[GRASS-SVN] r58409 - in grass/trunk/gui: icons/grass wxpython/lmgr
svn_grass at osgeo.org
Sun Dec 8 12:39:31 PST 2013
Author: martinl
Date: 2013-12-08 12:39:31 -0800 (Sun, 08 Dec 2013)
New Revision: 58409
Added:
grass/trunk/gui/icons/grass/layer-info.png
grass/trunk/gui/icons/grass/raster-stats.png
grass/trunk/gui/icons/grass/region.png
grass/trunk/gui/icons/grass/zoom-layer.png
grass/trunk/gui/icons/grass/polygon.png
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: define icons for layer contextual menu
Added: grass/trunk/gui/icons/grass/layer-info.png
(Binary files differ)
Property changes on: grass/trunk/gui/icons/grass/layer-info.png
___________________________________________________________________
Added: svn:mime-type
+ image/png
Property changes on: grass/trunk/gui/icons/grass/polygon.png
Modified: svn:mime-type
- application/octet-stream
+ image/png
Added: grass/trunk/gui/icons/grass/raster-stats.png
Property changes on: grass/trunk/gui/icons/grass/raster-stats.png
+ image/png
Added: grass/trunk/gui/icons/grass/region.png
Property changes on: grass/trunk/gui/icons/grass/region.png
+ image/png
Added: grass/trunk/gui/icons/grass/zoom-layer.png
Property changes on: grass/trunk/gui/icons/grass/zoom-layer.png
+ image/png
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2013-12-08 20:23:52 UTC (rev 58408)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2013-12-08 20:39:31 UTC (rev 58409)
@@ -191,53 +191,53 @@
trart = wx.ArtProvider.GetBitmap(wx.ART_FOLDER, wx.ART_OTHER, (16, 16))
self.folder = il.Add(trart)
- bmpsize = (16, 16)
- trgif = BaseIcons["addRast"].GetBitmap(bmpsize)
+ self.bmpsize = (16, 16)
+ trgif = BaseIcons["addRast"].GetBitmap(self.bmpsize)
self.rast_icon = il.Add(trgif)
- trgif = LMIcons["addRast3d"].GetBitmap(bmpsize)
+ trgif = LMIcons["addRast3d"].GetBitmap(self.bmpsize)
self.rast3d_icon = il.Add(trgif)
- trgif = LMIcons["addRgb"].GetBitmap(bmpsize)
+ trgif = LMIcons["addRgb"].GetBitmap(self.bmpsize)
self.rgb_icon = il.Add(trgif)
- trgif = LMIcons["addHis"].GetBitmap(bmpsize)
+ trgif = LMIcons["addHis"].GetBitmap(self.bmpsize)
self.his_icon = il.Add(trgif)
- trgif = LMIcons["addShaded"].GetBitmap(bmpsize)
+ trgif = LMIcons["addShaded"].GetBitmap(self.bmpsize)
self.shaded_icon = il.Add(trgif)
- trgif = LMIcons["addRArrow"].GetBitmap(bmpsize)
+ trgif = LMIcons["addRArrow"].GetBitmap(self.bmpsize)
self.rarrow_icon = il.Add(trgif)
- trgif = LMIcons["addRNum"].GetBitmap(bmpsize)
+ trgif = LMIcons["addRNum"].GetBitmap(self.bmpsize)
self.rnum_icon = il.Add(trgif)
- trgif = BaseIcons["addVect"].GetBitmap(bmpsize)
+ trgif = BaseIcons["addVect"].GetBitmap(self.bmpsize)
self.vect_icon = il.Add(trgif)
- trgif = LMIcons["addThematic"].GetBitmap(bmpsize)
+ trgif = LMIcons["addThematic"].GetBitmap(self.bmpsize)
self.theme_icon = il.Add(trgif)
- trgif = LMIcons["addChart"].GetBitmap(bmpsize)
+ trgif = LMIcons["addChart"].GetBitmap(self.bmpsize)
self.chart_icon = il.Add(trgif)
- trgif = LMIcons["addGrid"].GetBitmap(bmpsize)
+ trgif = LMIcons["addGrid"].GetBitmap(self.bmpsize)
self.grid_icon = il.Add(trgif)
- trgif = LMIcons["addGeodesic"].GetBitmap(bmpsize)
+ trgif = LMIcons["addGeodesic"].GetBitmap(self.bmpsize)
self.geodesic_icon = il.Add(trgif)
- trgif = LMIcons["addRhumb"].GetBitmap(bmpsize)
