
-+        G_zero(belongs_pix, row_size * sizeof(unsigned short));
-+        /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
-+        if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
-+            for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
-+                /* all pixels belongs */
-+                for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
-+                    belongs_pix[i_rows_pix] = 1;
-+        /* compute belonging pixels for defined conditions */
-+        else
-+            scatts_bands = scatts_conds->scatts_bands;
-+            /* check conditions from category raster condtitions file */
-+            if(f_cats_rasts_conds[i_cat]) {
-+                n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
-+                if (ferror(f_cats_rasts_conds[i_cat]))
-+                    G_free(rast_pixs);
-+                    G_free(belongs_pix);
-+                    G_warning(_("Unable to read from category raster condtition file."));
-+                    return -1;
-+                if (n_pixs != n_pixs) {
-+                    G_warning(_("Invalid size of category raster conditions file."));
-+                    return -1;
-+                    if(rast_pixs[i_rows_pix] != 0 & 255)
-+            /* check condtions defined in scatter plots*/
-+            for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
-+                i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
-+                    /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
-+                    if(belongs_pix[i_rows_pix] ||
-+                       b_1_null_row[i_rows_pix] == 1 ||
-+                       b_2_null_row[i_rows_pix] == 1)
-+                        continue;
-+                    array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
-+                        continue;
-+                    /* pixels meets condtion defined in scatter plot */
-+                    if(i_scatt_conds[array_idx])
-+        /* update category raster with belonging pixels */
-+        if(fd_cats_rasts[i_cat] >= 0) {
-+            Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
-+                if(belongs_pix[i_rows_pix])
-+                    cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
-+            Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
-+        /* update scatter plots with belonging pixels */
-+        update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
-+    G_free(cat_rast_row);
-+    return 0;
-+   \brief Get list if bands needed to be opened for analysis from scCats struct.
-+static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
-+    // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
-+    int i_cat, i_scatt, cat_id;
-+    for(i_cat = 0;  i_cat < cats->n_a_cats; i_cat++)
-+        for(i_scatt = 0;  i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
-+            G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
-+            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
-+            b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
-+    return;
-+   \brief Helper function for clean up.
-+static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
-+                                     int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
-+    int i, band_id;
-+    for(i = 0; i < n_a_bands; i++)
-+        band_id = bands_ids[i];
-+        if(band_id >= 0) {
-+            Rast_close(fd_bands[i]);
-+            G_free(bands_rows[band_id].row);
-+            G_free(bands_rows[band_id].null_row);
-+    if(f_cats_rasts_conds)
-+        for(i = 0; i < n_a_cats; i++)
-+            if(f_cats_rasts_conds[i])
-+                fclose(f_cats_rasts_conds[i]);
-+    if(fd_cats_rasts)
-+            if(fd_cats_rasts[i] >= 0)
-+                Rast_close(fd_cats_rasts[i]);
-+   \brief Compute scatter plots data.
-+    If category has not defined no category raster condition file and no scatter plot with consdtion,
-+    default scatter plot is computed.
-+   \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
-+   \param region function calls Rast_set_window for this region
-+   \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
-+   \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
-+   \param cats_rasts_conds index in array represents corresponding category id
-+   \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
-+   \param bands names of analyzed bands, order of bands is defined by their id
-+   \param n_bands number of bands
-+   \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+   \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
-+int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
-+                     const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
-+    char header[1024];
-+    int fd_cats_rasts[scatt_conds->n_a_cats];
-+    FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
-+    struct rast_row bands_rows[n_bands];
-+    RASTER_MAP_TYPE data_type;
-+    int nrows, i_band, n_a_bands, band_id,
-+        i, i_row, head_nchars, i_cat, id_cat;
-+    int fd_bands[n_bands];
-+    int bands_ids[n_bands];
-+    int b_needed_bands[n_bands];
-+    Rast_set_window(region);
-+    for(i_band = 0; i_band < n_bands; i_band++)
-+        fd_bands[i_band] = -1;
-+        bands_ids[i_band] = -1;
-+    if (n_bands != scatts->n_bands ||
-+        n_bands != scatt_conds->n_bands)
-+        return -1;
-+    memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
-+    get_needed_bands(scatt_conds, &b_needed_bands[0]);
-+    get_needed_bands(scatts, &b_needed_bands[0]);
-+    n_a_bands = 0;
-+    /* open band rasters, which are needed for computation */
-+    for(band_id = 0; band_id < n_bands; band_id++)
-+        if(b_needed_bands[band_id])
-+            G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
