[GRASS-SVN] r58442 - grass/trunk/gui/wxpython/iclass
    svn_grass at osgeo.org
    Wed Dec 11 11:35:23 PST 2013
Author: martinl
Date: 2013-12-11 11:35:22 -0800 (Wed, 11 Dec 2013)
New Revision: 58442
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
g.gui.iclass: fix setting group/subgroup from cli
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2013-12-11 13:02:19 UTC (rev 58441)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2013-12-11 19:35:22 UTC (rev 58442)
@@ -231,7 +231,11 @@
         vectorPath = grass.tempfile(create = False)
         return 'trAreas' + os.path.basename(vectorPath).replace('.','')
+    def SetGroup(self, group, subgroup):
+        """!Set group and subgroup manually"""
+        self.g = {'group' : group, 'subgroup' : subgroup}
     def CreateTempVector(self):
         """!Create temporary vector map for training areas"""
         vectorName = self._getTempVectorName()
Modified: grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
--- grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-12-11 13:02:19 UTC (rev 58441)
+++ grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-12-11 19:35:22 UTC (rev 58442)
@@ -5,7 +5,7 @@
 # AUTHOR(S): Anna Kratochvilova, Vaclav Petras
 # PURPOSE:   The Map Swipe is a wxGUI component which allows the user to
 #            interactively compare two maps
-# COPYRIGHT: (C) 2012 by Anna Kratochvilova, and the GRASS Development Team
+# COPYRIGHT: (C) 2012-2013 by Anna Kratochvilova, and the GRASS Development Team
 #  This program is free software; you can redistribute it and/or modify
 #  it under the terms of the GNU General Public License as published by
@@ -35,6 +35,9 @@
 #%option G_OPT_I_GROUP
 #% required: no
 #%end
+#%option G_OPT_I_SUBGROUP
+#% required: no
+#%end
 #%option G_OPT_R_MAP
 #% description: Name of raster map to load
 #% required: no
@@ -65,15 +68,23 @@
 from iclass.frame import IClassMapFrame
 def main():
-    group_name = map_name = trainingmap_name = None
+    group_name = subgroup_name = map_name = trainingmap_name = None
     if options['group']:
+        if not options['subgroup']:
+            grass.fatal(_("Name of subgroup required"))
         group_name = grass.find_file(name = options['group'], element = 'group')['name']
         if not group_name:
             grass.fatal(_("Group <%s> not found") % options['group'])
+        if options['subgroup'] not in grass.read_command('i.group', group = group_name, flags = 'sg').splitlines():
+            grass.fatal(_("Subgroup <%s> not found") % options['subgroup'])
+        subgroup_name = options['subgroup']
     if options['map']:
         map_name = grass.find_file(name = options['map'], element = 'cell')['fullname']
         if not map_name:
             grass.fatal(_("Raster map <%s> not found") % options['map'])
     if options['trainingmap']:
         trainingmap_name = grass.find_file(name = options['trainingmap'], element = 'vector')['fullname']
         if not trainingmap_name:
@@ -97,7 +108,7 @@
     if not flags['m']:
         frame.CenterOnScreen()
     if group_name:
-        frame.SetGroup(group_name)
+        frame.SetGroup(group_name, subgroup_name)
     if map_name:
         giface.WriteLog(_("Loading raster map <%s>...") % map_name)
         frame.trainingMapManager.AddLayer(map_name)
