[GRASS-SVN] r57495 - in grass/trunk/gui/wxpython: . timeline
svn_grass at osgeo.org
Sat Aug 24 10:50:00 PDT 2013
Author: annakrat
Date: 2013-08-24 10:50:00 -0700 (Sat, 24 Aug 2013)
New Revision: 57495
Added:
grass/trunk/gui/wxpython/timeline/
grass/trunk/gui/wxpython/timeline/Makefile
grass/trunk/gui/wxpython/timeline/__init__.py
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/timeline/frame.py
grass/trunk/gui/wxpython/timeline/g.gui.timeline.py
wxGUI: move Timeline Tool (help tool for temporal framework) from addons to trunk, make it pep8 compliant
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2013-08-23 18:55:52 UTC (rev 57494)
+++ grass/trunk/gui/wxpython/Makefile 2013-08-24 17:50:00 UTC (rev 57495)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr vdigit iclass gcp
+SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr vdigit iclass gcp timeline
EXTRA_CLEAN_FILES = menustrings.py build_ext.pyc xml/menudata.xml xml/module_tree_menudata.xml
include $(MODULE_TOPDIR)/include/Make/Dir.make
@@ -12,7 +12,7 @@
SRCFILES := $(wildcard icons/*.py scripts/*.py xml/*) \
$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
- mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* vdigit/* \
+ mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
vnet/*.py web_services/*.py wxplot/*.py) \
gis_set.py gis_set_error.py wxgui.py README
@@ -21,7 +21,7 @@
PYDSTDIRS := $(patsubst %,$(ETCDIR)/%,animation core dbmgr gcp gmodeler \
gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
- mapswipe vdigit wxplot web_services rlisetup vnet)
+ mapswipe vdigit wxplot web_services rlisetup vnet timeline)
DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
Added: grass/trunk/gui/wxpython/timeline/Makefile
--- grass/trunk/gui/wxpython/timeline/Makefile (rev 0)
+++ grass/trunk/gui/wxpython/timeline/Makefile 2013-08-24 17:50:00 UTC (rev 57495)
@@ -0,0 +1,5 @@
+MODULE_TOPDIR = ../../..
+include $(MODULE_TOPDIR)/include/Make/GuiScript.make
+default: guiscript
Added: grass/trunk/gui/wxpython/timeline/__init__.py
--- grass/trunk/gui/wxpython/timeline/__init__.py (rev 0)
+++ grass/trunk/gui/wxpython/timeline/__init__.py 2013-08-24 17:50:00 UTC (rev 57495)
@@ -0,0 +1,4 @@
+all = [
+ 'g.gui.timeline',
+ 'frame',
Modified: grass/trunk/gui/wxpython/timeline/frame.py
--- grass-addons/grass7/gui/wxpython/wx.timeline/frame.py 2013-08-23 17:02:04 UTC (rev 57491)
+++ grass/trunk/gui/wxpython/timeline/frame.py 2013-08-24 17:50:00 UTC (rev 57495)
@@ -8,7 +8,7 @@
- frame::TimelineFrame
- frame::LookUp
-(C) 2012 by the GRASS Development Team
+(C) 2012-13 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -17,46 +17,43 @@
import os
import sys
-import pprint
-import random
import wx
-# The recommended way to use wx with mpl is with the WXAgg
-# backend.
from math import ceil
from itertools import cycle
import numpy as np
-import grass.script as grass
try:
import matplotlib
+ # The recommended way to use wx with mpl is with the WXAgg
+ # backend.
+ matplotlib.use('WXAgg')
+ from matplotlib.figure import Figure
+ import matplotlib.pyplot as plt
+ from matplotlib.backends.backend_wxagg import \
+ FigureCanvasWxAgg as FigCanvas, \
+ NavigationToolbar2WxAgg as NavigationToolbar
+ import matplotlib.dates as mdates
+ from matplotlib import cbook
except ImportError:
- grass.fatal(_("Matplotlib is not installed"))
+ raise ImportError(_('The Timeline Tool needs "Matplotlib" package to be installed.'))
