[GRASS-SVN] r57532 - in grass-addons/grass7/raster: . r.sun.daily
svn_grass at osgeo.org
Wed Aug 28 12:37:55 PDT 2013
Author: annakrat
Date: 2013-08-28 12:37:53 -0700 (Wed, 28 Aug 2013)
New Revision: 57532
Added:
grass-addons/grass7/raster/r.sun.daily/
grass-addons/grass7/raster/r.sun.daily/Makefile
grass-addons/grass7/raster/r.sun.daily/r.sun.daily.html
grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py
grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh
r.sun.daily: initial version, wrapper script for r.sun, mode 2 (co-author: wenzeslaus)
Added: grass-addons/grass7/raster/r.sun.daily/Makefile
--- grass-addons/grass7/raster/r.sun.daily/Makefile (rev 0)
+++ grass-addons/grass7/raster/r.sun.daily/Makefile 2013-08-28 19:37:53 UTC (rev 57532)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=r.sun.daily
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.sun.daily/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/raster/r.sun.daily/r.sun.daily.html
--- grass-addons/grass7/raster/r.sun.daily/r.sun.daily.html (rev 0)
+++ grass-addons/grass7/raster/r.sun.daily/r.sun.daily.html 2013-08-28 19:37:53 UTC (rev 57532)
@@ -0,0 +1,47 @@
+<h2>DESCRIPTION</h2>
+<em>r.sun.daily</em> is a convenient script for running
+r.sun for multiple days in a loop. It corresponds to mode 2
+(see r.sun <a href="r.sun.html">manual page</a>).
+<h3>Output parameters explanation</h3>
+There are two basic options:
+<ul>
+<li>output series of maps (one for each day): options containing basename in their name</li>
+<li>output one map which is a sum of the intermediate maps</li>
+</ul>
+You can choose any combination of parameters: e.g. total map of diffuse radiance and
+series of beam radiance maps.
+Series of maps are (if flag <i>t</i> is checked) registered
+to space time raster dataset with relative time and point time (not interval time).
+For GRASS 6, only timestamp is assigned.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+r.sun.daily elev_in=elevation start_day=30 end_day=40 beam_rad_basename=beam beam_rad=beam_sum nprocs=4 -t
+# show information about newly created space time dataset
+t.info beam
+# show information about newly created beam_sum raster map
+r.info beam
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.sun.html">r.sun</a>
+<a href="r.sun.hourly.html">r.sun.hourly</a> in Addons
+</em>
+<h2>AUTHOR</h2>
+Vaclav Petras, Anna Petrasova<br>
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/raster/r.sun.daily/r.sun.daily.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py
--- grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py (rev 0)
+++ grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py 2013-08-28 19:37:53 UTC (rev 57532)
@@ -0,0 +1,447 @@
+#!/usr/bin/env python
+# MODULE: r.sun.daily for GRASS 6 and 7; based on rsun_crop.sh from GRASS book
+# AUTHOR(S): Vaclav Petras, Anna Petrasova
+# PURPOSE:
+# COPYRIGHT: (C) 2013 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Runs r.sun for multiple days in loop (mode 2)
+#% keywords: raster
+#% keywords: sun
+#%end
+#%option
+#% type: string
+#% gisprompt: old,cell,raster
+#% key: elev_in
+#% description: Name of the input elevation raster map [meters]
+#% required : yes
+#%end
+#%option
+#% type: string
+#% key: asp_in
+#% description: Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]
+#%end
+#%option
+#% type: string
+#% key: slope_in
+#% description: Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]
+#%end
+#%option
+#% key: start_day
+#% type: integer
+#% description: Start day (of year) of interval
