[GRASS-SVN] r58401 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Dec 6 08:41:39 PST 2013
Author: martinl
Date: 2013-12-06 08:41:39 -0800 (Fri, 06 Dec 2013)
New Revision: 58401
grass/trunk/lib/vector/Vlib/cindex.c
vlib: update cindex.c doxygen documentation
check_index() added (cosmetics)
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c 2013-12-06 16:24:03 UTC (rev 58400)
+++ grass/trunk/lib/vector/Vlib/cindex.c 2013-12-06 16:41:39 UTC (rev 58401)
@@ -1,11 +1,11 @@
\file lib/vector/Vlib/cindex.c
- \brief Vector library - category index.
+ \brief Vector library - category index management
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009 by the GRASS Development Team
+ (C) 2001-2013 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -23,12 +23,51 @@
#include "local_proto.h"
+#define SEP "------------------------------------------------------------------------------------------\n"
static void check_status(const struct Map_info *Map)
if (!Map->plus.cidx_up_to_date)
G_fatal_error(_("Category index is not up to date"));
+static void check_index(const struct Map_info *Map, int index)
+ if (index < 0 || index >= Map->plus.n_cidx)
+ G_fatal_error(_("Layer index out of range"));
+/* search for first occurence of cat in cat index, starting at first */
+static int ci_search_cat(struct Cat_index *ci, int first, int cat)
+ int lo, hi, mid;
+ lo = first;
+ if (lo < 0)
+ lo = 0;
+ if (ci->cat[lo][0] > cat)
+ return -1;
+ if (ci->cat[lo][0] == cat)
+ return lo;
+ hi = ci->n_cats - 1;
+ if (first > hi)
+ return -1;
+ /* deferred test for equality */
+ while (lo < hi) {
+ mid = (lo + hi) >> 1;
+ if (ci->cat[mid][0] < cat)
+ lo = mid + 1;
+ else
+ hi = mid;
+ return lo;
+ return -1;
\brief Get number of layers in category index
@@ -56,10 +95,8 @@
int Vect_cidx_get_field_number(const struct Map_info *Map, int index)
check_status(Map);
+ check_index(Map, index);
- if (index >= Map->plus.n_cidx)
- G_fatal_error(_("Invalid layer index (index >= number of layers)"));
return Map->plus.cidx[index].field;
@@ -96,7 +133,7 @@
G_fatal_error() is called when index not found.
\param Map pointer to Map_info structure
- \param index layer number
+ \param index layer index (starts at 0)
\return number of unique categories
\return -1 on error
@@ -104,10 +141,8 @@
int Vect_cidx_get_num_unique_cats_by_index(const struct Map_info *Map, int index)
check_status(Map);
- if (index < 0 || index >= Map->plus.n_cidx)
- G_fatal_error(_("Invalid layer index (index < 0 or index >= number of layers)"));
return Map->plus.cidx[index].n_ucats;
@@ -123,40 +158,38 @@
int Vect_cidx_get_num_cats_by_index(const struct Map_info *Map, int index)
check_status(Map);
return Map->plus.cidx[index].n_cats;
- \brief Get number of types for given layer index
+ \brief Get number of feature types for given layer index
\param field_index layer index
- \return number of types
+ \return number of feature types
\return -1 on error
int Vect_cidx_get_num_types_by_index(const struct Map_info *Map, int field_index)
check_status(Map);
- if (field_index >= Map->plus.n_cidx)
+ check_index(Map, field_index);
return Map->plus.cidx[field_index].n_types;
- \brief Get type count field index and type index
+ \brief Get count of feature types for given field and type index
\param type_index type index
- \param[out] type feature type
- \param[out] count number of items
+ \param[out] type feature type (GV_POINT, ...)
+ \param[out] count number of features or NULL
\return 1 on success
\return 0 on error
@@ -165,11 +198,11 @@
int type_index, int *type, int *count)
check_status(Map);
*type = Map->plus.cidx[field_index].type[type_index][0];
- *count = Map->plus.cidx[field_index].type[type_index][1];
+ if (count)
+ *count = Map->plus.cidx[field_index].type[type_index][1];
return 1;
@@ -182,7 +215,7 @@
\param type feature type
\return feature count
- \return 0 if no features, no such field or no such type in cidx
+ \return 0 if no features, no such field or no such type in category index
int Vect_cidx_get_type_count(const struct Map_info *Map, int field, int type)
@@ -212,7 +245,7 @@
- \brief Get number of categories for given field and category index
+ \brief Get number of categories for given layer and category index
@@ -228,10 +261,10 @@
int cat_index, int *cat, int *type, int *id)
check_status(Map); /* This check is slow ? */
- if (field_index >= Map->plus.n_cidx || field_index < 0 ||
- cat_index >= Map->plus.cidx[field_index].n_cats)
- G_fatal_error(_("Layer or category index out of range"));
+ if (cat_index < 0 || cat_index >= Map->plus.cidx[field_index].n_cats)
+ G_fatal_error(_("Category index out of range"));
*cat = Map->plus.cidx[field_index].cat[cat_index][0];
*type = Map->plus.cidx[field_index].cat[cat_index][1];
@@ -240,44 +273,13 @@
return 1;
-/* search for first occurence of cat in cat index, starting at first */
-static int ci_search_cat(struct Cat_index *ci, int first, int cat)
- int lo, hi, mid;
- lo = first;
- if (lo < 0)
- lo = 0;
- if (ci->cat[lo][0] > cat)
- return -1;
- if (ci->cat[lo][0] == cat)
- return lo;
- hi = ci->n_cats - 1;
- if (first > hi)
- return -1;
- /* deferred test for equality */
- while (lo < hi) {
- mid = (lo + hi) >> 1;
- if (ci->cat[mid][0] < cat)
- lo = mid + 1;
- else
- hi = mid;
- return lo;
- return -1;
\brief Find next line/area id for given category, start_index and type_mask
\param cat category number
- \param type_mask requested type
+ \param type_mask requested feature type
\param start_index start search at this index (0 - whole category index)
\param[out] type returned type
\param[out] id returned line/area id
@@ -296,11 +298,9 @@
cat, type_mask, start_index);
*type = *id = 0;
- G_fatal_error(_("Layer index out of range"));
/* pointer to category index */
ci = &(Map->plus.cidx[field_index]);
@@ -330,7 +330,7 @@
\param layer layer number
- \param type_mask type of objects to search for
+ \param type_mask feature type of objects to search for
\param[out] lines array of ids of found lines/points
@@ -369,11 +369,8 @@
return;
-#define SEP "------------------------------------------------------------------------------------------\n"
- \brief Write category index in text form to file
+ \brief Write (dump) category index in text form to file
\param[out] out output file
@@ -430,7 +427,7 @@
- \brief Save category index to file (cidx)
+ \brief Save category index to binary file (cidx)
@@ -473,10 +470,10 @@
- \brief Read category index from file if exists
+ \brief Read category index from cidx file if exists
- \param head_only read only header
+ \param head_only read only header of the file
\return 0 on success
\return 1 if file does not exist