-+            if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
-+                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
-+                                         bands_ids, NULL, NULL, scatt_conds->n_a_cats);
-+                G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
-+                return -1;
-+            if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
-+                G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
-+                return -1;
-+            data_type = Rast_get_map_type(fd_bands[n_a_bands]);
-+            if(data_type != CELL_TYPE) {
-+                G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
-+                return -1;
-+            bands_rows[band_id].row =  Rast_allocate_c_buf();
-+            bands_rows[band_id].null_row =  Rast_allocate_null_buf();
-+            if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
-+                G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
-+                return -1;
-+            bands_ids[n_a_bands] = band_id;
-+            ++n_a_bands;
-+    /* open category rasters condition files and category rasters */
-+    for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
-+        id_cat = scatts->cats_ids[i_cat];
-+        if(cats_rasts[id_cat]) {
-+            fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
-+        else
-+            fd_cats_rasts[i_cat] = -1;
-+        if(cats_rasts_conds[id_cat]) {
-+            f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
-+            if(!f_cats_rasts_conds[i_cat]) {
-+                free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
-+                                         f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+                G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
-+                return -1;
-+        else
-+            f_cats_rasts_conds[i_cat] = NULL;
-+    head_nchars =  get_cat_rast_header(region, header);
-+            if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
-+                G_warning(_("Corrupted category raster conditions file (fseek failed)"));
-+                return -1;
-+    nrows = Rast_window_rows();
-+    /* analyze bands by rows */
-+    for (i_row = 0; i_row < nrows; i_row++)
-+        for(i_band = 0; i_band < n_a_bands; i_band++)
-+            band_id = bands_ids[i_band];
-+            Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
-+            Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
-+        if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
-+            free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
-+                                     f_cats_rasts_conds, scatt_conds->n_a_cats);
-+            return -1;
-+                             fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+    return 0;
-\ No newline at end of file
-Index: lib/imagery/scatt_sccats.c
---- lib/imagery/scatt_sccats.c	(revision 0)
-+++ lib/imagery/scatt_sccats.c	(working copy)
-@@ -0,0 +1,405 @@
-+   \file lib/imagery/scatt_cat_rast.c
-+   \brief Imagery library - functions for manipulation with scatter plot structs.
-+#include <math.h>
-+   \brief Compute band ids from scatter plot id.
-+    Scatter plot id describes which bands defines the scatter plot.
-+    Let say we have 3 bands, their ids are 0, 1 and 2.
-+    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
-+    All scatter plots:
-+    scatt_id b_1_id b_2_id
-+    0        0      1
-+    1        0      2
-+    2        1      2
-+   \param scatt_id scatter plot id
-+   \param [out] b_1_id id of band1
-+   \param[out] b_2_id id of band2
-+   \return 0
-+int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
-+    int n_b1 = n_bands - 1;
-+    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
-+    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
-+    return 0;
-+   \brief Compute scatter plot id from band ids.
-+    See also I_id_scatt_to_bands().
-+   \param b_1_id id of band1
-+   \param b_1_id id of band2
-+   \param [out] scatt_id scatter plot id
-+   \return 0
-+int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
-+    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
-+    return 0;
-+   \brief Initialize structure for storing scatter plots data.
-+   \param cats pointer to scCats struct
-+   \param type SC_SCATT_DATA - stores scatter plots
-+   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
-+void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
-+    int i_cat;
-+    cats->type = type;
-+    cats->n_cats = 100;
-+    cats->n_a_cats = 0;
-+    cats->n_bands = n_bands;
-+    cats->n_scatts = (n_bands - 1) * n_bands / 2;
-+    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
-+    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
-+    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
-+    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
-+    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
-+        cats->cats_idxs[i_cat] = -1;
-+    return;
-+   \brief Free data of struct scCats, the structure itself remains alocated.
-+   \param cats pointer to existing scCats struct
-+void I_sc_free_cats(struct scCats * cats)
-+    int i_cat;
-+        if(cats->cats_arr[i_cat])
-+            G_free(cats->cats_arr[i_cat]->scatt_idxs);
-+            G_free(cats->cats_arr[i_cat]->scatts_bands);
-+            G_free(cats->cats_arr[i_cat]->scatts_arr);
-+            G_free(cats->cats_arr[i_cat]);
-+    G_free(cats->cats_ids);
-+    G_free(cats->cats_idxs);
-+    G_free(cats->cats_arr);
-+    cats->n_cats = 0;
-+    cats->n_bands = 0;
-+    cats->n_scatts = 0;
-+    cats->type = -1;
-+    return;
-+#if 0
-+void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
-+    a_cats_ids = cats->cats_ids;
-+    * n_a_cats = cats->n_a_cats;
-+#endif
-+   \brief Add category.