-matplotlib.use('WXAgg')
-from matplotlib.figure import Figure
-import matplotlib.pyplot as plt
-from matplotlib.backends.backend_wxagg import \
- FigureCanvasWxAgg as FigCanvas, \
- NavigationToolbar2WxAgg as NavigationToolbar
-import matplotlib.dates as mdates
-from matplotlib import cbook
-from mpl_toolkits.mplot3d import Axes3D
if __name__ == '__main__':
sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+import grass.script as grass
+from core.utils import _
import grass.temporal as tgis
-from core.gcmd import RunCommand, GError, GException
+from core.gcmd import GError, GException, RunCommand
from gui_core import gselect
from core import globalvar
ALPHA = 0.5
COLORS = ['b', 'g', 'r', 'c', 'm', 'y', 'k']
def check_version(*version):
+ """!Checks if given version or newer is installed"""
versionInstalled = []
for i in matplotlib.__version__.split('.'):
try:
@@ -69,10 +66,11 @@
else:
return True
class TimelineFrame(wx.Frame):
"""!The main frame of the application"""
def __init__(self, parent):
- wx.Frame.__init__(self, parent, id = wx.ID_ANY, title = _("Timeline Tool"))
+ wx.Frame.__init__(self, parent, id=wx.ID_ANY, title=_("Timeline Tool"))
tgis.init()
self.datasets = []
@@ -81,20 +79,19 @@
self.temporalType = None
self.unit = None
def _layout(self):
"""!Creates the main panel with all the controls on it:
- * mpl canvas
+ * mpl canvas
* mpl navigation toolbar
* Control panel for interaction
self.panel = wx.Panel(self)
- # Create the mpl Figure and FigCanvas objects.
+ # Create the mpl Figure and FigCanvas objects.
# 5x4 inches, 100 dots-per-inch
- # color = wx.SystemSettings.GetColour(wx.SYS_COLOUR_BACKGROUND)
- self.fig = Figure((5.0, 4.0), facecolor = (1, 1, 1))
+ # color = wx.SystemSettings.GetColour(wx.SYS_COLOUR_BACKGROUND)
+ self.fig = Figure((5.0, 4.0), facecolor=(1, 1, 1))
self.canvas = FigCanvas(self.panel, wx.ID_ANY, self.fig)
# axes are initialized later
self.axes2d = None
@@ -103,38 +100,43 @@
# Create the navigation toolbar, tied to the canvas
self.toolbar = NavigationToolbar(self.canvas)
# Layout
self.vbox = wx.BoxSizer(wx.VERTICAL)
self.vbox.Add(self.canvas, 1, wx.LEFT | wx.TOP | wx.EXPAND)
self.vbox.Add(self.toolbar, 0, wx.EXPAND)
self.vbox.AddSpacer(10)
- gridSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
- self.datasetSelect = gselect.Select(parent = self.panel, id = wx.ID_ANY,
- size = globalvar.DIALOG_GSELECT_SIZE,
- type = 'stds', multiple = True)
- self.drawButton = wx.Button(self.panel, id = wx.ID_ANY, label = _("Draw"))
+ gridSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ self.datasetSelect = gselect.Select(parent=self.panel, id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE,
+ type='stds', multiple=True)
+ self.drawButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Draw"))
self.drawButton.Bind(wx.EVT_BUTTON, self.OnRedraw)
- self.view3dCheck = wx.CheckBox(self.panel, id = wx.ID_ANY, label = _("3D plot of spatio-temporal extents"))
+ self.helpButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Help"))
+ self.helpButton.Bind(wx.EVT_BUTTON, self.OnHelp)
+ self.view3dCheck = wx.CheckBox(self.panel, id=wx.ID_ANY,
+ label=_("3D plot of spatio-temporal extents"))
