[GRASS-SVN] r57513 - grass/trunk/general/g.parser
svn_grass at osgeo.org
Tue Aug 27 02:55:31 PDT 2013
Author: neteler
Date: 2013-08-27 02:55:30 -0700 (Tue, 27 Aug 2013)
New Revision: 57513
grass/trunk/general/g.parser/g.parser.html
g.parser: mention the --ui switch
Modified: grass/trunk/general/g.parser/g.parser.html
--- grass/trunk/general/g.parser/g.parser.html 2013-08-27 08:41:45 UTC (rev 57512)
+++ grass/trunk/general/g.parser/g.parser.html 2013-08-27 09:55:30 UTC (rev 57513)
@@ -13,7 +13,7 @@
<em><b>g.parser</b></em> - Provides automated parser, GUI, and help support for GRASS scipts.
<h2>KEYWORDS</h2>
-general, support, scripts
+general, support, scripts, GUI
<h2>SYNOPSIS</h2>
<div id="name"><b>g.parser</b><br></div>
@@ -125,6 +125,10 @@
script should behave the same way regardless of whether they were set
by --o, --q or --v being passed to the script or set by other means.
+<p>In case that a GRASS module or script does not have any required
+options, executing the command without parameters will not open the
+respective parameter GUI dialog. The user can force a parameter dialog
+to be displayed using the --ui switch.
<h2>AUTOMATED SCRIPT CREATION</h2>
