[GRASS-SVN] r58381 - grass/trunk/lib/python/temporal
Tue Dec 3 16:55:31 PST 2013
Author: huhabla
Date: 2013-12-03 16:55:30 -0800 (Tue, 03 Dec 2013)
New Revision: 58381
Added:
   grass/trunk/lib/python/temporal/list_stds.py
   grass/trunk/lib/python/temporal/open_stds.py
   grass/trunk/lib/python/temporal/unittests_register.py
Removed:
   grass/trunk/lib/python/temporal/list.py
   grass/trunk/lib/python/temporal/open.py
   grass/trunk/lib/python/temporal/Makefile
   grass/trunk/lib/python/temporal/__init__.py
   grass/trunk/lib/python/temporal/c_libraries_interface.py
   grass/trunk/lib/python/temporal/datetime_math.py
   grass/trunk/lib/python/temporal/extract.py
   grass/trunk/lib/python/temporal/register.py
   grass/trunk/lib/python/temporal/stds_export.py
   grass/trunk/lib/python/temporal/univar_statistics.py
Better Python file naming. New unittests to test the map register function
in register.py. Fixes for map registration bugs with relative time
reported by Vaclav.
Modified: grass/trunk/lib/python/temporal/Makefile
--- grass/trunk/lib/python/temporal/Makefile	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/Makefile	2013-12-04 00:55:30 UTC (rev 58381)
@@ -8,7 +8,7 @@
 GDIR = $(PYDIR)/grass
 DSTDIR = $(GDIR)/temporal
-MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets open factory gui_support list register sampling metadata spatial_extent temporal_extent datetime_math temporal_granularity spatio_temporal_relationships unit_tests aggregation stds_export stds_import extract mapcalc univar_statistics temporal_topology_dataset_connector spatial_topology_dataset_connector c_libraries_interface
+MODULES = base core abstract_dataset abstract_map_dataset abstract_space_time_dataset space_time_datasets open_stds factory gui_support list_stds register sampling metadata spatial_extent temporal_extent datetime_math temporal_granularity spatio_temporal_relationships unit_tests aggregation stds_export stds_import extract mapcalc univar_statistics temporal_topology_dataset_connector spatial_topology_dataset_connector c_libraries_interface
 PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
 PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
Modified: grass/trunk/lib/python/temporal/__init__.py
--- grass/trunk/lib/python/temporal/__init__.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/__init__.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -12,10 +12,10 @@
 from datetime_math import *
 from temporal_granularity import *
 from spatio_temporal_relationships import *
-from open import *
+from open_stds import *
 from factory import *
 from gui_support import *
-from list import *
+from list_stds import *
 from register import *
 from sampling import *
 from aggregation import *
Modified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -549,11 +549,11 @@
                 unit = "hours"
                 start = dt1.hour
             elif dt1.minute > 0:
-                unit = "minutess"
-                start = dt1.minutes
-            elif dt1.seconds > 0:
+                unit = "minutes"
+                start = dt1.minute
+            elif dt1.second > 0:
                 unit = "seconds"
-                start = dt1.seconds
+                start = dt1.second
         if count == 2:
             if dt2.year > 0:
                 end = dt2.year
@@ -564,9 +564,9 @@
             elif dt2.hour > 0:
                 end = dt2.hour
             elif dt2.minute > 0:
-                end = dt2.minutes
-            elif dt2.seconds > 0:
-                end = dt2.seconds
+                end = dt2.minute
+            elif dt2.second > 0:
+                end = dt2.second
         return (start, end, unit)
@@ -635,11 +635,11 @@
        0
        >>> grass.run_command("v.random", output="test", n=10, overwrite=True, quiet=True)
        0
-       >>> grass.run_command("r.timestamp", map="test", date='12 Mar 1995', overwrite=True, quiet=True)
+       >>> grass.run_command("r.timestamp", map="test", date='12 Mar 1995 10:34:40', overwrite=True, quiet=True)
        0
-       >>> grass.run_command("r3.timestamp", map="test", date='12 Mar 1995', overwrite=True, quiet=True)
+       >>> grass.run_command("r3.timestamp", map="test", date='12 Mar 1995 10:34:40', overwrite=True, quiet=True)
        0
-       >>> grass.run_command("v.timestamp", map="test", date='12 Mar 1995', overwrite=True, quiet=True)
+       >>> grass.run_command("v.timestamp", map="test", date='12 Mar 1995 10:34:40', overwrite=True, quiet=True)