self.view3dCheck.Bind(wx.EVT_CHECKBOX, self.OnRedraw)
if not check_version(1, 0, 0):
- self.view3dCheck.SetLabel(_("3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"))
+ self.view3dCheck.SetLabel(_("3D plot of spatio-temporal extents "
+ "(matplotlib >= 1.0.0)"))
self.view3dCheck.Disable()
- gridSizer.Add(wx.StaticText(self.panel, id = wx.ID_ANY, label = _("Select space time dataset(s):")),
- pos = (0, 0), flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
- gridSizer.Add(self.datasetSelect, pos = (1, 0), flag = wx.EXPAND)
- gridSizer.Add(self.drawButton, pos = (1, 1), flag = wx.EXPAND)
- gridSizer.Add(self.view3dCheck, pos = (2, 0), flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ gridSizer.Add(wx.StaticText(self.panel, id=wx.ID_ANY,
+ label=_("Select space time dataset(s):")),
+ pos=(0, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ gridSizer.Add(self.datasetSelect, pos=(1, 0), flag=wx.EXPAND)
+ gridSizer.Add(self.drawButton, pos=(1, 1), flag=wx.EXPAND)
+ gridSizer.Add(self.helpButton, pos=(1, 2), flag=wx.EXPAND)
+ gridSizer.Add(self.view3dCheck, pos=(2, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ self.vbox.Add(gridSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=10)
- self.vbox.Add(gridSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = 10)
self.panel.SetSizer(self.vbox)
self.vbox.Fit(self)
@@ -148,29 +150,28 @@
etype = series[2]
sp = tgis.dataset_factory(etype, name)
if not sp.is_in_db():
- GError(self, message = _("Dataset <%s> not found in temporal database") % (name))
+ GError(self, message=_("Dataset <%s> not found in temporal database") % (name))
return
sp.select()
self.timeData[name] = {}
self.timeData[name]['elementType'] = series[2]
- self.timeData[name]['temporalType'] = sp.get_temporal_type() # abs/rel
+ self.timeData[name]['temporalType'] = sp.get_temporal_type() # abs/rel
- extent = dict(zip(['north', 'south', 'west', 'east', 'top', 'bottom'], sp.get_spatial_extent()))
- self.timeData[name]['spatialExtent'] = extent
if mode is None:
mode = self.timeData[name]['temporalType']
elif self.timeData[name]['temporalType'] != mode:
- GError(parent = self, message = _("Datasets have different temporal type (absolute x relative), which is not allowed."))
+ GError(parent=self, message=_("Datasets have different temporal type "
+ "(absolute x relative), which is not allowed."))
return
# check topology
maps = sp.get_registered_maps_as_objects()
self.timeData[name]['validTopology'] = sp.check_temporal_topology(maps)
- self.timeData[name]['temporalMapType'] = sp.get_map_time() # point/interval
- self.timeData[name]['unit'] = None # only with relative
+ self.timeData[name]['temporalMapType'] = sp.get_map_time() # point/interval
+ self.timeData[name]['unit'] = None # only with relative
if self.timeData[name]['temporalType'] == 'relative':
start, end, self.timeData[name]['unit'] = sp.get_relative_time()
if unit is None:
@@ -189,10 +190,11 @@
self.timeData[name]['west'] = []
self.timeData[name]['east'] = []
+ columns = ','.join(['name', 'start_time', 'end_time',
+ 'north', 'south', 'west', 'east'])
- columns = ','.join(['name', 'start_time', 'end_time', 'north', 'south', 'west', 'east'])
