[GRASS-SVN] r58399 - grass/trunk/raster/r.report
svn_grass at osgeo.org
Fri Dec 6 08:20:33 PST 2013
Author: martinl
Date: 2013-12-06 08:20:33 -0800 (Fri, 06 Dec 2013)
New Revision: 58399
grass/trunk/raster/r.report/global.h
grass/trunk/raster/r.report/main.c
grass/trunk/raster/r.report/parse.c
grass/trunk/raster/r.report/r.report.html
grass/trunk/raster/r.report/stats.c
r.report: implemente 'sort' parameter
major update of manual page
guisection cosmetics
Modified: grass/trunk/raster/r.report/global.h
--- grass/trunk/raster/r.report/global.h 2013-12-06 16:16:30 UTC (rev 58398)
+++ grass/trunk/raster/r.report/global.h 2013-12-06 16:20:33 UTC (rev 58399)
@@ -7,6 +7,10 @@
#include <grass/raster.h>
+#define SORT_DEFAULT 0
+#define SORT_ASC 1
+#define SORT_DESC 2
extern struct Cell_head window;
struct _layer_
@@ -57,6 +61,7 @@
extern int e_format;
extern int no_nulls;
extern int no_nulls_all;
+extern int do_sort;
extern char *stats_file;
extern char *no_data_str;
Modified: grass/trunk/raster/r.report/main.c
--- grass/trunk/raster/r.report/main.c 2013-12-06 16:16:30 UTC (rev 58398)
+++ grass/trunk/raster/r.report/main.c 2013-12-06 16:20:33 UTC (rev 58399)
@@ -6,8 +6,9 @@
* Roberto Flor <flor itc.it>
* Jachym Cepicky <jachym les-ejk.cz>,
* Jan-Oliver Wagner <jan intevation.de>
+ * Sort option by Martin Landa <landa.martin gmail.com>
* PURPOSE: Reports statistics for raster map(s).
- * COPYRIGHT: (C) 1999-2006, 2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2013 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -36,10 +37,10 @@
int use_formfeed;
int nlines;
int with_headers = 1;
-int verbose = 1;
int e_format;
int no_nulls;
int no_nulls_all;
+int do_sort = SORT_DEFAULT;
char *stats_file;
char *no_data_str;
Modified: grass/trunk/raster/r.report/parse.c
--- grass/trunk/raster/r.report/parse.c 2013-12-06 16:16:30 UTC (rev 58398)
+++ grass/trunk/raster/r.report/parse.c 2013-12-06 16:20:33 UTC (rev 58399)
@@ -19,6 +19,7 @@
struct Option *outfile;
struct Option *nv;
struct Option *nsteps;
+ struct Option *sort;
} parms;
struct
@@ -36,35 +37,42 @@
} flags;
parms.cell = G_define_standard_option(G_OPT_R_MAPS);
- parms.cell->description = _("Raster map(s) to report on");
+ parms.cell->description = _("Name of raster map(s) to report on");
parms.units = G_define_option();
parms.units->key = "units";
parms.units->type = TYPE_STRING;
parms.units->required = NO;
parms.units->multiple = YES;
- parms.units->description = _("Units");
+ parms.units->description = _("Units to report");
desc = NULL;
G_asprintf(&desc,
"mi;%s;me;%s;k;%s;a;%s;h;%s;c;%s;p;%s",
- _("miles"),
- _("meters"),
- _("kilometers"),
- _("acres"),
- _("hectares"),
- _("cell counts"),
+ _("area in square miles"),
+ _("area in square meters"),
+ _("area in square kilometers"),
+ _("area in acres"),
+ _("area in hectares"),
+ _("number of cells"),
_("percent cover"));
parms.units->descriptions = desc;
parms.units->options = "mi,me,k,a,h,c,p";
- parms.units->guisection = _("Output settings");
+ parms.units->guisection = _("Statistics");
+ parms.outfile = G_define_standard_option(G_OPT_F_OUTPUT);
+ parms.outfile->required = NO;
+ parms.outfile->label =
+ _("Name for output file to hold the report");
+ parms.outfile->description =
+ _("If no output given report is printed to standard output");
parms.nv = G_define_option();
parms.nv->key = "null";
parms.nv->type = TYPE_STRING;
parms.nv->required = NO;
parms.nv->multiple = NO;
parms.nv->answer = "*";
- parms.nv->description = _("Character representing no data cell value");
