[GRASS-SVN] r58354 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Dec 2 09:57:32 PST 2013
Author: martinl
Date: 2013-12-02 09:57:31 -0800 (Mon, 02 Dec 2013)
New Revision: 58354
grass/trunk/lib/vector/Vlib/close.c
vlib: cosmetics when closing spatial index file
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2013-12-02 17:11:26 UTC (rev 58353)
+++ grass/trunk/lib/vector/Vlib/close.c 2013-12-02 17:57:31 UTC (rev 58354)
@@ -198,17 +198,19 @@
else if (Map->format == GV_FORMAT_POSTGIS)
V2_close_pg(Map);
- /* spatial index must also be closed when opened with topo but
- * not modified */
- /* NOTE: also close sidx for GV_FORMAT_OGR if not direct OGR access */
- if (Map->format != GV_FORMAT_OGR_DIRECT &&
- Map->plus.Spidx_built == TRUE &&
+ /* spatial index must also be closed when opened with topo but not
+ * modified */
+ if (Map->plus.spidx_fp.file &&
+ Map->plus.Spidx_built == TRUE &&
!Map->support_updated &&
- Map->plus.built == GV_BUILD_ALL &&
- create_link) {
+ Map->plus.built == GV_BUILD_ALL) {
+ G_debug(1, "spatial index file closed");
fclose(Map->plus.spidx_fp.file);
+ /* release memory if required */
if (Map->level > 1 && Map->plus.release_support) {
G_debug(1, "free topology, spatial index, and category index");
dig_free_plus(&(Map->plus));