-+    Category represents group of scatter plots.
-+   \return assigned category id (starts with 0)
-+   \return -1 if maximum nuber of categories was reached
-+int I_sc_add_cat(struct scCats * cats)
-+    int i_scatt, i_cat_id, cat_id;
-+    int n_a_cats = cats->n_a_cats;
-+    if(cats->n_a_cats >= cats->n_cats)
-+        return -1;
-+    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
-+        if(cats->cats_idxs[i_cat_id] < 0) {
-+            cat_id = i_cat_id;
-+            break;
-+    cats->cats_ids[n_a_cats] = cat_id;
-+    cats->cats_idxs[cat_id] = n_a_cats;
-+    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
-+    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
-+    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
-+    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
-+    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
-+    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
-+    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
-+        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
-+    ++cats->n_a_cats;
-+    return cat_id;
-+#if 0
-+int I_sc_delete_cat(struct scCats * cats, int cat_id)
-+    int cat_idx, i_cat;
-+    if(cat_id < 0 || cat_id >= cats->n_cats)
-+        return -1;
-+    cat_idx = cats->cats_idxs[cat_id];
-+    if(cat_idx < 0)
-+        return -1;
-+    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
-+    G_free(cats->cats_arr[cat_idx]->scatts_bands);
-+    G_free(cats->cats_arr[cat_idx]->scatts_arr);
-+    G_free(cats->cats_arr[cat_idx]);
-+    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
-+        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
-+        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
-+    cats->cats_idxs[cat_id] = -1;
-+    --cats->n_a_cats;
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data .
-+    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
-+   \param cat_id id number of category.
-+   \param scatt_id id number of scatter plot.
-+int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int band_1, band_2, cat_idx, n_a_scatts;
-+    struct scScatts * scatts;
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
-+        return -1;
-+    scatts = cats->cats_arr[cat_idx];
-+    if(scatts->scatt_idxs[scatt_id] >= 0)
-+        return -1;
-+    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
-+        return -1;
-+    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
-+        return -1;
-+    n_a_scatts = scatts->n_a_scatts;
-+    scatts->scatt_idxs[scatt_id] = n_a_scatts;
-+    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
-+    scatts->scatts_bands[n_a_scatts * 2] = band_1;
-+    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
-+    scatts->scatts_arr[n_a_scatts] = scatt_data;
-+    ++scatts->n_a_scatts;
-+    return 0;
-+#if 0
-+int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
-+    if(cat_id < 0 && cat_id >= cats->n_cats)
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
-+        return -1;
-+    if(scatts->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_data = scatts->scatts_arr[scatt_idx];
-+    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
-+        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
-+        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
-+        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
-+    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
-+    scatts->scatt_idxs[scatt_id] = -1;
-+    scatt_data = scatts->scatts_arr[scatt_id];
-+    scatts->n_a_scatts--;
-+    return 0;
-+int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
-+    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
-+    int cat_idx, scatt_idx, ret;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
-+    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data.
-+   \param scatt_data pointer to existing struct scdScattData
-+   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
-+   \param n_vals number of data values
-+   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
-+void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
-+    scatt_data->n_vals = n_vals;
-+    if(type == SC_SCATT_DATA)
-+        if(data)
-+            scatt_data->scatt_vals_arr = (unsigned int *) data;
-+        else {
-+            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
-+            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
-+        scatt_data->b_conds_arr = NULL;
-+    else if(type == SC_SCATT_CONDITIONS)
-+        if(data)
-+            scatt_data->b_conds_arr = (unsigned char *) data;
-+        else {
-+            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
-+            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
-+        scatt_data->scatt_vals_arr = NULL;
-+    return;
-+#if 0
-+void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
-+    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
-+    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
-+    return;
-+s
-+void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
-+    if(!scatt_data->b_conds_arr)
-+        return scatt_data->b_conds_arr;
-+    else if(!scatt_data->scatt_vals_arr)
-+        return scatt_data->scatt_vals_arr;
-+    return NULL;
-+int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
-+    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
-+        return -1;
-+    if(scatt_data->b_conds_arr)
-+        scatt_data->b_conds_arr[val_idx] = val;
-+    else if(scatt_data->scatt_vals_arr)
-+        scatt_data->scatt_vals_arr[val_idx] = val;
-+    else
-+        return -1;
-+    return 0;
-+#endif
