[GRASS-SVN] r57541 - grass/trunk
Thu Aug 29 04:53:55 PDT 2013
Author: glynn
Date: 2013-08-29 04:53:55 -0700 (Thu, 29 Aug 2013)
New Revision: 57541
   grass/trunk/configure
   grass/trunk/configure.in
Add LIBLAS_INC to CPPFLAGS when compiling test case
Modified: grass/trunk/configure
--- grass/trunk/configure	2013-08-29 11:36:43 UTC (rev 57540)
+++ grass/trunk/configure	2013-08-29 11:53:55 UTC (rev 57541)
@@ -6256,17 +6256,19 @@
   LIBLAS=
   ac_save_libs="$LIBS"
   ac_save_cflags="$CFLAGS"
+  ac_save_cppflags="$CPPFLAGS"
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
+  CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
   cat > conftest.$ac_ext <<EOF
-#line 6263 "configure"
+#line 6265 "configure"
 #include "confdefs.h"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6274,14 +6276,14 @@
   rm -rf conftest*
-#line 6278 "configure"
+#line 6280 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6298,6 +6300,7 @@
 rm -f conftest*
   LIBS=${ac_save_libs}
   CFLAGS=${ac_save_cflags}
+  CPPFLAGS=${ac_save_cppflags}
   cat >> confdefs.h <<\EOF
 #define HAVE_LIBLAS 1
@@ -6313,7 +6316,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6317: checking whether to use NetCDF" >&5
+echo "configure:6320: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6330,7 +6333,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6334: checking for $ac_word" >&5
+echo "configure:6337: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6377,14 +6380,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6381 "configure"
+#line 6384 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6392,14 +6395,14 @@
   rm -rf conftest*
-#line 6396 "configure"
+#line 6399 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6430,7 +6433,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6434: checking whether to use GEOS" >&5
+echo "configure:6437: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6448,7 +6451,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6452: checking for $ac_word" >&5
+echo "configure:6455: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6496,15 +6499,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:6500: checking for $ac_hdr" >&5
+echo "configure:6503: checking for $ac_hdr" >&5
-#line 6503 "configure"
+#line 6506 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:6508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6511: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -6543,13 +6546,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6547: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6550: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lgeos_c  $LIBS"
-#line 6553 "configure"
+#line 6556 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -6560,7 +6563,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -6604,7 +6607,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6608: checking whether to use TIFF" >&5
+echo "configure:6611: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6624,7 +6627,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6628: checking for location of TIFF includes" >&5
+echo "configure:6631: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6650,15 +6653,15 @@
 do
-echo "configure:6654: checking for $ac_hdr" >&5
+echo "configure:6657: checking for $ac_hdr" >&5
-#line 6657 "configure"
+#line 6660 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6692,7 +6695,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6696: checking for location of TIFF library" >&5
+echo "configure:6699: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6723,13 +6726,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6727: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6730: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6733 "configure"
+#line 6736 "configure"
@@ -6740,7 +6743,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6759,13 +6762,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:6763: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6766: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6769 "configure"
+#line 6772 "configure"
@@ -6776,7 +6779,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6795,13 +6798,13 @@
-echo "configure:6799: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6802: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 6805 "configure"
+#line 6808 "configure"
@@ -6812,7 +6815,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6831,13 +6834,13 @@
-echo "configure:6835: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6838: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6841 "configure"
+#line 6844 "configure"
@@ -6848,7 +6851,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6867,13 +6870,13 @@
-echo "configure:6871: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6874: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 6877 "configure"
+#line 6880 "configure"
@@ -6884,7 +6887,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6903,13 +6906,13 @@
-echo "configure:6907: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6910: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6913 "configure"
+#line 6916 "configure"
@@ -6920,7 +6923,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6939,13 +6942,13 @@
-echo "configure:6943: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6946: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6949 "configure"
+#line 6952 "configure"
@@ -6956,7 +6959,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6975,13 +6978,13 @@
-echo "configure:6979: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6982: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6985 "configure"
+#line 6988 "configure"
@@ -6992,7 +6995,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7090,7 +7093,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7094: checking whether to use PNG" >&5
+echo "configure:7097: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7109,7 +7112,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7113: checking for location of PNG includes" >&5
+echo "configure:7116: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7135,15 +7138,15 @@
 do
-echo "configure:7139: checking for $ac_hdr" >&5
+echo "configure:7142: checking for $ac_hdr" >&5
-#line 7142 "configure"