        0
@@ -658,11 +658,11 @@
        ...     if res[0]:
        ...         print str(res[1][0]), str(res[1][0])
        ...         ciface.remove_raster_timestamp("test", tgis.get_current_mapset())
-       1995-03-12 00:00:00 1995-03-12 00:00:00
+       1995-03-12 10:34:40 1995-03-12 10:34:40
        1
        >>> ciface.has_raster_timestamp("test", tgis.get_current_mapset())
        False
-       >>> ciface.write_raster_timestamp("test", tgis.get_current_mapset(), "13 Jan 1999")
+       >>> ciface.write_raster_timestamp("test", tgis.get_current_mapset(), "13 Jan 1999 14:30:05")
        1
        True
@@ -682,11 +682,11 @@
        ...     if res[0]:
        ...         ciface.remove_raster3d_timestamp("test", tgis.get_current_mapset())
        1
        >>> ciface.has_raster3d_timestamp("test", tgis.get_current_mapset())
        False
-       >>> ciface.write_raster3d_timestamp("test", tgis.get_current_mapset(), "13 Jan 1999")
+       >>> ciface.write_raster3d_timestamp("test", tgis.get_current_mapset(), "13 Jan 1999 14:30:05")
        1
        True
@@ -707,11 +707,11 @@
        ...     if res[0]:
        ...         ciface.remove_vector_timestamp("test", tgis.get_current_mapset())
        1
        >>> ciface.has_vector_timestamp("test", tgis.get_current_mapset())
        False
-       >>> ciface.write_vector_timestamp("test", tgis.get_current_mapset(), "13 Jan 1999")
+       >>> ciface.write_vector_timestamp("test", tgis.get_current_mapset(), "13 Jan 1999 14:30:05")
        1
        True
Modified: grass/trunk/lib/python/temporal/datetime_math.py
--- grass/trunk/lib/python/temporal/datetime_math.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/datetime_math.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -737,8 +737,13 @@
         Time zones are not supported
         @param time_string The time string to convert
-        @return datetime object or None in case of an error
+        @return datetime object or None in case the string
+                         could not be converted
+    if not isinstance(time_string, str):
+        return None
     time_object = check_datetime_string(time_string)
     if not isinstance(time_object, datetime):
         core.error(time_object)
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/extract.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -13,7 +13,7 @@
 from space_time_datasets import *
-from open import *
 from multiprocessing import Process
Deleted: grass/trunk/lib/python/temporal/list.py
--- grass/trunk/lib/python/temporal/list.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/list.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -1,186 +0,0 @@
-"""!@package grass.temporal
- at brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS related functions to be used in Python scripts.
-Usage:
- at code
-import grass.temporal as tgis
-tgis.register_maps_in_space_time_dataset(type, name, maps)
- at endcode
-(C) 2008-2011 by the GRASS Development Team
-This program is free software under the GNU General Public
-License (>=v2). Read the file COPYING that comes with GRASS
-for details.
- at author Soeren Gebbert
-from space_time_datasets import *
-from factory import *
-from open import *
-def list_maps_of_stds(type, input, columns, order, where, separator, method, header, gran=None):
-    """! List the maps of a space time dataset using diffetent methods
-        @param type The type of the maps raster, raster3d or vector
-        @param input Name of a space time raster dataset
-        @param columns A comma separated list of columns to be printed to stdout
-        @param order A comma separated list of columns to order the
-                      space time dataset by category
-        @param where A where statement for selected listing without "WHERE"
-                      e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
-        @param separator The field separator character between the columns
-        @param method String identifier to select a method out of cols,
-                       comma,delta or deltagaps
-            - "cols" Print preselected columns specified by columns
-            - "comma" Print the map ids ("name at mapset") as comma separated string
-            - "delta" Print the map ids ("name at mapset") with start time,
-                       end time, relative length of intervals and the relative
-                       distance to the begin
-            - "deltagaps" Same as "delta" with additional listing of gaps.
