[GRASS-SVN] r58379 - grass/branches/develbranch_6/scripts/r.out.xyz
svn_grass at osgeo.org
Tue Dec 3 13:28:16 PST 2013
Author: neteler
Date: 2013-12-03 13:28:16 -0800 (Tue, 03 Dec 2013)
New Revision: 58379
grass/branches/develbranch_6/scripts/r.out.xyz/description.html
grass/branches/develbranch_6/scripts/r.out.xyz/r.out.xyz
r.out.xyz: added support for multiple file export, example added (with support of Vincent Bain)
Modified: grass/branches/develbranch_6/scripts/r.out.xyz/description.html
--- grass/branches/develbranch_6/scripts/r.out.xyz/description.html 2013-12-03 21:26:15 UTC (rev 58378)
+++ grass/branches/develbranch_6/scripts/r.out.xyz/description.html 2013-12-03 21:28:16 UTC (rev 58379)
@@ -15,9 +15,12 @@
The <em>r.out.ascii</em> module should be used to export an array (of
size row x column) containing z values.
<p>
+<em>r.out.xyz</em> can combine several input raster maps, which can be
+convenient when it comes to e.g. produce ASCII point cloud files.
+<p>
<em>r.out.xyz</em> is simply a front-end to "<tt>r.stats -1gn</tt>".
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
In this example, a LiDAR elevation map in the
North Carolina sample dataset location is exported to CSV format.
@@ -27,6 +30,25 @@
r.out.xyz input=elev_lid792_1m output=elev_lid792_1m.csv fs=","
</pre></div>
+<p>
+In this example, elevation data from the North Carolina dataset are
+exported along with R,G,B triplet of the related orthophoto into a
+combined file (requires the import of the supplementary high-resolution
+<a href="http://grass.osgeo.org/sampledata/north_carolina/ortho2010_t792_subset_20cm.tif">color orthophoto</a>, here called "ortho2010_t792"):
+<div class="code"><pre>
+g.region rast=elev_lid792_1m res=1 -a -p
+# R=1, G=2, B=3
+r.out.xyz input=elev_lid792_1m,ortho2010_t792.1,ortho2010_t792.2,ortho2010_t792.3 \
+ fs=space output=pointcloud.asc
+# validate: X Y Z R G B
+head -n 3 pointcloud.asc
+638300.5 220749.5 126.338218689 78 84 71
+638301.5 220749.5 126.3381958008 93 101 86
+638302.5 220749.5 126.3414840698 68 77 59
+</pre></div>
<h2>TODO</h2>
Implement this script as a <em>r.out.ascii</em> option?
Modified: grass/branches/develbranch_6/scripts/r.out.xyz/r.out.xyz
--- grass/branches/develbranch_6/scripts/r.out.xyz/r.out.xyz 2013-12-03 21:26:15 UTC (rev 58378)
+++ grass/branches/develbranch_6/scripts/r.out.xyz/r.out.xyz 2013-12-03 21:28:16 UTC (rev 58379)
@@ -24,6 +24,7 @@
#% gisprompt: old,cell,raster
#% key_desc: name
#% description: Name of input raster map
+#% multiple: yes
#% required: yes
#%end
#%option
