[GRASS-SVN] r57500 - grass/trunk/gui/wxpython/timeline
svn_grass at osgeo.org
Sun Aug 25 05:12:36 PDT 2013
Author: annakrat
Date: 2013-08-25 05:12:36 -0700 (Sun, 25 Aug 2013)
New Revision: 57500
grass/trunk/gui/wxpython/timeline/frame.py
wxGUI/timeline: fix 3d
Modified: grass/trunk/gui/wxpython/timeline/frame.py
--- grass/trunk/gui/wxpython/timeline/frame.py 2013-08-25 10:54:22 UTC (rev 57499)
+++ grass/trunk/gui/wxpython/timeline/frame.py 2013-08-25 12:12:36 UTC (rev 57500)
@@ -329,9 +329,10 @@
def OnRedraw(self, event):
"""!Required redrawing."""
- datasets = self.datasetSelect.GetValue().strip().split(',')
+ datasets = self.datasetSelect.GetValue().strip()
if not datasets:
return
+ datasets = datasets.split(',')
try:
datasets = self._checkDatasets(datasets)
except GException:
@@ -357,7 +358,7 @@
self.axes2d.change_geometry(2, 1, 1)
if not self.axes3d:
# do not remove this import - unused but it is required for 3D
-# from mpl_toolkits.mplot3d import Axes3D # pylint: disable=W0611
+ from mpl_toolkits.mplot3d import Axes3D # pylint: disable=W0611
self.axes3d = self.fig.add_subplot(2, 1, 2, projection='3d')
self.axes3d.set_visible(True)