-                           Gaps can be simply identified as the id is "None"
-            - "gran" List map using the granularity of the space time dataset,
-                      columns are identical to deltagaps
-        @param header Set True to print column names
-        @param gran The user defined granule to be used if method=gran is set, in case gran=None the
-            granule of the space time dataset is used
-    dbif, connected = init_dbif(None)
-    sp = open_old_space_time_dataset(input, type, dbif)
-    if separator is None or separator == "":
-        separator = "\t"
-    # This method expects a list of objects for gap detection
-    if method == "delta" or method == "deltagaps" or method == "gran":
-        if type == "stvds":
-            columns = "id,name,layer,mapset,start_time,end_time"
-        else:
-            columns = "id,name,mapset,start_time,end_time"
-        if method == "deltagaps":
-            maps = sp.get_registered_maps_as_objects_with_gaps(where=where, dbif=dbif)
-        elif method == "delta":
-            maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=dbif)
-        elif method == "gran":
-            if gran is not None and gran != "":
-                maps = sp.get_registered_maps_as_objects_by_granularity(gran=gran, dbif=dbif)
-            else:
-                maps = sp.get_registered_maps_as_objects_by_granularity(dbif=dbif)
-        if header:
-            string = ""
-            string += "%s%s" % ("id", separator)
-            string += "%s%s" % ("name", separator)
-                string += "%s%s" % ("layer", separator)
-            string += "%s%s" % ("mapset", separator)
-            string += "%s%s" % ("start_time", separator)
-            string += "%s%s" % ("end_time", separator)
-            string += "%s%s" % ("interval_length", separator)
-            string += "%s" % ("distance_from_begin")
-            print string
-        if maps and len(maps) > 0:
-            if isinstance(maps[0], list):
-                if len(maps[0]) > 0:
-                    first_time, dummy = maps[0][0].get_temporal_extent_as_tuple()
-                else:
-                    core.warning(_("Empty map list."))
-                    return
-            else:
-                first_time, dummy = maps[0].get_temporal_extent_as_tuple()
-            for mymap in maps:
-                if isinstance(mymap, list):
-                    if len(mymap) > 0:
-                        map = mymap[0]
-                    else:
-                        core.fatal(_("Empty entry in map list, this should not happen."))
-                else:
-                    map = mymap
-                start, end = map.get_temporal_extent_as_tuple()
-                if end:
-                    delta = end - start
-                else:
-                    delta = None
-                delta_first = start - first_time
-                if map.is_time_absolute():
-                    if end:
-                        delta = time_delta_to_relative_time(delta)
-                    delta_first = time_delta_to_relative_time(delta_first)
-                string = ""
-                string += "%s%s" % (map.get_id(), separator)
-                string += "%s%s" % (map.get_name(), separator)
-                    string += "%s%s" % (map.get_layer(), separator)
-                string += "%s%s" % (map.get_mapset(), separator)
-                string += "%s%s" % (start, separator)
-                string += "%s%s" % (end, separator)
-                string += "%s%s" % (delta, separator)
-                string += "%s" % (delta_first)
-                print string
-    else:
-        # In comma separated mode only map ids are needed
-        if method == "comma":
-            columns = "id"
-        rows = sp.get_registered_maps(columns, where, order, dbif)
-        if rows:
-                string = ""
-                count = 0
-                for row in rows:
-                    if count == 0:
-                        string += row["id"]
-                    else:
-                        string += ",%s" % row["id"]
-                    count += 1
-                print string
-            elif method == "cols":
-                # Print the column names if requested
-                if header:
-                    output = ""
-                    count = 0
-                    collist = columns.split(",")
-                    for key in collist:
-                        if count > 0:
-                            output += separator + str(key)
-                        else:
-                            output += str(key)
-                        count += 1
-                    print output
-                for row in rows:
-                    output = ""
-                    count = 0
-                    for col in row:
-                        if count > 0:
-                            output += separator + str(col)
-                        else:
-                            output += str(col)
-                        count += 1
-                    print output
-    if connected:
-        dbif.close()
Copied: grass/trunk/lib/python/temporal/list_stds.py (from rev 58380, grass/trunk/lib/python/temporal/list.py)
--- grass/trunk/lib/python/temporal/list_stds.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/list_stds.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -0,0 +1,186 @@
+"""!@package grass.temporal
+ at brief GRASS Python scripting module (temporal GIS functions)
+Temporal GIS related functions to be used in Python scripts.
