[GRASS-SVN] r57564 - grass/branches/releasebranch_6_4/scripts/db.dropcol
Sat Aug 31 23:06:14 PDT 2013
Author: hamish
Date: 2013-08-31 23:06:14 -0700 (Sat, 31 Aug 2013)
New Revision: 57564
   grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol
remove some unused code, minor robustness tweaks (merge r55200 from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol
--- grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol	2013-09-01 06:03:05 UTC (rev 57563)
+++ grass/branches/releasebranch_6_4/scripts/db.dropcol/db.dropcol	2013-09-01 06:06:14 UTC (rev 57564)
@@ -53,14 +53,7 @@
   exec g.parser "$0" "$@"
 fi
-PROG=`basename "$0"`
-#### check if we have awk
-if [ ! -x "`which awk`" ] ; then
-    g.message -e "awk required, please install awk or gawk first"
-    exit 1
-fi
 # setting environment, so that awk works properly in all languages
 unset LC_ALL
 LC_NUMERIC=C
@@ -89,9 +82,6 @@
 trap "exitprocedure" 2 3 15
 ### setup enviro vars ###
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
 table="$GIS_OPT_TABLE"
 # check if DB parameters are set, and if not set them.
@@ -102,8 +92,8 @@
 # schema needed for PG?
 col="$GIS_OPT_COLUMN"
-force=$GIS_FLAG_F
-if [ $force -eq 1 ] ; then
+force="$GIS_FLAG_F"
+if [ "$force" -eq 1 ] ; then
    g.message "Forcing ..."
 fi
@@ -115,14 +105,15 @@
    #exit 1
 fi
-db.describe -c $GIS_OPT_TABLE | grep '^Column ' | cut -d':' -f2 | grep "^ ${col}" 2>&1 >/dev/null
+db.describe -c "$GIS_OPT_TABLE" | grep '^Column ' | \
+   cut -d':' -f2 | grep "^ ${col}" 2>&1 >/dev/null
 if [ $? -ne 0 ] ; then
 	g.message -e "Column <$col> not found in table"
 	cleanup
 	exit 1
 fi
-if [ $force -eq 0 ] ; then
+if [ "$force" -eq 0 ] ; then
     g.message "The <$col> column would be deleted."
     g.message message=""
     g.message "You must use the force flag to actually remove it. Exiting."
@@ -138,7 +129,8 @@
 	cat "$TEMPFILE.coldesc" | cut -d':' -f1 > "$TEMPFILE.colnames"
 	COLDEF=`paste -d' ' "$TEMPFILE.colnames" "$TEMPFILE.coltypes" | tr '\n' ',' | sed 's+,$++g'`
 	COLNAMES=`cat "$TEMPFILE.colnames" | tr '\n' ',' | sed 's+,$++g'`
-echo "BEGIN TRANSACTION;
+	echo "BEGIN TRANSACTION;
 CREATE TEMPORARY TABLE ${table}_backup(${COLDEF});
 INSERT INTO ${table}_backup SELECT ${COLNAMES} FROM ${table};
 DROP TABLE ${table};
@@ -146,15 +138,17 @@
 INSERT INTO ${table} SELECT ${COLNAMES} FROM ${table}_backup;
 DROP TABLE ${table}_backup;
 COMMIT;" > "$TEMPFILE"
 	db.execute input="$TEMPFILE"
-	if [ $? -eq 1 ] ; then
+	if [ $? -ne 0 ] ; then
 	    	g.message -e "Cannot continue (problem deleting column)."
 	    	cleanup
 	    	exit 1
 	fi
 else
-	echo "ALTER TABLE $table DROP COLUMN $col" | db.execute database="${database}" driver=${driver}
+	echo "ALTER TABLE $table DROP COLUMN $col" | \
+	   db.execute database="$database" driver="$driver"
 	    	cleanup
 	    	exit 1
@@ -165,4 +159,3 @@
 cleanup
 exit 0