+ parms.nv->description = _("String representing no data cell value");
parms.nv->guisection = _("Formatting");
parms.pl = G_define_option();
@@ -85,15 +93,6 @@
parms.pw->description = pw_desc;
parms.pw->guisection = _("Formatting");
- parms.outfile = G_define_standard_option(G_OPT_F_OUTPUT);
- parms.outfile->key = "output";
- parms.outfile->required = NO;
- parms.outfile->label =
- _("Name for output file to hold the report");
- parms.outfile->description =
- _("If no output given report is printed to standard output");
- parms.outfile->guisection = _("Output settings");
parms.nsteps = G_define_option();
parms.nsteps->key = "nsteps";
parms.nsteps->type = TYPE_INTEGER;
@@ -101,9 +100,23 @@
parms.nsteps->multiple = NO;
parms.nsteps->answer = "255";
parms.nsteps->description =
- _("Number of fp subranges to collect stats from");
- parms.nsteps->guisection = _("FP maps");
+ _("Number of floating-point subranges to collect stats from");
+ parms.nsteps->guisection = _("Floating point");
+ parms.sort = G_define_option();
+ parms.sort->key = "sort";
+ parms.sort->type = TYPE_STRING;
+ parms.sort->required = NO;
+ parms.sort->multiple = NO;
+ parms.sort->label = _("Sort output statistics by cell counts");
+ parms.sort->description = _("Default: sorted by categories or intervals");
+ parms.sort->options = "asc,desc";
+ G_asprintf((char **)&(parms.sort->descriptions),
+ "asc;%s;desc;%s",
+ _("Sort by cell counts in ascending order"),
+ _("Sort by cell counts in descending order"));
+ parms.sort->guisection = _("Formatting");
flags.h = G_define_flag();
flags.h->key = 'h';
flags.h->description = _("Suppress page headers");
@@ -122,21 +135,23 @@
flags.n = G_define_flag();
flags.n->key = 'n';
flags.n->description = _("Filter out all no data cells");
+ flags.n->guisection = _("No data");
flags.N = G_define_flag();
flags.N->key = 'N';
flags.N->description = _("Filter out cells where all maps have no data");
+ flags.N->guisection = _("No data");
flags.C = G_define_flag();
flags.C->key = 'C';
- flags.C->description = _("Report for cats fp ranges (fp maps only)");
- flags.C->guisection = _("FP maps");
+ flags.C->description = _("Report for cats floating-point ranges (floating-point maps only)");
+ flags.C->guisection = _("Floating point");
flags.i = G_define_flag();
flags.i->key = 'i';
flags.i->description =
- _("Read fp map as integer (use map's quant rules)");
- flags.i->guisection = _("FP maps");
+ _("Read floating-point map as integer (use map's quant rules)");
+ flags.i->guisection = _("Floating point");
/* hidden feature.
* if first arg is >file just run r.stats into this file and quit
@@ -203,6 +218,22 @@
no_data_str = parms.nv->answer;
+ /* determine sorting method */
+ do_sort = SORT_DEFAULT; /* sort by cats by default */
+ if (parms.sort->answer) {
+ switch(parms.sort->answer[0]) {
+ case 'a':
+ do_sort = SORT_ASC;
+ break;
+ case 'd':
+ do_sort = SORT_DESC;
+ break;
+ default:
+ G_debug(1, "Sorting by '%s' not supported", parms.sort->answer);
+ break;
return 0;
Modified: grass/trunk/raster/r.report/r.report.html
--- grass/trunk/raster/r.report/r.report.html 2013-12-06 16:16:30 UTC (rev 58398)
+++ grass/trunk/raster/r.report/r.report.html 2013-12-06 16:20:33 UTC (rev 58399)
@@ -1,104 +1,103 @@
<h2>DESCRIPTION</h2>
-<em>r.report</em> allows the user to set up a series of report parameters to
-be applied to a raster map layer, and creates a report. If invoked with
-command line arguments, the report will print out to the screen only.
