[GRASS-SVN] r58456 - grass/trunk/misc/m.nviz.image
svn_grass at osgeo.org
Fri Dec 13 11:48:30 PST 2013
Author: annakrat
Date: 2013-12-13 11:48:30 -0800 (Fri, 13 Dec 2013)
New Revision: 58456
grass/trunk/misc/m.nviz.image/args.c
grass/trunk/misc/m.nviz.image/local_proto.h
grass/trunk/misc/m.nviz.image/volume.c
m.nviz.image: added flag to draw volume box
Modified: grass/trunk/misc/m.nviz.image/args.c
--- grass/trunk/misc/m.nviz.image/args.c 2013-12-13 12:10:17 UTC (rev 58455)
+++ grass/trunk/misc/m.nviz.image/args.c 2013-12-13 19:48:30 UTC (rev 58456)
@@ -706,6 +706,12 @@
_("Toggles normal direction of all isosurfaces (changes light effect)");
params->isosurf_toggle_norm_dir->guisection = _("Volumes");
+ params->draw_volume_box = G_define_flag();
+ params->draw_volume_box->key = 'b';
+ params->draw_volume_box->description =
+ _("Draw volume box");
+ params->draw_volume_box->guisection = _("Volumes");
/* slices */
/* slice axis */
params->slice = G_define_option();
Modified: grass/trunk/misc/m.nviz.image/local_proto.h
--- grass/trunk/misc/m.nviz.image/local_proto.h 2013-12-13 12:10:17 UTC (rev 58455)
+++ grass/trunk/misc/m.nviz.image/local_proto.h 2013-12-13 19:48:30 UTC (rev 58456)
@@ -8,6 +8,7 @@
struct Flag *mode_all;
struct Flag *isosurf_toggle_norm_dir;
+ struct Flag *draw_volume_box;
struct Option
/* surface */
Modified: grass/trunk/misc/m.nviz.image/volume.c
--- grass/trunk/misc/m.nviz.image/volume.c 2013-12-13 12:10:17 UTC (rev 58455)
+++ grass/trunk/misc/m.nviz.image/volume.c 2013-12-13 19:48:30 UTC (rev 58456)
@@ -61,6 +61,9 @@
GVL_set_trans(id, x, y, z);
+ if (params->draw_volume_box->answer) {
+ GVL_set_draw_wire(id, 1);
return 1;
