[GRASS-SVN] r58357 - grass/trunk/display/d.vect
Mon Dec 2 10:47:57 PST 2013
Author: martinl
Date: 2013-12-02 10:47:56 -0800 (Mon, 02 Dec 2013)
New Revision: 58357
   grass/trunk/display/d.vect/main.c
   grass/trunk/display/d.vect/opt.c
   grass/trunk/display/d.vect/plot.h
d.vect: remove `display=attr` attributes are display when `attrcol` is given
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2013-12-02 18:44:00 UTC (rev 58356)
+++ grass/trunk/display/d.vect/main.c	2013-12-02 18:47:56 UTC (rev 58357)
@@ -86,17 +86,16 @@
     display_opt->required = YES;
     display_opt->multiple = YES;
     display_opt->answer = "shape";
-    display_opt->options = "shape,cat,topo,vert,dir,attr,zcoor";
+    display_opt->options = "shape,cat,topo,vert,dir,zcoor";
     display_opt->description = _("Display");
     desc = NULL;
     G_asprintf(&desc,
-	       "shape;%s;cat;%s;topo;%s;vert;%s;dir;%s;attr;%s;zcoor;%s",
+	       "shape;%s;cat;%s;topo;%s;vert;%s;dir;%s;zcoor;%s",
 	       _("Display geometry of features"),
 	       _("Display category numbers of features"),
 	       _("Display topology information (nodes, edges)"),
                _("Display verteces of features"),
 	       _("Display direction of linear features"),
-	       _("Display selected attribute based on 'attrcolumn'"),
 	       _("Display z-coordinate of features (only for 3D vector maps)"));
     display_opt->descriptions = desc;
@@ -469,7 +468,7 @@
 	if (display & DISP_CAT)
 	    stat += display_label(&Map, type, Clist, &lattr, chcat);
-	if (display & DISP_ATTR)
+	if (attrcol_opt->answer)
 	    stat += display_attr(&Map, type, attrcol_opt->answer, Clist, &lattr, chcat);
 	if (display & DISP_ZCOOR)
Modified: grass/trunk/display/d.vect/opt.c
--- grass/trunk/display/d.vect/opt.c	2013-12-02 18:44:00 UTC (rev 58356)
+++ grass/trunk/display/d.vect/opt.c	2013-12-02 18:47:56 UTC (rev 58357)
@@ -28,9 +28,6 @@
 	case 'd':
 	    display |= DISP_DIR;
 	    break;
-	case 'a':
-	    display |= DISP_ATTR;
-	    break;
 	case 'z':
 	    display |= DISP_ZCOOR;
 	    break;
Modified: grass/trunk/display/d.vect/plot.h
--- grass/trunk/display/d.vect/plot.h	2013-12-02 18:44:00 UTC (rev 58356)
+++ grass/trunk/display/d.vect/plot.h	2013-12-02 18:47:56 UTC (rev 58357)
@@ -36,8 +36,7 @@
 #define DISP_TOPO  0x04
 #define DISP_VERT  0x08
 #define DISP_DIR   0x10
-#define DISP_ATTR  0x20
-#define DISP_ZCOOR 0x40
+#define DISP_ZCOOR 0x20
 #define RENDER_DP	2
 #define RENDER_DPC	3
