[GRASS-SVN] r58349 - in sandbox/martinl: . v.merge
svn_grass at osgeo.org
Sun Dec 1 21:30:28 PST 2013
Author: martinl
Date: 2013-12-01 21:30:28 -0800 (Sun, 01 Dec 2013)
New Revision: 58349
Added:
sandbox/martinl/v.merge/
sandbox/martinl/v.merge/Makefile
sandbox/martinl/v.merge/local_proto.h
sandbox/martinl/v.merge/main.c
sandbox/martinl/v.merge/merge.c
sandbox/martinl/v.merge/v.merge.html
v.merge (sandbox) - experiments
Added: sandbox/martinl/v.merge/Makefile
--- sandbox/martinl/v.merge/Makefile (rev 0)
+++ sandbox/martinl/v.merge/Makefile 2013-12-02 05:30:28 UTC (rev 58349)
@@ -0,0 +1,12 @@
+MODULE_TOPDIR = ../..
+PGM = v.merge
+LIBES = $(VECTORLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: sandbox/martinl/v.merge/local_proto.h
--- sandbox/martinl/v.merge/local_proto.h (rev 0)
+++ sandbox/martinl/v.merge/local_proto.h 2013-12-02 05:30:28 UTC (rev 58349)
@@ -0,0 +1,2 @@
+int merge_map_lines(struct Map_info *, double,
+ struct Map_info *);
Added: sandbox/martinl/v.merge/main.c
--- sandbox/martinl/v.merge/main.c (rev 0)
+++ sandbox/martinl/v.merge/main.c 2013-12-02 05:30:28 UTC (rev 58349)
@@ -0,0 +1,93 @@
+ * MODULE: v.merge
+ * PURPOSE: Merge two vector maps
+ * AUTHOR(S): Martin Landa <landa.martin gmail.com>
+ * COPYRIGHT: (C) 2013 by the GRASS Development Team
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that comes
+ * with GRASS for details.
+ * TODO: add 'layer' options
+ * handle feature types (currently assuming boundaries or lines)
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+#include "local_proto.h"
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct {
+ struct Option *refer_map, *patch_map, *thresh, *output_map;
+ } opt;
+ struct Map_info Refer, Patch, Out;
+ double thresh;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("vector"));
+ G_add_keyword(_("geometry"));
+ G_add_keyword(_("editing"));
+ module->description = _("Merges two vector maps.");
+ opt.refer_map = G_define_standard_option(G_OPT_V_MAP);
+ opt.refer_map->key = "reference_map";
+ opt.refer_map->label = _("Name of reference vector map to be edited");
+ opt.patch_map = G_define_standard_option(G_OPT_V_MAP);
+ opt.patch_map->key = "patch_map";
+ opt.patch_map->label = _("Name of vector map to be patched");
+ opt.thresh = G_define_option();
+ opt.thresh->key = "thresh";
+ opt.thresh->type = TYPE_DOUBLE;
+ opt.thresh->required = YES;
+ opt.thresh->description = _("Threshold in map units");
+ opt.output_map = G_define_standard_option(G_OPT_V_OUTPUT);
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ thresh = atof(opt.thresh->answer);
+ Vect_check_input_output_name(opt.refer_map->answer, opt.output_map->answer,
+ G_FATAL_EXIT);
+ Vect_check_input_output_name(opt.patch_map->answer, opt.output_map->answer,
+ G_FATAL_EXIT);
+ /* open input maps */
+ Vect_open_old(&Refer, opt.refer_map->answer, "");
+ Vect_open_old(&Patch, opt.patch_map->answer, "");
+ /* open output map */
+ Vect_open_new(&Out, opt.output_map->answer, Vect_is_3d(&Refer));
+ /* copy features from reference map to output map */