+ trgif = LMIcons["addRhumb"].GetBitmap(self.bmpsize)
self.rhumb_icon = il.Add(trgif)
- trgif = LMIcons["addLabels"].GetBitmap(bmpsize)
+ trgif = LMIcons["addLabels"].GetBitmap(self.bmpsize)
self.labels_icon = il.Add(trgif)
- trgif = LMIcons["addCmd"].GetBitmap(bmpsize)
+ trgif = LMIcons["addCmd"].GetBitmap(self.bmpsize)
self.cmd_icon = il.Add(trgif)
- trgif = LMIcons["wsImport"].GetBitmap(bmpsize)
+ trgif = LMIcons["wsImport"].GetBitmap(self.bmpsize)
self.ws_icon = il.Add(trgif)
self.AssignImageList(il)
@@ -414,10 +414,12 @@
currentMapset = grass.gisenv()['MAPSET']
self.popupMenu = wx.Menu()
numSelected = len(self.GetSelections())
- self.popupMenu.Append(self.popupID['remove'], text = _("Remove"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['remove'], text = _("Remove"))
+ item.SetBitmap(MetaIcon(img = 'layer-remove').GetBitmap(self.bmpsize))
+ self.popupMenu.AppendItem(item)
self.Bind(wx.EVT_MENU, self.lmgr.OnDeleteLayer, id = self.popupID['remove'])
if ltype != "command" and numSelected == 1:
@@ -439,9 +441,13 @@
if numSelected == 1:
self.popupMenu.AppendSeparator()
if ltype != '3d-raster':
- self.popupMenu.Append(self.popupID['opacity'], text=_("Change opacity level"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['opacity'], text=_("Change opacity level"))
+ item.SetBitmap(MetaIcon(img = 'layer-opacity').GetBitmap(self.bmpsize))
self.Bind(wx.EVT_MENU, self.OnPopupOpacityLevel, id=self.popupID['opacity'])
- self.popupMenu.Append(self.popupID['properties'], text = _("Properties"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['properties'], text = _("Properties"))
+ item.SetBitmap(MetaIcon(img = 'options').GetBitmap(self.bmpsize))
self.Bind(wx.EVT_MENU, self.OnPopupProperties, id = self.popupID['properties'])
if ltype in ('raster', 'vector', '3d-raster') and self.lmgr.IsPaneShown('toolbarNviz'):
@@ -450,9 +456,14 @@
if same and ltype in ('raster', 'vector', 'rgb', '3d-raster'):
- self.popupMenu.Append(self.popupID['zoom'], text = _("Zoom to selected map(s)"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['zoom'], text = _("Zoom to selected map(s)"))
+ item.SetBitmap(MetaIcon(img = 'zoom-layer').GetBitmap(self.bmpsize))
self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToMap, id = self.popupID['zoom'])
- self.popupMenu.Append(self.popupID['region'], text = _("Set computational region from selected map(s)"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['region'], text = _("Set computational region from selected map(s)"))
+ item.SetBitmap(MetaIcon(img = 'region').GetBitmap(self.bmpsize))
self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id = self.popupID['region'])
# specific items
@@ -464,7 +475,9 @@
# vector layers (specific items)
if mltype and mltype == "vector" and numSelected == 1:
- self.popupMenu.Append(self.popupID['export'], text = _("Export common formats"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['export'], text = _("Export common formats"))
+ item.SetBitmap(MetaIcon(img = 'layer-export').GetBitmap(self.bmpsize))
self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['v.out.ogr',
'input=%s' % mapLayer.GetName()]),
id = self.popupID['export'])
@@ -488,10 +501,15 @@
self.popupMenu.Append(self.popupID['color'], _("Set color table"))