+#line 7145 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7177,7 +7180,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7181: checking for location of PNG library" >&5
+echo "configure:7184: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7202,13 +7205,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7206: checking for png_read_image in -lpng" >&5
+echo "configure:7209: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7212 "configure"
+#line 7215 "configure"
@@ -7219,7 +7222,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7261,7 +7264,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7265: checking whether to use PostgreSQL" >&5
+echo "configure:7268: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7288,7 +7291,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7292: checking for location of PostgreSQL includes" >&5
+echo "configure:7295: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7314,15 +7317,15 @@
 do
-echo "configure:7318: checking for $ac_hdr" >&5
+echo "configure:7321: checking for $ac_hdr" >&5
-#line 7321 "configure"
+#line 7324 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7326: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7360,7 +7363,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7364: checking for location of PostgreSQL library" >&5
+echo "configure:7367: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7389,13 +7392,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7393: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7396: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7399 "configure"
+#line 7402 "configure"
@@ -7406,7 +7409,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7425,13 +7428,13 @@
-echo "configure:7429: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7432: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7435 "configure"
+#line 7438 "configure"
@@ -7442,7 +7445,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7461,13 +7464,13 @@
-echo "configure:7465: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7468: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7471 "configure"
+#line 7474 "configure"
@@ -7478,7 +7481,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7497,13 +7500,13 @@
-echo "configure:7501: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7504: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7507 "configure"
+#line 7510 "configure"
@@ -7514,7 +7517,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7571,13 +7574,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7575: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7578: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7581 "configure"
+#line 7584 "configure"
@@ -7588,7 +7591,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7610,13 +7613,13 @@
-echo "configure:7614: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7617: checking for PQcmdTuples in -lpq" >&5
-#line 7620 "configure"
+#line 7623 "configure"
@@ -7627,7 +7630,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7670,7 +7673,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7674: checking whether to use MySQL" >&5
+echo "configure:7677: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7690,7 +7693,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7694: checking for location of MySQL includes" >&5
+echo "configure:7697: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7716,15 +7719,15 @@
 do
-echo "configure:7720: checking for $ac_hdr" >&5
+echo "configure:7723: checking for $ac_hdr" >&5
-#line 7723 "configure"
+#line 7726 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7761,7 +7764,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7765: checking for location of MySQL library" >&5
+echo "configure:7768: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7792,13 +7795,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7796: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7799: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7802 "configure"
+#line 7805 "configure"
@@ -7809,7 +7812,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7828,13 +7831,13 @@
-echo "configure:7832: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7835: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7838 "configure"
+#line 7841 "configure"
@@ -7845,7 +7848,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7864,13 +7867,13 @@
-echo "configure:7868: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7871: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7874 "configure"
+#line 7877 "configure"
@@ -7881,7 +7884,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7900,13 +7903,13 @@
-echo "configure:7904: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7907: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7910 "configure"
+#line 7913 "configure"
@@ -7917,7 +7920,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7936,13 +7939,13 @@
-echo "configure:7940: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7943: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7946 "configure"
+#line 7949 "configure"
@@ -7953,7 +7956,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7972,13 +7975,13 @@
-echo "configure:7976: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7979: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7982 "configure"
+#line 7985 "configure"
@@ -7989,7 +7992,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8008,13 +8011,13 @@
-echo "configure:8012: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8015: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8018 "configure"
+#line 8021 "configure"
@@ -8025,7 +8028,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8044,13 +8047,13 @@
-echo "configure:8048: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8051: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8054 "configure"
+#line 8057 "configure"
@@ -8061,7 +8064,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8151,7 +8154,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:8155: checking for $ac_word" >&5
+echo "configure:8158: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8200,10 +8203,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8204: checking for mysql_server_init" >&5
+echo "configure:8207: checking for mysql_server_init" >&5
