[GRASS-SVN] r58390 - in grass/trunk/gui/wxpython: gui_core modules
Thu Dec 5 03:23:37 PST 2013
Author: turek
Date: 2013-12-05 03:23:37 -0800 (Thu, 05 Dec 2013)
New Revision: 58390
   grass/trunk/gui/wxpython/gui_core/gselect.py
   grass/trunk/gui/wxpython/modules/colorrules.py
vector colors dialog fix
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py	2013-12-05 08:14:46 UTC (rev 58389)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py	2013-12-05 11:23:37 UTC (rev 58390)
@@ -809,7 +809,6 @@
         if vector:
             layers = GetVectorNumberOfLayers(vector)
         elif dsn:
             ret = RunCommand('v.in.ogr',
                              read = True,
@@ -916,7 +915,8 @@
                  param = None, **kwargs):
         self.defaultValue = value
         self.param = param
+        self.columns = []
         wx.combo.ComboCtrl.__init__(self, parent, id, size = size, **kwargs)
         self.GetChildren()[0].SetName("ColumnSelect")
         self.GetChildren()[0].type = type
@@ -928,7 +928,10 @@
         if vector:
             self.InsertColumns(vector, layer)
         self.GetChildren()[0].Bind(wx.EVT_KEY_UP, self.OnKeyUp)
+    def GetColumns(self):
+        return self.columns
     def OnKeyUp(self, event):
         """!Shows popupwindow if down arrow key is released"""
         if event.GetKeyCode() == wx.WXK_DOWN and not self.IsPopupShown():
@@ -936,6 +939,10 @@
         else:
             event.Skip()
+    def Clear(self):
+        self.tcp.DeleteAllItems()
+        self.SetValue('')
     def InsertColumns(self, vector, layer, excludeKey = False, excludeCols = None, type = None, dbInfo = None):
         """!Insert columns for a vector attribute table into the columns combobox
@@ -947,7 +954,7 @@
         if not dbInfo:
             dbInfo = VectorDBInfo(vector)
         try:
             try:
                 layer = int(layer)
@@ -957,35 +964,35 @@
             table = dbInfo.GetTable(layer)
             columnchoices = dbInfo.GetTableDesc(table)
             keyColumn = dbInfo.GetKeyColumn(layer)
-            columns = len(columnchoices.keys()) * ['']
+            self.columns = len(columnchoices.keys()) * ['']
             for key, val in columnchoices.iteritems():
-                columns[val['index']] = key
+                self.columns[val['index']] = key
             if excludeKey: # exclude key column
-                columns.remove(keyColumn)
+                self.columns.remove(keyColumn)
             if excludeCols: # exclude key column
                 for key in columnchoices.iterkeys():
                     if key in excludeCols:
-                        columns.remove(key)
+                        self.columns.remove(key)
             if type: # only selected column types
                 for key, value in columnchoices.iteritems():
                     if value['type'] not in type:
                         try:
                         except ValueError:
                             pass
         except (KeyError, ValueError):
-            columns = list()
+            self.columns[:] = []
         # update list
-        for col in columns:
+        for col in self.columns:
             self.tcp.AddItem(col)
         self.SetValue(self.defaultValue)
         if self.param:
             value = self.param.get('value', '')
-            if value != '' and value in columns:
+            if value != '' and value in self.columns:
                 self.SetValue(value)
     def InsertTableColumns(self, table, driver=None, database=None):
@@ -995,7 +1002,7 @@
         @param driver driver name
         @param database database name
-        columns = list()
         ret = RunCommand('db.columns',
                          read = True,
@@ -1004,17 +1011,17 @@
                          table = table)
         if ret:
-            columns = ret.splitlines()
+            self.columns = ret.splitlines()
         # update list
         if self.param:
 class DbaseSelect(wx.lib.filebrowsebutton.DirBrowseButton):
Modified: grass/trunk/gui/wxpython/modules/colorrules.py
--- grass/trunk/gui/wxpython/modules/colorrules.py	2013-12-05 08:14:46 UTC (rev 58389)