+Usage:
+ at code
+import grass.temporal as tgis
+tgis.register_maps_in_space_time_dataset(type, name, maps)
+ at endcode
+(C) 2008-2011 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+from space_time_datasets import *
+from factory import *
+def list_maps_of_stds(type, input, columns, order, where, separator, method, header, gran=None):
+    """! List the maps of a space time dataset using diffetent methods
+        @param type The type of the maps raster, raster3d or vector
+        @param input Name of a space time raster dataset
+        @param columns A comma separated list of columns to be printed to stdout
+        @param order A comma separated list of columns to order the
+                      space time dataset by category
+        @param where A where statement for selected listing without "WHERE"
+                      e.g: start_time < "2001-01-01" and end_time > "2001-01-01"
+        @param separator The field separator character between the columns
+        @param method String identifier to select a method out of cols,
+                       comma,delta or deltagaps
+            - "cols" Print preselected columns specified by columns
+            - "comma" Print the map ids ("name at mapset") as comma separated string
+            - "delta" Print the map ids ("name at mapset") with start time,
+                       end time, relative length of intervals and the relative
+                       distance to the begin
+            - "deltagaps" Same as "delta" with additional listing of gaps.
+                           Gaps can be simply identified as the id is "None"
+            - "gran" List map using the granularity of the space time dataset,
+                      columns are identical to deltagaps
+        @param header Set True to print column names
+        @param gran The user defined granule to be used if method=gran is set, in case gran=None the
+            granule of the space time dataset is used
+    dbif, connected = init_dbif(None)
+    sp = open_old_space_time_dataset(input, type, dbif)
+    if separator is None or separator == "":
+        separator = "\t"
+    # This method expects a list of objects for gap detection
+    if method == "delta" or method == "deltagaps" or method == "gran":
+        if type == "stvds":
+            columns = "id,name,layer,mapset,start_time,end_time"
+        else:
+            columns = "id,name,mapset,start_time,end_time"
+        if method == "deltagaps":
+            maps = sp.get_registered_maps_as_objects_with_gaps(where=where, dbif=dbif)
+        elif method == "delta":
+            maps = sp.get_registered_maps_as_objects(where=where, order="start_time", dbif=dbif)
+        elif method == "gran":
+            if gran is not None and gran != "":
+                maps = sp.get_registered_maps_as_objects_by_granularity(gran=gran, dbif=dbif)
+            else:
+                maps = sp.get_registered_maps_as_objects_by_granularity(dbif=dbif)
+        if header:
+            string = ""
+            string += "%s%s" % ("id", separator)
+            string += "%s%s" % ("name", separator)
+                string += "%s%s" % ("layer", separator)
+            string += "%s%s" % ("mapset", separator)
+            string += "%s%s" % ("start_time", separator)
+            string += "%s%s" % ("end_time", separator)
+            string += "%s%s" % ("interval_length", separator)
+            string += "%s" % ("distance_from_begin")
+            print string
+        if maps and len(maps) > 0:
+            if isinstance(maps[0], list):
+                if len(maps[0]) > 0:
+                    first_time, dummy = maps[0][0].get_temporal_extent_as_tuple()
+                else:
+                    core.warning(_("Empty map list."))
+                    return
+            else:
+                first_time, dummy = maps[0].get_temporal_extent_as_tuple()
+            for mymap in maps:
+                if isinstance(mymap, list):
+                    if len(mymap) > 0:
+                        map = mymap[0]
+                    else:
+                        core.fatal(_("Empty entry in map list, this should not happen."))
+                else:
+                    map = mymap
+                start, end = map.get_temporal_extent_as_tuple()
+                if end:
+                    delta = end - start
+                else:
+                    delta = None
+                delta_first = start - first_time
+                if map.is_time_absolute():
+                    if end:
+                        delta = time_delta_to_relative_time(delta)
+                    delta_first = time_delta_to_relative_time(delta_first)
+                string = ""
+                string += "%s%s" % (map.get_id(), separator)
+                string += "%s%s" % (map.get_name(), separator)
+                    string += "%s%s" % (map.get_layer(), separator)
+                string += "%s%s" % (map.get_mapset(), separator)
+                string += "%s%s" % (start, separator)
+                string += "%s%s" % (end, separator)
+                string += "%s%s" % (delta, separator)
+                string += "%s" % (delta_first)
+                print string
+    else:
+        # In comma separated mode only map ids are needed
+        if method == "comma":
+            columns = "id"
+        rows = sp.get_registered_maps(columns, where, order, dbif)
+        if rows:
+                string = ""
+                count = 0
+                for row in rows:
+                    if count == 0:
+                        string += row["id"]
+                    else:
+                        string += ",%s" % row["id"]
+                    count += 1
+                print string
+            elif method == "cols":
+                # Print the column names if requested
+                if header:
+                    output = ""
+                    count = 0
+                    collist = columns.split(",")
+                    for key in collist:
+                        if count > 0:
+                            output += separator + str(key)
+                        else:
+                            output += str(key)
+                        count += 1
+                    print output
+                for row in rows:
+                    output = ""
+                    count = 0
+                    for col in row:
+                        if count > 0:
+                            output += separator + str(col)
+                        else:
+                            output += str(col)
+                        count += 1
+                    print output
+    if connected:
+        dbif.close()
Deleted: grass/trunk/lib/python/temporal/open.py
--- grass/trunk/lib/python/temporal/open.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/open.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -1,249 +0,0 @@
-Usage:
- at code
- at endcode
-for details.