-#line 8207 "configure"
+#line 8210 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -8229,7 +8232,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8281,7 +8284,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8285: checking whether to use SQLite" >&5
+echo "configure:8288: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8301,7 +8304,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8305: checking for location of SQLite includes" >&5
+echo "configure:8308: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8327,15 +8330,15 @@
 do
-echo "configure:8331: checking for $ac_hdr" >&5
+echo "configure:8334: checking for $ac_hdr" >&5
-#line 8334 "configure"
+#line 8337 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8342: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8378,7 +8381,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8382: checking for location of SQLite library" >&5
+echo "configure:8385: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8407,13 +8410,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8411: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8414: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8417 "configure"
+#line 8420 "configure"
@@ -8424,7 +8427,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8443,13 +8446,13 @@
-echo "configure:8447: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8450: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8453 "configure"
+#line 8456 "configure"
@@ -8460,7 +8463,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8479,13 +8482,13 @@
-echo "configure:8483: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8486: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8489 "configure"
+#line 8492 "configure"
@@ -8496,7 +8499,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8515,13 +8518,13 @@
-echo "configure:8519: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8522: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8525 "configure"
+#line 8528 "configure"
@@ -8532,7 +8535,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8601,7 +8604,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8605: checking whether to use FFMPEG" >&5
+echo "configure:8608: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -8621,7 +8624,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8625: checking for location of FFMPEG includes" >&5
+echo "configure:8628: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8647,15 +8650,15 @@
 do
-echo "configure:8651: checking for $ac_hdr" >&5
+echo "configure:8654: checking for $ac_hdr" >&5
-#line 8654 "configure"
+#line 8657 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8659: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8691,15 +8694,15 @@
 do
-echo "configure:8695: checking for $ac_hdr" >&5
+echo "configure:8698: checking for $ac_hdr" >&5
-#line 8698 "configure"
+#line 8701 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8735,15 +8738,15 @@
 do
-echo "configure:8739: checking for $ac_hdr" >&5
+echo "configure:8742: checking for $ac_hdr" >&5
-#line 8742 "configure"
+#line 8745 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8750: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8786,7 +8789,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8790: checking for location of FFMPEG library" >&5
+echo "configure:8793: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8813,13 +8816,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8817: checking for av_free in -lavutil" >&5
+echo "configure:8820: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 8823 "configure"
+#line 8826 "configure"
@@ -8830,7 +8833,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8849,13 +8852,13 @@
-echo "configure:8853: checking for av_free in -lavutil" >&5
+echo "configure:8856: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 8859 "configure"
+#line 8862 "configure"
@@ -8866,7 +8869,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:8870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8911,13 +8914,13 @@
 echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8915: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8918: checking for avcodec_register in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 8921 "configure"
+#line 8924 "configure"
@@ -8928,7 +8931,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8947,13 +8950,13 @@
-echo "configure:8951: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8954: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8957 "configure"
+#line 8960 "configure"
@@ -8964,7 +8967,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:8968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9009,13 +9012,13 @@
 echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:9013: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9016: checking for avformat_alloc_context in -lavformat" >&5
 ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9019 "configure"
+#line 9022 "configure"
@@ -9026,7 +9029,7 @@
 avformat_alloc_context()
 ; return 0; }
 EOF
-if { (eval echo configure:9030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9045,13 +9048,13 @@
-echo "configure:9049: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9052: checking for avformat_alloc_context in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9055 "configure"
+#line 9058 "configure"
@@ -9062,7 +9065,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9121,7 +9124,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9125: checking whether to use OpenGL" >&5
+echo "configure:9128: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9155,7 +9158,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9159: checking for location of OpenGL includes" >&5
+echo "configure:9162: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9181,15 +9184,15 @@
 do
-echo "configure:9185: checking for $ac_hdr" >&5
+echo "configure:9188: checking for $ac_hdr" >&5
-#line 9188 "configure"
+#line 9191 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9223,7 +9226,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9227: checking for location of OpenGL library" >&5
+echo "configure:9230: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9252,13 +9255,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9256: checking for glBegin in -lGL" >&5