+++ grass/trunk/gui/wxpython/modules/colorrules.py	2013-12-05 11:23:37 UTC (rev 58390)
@@ -967,9 +967,10 @@
         # additional bindings for vector color management
         self.Bind(wx.EVT_COMBOBOX, self.OnLayerSelection, self.layerSelect)
-        self.Bind(wx.EVT_COMBOBOX, self.OnSourceColumnSelection, self.sourceColumn)
-        self.Bind(wx.EVT_COMBOBOX, self.OnFromColSelection, self.fromColumn)
-        self.Bind(wx.EVT_COMBOBOX, self.OnToColSelection, self.toColumn)
+        self.sourceColumn.Bind(wx.EVT_TEXT, self.OnSourceColumnSelection)
+        self.fromColumn.Bind(wx.EVT_TEXT, self.OnFromColSelection)
+        self.toColumn.Bind(wx.EVT_TEXT, self.OnToColSelection)
         self.Bind(wx.EVT_BUTTON, self.OnAddColumn, self.addColumn)
         self._initLayer()
@@ -1148,8 +1149,8 @@
     def OnCheckColumn(self, event):
         """!Use color column instead of color table"""
         if self.useColumn.GetValue():
-            self.properties['loadColumn'] = self.fromColumn.GetStringSelection()
-            self.properties['storeColumn'] = self.toColumn.GetStringSelection()
+            self.properties['loadColumn'] = self.fromColumn.GetValue()
+            self.properties['storeColumn'] = self.toColumn.GetValue()
             self.fromColumn.Enable(True)
             self.toColumn.Enable(True)
             self.colorTable = False
@@ -1219,6 +1220,7 @@
         # check for db connection
         self.dbInfo = VectorDBInfo(self.inmap)
         enable = True
         if not len(self.dbInfo.layers): # no connection
             if not (self.version7 and self.attributeType == 'color'): # otherwise it doesn't matter
                 wx.CallAfter(self.NoConnection, self.inmap)
@@ -1305,8 +1307,8 @@
         self.sourceColumn.InsertColumns(vector = self.inmap, layer = vlayer,
                                         type = ['integer', 'double precision'], dbInfo = self.dbInfo,
                                         excludeCols = ['tmpColumn'])
-        self.sourceColumn.SetStringSelection('cat')
-        self.properties['sourceColumn'] = self.sourceColumn.GetString(0)
+        self.sourceColumn.SetValue('cat')
+        self.properties['sourceColumn'] = self.sourceColumn.GetValue()
         if self.attributeType == 'color':
             type = ['character']
@@ -1317,12 +1319,16 @@
         self.toColumn.InsertColumns(vector = self.inmap, layer = vlayer, type = type,
                                     dbInfo = self.dbInfo, excludeCols = ['tmpColumn'])
-        found = self.fromColumn.FindString(self.columnsProp[self.attributeType]['name'])
+        v = self.columnsProp[self.attributeType]['name']
+        found = False
+        if v in self.fromColumn.GetColumns():
+            found = True
         if found != wx.NOT_FOUND:
-            self.fromColumn.SetSelection(found)
-            self.toColumn.SetSelection(found)
-            self.properties['loadColumn'] = self.fromColumn.GetString(found)
-            self.properties['storeColumn'] = self.toColumn.GetString(found)
+            self.fromColumn.SetValue(v)
+            self.toColumn.SetValue(v)
+            self.properties['loadColumn'] = v
+            self.properties['storeColumn'] = v
         else:
             self.properties['loadColumn'] = ''
             self.properties['storeColumn'] = ''
@@ -1338,7 +1344,7 @@
     def OnAddColumn(self, event):
         """!Add GRASS(RGB,SIZE,WIDTH) column if it doesn't exist"""
-        if self.columnsProp[self.attributeType]['name'] not in self.fromColumn.GetItems():
+        if self.columnsProp[self.attributeType]['name'] not in self.fromColumn.GetColumns():
             if self.version7:
                 modul = 'v.db.addcolumn'
             else:
@@ -1350,8 +1356,8 @@
                                                   self.columnsProp[self.attributeType]['type1']))
             self.toColumn.InsertColumns(self.inmap, self.properties['layer'],
                                         type = self.columnsProp[self.attributeType]['type2'])
-            self.toColumn.SetStringSelection(self.columnsProp[self.attributeType]['name'])
+            self.toColumn.SetValue(self.columnsProp[self.attributeType]['name'])
             self.LoadTable()
         else:
