[GRASS-SVN] r57549 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Thu Aug 29 14:35:03 PDT 2013
Author: wenzeslaus
Date: 2013-08-29 14:35:03 -0700 (Thu, 29 Aug 2013)
New Revision: 57549
grass/trunk/gui/wxpython/gis_set.py
wxGUI/startup: replacing dialog which was showed during initialization by a message in the main window (smoother gui start, less annoying dialogs)
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py 2013-08-29 14:57:56 UTC (rev 57548)
+++ grass/trunk/gui/wxpython/gis_set.py 2013-08-29 21:35:03 UTC (rev 57549)
@@ -112,6 +112,17 @@
style = wx.ALIGN_CENTRE)
self.ldbase = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
label = _("GIS Data Directory:"))
+ # no message at the beginning
+ self.lmessage = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ label=_(""))
+ # It is not clear if all wx versions supports color, so try-except.
+ # The color itself may not be correct for all platforms/system settings
+ # but in http://xoomer.virgilio.it/infinity77/wxPython/Widgets/wx.SystemSettings.html
+ # there is no 'warning' color.
+ try:
+ self.lmessage.SetForegroundColour(wx.Colour(255, 0, 0))
+ except AttributeError:
+ pass
self.llocation = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
label = _("Project location\n(projection/coordinate system)"),
@@ -356,6 +367,11 @@
flag = wx.ALIGN_CENTER_HORIZONTAL |
wx.RIGHT | wx.LEFT | wx.EXPAND,
border = 20) # GISDBASE setting
+ # warning/error message
+ sizer.Add(item=self.lmessage,
+ proportion=0,
+ flag=wx.ALIGN_CENTER_VERTICAL |
+ wx.ALIGN_LEFT| wx.LEFT | wx.RIGHT | wx.BOTTOM, border=8)
sizer.Add(item = location_sizer, proportion = 1,
flag = wx.RIGHT | wx.LEFT | wx.EXPAND,
border = 1)
@@ -394,6 +410,28 @@
return grassrc
+ def _showWarning(self, text):
+ """Displays a warning message to the user.
+ There is no cleaning procedure. You should call _hideMessage when
+ you know that there is everything correct now.
+ self.lmessage.SetLabel(_("Warning: ") + text)
+ def _showError(self, text):
+ """Displays a error message to the user.
+ self.lmessage.SetLabel(_("Error: ") + text)
+ def _hideMessage(self):
+ """Clears/hides the error message."""
+ # we do no hide widget
+ # because we do not want the dialog to change the size
+ self.lmessage.SetLabel("")
def GetRCValue(self, value):
"""!Return GRASS variable (read from GISRC)
@@ -663,12 +701,13 @@
self.lblocations.InsertItems(self.listOfLocations, 0)
if len(self.listOfLocations) > 0:
+ self._hideMessage()
self.lblocations.SetSelection(0)
else:
self.lblocations.SetSelection(wx.NOT_FOUND)
- GWarning(_("No GRASS location found in '%s'.") % self.gisdbase,
- parent = self)
+ self._showWarning(_("No GRASS location found in '%s'.")
+ % self.gisdbase)
return self.listOfLocations
def UpdateMapsets(self, location):
@@ -771,9 +810,9 @@
def OnSetDatabase(self, event):
"""!Database set"""
gisdbase = self.tgisdbase.GetValue()
if not os.path.exists(gisdbase):
- GError(_("Path '%s' doesn't exist.") % gisdbase,
- parent = self)
+ self._showError(_("Path '%s' doesn't exist.") % gisdbase)
return
self.gisdbase = self.tgisdbase.GetValue()