+echo "configure:9259: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9262 "configure"
+#line 9265 "configure"
@@ -9269,7 +9272,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9288,13 +9291,13 @@
-echo "configure:9292: checking for glBegin in -lGL" >&5
+echo "configure:9295: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9298 "configure"
+#line 9301 "configure"
@@ -9305,7 +9308,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9324,13 +9327,13 @@
-echo "configure:9328: checking for glBegin in -lGL" >&5
+echo "configure:9331: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9334 "configure"
+#line 9337 "configure"
@@ -9341,7 +9344,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9360,13 +9363,13 @@
-echo "configure:9364: checking for glBegin in -lGL" >&5
+echo "configure:9367: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9370 "configure"
+#line 9373 "configure"
@@ -9377,7 +9380,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9439,13 +9442,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9443: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9446: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9449 "configure"
+#line 9452 "configure"
@@ -9456,7 +9459,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9475,13 +9478,13 @@
-echo "configure:9479: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9482: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9485 "configure"
+#line 9488 "configure"
@@ -9492,7 +9495,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9539,10 +9542,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9543: checking for glXCreatePbuffer" >&5
+echo "configure:9546: checking for glXCreatePbuffer" >&5
-#line 9546 "configure"
+#line 9549 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9565,7 +9568,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9602,10 +9605,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9606: checking for glXCreateGLXPixmap" >&5
+echo "configure:9609: checking for glXCreateGLXPixmap" >&5
-#line 9609 "configure"
+#line 9612 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9628,7 +9631,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9671,7 +9674,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9675: checking for location of OpenGL framework" >&5
+echo "configure:9678: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9695,15 +9698,15 @@
 do
-echo "configure:9699: checking for $ac_hdr" >&5
+echo "configure:9702: checking for $ac_hdr" >&5
-#line 9702 "configure"
+#line 9705 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9739,10 +9742,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9743: checking for glBegin" >&5
+echo "configure:9746: checking for glBegin" >&5
-#line 9746 "configure"
+#line 9749 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9765,7 +9768,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9802,10 +9805,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9806: checking for gluBeginCurve" >&5
+echo "configure:9809: checking for gluBeginCurve" >&5
-#line 9809 "configure"
+#line 9812 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9828,7 +9831,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9876,7 +9879,7 @@
-echo "configure:9880: checking for location of OpenGL includes" >&5
+echo "configure:9883: checking for location of OpenGL includes" >&5
@@ -9902,15 +9905,15 @@
 do
-echo "configure:9906: checking for $ac_hdr" >&5
+echo "configure:9909: checking for $ac_hdr" >&5
-#line 9909 "configure"
+#line 9912 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9944,7 +9947,7 @@
-echo "configure:9948: checking for location of OpenGL library" >&5
+echo "configure:9951: checking for location of OpenGL library" >&5
@@ -9969,18 +9972,18 @@
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9973: checking for OpenGL library" >&5
+echo "configure:9976: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9977 "configure"
+#line 9980 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10004,18 +10007,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10008: checking for GLU library" >&5
+echo "configure:10011: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10012 "configure"
+#line 10015 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10064,7 +10067,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10068: checking whether to use ODBC" >&5
+echo "configure:10071: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -10083,7 +10086,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10087: checking for location of ODBC includes" >&5
+echo "configure:10090: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10109,15 +10112,15 @@
 do
-echo "configure:10113: checking for $ac_hdr" >&5
+echo "configure:10116: checking for $ac_hdr" >&5
-#line 10116 "configure"
+#line 10119 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10124: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10151,7 +10154,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10155: checking for location of ODBC library" >&5
+echo "configure:10158: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10176,13 +10179,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10180: checking for SQLConnect in -lodbc" >&5
+echo "configure:10183: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10186 "configure"
+#line 10189 "configure"
@@ -10193,7 +10196,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10218,13 +10221,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10222: checking for SQLConnect in -liodbc" >&5
+echo "configure:10225: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10228 "configure"
+#line 10231 "configure"
@@ -10235,7 +10238,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10260,11 +10263,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10264: checking for ODBC library" >&5
+echo "configure:10267: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10268 "configure"
+#line 10271 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10272,7 +10275,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10321,7 +10324,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10325: checking whether to use FFTW" >&5