-def open_old_space_time_dataset(name, type, dbif=None):
-    """!This function opens an existing space time dataset and return the
-       created and intialized object of the specified type.
-       This function will raise a ScriptError in case the type is wrong,
-       or the space time dataset was not found.
-       @param name The name of the space time dataset, if the name does not
-                    contain the mapset (name at mapset) then the current mapset
-                    will be used to identifiy the space time dataset
-       @param type The type of the space time dataset (strd, str3ds, stvds,
-                                                       raster, vector, raster3d)
-       @param dbif The optional database interface to be used
-    mapset = get_current_mapset()
-    # Check if the dataset name contains the mapset as well
-    if name.find("@") < 0:
-        id = name + "@" + mapset
-    else:
-        id = name
-    if type == "strds" or type == "rast" or type == "raster":
-        sp = dataset_factory("strds", id)
-    elif type == "str3ds" or type == "rast3d" or type == "raster3d":
-        sp = dataset_factory("str3ds", id)
-    elif type == "stvds" or type == "vect" or type == "vector":
-        sp = dataset_factory("stvds", id)
-    else:
-        core.fatal(_("Unkown type: %s") % (type))
-    dbif, connected = init_dbif(dbif)
-    if not sp.is_in_db(dbif):
-        dbif.close()
-        core.fatal(_("Space time %(sp)s dataset <%(name)s> no found") %
-                     {'sp': sp.get_new_map_instance(None).get_type(),
-                      'name': name})
-    # Read content from temporal database
-    sp.select(dbif)
-    if connected:
-        dbif.close()
-    return sp
-def check_new_space_time_dataset(name, type, dbif=None, overwrite=False):
-    """!Check if a new space time dataset of a specific type can be created
-       @param name The name of the new space time dataset
-       @param type The type of the new space time dataset (strd, str3ds, stvds,
-       @param dbif The temporal database interface to be used
-       @param overwrite Flag to allow overwriting
-       @return A space time dataset object that must be filled with
-               content before insertion in the temporal database
-       This function will raise a ScriptError in case of an error.
-    #Get the current mapset to create the id of the space time dataset
-    else:
-        n, m = name.split("@")
-        if mapset != m:
-            core.fatal(_("Space time datasets can only be created in the "
-                         "current mapset"))
-        id = name
-    else:
-        core.error(_("Unkown type: %s") % (type))
-        return None
-    if sp.is_in_db(dbif) and overwrite is False:
-        core.fatal(_("Space time %(sp)s dataset <%(name)s> is already in the"
-                      " database. Use the overwrite flag.") % {
-                      'sp': sp.get_new_map_instance(None).get_type(),
-                      'name': name})
-    if connected:
-        dbif.close()
-    return sp
-def open_new_space_time_dataset(name, type, temporaltype, title, descr, semantic,
-                              dbif=None, overwrite=False):
-    """!Create a new space time dataset of a specific type
-       @param temporaltype The temporal type (relative or absolute)
-       @param title The title
-       @param descr The dataset description
-       @param semantic Semantical information
-       @param dry Do not create the space time dataset in the temporal database,
-                  make a dry run with including all checks
-       @return The new created space time dataset
-    sp =  check_new_space_time_dataset(name, type, dbif, overwrite)
-    if sp.is_in_db(dbif):
-        core.warning(_("Overwrite space time %(sp)s dataset <%(name)s> and "
-                       "unregister all maps.") % {
-                       'name': name})
-        id = sp.get_id()
-        sp.delete(dbif)
-        sp = sp.get_new_instance(id)
-    core.verbose(_("Create new space time %s dataset.") %
-                   sp.get_new_map_instance(None).get_type())
-    sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
-                          title=title, description=descr)
-    sp.insert(dbif)
-    if connected:
-        dbif.close()
-    return sp
-def check_new_map_dataset(name, layer=None, type="raster",
-                          overwrite=False, dbif=None):
-    """!Check if a new map dataset of a specific type can be created in
-        the temporal database
-       @param name The name of the new map dataset
-       @param layer The layer of the new map dataset
-       @param type The type of the new map dataset (raster, vector, raster3d)
-       @return A map dataset object
-    map_id = AbstractMapDataset.build_id(name, mapset, layer)
-    new_map = dataset_factory(type, map_id)
-    # Check if new map is in the temporal database
-    if new_map.is_in_db(dbif):
-        if not overwrite:
-            if connected:
-                dbif.close()
-            core.fatal(_("Map <%s> is already in temporal database,"
-                         " use overwrite flag to overwrite") % (map_id))
-    if connected:
-        dbif.close()
-    return new_map
-def open_new_map_dataset(name, layer=None, type="raster",
-                         temporal_extent=None, overwrite=False,
-                         dbif=None):
-    """!Create a new map dataset object of a specific type that can be
-        registered in the temporal database
-    new_map = check_new_map_dataset(name, layer, "raster", overwrite, dbif)
-        # Remove the existing temporal database entry
-        map_id = new_map.get_id()
-        new_map.delete(dbif)
-        new_map = new_map.get_new_instance(map_id)
-    if temporal_extent:
-        new_map.set_temporal_extent(temporal_extent)
-    if connected:
-        dbif.close()
-    return new_map
Copied: grass/trunk/lib/python/temporal/open_stds.py (from rev 58380, grass/trunk/lib/python/temporal/open.py)
--- grass/trunk/lib/python/temporal/open_stds.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/open_stds.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -0,0 +1,248 @@
+Usage:
+ at code
+ at endcode
+for details.
+def open_old_space_time_dataset(name, type, dbif=None):
+    """!This function opens an existing space time dataset and return the
+       created and intialized object of the specified type.
+       This function will raise a ScriptError in case the type is wrong,
+       or the space time dataset was not found.
+       @param name The name of the space time dataset, if the name does not
+                    contain the mapset (name at mapset) then the current mapset
+                    will be used to identifiy the space time dataset
+       @param type The type of the space time dataset (strd, str3ds, stvds,
+                                                       raster, vector, raster3d)
+       @param dbif The optional database interface to be used
+    mapset = get_current_mapset()
+    # Check if the dataset name contains the mapset as well
+    if name.find("@") < 0:
+        id = name + "@" + mapset
+    else:
+        id = name
+    if type == "strds" or type == "rast" or type == "raster":
+        sp = dataset_factory("strds", id)
+    elif type == "str3ds" or type == "rast3d" or type == "raster3d":
+        sp = dataset_factory("str3ds", id)
+    elif type == "stvds" or type == "vect" or type == "vector":
+        sp = dataset_factory("stvds", id)
+    else:
+        core.fatal(_("Unkown type: %s") % (type))
+    dbif, connected = init_dbif(dbif)
+    if not sp.is_in_db(dbif):
+        dbif.close()
+        core.fatal(_("Space time %(sp)s dataset <%(name)s> no found") %
+                     {'sp': sp.get_new_map_instance(None).get_type(),
+                      'name': name})
+    # Read content from temporal database
+    sp.select(dbif)
+    if connected:
+        dbif.close()
+    return sp
+def check_new_space_time_dataset(name, type, dbif=None, overwrite=False):
+    """!Check if a new space time dataset of a specific type can be created
+       @param name The name of the new space time dataset
+       @param type The type of the new space time dataset (strd, str3ds, stvds,
+       @param dbif The temporal database interface to be used
+       @param overwrite Flag to allow overwriting
+       @return A space time dataset object that must be filled with
+               content before insertion in the temporal database
+       This function will raise a ScriptError in case of an error.