+#% options: 1-365
+#% required : yes
+#%end
+#%option
+#% key: end_day
+#% type: integer
+#% description: End day (of year) of interval
+#% options: 1-365
+#% required : yes
+#%end
+#%option
+#% key: day_step
+#% type: integer
+#% description: Run r.sun for every n-th day [days]
+#% options: 1-365
+#% answer: 1
+#%end
+#%option
+#% key: step
+#% type: double
+#% description: Time step when computing all-day radiation sums [decimal hours]
+#% answer: 0.5
+#%end
+#%option
+#% key: civil_time
+#% type: double
+#% description: Civil time zone value, if none, the time will be local solar time
+#%end
+#%option
+#% type: string
+#% gisprompt: new,cell,raster
+#% key: beam_rad
+#% description: Output beam irradiation raster map [Wh.m-2.day-1]
+#% required: no
+#%end
+#%option
+#% type: string
+#% key: diff_rad
+#% description: Output diffuse irradiation raster map [Wh.m-2.day-1]
+#% required: no
+#%end
+#%option
+#% type: string
+#% key: refl_rad
+#% description: Output ground reflected irradiation raster map [Wh.m-2.day-1]
+#% required: no
+#%end
+#%option
+#% type: string
+#% key: glob_rad
+#% description: Output global (total) irradiance/irradiation raster map [Wh.m-2.day-1]
+#% required: no
+#%end
+#%option
+#% key: beam_rad_basename
+#% type: string
+#% label: Base name for output beam irradiation raster maps [Wh.m-2.day-1]
+#% description: Underscore and day number are added to the base name for daily maps
+#%end
+#%option
+#% key: diff_rad_basename
+#% type: string
+#% label: Base name for output diffuse irradiation raster maps [Wh.m-2.day-1]
+#%end
+#%option
+#% key: refl_rad_basename
+#% type: string
+#% label: Base name for output ground reflected irradiation raster maps [Wh.m-2.day-1]
+#%end
+#%option
+#% key: glob_rad_basename
+#% type: string
+#% label: Base name for output global (total) irradiance/irradiation raster maps [Wh.m-2.day-1]
+#%end
+#%option
+#% key: nprocs
+#% type: integer
+#% description: Number of r.sun processes to run in parallel
+#% options: 1-
+#% answer: 1
+#%end
+#%flag
+#% key: t
+#% description: Dataset name is the same as the base name for the output series of maps
+#% label: Register created series of output maps into temporal dataset
+#%end
+import os
+import atexit
+from multiprocessing import Process
+import grass.script as grass
+import grass.script.core as core
+REMOVE = []
+MREMOVE = []
+def cleanup():
+ if REMOVE or MREMOVE:
+ core.info(_("Cleaning temporary maps..."))
+ for rast in REMOVE:
+ grass.run_command('g.remove', rast=rast, quiet=True)
+ for pattern in MREMOVE:
+ grass.run_command('g.mremove', rast='%s*' % pattern,
+ flags='f', quiet=True)
+def is_grass_7():
+ if core.version()['version'].split('.')[0] == '7':
+ return True
+ return False
+def create_tmp_map_name(name):
+ return '{mod}{pid}_{map_}_tmp'.format(mod='r_sun_crop',
+ pid=os.getpid(),
+ map_=name)
+# add latitude map
+def run_r_sun(elevation, aspect, slope, day, step,
+ beam_rad, diff_rad, refl_rad, glob_rad, suffix):
+ params = {}
+ if beam_rad:
+ params.update({'beam_rad': beam_rad + suffix})
+ if diff_rad:
+ params.update({'diff_rad': diff_rad + suffix})
+ if refl_rad:
+ params.update({'refl_rad': refl_rad + suffix})
+ if glob_rad:
+ params.update({'glob_rad': glob_rad + suffix})
+ if is_grass_7():
+ grass.run_command('r.sun', elev_in=elevation, asp_in=aspect,
+ slope_in=slope,
+ day=day, step=step,
+ overwrite=core.overwrite(), quiet=True,
+ **params)
+ else:
+ grass.run_command('r.sun', elevin=elevation, aspin=aspect,
+ slopein=slope,