+echo "configure:10328: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10340,7 +10343,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10344: checking for location of FFTW includes" >&5
+echo "configure:10347: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10366,15 +10369,15 @@
 do
-echo "configure:10370: checking for $ac_hdr" >&5
+echo "configure:10373: checking for $ac_hdr" >&5
-#line 10373 "configure"
+#line 10376 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10381: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10402,15 +10405,15 @@
 do
-echo "configure:10406: checking for $ac_hdr" >&5
+echo "configure:10409: checking for $ac_hdr" >&5
-#line 10409 "configure"
+#line 10412 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10438,15 +10441,15 @@
 do
-echo "configure:10442: checking for $ac_hdr" >&5
+echo "configure:10445: checking for $ac_hdr" >&5
-#line 10445 "configure"
+#line 10448 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10453: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10492,7 +10495,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10496: checking for location of FFTW library" >&5
+echo "configure:10499: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10517,13 +10520,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10521: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10524: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10527 "configure"
+#line 10530 "configure"
@@ -10534,7 +10537,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10559,13 +10562,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10563: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10566: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10569 "configure"
+#line 10572 "configure"
@@ -10576,7 +10579,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10601,13 +10604,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10605: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10608: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10611 "configure"
+#line 10614 "configure"
@@ -10618,7 +10621,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10675,7 +10678,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10679: checking whether to use BLAS" >&5
+echo "configure:10682: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10696,7 +10699,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10700: checking for location of BLAS includes" >&5
+echo "configure:10703: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10716,7 +10719,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10720: checking for location of BLAS library" >&5
+echo "configure:10723: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10742,15 +10745,15 @@
 do
-echo "configure:10746: checking for $ac_hdr" >&5
+echo "configure:10749: checking for $ac_hdr" >&5
-#line 10749 "configure"
+#line 10752 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10757: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10785,13 +10788,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10789: checking for dnrm2_ in -lblas" >&5
+echo "configure:10792: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10795 "configure"
+#line 10798 "configure"
@@ -10802,7 +10805,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10821,13 +10824,13 @@
-echo "configure:10825: checking for dnrm2_ in -lblas" >&5
+echo "configure:10828: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10831 "configure"
+#line 10834 "configure"
@@ -10838,7 +10841,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10882,13 +10885,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10886: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10889: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10892 "configure"
+#line 10895 "configure"
@@ -10899,7 +10902,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10914,13 +10917,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10918: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10921: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10924 "configure"
+#line 10927 "configure"
@@ -10931,7 +10934,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10946,13 +10949,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10950: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10953: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10956 "configure"
+#line 10959 "configure"
@@ -10963,7 +10966,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11009,16 +11012,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11013: checking for sgemm in $vlib_flags" >&5
+echo "configure:11016: checking for sgemm in $vlib_flags" >&5
-#line 11015 "configure"
+#line 11018 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:11022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -11036,13 +11039,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11040: checking for sgemm_ in -lblas" >&5
+echo "configure:11043: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 11046 "configure"
+#line 11049 "configure"
@@ -11053,7 +11056,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11068,13 +11071,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11072: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11075: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 11078 "configure"
+#line 11081 "configure"
@@ -11085,7 +11088,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11100,13 +11103,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11104: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11107: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 11110 "configure"
+#line 11113 "configure"
@@ -11117,7 +11120,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11151,13 +11154,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11155: checking for acosp in -lsunmath" >&5
+echo "configure:11158: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 11161 "configure"
+#line 11164 "configure"
@@ -11168,7 +11171,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11183,13 +11186,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11187: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11190: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11193 "configure"
+#line 11196 "configure"
@@ -11200,7 +11203,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11230,13 +11233,13 @@
