[GRASS-SVN] r58347 - grass-addons/grass7/raster/r.lake.series
svn_grass at osgeo.org
Sun Dec 1 18:59:21 PST 2013
Author: wenzeslaus
Date: 2013-12-01 18:59:21 -0800 (Sun, 01 Dec 2013)
New Revision: 58347
grass-addons/grass7/raster/r.lake.series/r.lake.series.py
r.lake.series: checking the r.lake return code and failing if failed; changes in temporal registration because of r58209
Modified: grass-addons/grass7/raster/r.lake.series/r.lake.series.py
--- grass-addons/grass7/raster/r.lake.series/r.lake.series.py 2013-12-01 23:34:46 UTC (rev 58346)
+++ grass-addons/grass7/raster/r.lake.series/r.lake.series.py 2013-12-02 02:59:21 UTC (rev 58347)
@@ -68,7 +68,7 @@
#%end
#%option
#% key: time_step
-#% type: double
+#% type: integer
#% label: Time increment
#% description: Time increment between two states (maps) used to register output maps in space-time raster dataset. Used together with time_units parameter.
#% required: no
@@ -142,6 +142,11 @@
gcore.fatal(_("Raster map <%s> already exists. Change the base name or allow overwrite.") % map_)
+def remove_raster_maps(maps, quiet=False):
+ for map_ in maps:
+ gcore.run_command('g.remove', rast=map_, quiet=quiet)
def main():
options, flags = gcore.parser()
@@ -161,7 +166,7 @@
" together, please specify only one of them."))
time_unit = options['time_unit']
- time_step = options['time_step']
+ time_step = options['time_step'] # temporal fucntions accepts only string now
if time_step <= 0:
gcore.fatal(_("Time step must be greater than zero."
" Please specify number > 0."))
@@ -188,12 +193,16 @@
flags += 'n'
for i, water_level in enumerate(water_levels):
- print outputs[i]
- gcore.run_command('r.lake', elevation=elevation, lake=outputs[i],
- wl=water_level,
- overwrite=gcore.overwrite(), # TODO: really works? Its seems that hardcoding here False does not prevent overwriting.
- **kwargs)
+ return_code = gcore.run_command('r.lake', elevation=elevation,
+ lake=outputs[i],
+ wl=water_level,
+ overwrite=gcore.overwrite(), # TODO: really works? Its seems that hardcoding here False does not prevent overwriting.
+ **kwargs)
+ if return_code:
+ # remove maps created so far, try to remove also i-th map
+ remove_raster_maps(outputs[:i], quiet=True)
+ gcore.fatal(_("r.lake command failed. Check above error messages."
+ " Try different water levels or seed points."))
gcore.info(_("Registering created maps into temporal dataset..."))
# Make sure the temporal database exists
@@ -204,9 +213,12 @@
title=title, descr=desctiption,
semantic='sum', dbif=None,
overwrite=gcore.overwrite())
- # we must start from 1 because there is a bug in register_maps_in_space_time_dataset
+ # TODO: we must start from 1 because there is a bug in register_maps_in_space_time_dataset
tgis.register_maps_in_space_time_dataset(
- type='rast', name=basename, maps=','.join(outputs), start=1, end=None,
- unit=time_unit, increment=time_step, dbif=None, interval=False)
+ type='rast', name=basename, maps=','.join(outputs),
+ start=str(1), end=None, unit=time_unit, increment=time_step,
+ interval=False, dbif=None)
if __name__ == '__main__':
sys.exit(main())
