[GRASS-SVN] r58418 - grass/trunk/raster/r.in.xyz
svn_grass at osgeo.org
Sun Dec 8 15:13:29 PST 2013
Author: martinl
Date: 2013-12-08 15:13:29 -0800 (Sun, 08 Dec 2013)
New Revision: 58418
grass/trunk/raster/r.in.xyz/main.c
r.in.xyz: description cosmetics, fix compiler warning (cosmetics)
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c 2013-12-08 23:05:56 UTC (rev 58417)
+++ grass/trunk/raster/r.in.xyz/main.c 2013-12-08 23:13:29 UTC (rev 58418)
@@ -105,7 +105,7 @@
char *fs; /* field delim */
off_t filesize;
int linesize;
- long estimated_lines;
+ unsigned long estimated_lines;
int from_stdin;
int can_seek;
@@ -163,7 +163,7 @@
G_add_keyword("ASCII");
G_add_keyword(_("LIDAR"));
module->description =
- _("Create a raster map from an assemblage of many coordinates using univariate statistics.");
+ _("Creates a raster map from an assemblage of many coordinates using univariate statistics.");
input_opt = G_define_standard_option(G_OPT_F_INPUT);
input_opt->description =