 # Generic BLAS library
-echo "configure:11234: checking for sgemm_ in -lblas" >&5
+echo "configure:11237: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11240 "configure"
+#line 11243 "configure"
@@ -11247,7 +11250,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11286,7 +11289,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11290: checking whether to use LAPACK" >&5
+echo "configure:11293: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11311,7 +11314,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11315: checking for location of LAPACK includes" >&5
+echo "configure:11318: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11331,7 +11334,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11335: checking for location of LAPACK library" >&5
+echo "configure:11338: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11357,15 +11360,15 @@
 do
-echo "configure:11361: checking for $ac_hdr" >&5
+echo "configure:11364: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 11364 "configure"
+#line 11367 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11397,10 +11400,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11401: checking for dsegv_" >&5
+echo "configure:11404: checking for dsegv_" >&5
-#line 11404 "configure"
+#line 11407 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11423,7 +11426,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11450,13 +11453,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11454: checking for desgv_ in -llapack" >&5
+echo "configure:11457: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11460 "configure"
+#line 11463 "configure"
@@ -11467,7 +11470,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11499,13 +11502,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11503: checking for dgesv_ in -llapack" >&5
+echo "configure:11506: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11509 "configure"
+#line 11512 "configure"
@@ -11516,7 +11519,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11535,13 +11538,13 @@
-echo "configure:11539: checking for dgesv_ in -llapack" >&5
+echo "configure:11542: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11545 "configure"
+#line 11548 "configure"
@@ -11552,7 +11555,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11608,7 +11611,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11612: checking whether to use Cairo" >&5
+echo "configure:11615: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11640,7 +11643,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11644: checking for location of cairo includes" >&5
+echo "configure:11647: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11666,15 +11669,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11670: checking for $ac_hdr" >&5
+echo "configure:11673: checking for $ac_hdr" >&5
-#line 11673 "configure"
+#line 11676 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11710,7 +11713,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11714: checking for location of cairo library" >&5
+echo "configure:11717: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11730,7 +11733,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11734: checking for cairo linking flags" >&5
+echo "configure:11737: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11746,10 +11749,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11750: checking for cairo_create" >&5
+echo "configure:11753: checking for cairo_create" >&5
-#line 11753 "configure"
+#line 11756 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11772,7 +11775,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11806,10 +11809,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11810: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11813: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11813 "configure"
+#line 11816 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11832,7 +11835,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11865,10 +11868,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11869: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11872: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11872 "configure"
+#line 11875 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11891,7 +11894,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11933,7 +11936,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11937: checking whether to use FreeType" >&5
+echo "configure:11940: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11952,7 +11955,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11956: checking for location of FreeType includes" >&5
+echo "configure:11959: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11978,15 +11981,15 @@
 do
-echo "configure:11982: checking for $ac_hdr" >&5
+echo "configure:11985: checking for $ac_hdr" >&5
-#line 11985 "configure"
+#line 11988 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11993: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12020,7 +12023,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12024: checking for location of FreeType library" >&5
+echo "configure:12027: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12045,13 +12048,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12049: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12052: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfreetype  $LIBS"
-#line 12055 "configure"
+#line 12058 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -12062,7 +12065,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:12066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -12103,7 +12106,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12107: checking whether to use NLS" >&5
+echo "configure:12110: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -12123,10 +12126,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12127: checking for gettext" >&5
+echo "configure:12130: checking for gettext" >&5
-#line 12130 "configure"
+#line 12133 "configure"
     which can conflict with char gettext(); below.  */
@@ -12149,7 +12152,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -12167,13 +12170,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12171: checking for gettext in -lintl" >&5
+echo "configure:12174: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12177 "configure"