+ Vect_copy_map_lines(&Refer, &Out);
+ Vect_close(&Refer);
+ Vect_build(&Out);
+ /* read and patch features from patch map */
+ merge_map_lines(&Patch, thresh, &Out);
+ Vect_close(&Patch);
+ Vect_build(&Out);
+ Vect_close(&Out);
+ exit(EXIT_SUCCESS);
Added: sandbox/martinl/v.merge/merge.c
--- sandbox/martinl/v.merge/merge.c (rev 0)
+++ sandbox/martinl/v.merge/merge.c 2013-12-02 05:30:28 UTC (rev 58349)
@@ -0,0 +1,100 @@
+int merge_map_lines(struct Map_info *Patch, double thresh,
+ struct Map_info *Out)
+ int i, j, iline, type, with_z, nearest_line, last_line;
+ int iseg, pseg, nseg; /* current/previous/next segment */
+ int last_modified, last_type;
+ double dist;
+ struct line_pnts *Points, *Points_ref;
+ struct line_cats *Cats_ref;
+ Points = Vect_new_line_struct();
+ Points_ref = Vect_new_line_struct();
+ Cats_ref = Vect_new_cats_struct();
+ with_z = Vect_is_3d(Out) && Vect_is_3d(Patch);
+ /* read features from patch map */
+ Vect_rewind(Patch);
+ iline = 1;
+ while(TRUE) {
+ last_line = -1;
+ last_modified = FALSE;
+ type = Vect_read_next_line(Patch, Points, NULL);
+ if (type == -2)
+ break;
+ /* read line verteces */
+ for (i = 0; i < Points->n_points; i++) {
+ /* find nearest features from reference map */
+ nearest_line = Vect_find_line(Out, Points->x[i], Points->y[i], Points->z[i],
+ GV_LINES, thresh, with_z, -1);
+ G_debug(0, "line: %d, vertex: %d -> nearest: %d", iline, i, nearest_line);
+ if (nearest_line > 0) {
+ if (nearest_line != last_line) {
+ if (last_modified) {
+ Vect_rewrite_line(Out, last_line, last_type, Points_ref, Cats_ref);
+ last_type = Vect_read_line(Out, Points_ref, Cats_ref, nearest_line);
+ last_line = nearest_line;
+ Vect_line_distance(Points_ref, Points->x[i], Points->y[i], Points->z[i],
+ with_z, NULL, NULL, NULL, &dist, NULL, NULL);
+ G_debug(0, "\t-> dist: %f", dist);
+ else {
+ if (last_line != -1) {
+ /* modify cached line, insert new point */
+ iseg = Vect_line_distance(Points_ref, Points->x[i], Points->y[i], Points->z[i],
+ G_debug(0, "\t-> dist: %f, iseg: %d", dist, iseg);
+ pseg = nseg = 0;
+ if (i > 0) {
+ /* find previous vertex */
+ pseg = Vect_line_distance(Points_ref, Points->x[i-1], Points->y[i-1],
+ Points->z[i-1],
+ G_debug(0, "\t(previous) -> dist: %f, pseg: %d", dist, pseg);
+ if (i < Points->n_points-1) {
+ /* find last vertex */
+ nseg = Vect_line_distance(Points_ref, Points->x[i+1], Points->y[i+1],
+ Points->z[i+1],
+ G_debug(0, "\t(next) -> dist: %f, nseg: %d", dist, nseg);
+ for (j = 1; j < nseg-pseg; j++) {
+ G_debug(0, "%d", pseg);
+ Vect_line_delete_point(Points_ref, pseg+1);
+ Vect_line_insert_point(Points_ref, pseg > 0 ? pseg+1 : iseg,
+ Points->x[i], Points->y[i], Points->z[i]);
+ last_modified = TRUE;
+ iline++;
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_line_struct(Points_ref);
+ Vect_destroy_cats_struct(Cats_ref);
+ return 0;
Added: sandbox/martinl/v.merge/v.merge.html
--- sandbox/martinl/v.merge/v.merge.html (rev 0)
+++ sandbox/martinl/v.merge/v.merge.html 2013-12-02 05:30:28 UTC (rev 58349)
@@ -0,0 +1 @@
+TODO