+    #Get the current mapset to create the id of the space time dataset
+    else:
+        n, m = name.split("@")
+        if mapset != m:
+            core.fatal(_("Space time datasets can only be created in the "
+                         "current mapset"))
+        id = name
+    else:
+        core.error(_("Unkown type: %s") % (type))
+        return None
+    if sp.is_in_db(dbif) and overwrite is False:
+        core.fatal(_("Space time %(sp)s dataset <%(name)s> is already in the"
+                      " database. Use the overwrite flag.") % {
+                      'sp': sp.get_new_map_instance(None).get_type(),
+                      'name': name})
+    if connected:
+        dbif.close()
+    return sp
+def open_new_space_time_dataset(name, type, temporaltype, title, descr, semantic,
+                              dbif=None, overwrite=False):
+    """!Create a new space time dataset of a specific type
+       @param temporaltype The temporal type (relative or absolute)
+       @param title The title
+       @param descr The dataset description
+       @param semantic Semantical information
+       @param dry Do not create the space time dataset in the temporal database,
+                  make a dry run with including all checks
+       @return The new created space time dataset
+    sp =  check_new_space_time_dataset(name, type, dbif, overwrite)
+    if sp.is_in_db(dbif):
+        core.warning(_("Overwrite space time %(sp)s dataset <%(name)s> and "
+                       "unregister all maps.") % {
+                       'name': name})
+        id = sp.get_id()
+        sp.delete(dbif)
+        sp = sp.get_new_instance(id)
+    core.verbose(_("Create new space time %s dataset.") %
+                   sp.get_new_map_instance(None).get_type())
+    sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
+                          title=title, description=descr)
+    sp.insert(dbif)
+    if connected:
+        dbif.close()
+    return sp
+def check_new_map_dataset(name, layer=None, type="raster",
+                          overwrite=False, dbif=None):
+    """!Check if a new map dataset of a specific type can be created in
+        the temporal database
+       @param name The name of the new map dataset
+       @param layer The layer of the new map dataset
+       @param type The type of the new map dataset (raster, vector, raster3d)
+       @return A map dataset object
+    map_id = AbstractMapDataset.build_id(name, mapset, layer)
+    new_map = dataset_factory(type, map_id)
+    # Check if new map is in the temporal database
+    if new_map.is_in_db(dbif):
+        if not overwrite:
+            if connected:
+                dbif.close()
+            core.fatal(_("Map <%s> is already in temporal database,"
+                         " use overwrite flag to overwrite") % (map_id))
+    if connected:
+        dbif.close()
+    return new_map
+def open_new_map_dataset(name, layer=None, type="raster",
+                         temporal_extent=None, overwrite=False,
+                         dbif=None):
+    """!Create a new map dataset object of a specific type that can be
+        registered in the temporal database
+    new_map = check_new_map_dataset(name, layer, "raster", overwrite, dbif)
+        # Remove the existing temporal database entry
+        map_id = new_map.get_id()
+        new_map.delete(dbif)
+        new_map = new_map.get_new_instance(map_id)
+    if temporal_extent:
+        new_map.set_temporal_extent(temporal_extent)
+    if connected:
+        dbif.close()
+    return new_map
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/register.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -22,9 +22,7 @@
 @author Soeren Gebbert
-from open import *
@@ -41,29 +39,6 @@
        It takes care of the correct update of the space time datasets from all
        registered maps.
-       @code
-        >>> import grass.script as grass
-        >>> import grass.temporal as tgis
-        >>> grass.use_temp_region()
-        >>> grass.run_command("g.region", n=80.0, s=0.0, e=120.0, w=0.0,
-        ... t=1.0, b=0.0, res=10.0)
-        0
-        >>> grass.run_command("r.mapcalc", overwrite=True, quiet=True, expression="register_map_1 = 1")
-        0
-        >>> grass.run_command("r.mapcalc", overwrite=True, quiet=True, expression="register_map_2 = 2")
-        0
-        >>> grass.run_command("r.mapcalc", overwrite=True, quiet=True, expression="register_map_3 = 3")
-        0
-        >>> grass.run_command("r.mapcalc", overwrite=True, quiet=True, expression="register_map_4 = 4")
-        0
-        >>> tgis.init(True)
-        >>> tgis.register_maps_in_space_time_dataset(type="strds", name=None,
-        ...               maps="register_map_1,register_map_2,register_map_3,register_map_4",
-        ...               start="2001-01-01", increment="1 day", interval=True)
-       @endcode
        @param type The type of the maps rast, rast3d or vect
        @param name The name of the space time dataset. Maps will be registered in the
                    temporal database if the name was set to None
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/stds_export.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -35,7 +35,7 @@
-from open import *
 proj_file_name = "proj.txt"
 init_file_name = "init.txt"
Added: grass/trunk/lib/python/temporal/unittests_register.py
--- grass/trunk/lib/python/temporal/unittests_register.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/unittests_register.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -0,0 +1,204 @@
+"""!Unit test to register raster maps with absolute and relative
+   time using tgis.register_maps_in_space_time_dataset()
+(C) 2013 by the GRASS Development Team
+for details.