+ **params)
+def set_color_table(rasters):
+ if is_grass_7():
+ grass.run_command('r.colors', map=rasters, col='gyr', quiet=True)
+ else:
+ for rast in rasters:
+ grass.run_command('r.colors', map=rast, col='gyr', quiet=True)
+def set_time_stamp(raster, day):
+ grass.run_command('r.timestamp', map=raster, date='%d days' % day, quiet=True)
+def format_order(number, zeros=3):
+ return str(number).zfill(zeros)
+def check_daily_map_names(basename, mapset, start_day, end_day, day_step):
+ if not basename:
+ return
+ for day in range(start_day, end_day + 1, day_step):
+ map_ = '%s%s%s' % (basename, '_', format_order(day))
+ if grass.find_file(map_, element='cell', mapset=mapset)['file']:
+ grass.fatal(_("Raster map <%s> already exists. Change the base name or allow overwrite.") % map_)
+def sum_maps(sum_, basename, suffixes):
+ maps = '+'.join([basename + suf for suf in suffixes])
+ grass.mapcalc('{sum_}={sum_} + {new}'.format(sum_=sum_, new=maps),
+ overwrite=True, quiet=True)
+def main():
+ options, flags = grass.parser()
+ elevation_input = options['elev_in']
+ aspect_input = options['asp_in']
+ slope_input = options['slope_in']
+ beam_rad = options['beam_rad']
+ diff_rad = options['diff_rad']
+ refl_rad = options['refl_rad']
+ glob_rad = options['glob_rad']
+ beam_rad_basename = beam_rad_basename_user = options['beam_rad_basename']
+ diff_rad_basename = diff_rad_basename_user = options['diff_rad_basename']
+ refl_rad_basename = refl_rad_basename_user = options['refl_rad_basename']
+ glob_rad_basename = glob_rad_basename_user = options['glob_rad_basename']
+ if not any([beam_rad, diff_rad, refl_rad, glob_rad,
+ beam_rad_basename, diff_rad_basename,
+ refl_rad_basename, glob_rad_basename]):
+ grass.fatal(_("No output specified."))
+ if beam_rad and not beam_rad_basename:
+ beam_rad_basename = create_tmp_map_name('beam_rad')
+ MREMOVE.append(beam_rad_basename)
+ if diff_rad and not diff_rad_basename:
+ diff_rad_basename = create_tmp_map_name('diff_rad')
+ MREMOVE.append(diff_rad_basename)
+ if refl_rad and not refl_rad_basename:
+ refl_rad_basename = create_tmp_map_name('refl_rad')
+ MREMOVE.append(refl_rad_basename)
+ if glob_rad and not glob_rad_basename:
+ glob_rad_basename = create_tmp_map_name('glob_rad')
+ MREMOVE.append(glob_rad_basename)
+ start_day = int(options['start_day'])
+ end_day = int(options['end_day'])
+ day_step = int(options['day_step'])
+ step = float(options['step'])
+ nprocs = int(options['nprocs'])
+ temporal = flags['t']
+ if not is_grass_7() and temporal:
+ grass.warning(_("Flag t has effect only in GRASS 7"))
+ # check: start < end
+ if start_day > end_day:
+ grass.fatal(_("Start day is after end day."))
+ if day_step >= end_day - start_day:
+ grass.fatal(_("Day step is too big."))
+ # here we check all the days
+ if not grass.overwrite():
+ check_daily_map_names(beam_rad_basename, grass.gisenv()['MAPSET'],
+ start_day, end_day, day_step)
+ check_daily_map_names(diff_rad_basename, grass.gisenv()['MAPSET'],
+ check_daily_map_names(refl_rad_basename, grass.gisenv()['MAPSET'],
+ check_daily_map_names(glob_rad_basename, grass.gisenv()['MAPSET'],
+ # check for slope/aspect
+ if not aspect_input or not slope_input:
+ params = {}
+ if not aspect_input:
+ aspect_input = create_tmp_map_name('aspect')
+ params.update({'aspect': aspect_input})
+ REMOVE.append(aspect_input)
+ if not slope_input:
+ slope_input = create_tmp_map_name('slope')
+ params.update({'slope': slope_input})
+ REMOVE.append(slope_input)
+ grass.info(_("Running r.slope.aspect..."))