- rows = sp.get_registered_maps(columns = columns, where = None, order = 'start_time', dbif = None)
+ rows = sp.get_registered_maps(columns=columns, where=None,
+ order='start_time', dbif=None)
if rows is None:
rows = []
for row in rows:
@@ -228,7 +230,7 @@
colors = cycle(COLORS)
plots = []
- for i, name in enumerate(self.datasets):
+ for name in self.datasets:
name = name[0] + '@' + name[1]
startZ = convert(self.timeData[name]['start_datetime'])
mapType = self.timeData[name]['temporalMapType']
@@ -244,9 +246,10 @@
dY = self.timeData[name]['north'] - np.array(startY)
color = colors.next()
- plots.append(self.axes3d.bar3d(startX, startY, startZ, dX, dY, dZ, color = color, alpha = ALPHA))
+ plots.append(self.axes3d.bar3d(startX, startY, startZ, dX, dY, dZ,
+ color=color, alpha=ALPHA))
- params = grass.read_command('g.proj', flags = 'g')
+ params = grass.read_command('g.proj', flags='g')
params = grass.parse_key_val(params)
if 'unit' in params:
self.axes3d.set_xlabel(_("X [%s]") % params['unit'])
@@ -258,7 +261,6 @@
self.axes3d.set_zlabel(_('Time'))
self.axes3d.mouse_init()
self.canvas.draw()
def _draw2dFigure(self):
"""!Draws 2D plot (temporal extents)"""
@@ -292,19 +294,20 @@
lookUpData = zip(start, end)
duration = end - np.array(start)
barData = zip(start, duration)
- yrange = (i - 0.1, 0.2)
- lookUp.AddDataset(type = 'bar', yrange = (i - 0.1, i + 0.1), xranges = lookUpData, datasetName = name)
+ lookUp.AddDataset(type_='bar', yrange=(i - 0.1, i + 0.1),
+ xranges=lookUpData, datasetName=name)
else:
# self.timeData[name]['end_plot'] = None
pointData = start
- lookUp.AddDataset(type = 'point', yrange = i, xranges = pointData, datasetName = name)
+ lookUp.AddDataset(type_='point', yrange=i, xranges=pointData, datasetName=name)
if mapType == 'interval':
- plots.append(self.axes2d.broken_barh(xranges = barData , yrange = (i - 0.1, 0.2),
- facecolors = color, alpha = ALPHA))
+ plots.append(self.axes2d.broken_barh(xranges=barData, yrange=(i - 0.1, 0.2),
+ facecolors=color, alpha=ALPHA))
else:
- plots.append(self.axes2d.plot(pointData, [i] * len(pointData), marker = 'o', linestyle = 'None', color = color)[0])
+ plots.append(self.axes2d.plot(pointData, [i] * len(pointData),
+ marker='o', linestyle='None', color=color)[0])
if self.temporalType == 'absolute':
pass
@@ -312,17 +315,15 @@
else:
self.axes2d.set_xlabel(_("Time [%s]") % self.unit)
self.axes2d.set_yticks(yticksPos)
self.axes2d.set_yticklabels(yticksNames)
- self.axes2d.set_ylim(min(yticksPos)-1, max(yticksPos) + 1)
+ self.axes2d.set_ylim(min(yticksPos) - 1, max(yticksPos) + 1)
# adjust xlim
xlim = self.axes2d.get_xlim()
padding = ceil((xlim[1] - xlim[0]) / 20.)
self.axes2d.set_xlim(xlim[0] - padding, xlim[1] + padding)
self.canvas.draw()
DataCursor(plots, lookUp, InfoFormat)
@@ -334,14 +335,14 @@
try:
datasets = self._checkDatasets(datasets)
except GException:
- GError(parent = self, message = _("Invalid input data"))
+ GError(parent=self, message=_("Invalid input data"))
return
self.datasets = datasets
self._redraw()
def _redraw(self):
- """!Readraw data.
+ """!Readraw data.
Decides if to draw also 3D and adjusts layout if needed.