-However, output may be redirected to a file or another program using the
-UNIX redirection mechanism. If invoked without command line arguments, the
-user is given the option of printing out each report and/or saving output to
-a file.
+<em>r.report</em> allows the user to set up a series of report
+parameters to be applied to a raster map, and creates a report. The
+report will print out to the standard output if <b>output</b>
+parameter is not given.
-<p>The report itself consists of two parts, a header section and the main body
-of the report.
+<p>
+The report itself consists of two parts, a header section and the main
+body of the report.
-<p>The header section of the report identifies the raster map layer(s) (by map
-layer name and TITLE), location, mapset, report date, and the region of
-interest. The area of interest is described in two parts: the user's current
-geographic region is presented, and the mask is presented (if any is used).
+<p>
+The header section of the report identifies the raster map(s) (by map
+name and title), location, mapset, report date, and the region of
+interest. The area of interest is described in two parts: the user's
+current geographic region is presented, and the mask is presented (if
+any is used).
-<p>The main body of the report consists of from one to three tables which
+<p>
+The main body of the report consists of from one to three tables which
present the statistics for each category and the totals for each unit
-column.
+column. Note that the statistics is always computed in the current
+geographical region.
-<p>Note that, unlike <em><a href="r.stats.html">r.stats</a></em>,
-<em>r.report</em> allows the user to select the specific units of measure in
-which statistics will be reported.
-<p>Following is the result of a <em>r.report</em> run on the raster map layer
-<em>geology</em> (located in the Spearfish, SD sample data base), with the
-units expressed in square miles and acres. Here, <em>r.report</em> output is
-directed into the file <em>report.file</em>.
-<h2>EXAMPLE:</h2>
-<dl>
-<dd>
-<b>r.report map=</b><em>geology</em> <b>units=</b><em>miles,acres</em> > <em>report.file </em>
-</dl>
-<pre>
- ____________________________________________________________
-| RASTER MAP CATEGORY REPORT |
-|____________________________________________________________|
-| north: 4928000.00 east: 609000.00 |
-| REGION: south: 4914000.00 west: 590000.00 |
-| res: 100.00 res: 100.00 |
-| MASK: none |
-| MAP: geology in PERMANENT |
-| Category Information | Acres Square |
-| # description | Miles |
-|________|_________________________|_________________________|
-| 0 | no data | 415.13| 0.65 |
-| 1 | metamorphic | 2597.02| 4.06 |
-| 2 | transition | 32.12| 0.05 |
-| 3 | igneous | 8117.24| 12.68 |
-| 4 | sandstone | 16691.60| 26.08 |
-| 5 | limestone | 13681.93| 21.38 |
-| 6 | shale | 10304.07| 16.10 |
-| 7 | sandy shale | 2517.95| 3.93 |
-| 8 | claysand | 3229.60| 5.05 |
-| 9 | sand | 8141.95| 12.72 |
-|__________________________________|___________|_____________|
-| TOTAL | 65728.60| 102.70 |
-</pre>
<h2>NOTES</h2>
If the user runs <em>r.report</em> interactively and saves the report output
in a file, this file will be placed into the user's current working
directory.
-<p>
If the user runs <em>r.report</em> non-interactively, report output can be
saved by redirecting it to a file or a printer using the UNIX redirection
mechanism.
-<p>
-To output computer-friendly data suitable for importing into a spreadsheet
-use the <em>r.stats</em> module. In fact <em>r.report</em> is running
-<em>r.stats</em> in the background and reformatting the results to be
-more human-friendly.