+ grass.run_command('r.slope.aspect', elevation=elevation_input, quiet=True, **params)
+ if beam_rad:
+ grass.mapcalc('%s=0' % beam_rad, quiet=True)
+ if diff_rad:
+ grass.mapcalc('%s=0' % diff_rad, quiet=True)
+ if refl_rad:
+ grass.mapcalc('%s=0' % refl_rad, quiet=True)
+ if glob_rad:
+ grass.mapcalc('%s=0' % glob_rad, quiet=True)
+ grass.info(_("Running r.sun in a loop..."))
+ count = 0
+ # Parallel processing
+ proc_list = []
+ proc_count = 0
+ suffixes = []
+ suffixes_all = []
+ days = range(start_day, end_day + 1, day_step)
+ num_days = len(days)
+ core.percent(0, num_days, 1)
+ for day in days:
+ count += 1
+ core.percent(count, num_days, 10)
+ suffix = '_' + format_order(day)
+ proc_list.append(Process(target=run_r_sun,
+ args=(elevation_input, aspect_input,
+ slope_input, day, step,
+ diff_rad_basename,
+ glob_rad_basename,
+ suffix)))
+ proc_list[proc_count].start()
+ proc_count += 1
+ suffixes.append(suffix)
+ suffixes_all.append(suffix)
+ if proc_count == nprocs or proc_count == num_days or count == num_days:
+ proc_count = 0
+ exitcodes = 0
+ for proc in proc_list:
+ proc.join()
+ exitcodes += proc.exitcode
+ if exitcodes != 0:
+ core.fatal(_("Error while r.sun computation"))
+ if beam_rad:
+ sum_maps(beam_rad, beam_rad_basename, suffixes)
+ if diff_rad:
+ sum_maps(diff_rad, diff_rad_basename, suffixes)
+ if refl_rad:
+ sum_maps(refl_rad, refl_rad_basename, suffixes)
+ if glob_rad:
+ sum_maps(glob_rad, glob_rad_basename, suffixes)
+ # Empty process list
+ proc_list = []
+ suffixes = []
+ # FIXME: how percent really works?
+ # core.percent(1, 1, 1)
+ # set color table
+ if beam_rad:
+ set_color_table([beam_rad])
+ if diff_rad:
+ set_color_table([diff_rad])
+ if refl_rad:
+ set_color_table([refl_rad])
+ if glob_rad:
+ set_color_table([glob_rad])
+ if not any([beam_rad_basename_user, diff_rad_basename_user,
+ refl_rad_basename_user, glob_rad_basename_user]):
+ return 0
+ # add timestamps either via temporal framework in 7 or r.timestamp in 6.x
+ if is_grass_7() and temporal:
+ core.info(_("Registering created maps into temporal dataset..."))