self.Bind (wx.EVT_MENU, self.OnVectorColorTable, id = self.popupID['color'])
- self.popupMenu.Append(self.popupID['attr'], text = _("Show attribute data"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['attr'], text = _("Show attribute data"))
+ item.SetBitmap(MetaIcon(img = 'layer-raster-profile').GetBitmap(self.bmpsize))
self.Bind(wx.EVT_MENU, self.lmgr.OnShowAttributeTable, id = self.popupID['attr'])
- self.popupMenu.Append(self.popupID['edit0'], text = _("Start editing"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['edit0'], text = _("Start editing"))
+ item.SetBitmap(MetaIcon(img = 'edit').GetBitmap(self.bmpsize))
self.popupMenu.Append(self.popupID['edit1'], text = _("Stop editing"))
self.popupMenu.Enable(self.popupID['edit1'], False)
self.Bind (wx.EVT_MENU, self.OnStartEditing, id = self.popupID['edit0'])
@@ -545,9 +563,11 @@
self.popupMenu.Enable(self.popupID['bgmap'], True)
- self.popupMenu.Append(self.popupID['meta'], _("Metadata"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['meta'], text = _("Metadata"))
+ item.SetBitmap(MetaIcon(img = 'layer-info').GetBitmap(self.bmpsize))
self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID['meta'])
# raster layers (specific items)
elif mltype and mltype == "raster":
if same:
@@ -559,7 +579,9 @@
- self.popupMenu.Append(self.popupID['export'], text = _("Export"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['export'], text = _("Export"))
self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['r.out.gdal',
@@ -573,17 +595,31 @@
self.Bind (wx.EVT_MENU, self.OnRasterColorTable, id = self.popupID['color'])
- self.popupMenu.Append(self.popupID['hist'], _("Histogram"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['hist'], text = _("Histogram"))
+ item.SetBitmap(MetaIcon(img = 'layer-raster-histogram').GetBitmap(self.bmpsize))
self.Bind (wx.EVT_MENU, self.OnHistogram, id = self.popupID['hist'])
- self.popupMenu.Append(self.popupID['univar'], _("Univariate raster statistics"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['univar'], text = _("Univariate raster statistics"))
+ item.SetBitmap(MetaIcon(img = 'raster-stats').GetBitmap(self.bmpsize))
self.Bind (wx.EVT_MENU, self.OnUnivariateStats, id = self.popupID['univar'])
- self.popupMenu.Append(self.popupID['report'], text = _("Report raster statistics"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['report'], text = _("Report raster statistics"))
+ item.SetBitmap(MetaIcon(img = 'stats').GetBitmap(self.bmpsize))
self.Bind(wx.EVT_MENU, self.OnReportStats, id = self.popupID['report'])
- self.popupMenu.Append(self.popupID['prof'], _("Profile"))
+ item = wx.MenuItem(self.popupMenu, id = self.popupID['prof'], text = _("Profile"))
self.Bind (wx.EVT_MENU, self.OnProfile, id = self.popupID['prof'])
elif mltype and mltype == '3d-raster':
@@ -591,10 +627,16 @@
self.Bind(wx.EVT_MENU, self.OnRasterColorTable, id=self.popupID['color'])
- self.Bind(wx.EVT_MENU, self.OnUnivariateStats, id=self.popupID['univar'])
- self.Bind(wx.EVT_MENU, self.OnMetadata, id=self.popupID['meta'])
+ self.Bind (wx.EVT_MENU, self.OnUnivariateStats, id = self.popupID['univar'])
+ self.Bind (wx.EVT_MENU, self.OnMetadata, id = self.popupID['meta'])
# web service layers (specific item)
elif mltype and mltype == "wms":
