[GRASS-SVN] r57524 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Wed Aug 28 04:48:45 PDT 2013
Author: huhabla
Date: 2013-08-28 04:48:44 -0700 (Wed, 28 Aug 2013)
New Revision: 57524
grass/trunk/lib/python/pygrass/modules/interface/module.py
grass/trunk/lib/python/pygrass/modules/interface/parameter.py
Fixed floating point range value handling and command string creation. Added test.
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2013-08-28 08:32:13 UTC (rev 57523)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2013-08-28 11:48:44 UTC (rev 57524)
@@ -3,6 +3,40 @@
Created on Tue Apr 2 18:41:27 2013
@author: pietro
+ at code
+>>> import grass.pygrass.modules as pymod
+>>> import copy
+>>> region = pymod.Module("g.region")
+>>> region.flags["p"].value = True
+>>> region.flags["3"].value = True
+>>> region.get_bash()
+'g.region -p -3'
+>>> new_region = copy.deepcopy(region)
+>>> new_region.inputs["res"].value = "10"
+>>> new_region.get_bash()
+'g.region res=10 -p -3'
+>>> neighbors = pymod.Module("r.neighbors")
+>>> neighbors.inputs["input"].value = "mapA"
+>>> neighbors.outputs["output"].value = "mapB"
+>>> neighbors.inputs["size"].value = 5
+>>> neighbors.get_bash()
+'r.neighbors input=mapA method=average size=5 quantile=0.5 output=mapB'
+>>> new_neighbors1 = copy.deepcopy(neighbors)
+>>> new_neighbors1.inputs["input"].value = "mapD"
+>>> new_neighbors1.inputs["size"].value = 3
+>>> new_neighbors1.get_bash()
+'r.neighbors input=mapD method=average size=3 quantile=0.5 output=mapB'
+>>> new_neighbors2 = copy.deepcopy(neighbors)
+>>> new_neighbors2(input="mapD", size=3, run_=False)
+>>> new_neighbors2.get_bash()
+ at endcode
from __future__ import print_function
@@ -227,6 +261,8 @@
return "%s.%s(%s)" % (prefix, name, params)
def __str__(self):
+ """!Return the command string that can be executed in a shell
return ' '.join(self.make_cmd())
def __repr__(self):
@@ -249,6 +285,9 @@
return '\n'.join([head, params, DOC['flag_head'], flags, DOC['foot']])
def get_dict(self):
+ """!Return a dictionary that includes the name, all valid
+ inputs, outputs and flags
dic = {}
dic['name'] = self.name
dic['inputs'] = [(k, v.value) for k, v in self.inputs.items()
@@ -259,10 +298,17 @@
return dic
def make_cmd(self):
+ """!Create the commdn string that can be exceuted in a shell
+ @return The command string
args = [self.name, ]
- for par in self.params_list:
- if par.value is not None:
- args.append(str(par))
+ for key in self.inputs:
+ if self.inputs[key].value:
+ args.append(self.inputs[key].get_bash())
+ for key in self.outputs:
+ if self.outputs[key].value:
+ args.append(self.outputs[key].get_bash())
for flg in self.flags:
if self.flags[flg].value:
args.append(str(self.flags[flg]))
@@ -296,3 +342,9 @@
stdout, stderr = self.popen.communicate(input=self.stdin)
self.outputs['stdout'].value = stdout if stdout else ''
self.outputs['stderr'].value = stderr if stderr else ''
+if __name__ == "__main__":
+ import doctest
+ doctest.testmod()
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2013-08-28 08:32:13 UTC (rev 57523)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2013-08-28 11:48:44 UTC (rev 57524)
@@ -37,14 +37,24 @@
if 'values' in diz:
try:
- # chek if it's a range string: "3-30"
+ # Check for integer ranges: "3-30"
isrange = re.match("(?P<min>\d+)-(?P<max>\d+)",
diz['values'][0])
if isrange:
range_min, range_max = isrange.groups()
self.values = range(int(range_min), int(range_max) + 1)
+ print(self.values)
self.isrange = diz['values'][0]
- else:
+ # Check for float ranges: "0.0-1.0"
+ if not isrange:
+ isrange = re.match("(?P<min>\d+.\d+)-(?P<max>\d+.\d+)",
+ diz['values'][0])
+ if isrange:
+ # We are not able to create range values from
+ # floating point ranges
+ self.isrange = diz['values'][0]
+ # No range was found
+ if not isrange:
self.values = [self.type(i) for i in diz['values']]
self.isrange = False
except TypeError:
