[GRASS-SVN] r57546 - grass/trunk/gui/wxpython/animation
svn_grass at osgeo.org
Thu Aug 29 07:23:59 PDT 2013
Author: annakrat
Date: 2013-08-29 07:23:58 -0700 (Thu, 29 Aug 2013)
New Revision: 57546
grass/trunk/gui/wxpython/animation/dialogs.py
grass/trunk/gui/wxpython/animation/frame.py
grass/trunk/gui/wxpython/animation/temporal_manager.py
wxGUI/animation: various fixes
Modified: grass/trunk/gui/wxpython/animation/dialogs.py
--- grass/trunk/gui/wxpython/animation/dialogs.py 2013-08-29 13:17:16 UTC (rev 57545)
+++ grass/trunk/gui/wxpython/animation/dialogs.py 2013-08-29 14:23:58 UTC (rev 57546)
@@ -174,7 +174,7 @@
choiceWidget.Append(item, cdata)
if self.temporalMode == TemporalMode.TEMPORAL:
- unit = self.timeGranularity.split()[1]
+ unit = self.timeGranularity[1]
try:
index = timeUnits.index(unit)
except ValueError:
@@ -202,7 +202,7 @@
delta = self._timedelta(unit = unit, number = 1)
seconds1 = self._total_seconds(delta)
- number, unit = self.timeGranularity.split()
+ number, unit = self.timeGranularity
number = float(number)
delta = self._timedelta(unit = unit, number = number)
seconds2 = self._total_seconds(delta)
@@ -223,7 +223,7 @@
@@ -240,17 +240,17 @@
self.speedChanged.emit(ms = ms)
def _timedelta(self, unit, number):
- if unit == "years":
+ if unit in "years":
delta = datetime.timedelta(days = 365.25 * number)
- elif unit == "months":
+ elif unit in "months":
delta = datetime.timedelta(days = 30.4375 * number) # 365.25/12
- elif unit == "days":
+ elif unit in "days":
delta = datetime.timedelta(days = 1 * number)
- elif unit == "hours":
+ elif unit in "hours":
delta = datetime.timedelta(hours = 1 * number)
- elif unit == "minutes":
+ elif unit in "minutes":
delta = datetime.timedelta(minutes = 1 * number)
- elif unit == "seconds":
+ elif unit in "seconds":
delta = datetime.timedelta(seconds = 1 * number)
return delta
Modified: grass/trunk/gui/wxpython/animation/frame.py
--- grass/trunk/gui/wxpython/animation/frame.py 2013-08-29 13:17:16 UTC (rev 57545)
+++ grass/trunk/gui/wxpython/animation/frame.py 2013-08-29 14:23:58 UTC (rev 57546)
@@ -462,6 +462,8 @@
self.framesCount = len(timeLabels)
self.slider.SetRange(0, self.framesCount - 1)
self._setLabel()
+ # TODO: fix setting index values, until then:
+ self.indexField.Disable()
def _setLabel(self):
if self.timeLabels:
Modified: grass/trunk/gui/wxpython/animation/temporal_manager.py
--- grass/trunk/gui/wxpython/animation/temporal_manager.py 2013-08-29 13:17:16 UTC (rev 57545)
+++ grass/trunk/gui/wxpython/animation/temporal_manager.py 2013-08-29 14:23:58 UTC (rev 57546)
@@ -48,7 +48,7 @@
self.dataMode = None
self.temporalType = None
- self.granularityMode = GranularityMode.ONE_UNIT
+ self.granularityMode = GranularityMode.ORIGINAL
# Make sure the temporal database exists
tgis.init()
@@ -140,16 +140,17 @@
"""!Returns temporal granularity of currently loaded timeseries."""
if self.dataMode == DataMode.SIMPLE:
gran = self.timeseriesInfo[self.timeseriesList[0]]['granularity']
- if 'unit' in self.timeseriesInfo[self.timeseriesList[0]]: # relative
+ if 'unit' in self.timeseriesInfo[self.timeseriesList[0]]: # relative:
+ granNum = gran
+ unit = self.timeseriesInfo[self.timeseriesList[0]]['unit']
if self.granularityMode == GranularityMode.ONE_UNIT:
- gran = 1
- gran = "%(gran)s %(unit)s" % {'gran': gran,
- 'unit': self.timeseriesInfo[self.timeseriesList[0]]['unit']}
- elif self.granularityMode == GranularityMode.ONE_UNIT: # absolute
- number, unit = gran.split()
- gran = "1 %s" % unit
+ granNum = 1
+ else: # absolute
+ granNum, unit = gran.split()
+ if self.granularityMode == GranularityMode.ONE_UNIT:
+ granNum = 1
- return gran
+ return (int(granNum), unit)
if self.dataMode == DataMode.MULTIPLE:
return self._getCommonGranularity()
@@ -162,17 +163,16 @@
if self.temporalType == TemporalType.ABSOLUTE:
gran = tgis.compute_absolute_time_granularity(allMaps)
- return gran
+ granNum = 1
+ return int(granNum), unit
if self.temporalType == TemporalType.RELATIVE:
- gran = tgis.compute_relative_time_granularity(allMaps)
+ granNum = tgis.compute_relative_time_granularity(allMaps)
- gran = 1
- return gran
+ granNum = 1
+ return (granNum, unit)
def GetLabelsAndMaps(self):
@@ -214,17 +214,19 @@
listOfMaps = []
timeLabels = []
- gran = self.GetGranularity()
- unit = None
- if self.temporalType == TemporalType.ABSOLUTE and \
- self.granularityMode == GranularityMode.ONE_UNIT:
- gran, unit = gran.split()
- gran = '%(one)d %(unit)s' % {'one': 1, 'unit': unit}
+ granNum, unit = self.GetGranularity()
+ if self.temporalType == TemporalType.ABSOLUTE:
+ gran = '%(one)d %(unit)s' % {'one': 1, 'unit': unit}
+ else:
+ gran = '%(num)d %(unit)s' % {'num': granNum, 'unit': unit}
elif self.temporalType == TemporalType.RELATIVE:
unit = self.timeseriesInfo[timeseries]['unit']
gran = 1
+ else:
+ gran = granNum
# start sampling - now it can be used for both interval and point data
# after instance, there can be a gap or an interval
# if it is a gap we remove it and put there the previous instance instead
@@ -244,15 +246,15 @@
series = map.get_id()
start, end = map.get_temporal_extent_as_tuple()
- if end:
- end = str(end)
- if end is None:
+ if self.timeseriesInfo[timeseries]['map_time'] == 'point':
# point data
listOfMaps.append(series)
afterPoint = True
followsPoint = True
lastTimeseries = series
+ end = None
else:
+ end = str(end)
# interval data
if series:
# map exists, stop point mode
@@ -272,7 +274,6 @@
else:
# append series which is None
timeLabels.append((str(start), end, unit))
@@ -329,11 +330,11 @@
from pprint import pprint
temp = TemporalManager()
+# timeseries = createAbsolutePoint()
+# timeseries = createRelativePoint()
+# timeseries1, timeseries2 = createAbsoluteInterval()
+ timeseries1, timeseries2 = createRelativeInterval()
- timeseries1 = 'precip_abs0'
- timeseries2 = 'precip_abs2'
- createAbsoluteInterval(timeseries1, timeseries2)
temp.AddTimeSeries(timeseries1, 'strds')
temp.AddTimeSeries(timeseries2, 'strds')
@@ -351,7 +352,7 @@
-def createAbsoluteInterval(name1, name2):
+def createAbsoluteInterval():
grass.run_command('g.region', s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10, flags = 'p3', quiet = True)
grass.mapcalc(exp="prec_1 = rand(0, 550)", overwrite = True)
@@ -391,6 +392,8 @@
"temp_6|2002-05-01|2002-07-01\n"
fd.close()
+ name1 = 'absinterval1'
+ name2 = 'absinterval2'
grass.run_command('t.unregister', type = 'rast',
maps='prec_1,prec_2,prec_3,prec_4,prec_5,prec_6,temp_1,temp_2,temp_3,temp_4,temp_5,temp_6')
for name, fname in zip((name1, name2), (n1, n2)):
@@ -399,7 +402,9 @@
title="A test with input files", descr="A test with input files")
grass.run_command('t.register', flags = 'i', input=name, file=fname, overwrite = True)
-def createRelativeInterval(name1, name2):
+ return name1, name2
+def createRelativeInterval():
@@ -439,6 +444,8 @@
"temp_6|14|17\n"
fd.close()
+ name1 = 'relinterval1'
+ name2 = 'relinterval2'
@@ -446,8 +453,9 @@
temporaltype='relative', output=name,
grass.run_command('t.register', flags = 'i', input = name, file = fname, unit = "years", overwrite = True)
-def createAbsolutePoint(name):
+def createAbsolutePoint():
@@ -468,12 +476,43 @@
"prec_6|2001-09-01\n"
fd.close()
+ name = 'abspoint'
grass.run_command('t.create', overwrite = True, type='strds',
temporaltype='absolute', output=name,
grass.run_command('t.register', flags = 'i', input=name, file=n1, overwrite = True)
+ return name
+def createRelativePoint():
+ grass.run_command('g.region', s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10, flags = 'p3', quiet = True)
+ grass.mapcalc(exp="prec_1 = rand(0, 550)", overwrite = True)
+ grass.mapcalc(exp="prec_2 = rand(0, 450)", overwrite = True)
+ grass.mapcalc(exp="prec_3 = rand(0, 320)", overwrite = True)
+ grass.mapcalc(exp="prec_4 = rand(0, 510)", overwrite = True)
+ grass.mapcalc(exp="prec_5 = rand(0, 300)", overwrite = True)
+ grass.mapcalc(exp="prec_6 = rand(0, 650)", overwrite = True)
+ n1 = grass.read_command("g.tempfile", pid = 1, flags = 'd').strip()
+ fd = open(n1, 'w')
+ fd.write(
+ "prec_1|1\n"
+ "prec_2|3\n"
+ "prec_3|5\n"
+ "prec_4|7\n"
+ "prec_5|11\n"
+ "prec_6|13\n"
+ fd.close()
+ name = 'relpoint'
+ grass.run_command('t.create', overwrite = True, type='strds',
+ temporaltype='relative', output=name,
+ title="A test with input files", descr="A test with input files")
+ grass.run_command('t.register', unit="day", input=name, file=n1, overwrite = True)
+ return name
if __name__ == '__main__':
test()