+#line 12180 "configure"
@@ -12184,7 +12187,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12219,7 +12222,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12223: checking whether to use C++" >&5
+echo "configure:12226: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12235,7 +12238,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:12239: checking for $ac_word" >&5
+echo "configure:12242: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12264,7 +12267,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12268: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12271: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12275,12 +12278,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12279 "configure"
+#line 12282 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12306,19 +12309,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12310: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12313: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12315: checking whether we are using GNU C++" >&5
+echo "configure:12318: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12336,7 +12339,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12340: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12343: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12377,7 +12380,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12381: checking whether to use openDWG" >&5
+echo "configure:12384: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12397,7 +12400,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12401: checking for location of openDGW includes" >&5
+echo "configure:12404: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12423,15 +12426,15 @@
 do
-echo "configure:12427: checking for $ac_hdr" >&5
+echo "configure:12430: checking for $ac_hdr" >&5
-#line 12430 "configure"
+#line 12433 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12465,7 +12468,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12469: checking for location of openDWG library" >&5
+echo "configure:12472: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12506,7 +12509,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12510: checking whether to use POSIX threads" >&5
+echo "configure:12513: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12526,7 +12529,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12530: checking for location of POSIX threads includes" >&5
+echo "configure:12533: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12552,15 +12555,15 @@
 do
-echo "configure:12556: checking for $ac_hdr" >&5
+echo "configure:12559: checking for $ac_hdr" >&5
-#line 12559 "configure"
+#line 12562 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12564: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12567: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12594,7 +12597,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12598: checking for location of POSIX threads library" >&5
+echo "configure:12601: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12619,10 +12622,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12623: checking for pthread_create" >&5
+echo "configure:12626: checking for pthread_create" >&5
-#line 12626 "configure"
+#line 12629 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12645,7 +12648,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12672,13 +12675,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12676: checking for pthread_create in -lpthread" >&5
+echo "configure:12679: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 12682 "configure"
+#line 12685 "configure"
@@ -12689,7 +12692,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12739,7 +12742,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12743: checking whether to use OpenMP" >&5
+echo "configure:12746: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12760,7 +12763,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12764: checking for location of OpenMP includes" >&5
+echo "configure:12767: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12786,15 +12789,15 @@
 do
-echo "configure:12790: checking for $ac_hdr" >&5
+echo "configure:12793: checking for $ac_hdr" >&5
-#line 12793 "configure"
+#line 12796 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12832,7 +12835,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12836: checking for location of OpenMP library" >&5
+echo "configure:12839: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12857,10 +12860,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12861: checking for GOMP_parallel_start" >&5
+echo "configure:12864: checking for GOMP_parallel_start" >&5
-#line 12864 "configure"
+#line 12867 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12883,7 +12886,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12910,13 +12913,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12914: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12917: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12920 "configure"
+#line 12923 "configure"
@@ -12927,7 +12930,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13000,7 +13003,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13004: checking whether to use OpenCL" >&5
+echo "configure:13007: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -13020,7 +13023,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13024: checking for location of OpenCL includes" >&5
+echo "configure:13027: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13047,15 +13050,15 @@
 do
-echo "configure:13051: checking for $ac_hdr" >&5
+echo "configure:13054: checking for $ac_hdr" >&5
-#line 13054 "configure"
+#line 13057 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13095,10 +13098,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13099: checking for clGetPlatformInfo" >&5
+echo "configure:13102: checking for clGetPlatformInfo" >&5
-#line 13102 "configure"
+#line 13105 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -13121,7 +13124,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -13160,15 +13163,15 @@
 do
-echo "configure:13164: checking for $ac_hdr" >&5
+echo "configure:13167: checking for $ac_hdr" >&5
-#line 13167 "configure"