@@ -353,9 +354,11 @@
self._draw2dFigure()
if check_version(1, 0, 0):
if self.view3dCheck.IsChecked():
- self.axes2d.change_geometry(2,1,1)
+ self.axes2d.change_geometry(2, 1, 1)
if not self.axes3d:
- self.axes3d = self.fig.add_subplot(2, 1, 2, projection = '3d')
+ # do not remove this import - unused but it is required for 3D
+# from mpl_toolkits.mplot3d import Axes3D # pylint: disable=W0611
+ self.axes3d = self.fig.add_subplot(2, 1, 2, projection='3d')
self.axes3d.set_visible(True)
self._draw3dFigure()
@@ -363,7 +366,7 @@
if self.axes3d:
self.fig.delaxes(self.axes3d)
self.axes3d = None
- self.axes2d.change_geometry(1,1,1)
+ self.axes2d.change_geometry(1, 1, 1)
self.canvas.draw()
if check_version(1, 1, 0):
@@ -381,14 +384,14 @@
@return (mapName, mapset, type)
validated = []
- tDict = tgis.tlist_grouped('stds', group_type = True)
+ tDict = tgis.tlist_grouped('stds', group_type=True)
# nested list with '(map, mapset, etype)' items
allDatasets = [[[(map, mapset, etype) for map in maps]
for etype, maps in etypesDict.iteritems()]
for mapset, etypesDict in tDict.iteritems()]
# flatten this list
- allDatasets = reduce(lambda x,y: x+y, reduce(lambda x,y: x+y, allDatasets))
+ allDatasets = reduce(lambda x, y: x + y, reduce(lambda x, y: x + y, allDatasets))
for dataset in datasets:
errorMsg = _("Space time dataset <%s> not found.") % dataset
if dataset.find("@") >= 0:
@@ -403,12 +406,13 @@
raise GException(errorMsg)
elif len(indices) >= 2:
dlg = wx.SingleChoiceDialog(self,
- message = _("Please specify the space time dataset <%s>." % dataset),
- caption = _("Ambiguous dataset name"),
- choices = [("%(map)s@%(mapset)s: %(etype)s" % {'map': allDatasets[i][0],
- 'mapset': allDatasets[i][1],
- 'etype': allDatasets[i][2]}) for i in indices],
- style = wx.CHOICEDLG_STYLE | wx.OK)
+ message=_("Please specify the space time dataset <%s>." % dataset),
+ caption=_("Ambiguous dataset name"),
+ choices=[("%(map)s@%(mapset)s: %(etype)s" % {'map': allDatasets[i][0],
+ 'mapset': allDatasets[i][1],
+ 'etype': allDatasets[i][2]})
+ for i in indices],
+ style=wx.CHOICEDLG_STYLE | wx.OK)
if dlg.ShowModal() == wx.ID_OK:
index = dlg.GetSelection()
validated.append(allDatasets[indices[index]])
@@ -417,6 +421,9 @@
return validated
+ def OnHelp(self, event):
+ RunCommand('g.manual', quiet=True, entry='g.gui.timeline')
# interface
def SetDatasets(self, datasets):
@@ -426,7 +433,7 @@
try:
except GException:
return
self.datasetSelect.SetValue(','.join(map(lambda x: x[0] + '@' + x[1], datasets)))
@@ -444,18 +451,18 @@
self.data = {}
self.timeData = timeData
- def AddDataset(self, type, yrange, xranges, datasetName):
- if type == 'bar':
+ def AddDataset(self, type_, yrange, xranges, datasetName):
+ if type_ == 'bar':
self.data[yrange] = {'name': datasetName}
for i, (start, end) in enumerate(xranges):
self.data[yrange][(start, end)] = i
- elif type == 'point':
+ elif type_ == 'point':
self.data[(yrange, yrange)] = {'name': datasetName}
for i, start in enumerate(xranges):
self.data[(yrange, yrange)][(start, start)] = i
def GetInformation(self, x, y):
- keys = None
+ keys = None
for keyY in self.data.keys():
if keyY[0] <= y <= keyY[1]:
for keyX in self.data[keyY].keys():
@@ -490,6 +497,8 @@
if not timeData[datasetName]['validTopology']:
text.append(_("WARNING: invalid topology"))
+ text.append(_("\nPress Del to dismiss."))
return '\n'.join(text)
@@ -501,18 +510,18 @@
Source: http://stackoverflow.com/questions/4652439/
is-there-a-matplotlib-equivalent-of-matlabs-datacursormode/4674445
- def __init__(self, artists, lookUp, formatFunction, tolerance=5, offsets=(-30, 30),
+ def __init__(self, artists, lookUp, formatFunction, tolerance=5, offsets=(-30, 30),
display_all=False):
"""Create the data cursor and connect it to the relevant figure.
- "artists" is the matplotlib artist or sequence of artists that will be
- selected.
+ "artists" is the matplotlib artist or sequence of artists that will be
+ selected.
"tolerance" is the radius (in points) that the mouse click must be
within to select the artist.
"offsets" is a tuple of (x,y) offsets in points from the selected
point to the displayed annotation box
"display_all" controls whether more than one annotation box will
be shown if there are multiple axes. Only one will be shown
- per-axis, regardless.
