[GRASS-SVN] r58345 - in grass/trunk/gui/wxpython: animation core dbmgr gui_core lmgr vdigit
Sun Dec 1 11:48:33 PST 2013
Author: annakrat
Date: 2013-12-01 11:48:33 -0800 (Sun, 01 Dec 2013)
New Revision: 58345
   grass/trunk/gui/wxpython/animation/provider.py
   grass/trunk/gui/wxpython/core/layerlist.py
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/core/workspace.py
   grass/trunk/gui/wxpython/dbmgr/base.py
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/simplelmgr.py
   grass/trunk/gui/wxpython/lmgr/layertree.py
   grass/trunk/gui/wxpython/vdigit/toolbars.py
wxGUI: unify opacity values to range <0; 1>
Modified: grass/trunk/gui/wxpython/animation/provider.py
--- grass/trunk/gui/wxpython/animation/provider.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/animation/provider.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -519,7 +519,7 @@
         _setEnvironment(self.imageWidth, self.imageHeight, filename,
                         transparent=False, bgcolor=bgcolor)
-        opacities = [str(op / 100.) for op in opacities]
+        opacities = [str(op) for op in opacities]
         bgcolor = ':'.join([str(part) for part in bgcolor])
         returncode, messages = RunCommand('g.pnmcomp',
                                           getErrorMsg=True,
Modified: grass/trunk/gui/wxpython/core/layerlist.py
--- grass/trunk/gui/wxpython/core/layerlist.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/core/layerlist.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -70,7 +70,7 @@
         return layers
     def AddNewLayer(self, name, mapType, cmd, active=True, hidden=False,
-                    opacity=100, label=None, pos=0):
+                    opacity=1, label=None, pos=0):
         """!Creates new layer and adds it to the list (insert to the first position).
         @param ltype layer type (raster, vector, 3d-raster, ...)
@@ -255,18 +255,18 @@
     def GetOpacity(self):
         """!Returns opacity value.
-        @return opacity as integer between 0 and 100
+        @return opacity as float between 0 and 1
-        return int(self._opacity * 100)
+        return self._opacity
     def SetOpacity(self, opacity):
         """!Sets opacity of the layer.
-        @param opacity integer between 0 and 100
+        @param opacity float between 0 and 1
-        if not (0 <= opacity <= 100) or opacity != int(opacity):
-            raise ValueError("Opacity must be an integer between 0 and 100, not {op}.".format(op=opacity))
-        self._opacity = opacity / 100.
+        if not (0 <= opacity <= 1):
+            raise ValueError("Opacity value must be between 0 and 1, not {op}.".format(op=opacity))
+        self._opacity = opacity
     opacity = property(fget=GetOpacity, fset=SetOpacity)
@@ -324,7 +324,7 @@
     def ChangeLayerOpacity(self, index, layer):
         """!Changes layer opacity in renderer."""
         rLayer = self._getRendererLayer(index)
-        self._renderer.ChangeLayer(rLayer, opacity=layer.opacity / 100.)
+        self._renderer.ChangeLayer(rLayer, opacity=layer.opacity)
     def ChangeLayerCmd(self, index, layer):
         """!Changes layer cmd in renderer."""
@@ -363,7 +363,7 @@
             mapType = '3d-raster'
         self._renderer.AddLayer(ltype=mapType, command=layer.cmd,
                                 name=layer.name, active=layer.active,
-                                hidden=False, opacity=layer.opacity / 100.,
+                                hidden=False, opacity=layer.opacity,
                                 render=True, pos=-1)
     def RemoveLayer(self, index):
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/core/render.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -218,18 +218,13 @@
             return 'cell'
         return self.type
-    def GetOpacity(self, float = False):
+    def GetOpacity(self):
         Get layer opacity level
-        @param float get opacity level in <0,1> otherwise <0,100>
-        @return opacity level
+        @return opacity level (<0, 1>)
-        if float:
-            return self.opacity
-        return int (self.opacity * 100)
+        return self.opacity
     def GetName(self, fullyQualified = True):
         """!Get map layer name
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/core/workspace.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -697,7 +697,7 @@
             else:
                 cmd = mapTree.GetLayerInfo(item, key = 'maplayer').GetCmd(string = False)
                 name = mapTree.GetItemText(item).replace(os.linesep, '\\n')
-                opacity = maplayer.GetOpacity(float = True)
+                opacity = maplayer.GetOpacity()
                 # remove 'opacity' part
                 if opacity < 1:
                     name = name.split('(', -1)[0].strip()
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/dbmgr/base.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -1584,7 +1584,7 @@
             if self.parent and self.mapdisplay.tree and \
                     self.dbMgrData['treeItem']:
                 maptree = self.mapdisplay.tree
-                opacity = maptree.GetLayerInfo(self.dbMgrData['treeItem'], key = 'maplayer').GetOpacity(float = True)
+                opacity = maptree.GetLayerInfo(self.dbMgrData['treeItem'], key = 'maplayer').GetOpacity()
                 self.qlayer.SetOpacity(opacity)
             if zoom:
                 keyColumn = self.dbMgrData['mapDBInfo'].layers[self.selLayer]['key']
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -2139,10 +2139,12 @@
         return data
 class SetOpacityDialog(wx.Dialog):
-    """!Set opacity of map layers"""
+    """!Set opacity of map layers.