+#line 13170 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13172: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13175: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13201,7 +13204,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13205: checking for location of OpenCL library" >&5
+echo "configure:13208: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13225,13 +13228,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13229: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13232: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13235 "configure"
+#line 13238 "configure"
@@ -13242,7 +13245,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13302,7 +13305,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13306: checking for special C compiler options needed for large files" >&5
+echo "configure:13309: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13310,7 +13313,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13314 "configure"
+#line 13317 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13326,7 +13329,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13333: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -13335,7 +13338,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13339 "configure"
+#line 13342 "configure"
@@ -13351,7 +13354,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13358: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13378,11 +13381,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13382: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13385: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13386 "configure"
+#line 13389 "configure"
@@ -13398,14 +13401,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13402: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13405: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 13409 "configure"
+#line 13412 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13423,7 +13426,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13427: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13430: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13449,11 +13452,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13453: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13456: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13457 "configure"
+#line 13460 "configure"
@@ -13469,14 +13472,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13473: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13476: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13480 "configure"
+#line 13483 "configure"
 #define _LARGE_FILES 1
@@ -13494,7 +13497,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13498: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13501: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13520,25 +13523,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13524: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13527: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13528 "configure"
+#line 13531 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13535: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13538: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13542 "configure"
+#line 13545 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13547,7 +13550,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13551: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13554: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13579,25 +13582,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13583: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13586: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13587 "configure"
+#line 13590 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13594: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13597: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13601 "configure"
+#line 13604 "configure"
 #include <stdio.h>
@@ -13606,7 +13609,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13610: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13613: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13636,18 +13639,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13640: checking for fseeko" >&5
+echo "configure:13643: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13644 "configure"
+#line 13647 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13664,10 +13667,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13668: checking if system supports Large Files at all" >&5
+echo "configure:13671: checking if system supports Large Files at all" >&5
-#line 13671 "configure"
+#line 13674 "configure"
 #include <stdio.h>
@@ -13699,7 +13702,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13703: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13706: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13730,7 +13733,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13734: checking whether to use wxWidgets" >&5
+echo "configure:13737: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -13751,7 +13754,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:13755: checking for $ac_word" >&5
+echo "configure:13758: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -13799,7 +13802,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13803: checking wxWidgets version" >&5
+echo "configure:13806: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -13822,15 +13825,15 @@
 do
-echo "configure:13826: checking for $ac_hdr" >&5
+echo "configure:13829: checking for $ac_hdr" >&5
-#line 13829 "configure"
+#line 13832 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13834: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2013-08-29 11:36:43 UTC (rev 57540)
+++ grass/trunk/configure.in	2013-08-29 11:53:55 UTC (rev 57541)
@@ -806,8 +806,10 @@
   LIBLAS=
   ac_save_libs="$LIBS"
   ac_save_cflags="$CFLAGS"
+  ac_save_cppflags="$CPPFLAGS"
   LIBS="$LIBS $LIBLAS_LIBS"
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
+  CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
   AC_TRY_LINK([#include <liblas/capi/liblas.h>],[LASReader_Create("foo");],,[
   AC_TRY_LINK([#include <liblas/capi/liblas.h>],[LASReader_Create("foo");],LAS_LIBS="$LAS_LIBS",[
   AC_MSG_ERROR([*** Unable to locate libLAS library.])
@@ -815,6 +817,7 @@
   LIBS=${ac_save_libs}
   CFLAGS=${ac_save_cflags}
+  CPPFLAGS=${ac_save_cppflags}
   AC_DEFINE(HAVE_LIBLAS)
 fi