+import grass.script as grass
+import unittest
+import datetime
+class TestRegisterFunctions(unittest.TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """!Initiate the temporal GIS and set the region
+        tgis.init(True)
+        grass.overwrite = True
+        grass.use_temp_region()
+        ret = grass.run_command("g.region", n=80.0, s=0.0, e=120.0,
+                                w=0.0, t=1.0, b=0.0, res=10.0)
+    def setUp(self):
+        """!Create the test maps
+        ret = 0
+        ret += grass.run_command("r.mapcalc", overwrite=True, quiet=True,
+                          expression="register_map_1 = 1")
+                          expression="register_map_2 = 2")
+        self.assertEqual(ret, 0)
+    def test_absolute_time_strds(self):
+        """!Test the registration of maps with absolute time in a
+           space time raster dataset
+        ret = grass.run_command("t.create", output="register_test",
+                                title="Test strds", description="Test strds",
+                                temporaltype="absolute")
+        tgis.register_maps_in_space_time_dataset(type="rast", name="register_test",
+                 maps="register_map_1,register_map_2",
+                 start="2001-01-01", increment="1 day", interval=True)
+        map = tgis.RasterDataset("register_map_1@" + tgis.get_current_mapset())
+        map.select()
+        start, end, tz = map.get_absolute_time()
+        self.assertEqual(start, datetime.datetime(2001, 1, 1))
+        self.assertEqual(end, datetime.datetime(2001, 1, 2))
+        map = tgis.RasterDataset("register_map_2@" + tgis.get_current_mapset())
+        map.select()
+        self.assertEqual(start, datetime.datetime(2001, 1, 2))
+        self.assertEqual(end, datetime.datetime(2001, 1, 3))
+        strds = tgis.SpaceTimeRasterDataset("register_test@" + tgis.get_current_mapset())
+        strds.select()
+        start, end, tz = strds.get_absolute_time()
+        ret = grass.run_command("t.remove", input="register_test")
+    def test_absolute_time_1(self):
+        tgis.register_maps_in_space_time_dataset(type="rast", name=None,
+        map.select()
+        map.select()
+    def test_absolute_time_2(self):
+                 start="2001-01-01 10:30:01", increment="8 hours", interval=False)
+        map.select()
+        self.assertEqual(start, datetime.datetime(2001, 1, 1, 10, 30, 1))
+        map.select()
+        self.assertEqual(start, datetime.datetime(2001, 1, 1, 18, 30, 1))
+    def test_relative_time_strds(self):
+        """!Test the registration of maps with relative time in a
+                                temporaltype="relative")
+                 start=0, increment=1, unit="day", interval=True)
+        map.select()
+        start, end, unit = map.get_relative_time()
+        self.assertEqual(start, 0)
+        self.assertEqual(end, 1)
+        self.assertEqual(unit, "day")
+        map.select()
+        self.assertEqual(start, 1)
+        self.assertEqual(end, 2)
+        strds.select()
+        start, end, unit = strds.get_relative_time()
+    def test_relative_time_1(self):
+        map.select()
+        map.select()
+    def test_relative_time_2(self):
+                 start=1000000, increment=500000, unit="second", interval=True)
+        map.select()
+        self.assertEqual(start, 1000000)
+        self.assertEqual(end, 1500000)
+        self.assertEqual(unit, "second")
+        map.select()
+        self.assertEqual(start, 1500000)
+        self.assertEqual(end, 2000000)
+    def tearDown(self):
+        """!Remove maps from temporal database
+        ret = grass.run_command("t.unregister", maps="register_map_1,register_map_2")
+    @classmethod
+    def tearDownClass(cls):
+        """!Remove the temporary region
+        grass.del_temp_region()
+if __name__ == '__main__':
+    unittest.main()
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py	2013-12-03 21:34:42 UTC (rev 58380)
+++ grass/trunk/lib/python/temporal/univar_statistics.py	2013-12-04 00:55:30 UTC (rev 58381)
@@ -25,7 +25,7 @@
-from open import *