+ per-axis, regardless.
self.lookUp = lookUp
self.formatFunction = formatFunction
@@ -521,7 +530,7 @@
if not cbook.iterable(artists):
artists = [artists]
self.artists = artists
self.axes = tuple(set(art.axes for art in self.artists))
self.figures = tuple(set(ax.figure for ax in self.axes))
@@ -532,15 +541,25 @@
artist.set_picker(tolerance)
for fig in self.figures:
fig.canvas.mpl_connect('pick_event', self)
+ fig.canvas.mpl_connect('key_press_event', self.keyPressed)
+ def keyPressed(self, event):
+ """!Key pressed - hide annotation if Delete was pressed"""
+ if event.key != 'delete':
+ return
+ for ax in self.axes:
+ self.annotations[ax].set_visible(False)
+ event.canvas.draw()
def annotate(self, ax):
"""Draws and hides the annotation box for the given axis "ax"."""
- annotation = ax.annotate(self.formatFunction, xy=(0, 0), ha = 'center',
+ annotation = ax.annotate(self.formatFunction, xy=(0, 0), ha='center',
xytext=self.offsets, textcoords='offset points', va='bottom',
bbox=dict(boxstyle='round,pad=0.5', fc='yellow', alpha=0.7),
arrowprops=dict(arrowstyle='->', connectionstyle='arc3,rad=0'),
- annotation_clip = False, multialignment = 'left')
+ annotation_clip=False, multialignment='left')
annotation.set_visible(False)
return annotation
def __call__(self, event):
@@ -556,11 +575,11 @@
ann.set_visible(False)
# Update the annotation in the current axis..
annotation.xy = x, y
if 'Line2D' in str(type(event.artist)):
- y = event.artist.get_ydata()[0]
+ y = event.artist.get_ydata()[0]
xData = event.artist.get_xdata()
- x = xData[np.argmin(abs(xData - x))]
+ x = xData[np.argmin(abs(xData - x))]
info = self.lookUp.GetInformation(x, y)
if not info:
@@ -569,3 +588,14 @@
annotation.set_text(text)
annotation.set_visible(True)
event.canvas.draw()
+def run(parent=None, datasets=None):
+ frame = TimelineFrame(parent)
+ if datasets:
+ frame.SetDatasets(datasets)
+ frame.Show()
+if __name__ == '__main__':
+ run()
Modified: grass/trunk/gui/wxpython/timeline/g.gui.timeline.py
--- grass-addons/grass7/gui/wxpython/wx.timeline/g.gui.timeline.py 2013-08-23 17:02:04 UTC (rev 57491)
+++ grass/trunk/gui/wxpython/timeline/g.gui.timeline.py 2013-08-24 17:50:00 UTC (rev 57495)
@@ -5,7 +5,7 @@
# AUTHOR(S): Anna Kratochvilova
# PURPOSE: Timeline Tool is a wxGUI component (based on matplotlib)
# which allows the user to compare temporal datasets' extents.
-# COPYRIGHT: (C) 2012 by Anna Kratochvilova, and the GRASS Development Team
+# COPYRIGHT: (C) 2012-13 by Anna Kratochvilova, and the GRASS Development Team
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -33,28 +33,27 @@
import os
import sys
import wx
-import gettext
+gui_wx_path = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
+if gui_wx_path not in sys.path:
+ sys.path.append(gui_wx_path)
+from core.utils import _, GuiModuleMain
-# if __name__ == '__main__':
-# sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
-sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc', 'g.gui.timeline'))
def main():
- gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+ try:
+ from timeline.frame import TimelineFrame
+ except ImportError, e:
+ grass.fatal(e.message)
- options, flags = grass.parser()
datasets = options['inputs'].strip().split(',')
datasets = [data for data in datasets if data]
view3d = flags['3']
- app = wx.PySimpleApp()
- from frame import TimelineFrame
+ app = wx.App()
frame = TimelineFrame(None)
frame.Show3D(view3d)
@@ -63,5 +62,6 @@
- main()
+ options, flags = grass.parser()
+ GuiModuleMain(main)