+ import grass.temporal as tgis
+ def registerToTemporal(basename, suffixes, mapset, start_day, day_step, title, desc):
+ maps = ','.join([basename + suf + '@' + mapset for suf in suffixes])
+ tgis.open_new_space_time_dataset(basename, type='strds', temporaltype='relative',
+ title=title, descr=desc,
+ semantic='sum', dbif=None, overwrite=grass.overwrite())
+ tgis.register_maps_in_space_time_dataset(
+ type='rast', name=basename, maps=maps, start=start_day, end=None,
+ unit='days', increment=day_step, dbif=None, interval=False)
+ # Make sure the temporal database exists
+ tgis.init()
+ mapset = grass.gisenv()['MAPSET']
+ if beam_rad_basename_user:
+ registerToTemporal(beam_rad_basename, suffixes_all, mapset, start_day, day_step,
+ title="Beam irradiation",
+ desc="Output beam irradiation raster maps [Wh.m-2.day-1]")
+ if diff_rad_basename_user:
+ registerToTemporal(diff_rad_basename, suffixes_all, mapset, start_day, day_step,
+ title="Diffuse irradiation",
+ desc="Output diffuse irradiation raster maps [Wh.m-2.day-1]")
+ if refl_rad_basename_user:
+ registerToTemporal(refl_rad_basename, suffixes_all, mapset, start_day, day_step,
+ title="Reflected irradiation",
+ desc="Output reflected irradiation raster maps [Wh.m-2.day-1]")
+ if glob_rad_basename_user:
+ registerToTemporal(glob_rad_basename, suffixes_all, mapset, start_day, day_step,
+ title="Total irradiation",
+ desc="Output total irradiation raster maps [Wh.m-2.day-1]")
+ else:
+ for i, day in enumerate(days):
+ set_time_stamp(beam_rad_basename + suffixes_all[i], day=day)
+ set_time_stamp(diff_rad_basename + suffixes_all[i], day=day)
+ set_time_stamp(refl_rad_basename + suffixes_all[i], day=day)
+ set_time_stamp(glob_rad_basename + suffixes_all[i], day=day)
+ maps = []
+ maps.extend([beam_rad_basename + suf for suf in suffixes_all])
+ maps.extend([diff_rad_basename + suf for suf in suffixes_all])
+ maps.extend([refl_rad_basename + suf for suf in suffixes_all])
+ maps.extend([glob_rad_basename + suf for suf in suffixes_all])
+ set_color_table(maps)
+if __name__ == "__main__":
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py
Added: svn:executable
+ text/x-python
+ native
Added: grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh
--- grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh (rev 0)
+++ grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh 2013-08-28 19:37:53 UTC (rev 57532)
@@ -0,0 +1,73 @@
+#!/bin/sh
+# TEST: test.r.sun.daily
+# PURPOSE: This is test for r.sun.daily module
+# for details.
+# @preprocess step
+# The region setting should work for UTM and LL test locations
+# region could be set to some real values to avoid unable to read fp range warning
+g.region s=30 n=40 w=40 e=60 res=10
+r.mapcalc --o expr="building = 50"
+g.region s=0 n=80 w=0 e=120 res=10
+r.mapcalc --o expr="terrain = 10"
+r.mapcalc --o expr="terrain = terrain + building"
+map_basename=reflmap
+map_names_file=`g.tempfile pid=$$`
+created_map_names_file=`g.tempfile pid=$$`
+cat > "${map_names_file}" << EOF
+${map_basename}_026
+${map_basename}_029
+${map_basename}_032
+${map_basename}_035
+EOF
+# The @test
+NAME="Missing parameter test (module should fail)"
+r.sun.daily elev_in=terrain start_day=26 end_day=37 day_step=3
+echo "$NAME: r.sun.daily returned: $? (expecting 1)"
+NAME="Wrong start and end day parameter values test (module should fail)"
+r.sun.daily elev_in=terrain start_day=82 end_day=37 day_step=3 reflrad_basename=${map_basename}
+NAME="Wrong day step parameter values test (module should fail)"
+r.sun.daily elev_in=terrain start_day=82 end_day=85 day_step=9 reflrad_basename=${map_basename}
+NAME="Map creation test"
+r.sun.daily elev_in=terrain start_day=26 end_day=37 day_step=3 reflrad_basename=${map_basename}
+g.mlist -e type=rast pattern=${map_basename}_[0-9]{3} sep=newline > ${created_map_names_file}
+diff ${map_names_file} ${created_map_names_file}
+echo "$NAME: Diff returned $? (expecting 0)"
+NAME="Overwrite flag test"
+r.sun.daily elev_in=terrain start_day=26 end_day=37 day_step=3 reflrad_basename=${map_basename} --overwrite
+echo "$NAME: r.sun.daily returned: $? (expecting 0)"
+NAME="Map already exists test (module should fail)"
+# clean
+rm ${map_names_file} ${created_map_names_file}
+g.remove rast=`g.mlist -e type=rast pattern=${map_basename}_[0-9]{3} sep=,`
Property changes on: grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh
+ text/x-sh
+ native