+Note that, unlike <em><a href="r.stats.html">r.stats</a></em>,
+<em>r.report</em> allows the user to select the specific units of
+measure in which statistics will be reported. To output
+computer-friendly data suitable for importing into a spreadsheet use
+the <em><a href="r.stats.html">r.stats</a></em> module. In
+fact <em>r.report</em> is running
+<em><a href="r.stats.html">r.stats</a></em> in the background and
+reformatting the results to be more human-friendly.
+<h2>EXAMPLE</h2>
+Report sorted areas in square miles and acres for each
+category. No-data are not reported (see <b>-n</b> flag).
+<div class="code"><pre>
+r.report -n map=geology_30m units=mi,a sort=desc
+| RASTER MAP CATEGORY REPORT |
+|LOCATION: nc_spm_08_grass7 Fri Dec 6 17:00:21 2013|
+| north: 279073.97546639 east: 798143.31179672 |
+|REGION south: 113673.97546639 west: 595143.31179672 |
+| res: 200 res: 200 |
+|MASK: none |
+|MAP: South-West Wake county: geology derived from vector map (geology_30m in |
+| Category Information | square| |
+| #|description | miles| acres|
+|217|CZfg . . . . . . . . . . . . . . . . . . . . . . . | 27.783911|17,781.703|
+|270|CZig . . . . . . . . . . . . . . . . . . . . . . . | 26.162282|16,743.861|
+|405|CZbg . . . . . . . . . . . . . . . . . . . . . . . | 9.698886| 6207.287|
+|262|CZlg . . . . . . . . . . . . . . . . . . . . . . . | 7.629379| 4882.802|
+|862|CZam . . . . . . . . . . . . . . . . . . . . . . . | 2.532830| 1621.011|
+|910|CZbg . . . . . . . . . . . . . . . . . . . . . . . | 1.683405| 1077.379|
+|583|CZve . . . . . . . . . . . . . . . . . . . . . . . | 0.972977| 622.706|
+|921|Km . . . . . . . . . . . . . . . . . . . . . . . . | 0.463323| 296.526|
+|766|CZg. . . . . . . . . . . . . . . . . . . . . . . . | 0.324326| 207.569|
+|720|CZam . . . . . . . . . . . . . . . . . . . . . . . | 0.185329| 118.611|
+|946|CZam . . . . . . . . . . . . . . . . . . . . . . . | 0.138997| 88.958|
+|948|CZam . . . . . . . . . . . . . . . . . . . . . . . | 0.030888| 19.768|
+|TOTAL | 77.606534|49,668.182|
+</div>
<h2>SEE ALSO</h2>
-<em><a href="g.region.html">g.region</a>,
+<em>
+<a href="r.stats.html">r.stats</a>,
+<a href="g.region.html">g.region</a>,
<a href="r.coin.html">r.coin</a>,
<a href="r.describe.html">r.describe</a>,
<a href="r.info.html">r.info</a>,
-<a href="r.stats.html">r.stats</a>,
<a href="r.univar.html">r.univar</a>
</em>
+<h2>AUTHORS</h2>
-<h2>AUTHOR</h2>
-Michael Shapiro,
-U.S. Army Construction Engineering Research Laboratory
+Michael Shapiro, U.S. Army Construction Engineering Research Laboratory<br>
+Sort option by Martin Landa, Czech Technical University in Prague, 2013
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.report/stats.c
--- grass/trunk/raster/r.report/stats.c 2013-12-06 16:16:30 UTC (rev 58398)
+++ grass/trunk/raster/r.report/stats.c 2013-12-06 16:20:33 UTC (rev 58399)
@@ -54,6 +54,11 @@
argv[argc++] = SF_MODE_OUT;
argv[argc++] = stats_file;
+ if (do_sort == SORT_ASC)
+ argv[argc++] = "sort=asc";
+ else if (do_sort == SORT_DESC)
+ argv[argc++] = "sort=desc";
for (i = 0; i < nlayers; i++) {
char *name = G_fully_qualified_name(layers[i].name, layers[i].mapset);
char *buf = G_malloc(6 + strlen(name) + 1);
