[GRASS-SVN] r58450 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Wed Dec 11 15:41:06 PST 2013
Author: martinl
Date: 2013-12-11 15:41:05 -0800 (Wed, 11 Dec 2013)
New Revision: 58450
grass/trunk/vector/v.out.ogr/args.c
grass/trunk/vector/v.out.ogr/local_proto.h
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: replace -p flag with `otype=boundary`
Modified: grass/trunk/vector/v.out.ogr/args.c
--- grass/trunk/vector/v.out.ogr/args.c 2013-12-11 23:33:42 UTC (rev 58449)
+++ grass/trunk/vector/v.out.ogr/args.c 2013-12-11 23:41:05 UTC (rev 58450)
@@ -28,7 +28,7 @@
options->dsn->label = _("Name of output OGR datasource");
options->dsn->description =
_("For example: ESRI Shapefile: filename or directory for storage\n"
- "\tPostGIS database: connection string");
+ "\t\t\tPostGIS database: connection string");
options->format = G_define_option();
options->format->key = "format";
@@ -47,7 +47,7 @@
_("Name for output OGR layer. If not specified, input name is used");
options->layer->description =
_("For example: ESRI Shapefile: shapefile name\n"
- "\tPostGIS database: table name");
+ "\t\t\tPostGIS database: table name");
options->layer->guisection = _("Creation");
options->otype = G_define_standard_option(G_OPT_V_TYPE);
@@ -115,11 +115,6 @@
flags->force2d->description = _("Useful if input is 3D but all z coordinates are identical");
flags->force2d->guisection = _("Creation");
- flags->poly = G_define_flag();
- flags->poly->key = 'p';
- flags->poly->description = _("Export lines as polygons");
- flags->poly->guisection = _("Creation");
flags->multi = G_define_flag();
flags->multi->key = 'm';
flags->multi->description =
Modified: grass/trunk/vector/v.out.ogr/local_proto.h
--- grass/trunk/vector/v.out.ogr/local_proto.h 2013-12-11 23:33:42 UTC (rev 58449)
+++ grass/trunk/vector/v.out.ogr/local_proto.h 2013-12-11 23:41:05 UTC (rev 58450)
@@ -16,7 +16,7 @@
struct Flags {
- struct Flag *cat, *esristyle, *poly, *update, *nocat, *new, *append, *force2d, *multi;
+ struct Flag *cat, *esristyle, *update, *nocat, *new, *append, *force2d, *multi;
/* args.c */
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2013-12-11 23:33:42 UTC (rev 58449)
+++ grass/trunk/vector/v.out.ogr/main.c 2013-12-11 23:41:05 UTC (rev 58450)
@@ -195,7 +195,7 @@
options.layer->answer = G_store(options.input->answer);
- if (flags.poly->answer) {
+ if (ftype == GV_BOUNDARY) {
if (!flags.multi->answer)
wkbtype = wkbPolygon;
else
@@ -668,7 +668,7 @@
G_message(_("Exporting %d features..."), Vect_get_num_primitives(&In, otype));
n_feat += export_lines(&In, field, otype, flags.multi->answer ? TRUE : FALSE,
- donocat, flags.poly->answer ? TRUE : FALSE,
+ donocat, ftype == GV_BOUNDARY ? TRUE : FALSE,
Ogr_featuredefn, Ogr_layer,
Fi, Driver, ncol, colctype,
colname, doatt, flags.nocat->answer ? TRUE : FALSE,