+    Dialog expects opacity between 0 and 1 and returns this range, too.
     def __init__(self, parent, id = wx.ID_ANY, title = _("Set Map Layer Opacity"),
                  size = wx.DefaultSize, pos = wx.DefaultPosition,
-                 style = wx.DEFAULT_DIALOG_STYLE, opacity = 100):
+                 style = wx.DEFAULT_DIALOG_STYLE, opacity = 1):
         self.parent = parent    # GMFrame
         self.opacity = opacity  # current opacity
@@ -2156,7 +2158,7 @@
         sizer = wx.BoxSizer(wx.VERTICAL)
         box = wx.GridBagSizer(vgap = 5, hgap = 5)
-        self.value = wx.Slider(panel, id = wx.ID_ANY, value = self.opacity,
+        self.value = wx.Slider(panel, id = wx.ID_ANY, value = int(self.opacity * 100),
                                style = wx.SL_HORIZONTAL | wx.SL_AUTOTICKS | \
                                    wx.SL_TOP | wx.SL_LABELS,
                                minValue = 0, maxValue = 100,
Modified: grass/trunk/gui/wxpython/gui_core/simplelmgr.py
--- grass/trunk/gui/wxpython/gui_core/simplelmgr.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/gui_core/simplelmgr.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -247,8 +247,7 @@
     def _setLayerOpacity(self, layer, value):
         """!Sets layer's opacity.'"""
-        # * 100 to be compatible, should be changes everywhere to 0-100 range
-        layer.opacity = int(value * 100)
+        layer.opacity = value
         self._update()
         self.opacityChanged.emit(index=self._layerList.GetLayerIndex(layer), layer=layer)
         self.anyChange.emit()
@@ -259,9 +258,9 @@
         active = []
         selected = []
         for layer in self._layerList:
-            if layer.opacity < 100:
+            if layer.opacity < 1:
                 items.append("{name} (opacity {opacity}%)".format(name=layer.name,
-        opacity=layer.opacity))
+        opacity=int(layer.opacity * 100)))
             else:
                 items.append(layer.name)
             active.append(layer.IsActive())
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -1614,7 +1614,7 @@
         if not lname:
             lname  = self.GetLayerInfo(item, key = 'label')
-        opacity  = int(mapLayer.GetOpacity(float = True) * 100)
+        opacity  = int(mapLayer.GetOpacity() * 100)
         if not lname:
             dcmd    = self.GetLayerInfo(item, key = 'cmd')
             lname, found = GetLayerNameFromCmd(dcmd, layerType = mapLayer.GetType(),
@@ -1739,7 +1739,7 @@
         elif type != 'group':
             if self.GetPyData(item) is not None:
                 cmdlist = self.GetLayerInfo(item, key = 'cmd')
-                opac = self.GetLayerInfo(item, key = 'maplayer').GetOpacity(float = True)
+                opac = self.GetLayerInfo(item, key = 'maplayer').GetOpacity()
                 chk = self.IsItemChecked(item)
                 hidden = not self.IsVisible(item)
                 # determine layer name
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py	2013-12-01 03:49:36 UTC (rev 58344)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py	2013-12-01 19:48:33 UTC (rev 58345)
@@ -857,7 +857,7 @@
             self.MapWindow.UpdateMap(render = True)
         # respect opacity
-        opacity = mapLayer.GetOpacity(float = True)
+        opacity = mapLayer.GetOpacity()
         if opacity < 1.0:
             alpha = int(opacity * 255)
